Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Coding support for VW UP GTi 2018
  1. #21
    Dec 2018
    Got it, thanks 😀
  2. Likes Uwe, Dana liked this post
  3. #22
    Jan 2019
    I have the same issue with a brand new Ross-Tech HEX-V2 (3 vin) and my 2019 Up GTi.
    If possible, I would like to test the label file as well.
    Log file extract
    Friday,11,January,2019,16:27:44:42085
    VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
    VIN: WVWZZZAAZKDx
    Mileage: 920km-571mi   Repair Order:
    Chassis Type: AA-VW12 (1S0)
    Scan: 01 03 08 09 10 15 17 19 25 44 5F 61 A9 AD
    VIN: WVWZZZAAZKDx
    AD-Brake Sensors -- Status: OK 0000
       Part No SW: 1S0 937 090 J    HW: 1S0 937 090 J
       Component: BCM PQ25 1MX4 H82 0762
       Revision: BW082001    Serial number: 8901 320180122
       Coding: 62B82B0000010000090807D06CEB8ED079C0706D60CF2D602101000B0900
       Shop #: WSC 31414 790 00001
       VCID: 3A2D30E32C55DF8790F-806E
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 201118 05  50  0106
       Coding: 0228DD
       Subsystem 2 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS72.405  H04 0005
       Serial number: 0000FST00276LWW00000
       Coding: 181100
       Subsystem 3 - Part No SW: 1K8 959 442     HW: 1K8 959 442
       Component: E221__MFL-DC1  H04 0103
       Serial number: 29180002450720078422
       Coding: A4FFFF
    Control Module Part Number: 1S0 937 090 J
      Component and/or Version: BCM PQ25 1MX4 H82 0762
               Software Coding: 62B82B0000010000090807D06CEB8ED079C0706D60CF2D602101000B0900
                Work Shop Code: WSC 31414
    Advanced Identification
         Identification: SME-RBG
         Revision: BW082001
         Date: 23.11.18
         Manufacturer number: 0005
         Test stand number: 0096
    Flash Status
         Programming Attempts(application): 0
         Successful Attempts(application): 0
         Successful Attempts(data): 0
         Programming Status: 00000000
         Flash Date: 0000.00.00
         Flash Tool Code: 00000 000 00000
    Software
         HiSpd Net: 01.01.00
    Misc.
         Hardware number: 1S0 937 090 J
         Workshop System Name: J519
         Equipment/PR Code: 0000000000000000
         Dataset Number: -----------
         Dataset Version: ----
         End of Line Equipment Level: --------------------
    VCDS Info:
           Labels: Redir Fail!
  4. #23
    Quote Originally Posted by max2100 View Post
    You can use this file with the Danish VCDS, copy it to:
    C:\NEtech\VCDS-NEZ\Labels\User
    Please post a complete Autoscan file.
  5. Likes Uwe liked this post
  6. #24
    Jan 2019
    Thanks for the quick response.
    I have now modified auto-lock, comfort-blinks and teardrop.
    I must admit that I prefer the english version.
    Translating technical terms isn't easy, and some of the danish translations are hard to understand.
    Lørdag,12,Januar,2019,17:21:13:42085
    VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
    VCDS version: NEZ 18.9.0.2  HEX-V2 CB: 0.4437.4
    Dataversion: 20181005 DS296.0
    www.vcds.dk
    Stelnummer: WVWZZZAAZKDx   Indreg.nr.:
    Kørestrækning: 920km   Reparationsordre:
    Modeltype: AA-VW12 (1S0)
    Søgt på: 01 03 08 09 10 15 17 19 25 44 5F 61 A9 AD
    Stelnummer: WVWZZZAAZKDx   Kørestrækning: 920km
    01-Motor -- Status: Fejlfunktion 0010
    03-ABS bremser -- Status: Ok 0000
    04-Styrevinkel -- Status: Ok 0000
    08-Klimaanlæg -- Status: Ok 0000
    09-Centralelektrik -- Status: Ok 0000
    10-Park.assist. -- Status: Ok 0000
    15-Airbags -- Status: Ok 0000
    17-Instrument -- Status: Ok 0000
    19-CAN Gateway -- Status: Ok 0000
    25-Startspærre -- Status: Ok 0000
    44-Servostyring -- Status: Ok 0000
    5F-Informationselek. -- Status: Ok 0000
    61-Batteriregulering -- Status: Ok 0000
    A9-Lydsvingninger -- Status: Ok 0000
    AD-Bremsesensor -- Status: Ok 0000
    Styreenhed  01: Motor (J623-DKRA)     Forklaringsfil:. NEZ\04E-907-309-V1.clb
       Styreenhedsnr: SW: 04C 906 025 F    HW: 04C 907 309 BA
       Komponent	: R3 1.0l TFS   H20 6355
       Revision: D8H20000
       Kodning	: 00190032232401000000
       Forhandler	: WSC 31414 790 00001
       ASAM datasæt: EV_ECM10TFS01104C906025F 003009
       ROD: EV_ECM10TFS01104C906025F_003.rod
       VCID: 2313ED87BB5FBE4FA37-8076
    1 fejl fundet:
    33708 - Ukendt fejlkode
              P2B63 00 [032] - -
              Periodisk - Ikke bekræftet - Testet siden sletning af hukommelse
                 Fryseramme:
                        Fejl status  : 00000001
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Kørestrækning: 115 km
                        Dato: 2019.01.04
                        Tid: 13:23:38
                        Motoromdrejningstal: 3120.50 /min
                        Normeret belastningsv糤i: 29.8 %
                        K��astighed: 121 km/t
                        K��紫etemperatur: 96 у
                        Inds.lufttemperatur: 35 у
                        Barometerstand lufttryk: 1010 mbar
                        Sp篤ing kl. 30: 12.200 V
                        Nulstillingst筬er: EOBD: 22
                        Udelufttemperatur: 5 у
                        Absolut indsugningstryk: 91 kPa abs
                        Motordrejningsmoment: 77.5 Nm
                        Br篤stof: tankniveau: 35.0 l
                        Lambdasonde B1-S1: foreskr. v糤i: 1.0000
                        Indsugningsknastaksel: B1: aktiv driftstilstand-Bits 0-7: 0
                        Indsugningsknastaksel: B1: aktiv driftstilstand-Bits 0-7: 1
                        P歸bsafbrydelse-Bits 0-7: 0
    Styreenhed  03: ABS bremser (J104)     Forklaringsfil:. NEZ\1S0-614-517.clb
       Styreenhedsnr: SW: 1S0 614 517 R    HW: 1S0 614 517 R
       Komponent	: EBC 460 ESP   H17 0031
       Serienummer: A01WKG6
       Kodning	: B9BF64712BB002F89DFE26F7D4AD40505FB000
       ASAM datasæt: EV_Brake1ESPEBC460TRW 002107
       ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
       VCID: 3E253CF330FDF3A7AC9-806A
    Ingen fejlkoder fundet.
    Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil: NEZ\1S0-907-044.clb
       Styreenhedsnr: SW: 1S0 907 044     HW: 1S0 907 044
       Komponent	: Climatronic   H05 0102
       Revision: K0000000
       VCID: 6C81C6BB1681B13752D-8038
    Styreenhed  09: Centralelektrik (J519)     Forklaringsfil:. NEZ\1S0-937-09x-V2.clb
       Styreenhedsnr: SW: 1S0 937 090 J    HW: 1S0 937 090 J
       Komponent	: BCM PQ25 1MX4 H82 0762
       Revision: BW082001    Serienummer: 8901 320180122
       Kodning	: 72B82B0000010000090807D06CEB8ED079C0706D60CF2D602101000B0900
       VCID: 3A2D30E32C55DF87901-806E
       Undersystem 1 - Styreenhedsnr:: 5K7 955 559 C  Forklaringsfil: NEZ\5K7-955-559.CLB
       Komponent	: RLS 201118 05  50  0106
       Kodning	: 0228DD
       Undersystem 2 - Styreenhedsnr: SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Komponent	: J245 PS72.405  H04 0005
       Serienummer: 0000FST00276LWW00000
       Kodning	: 181100
       Undersystem 3 - Styreenhedsnr: SW: 1K8 959 442     HW: 1K8 959 442
       Komponent	: E221__MFL-DC1  H04 0103
       Serienummer: 29180002450720078422
       Kodning	: A4FFFF
    Styreenhed  10: Park.assist. (J446)     Forklaringsfil:| NEZ\1Sx-919-475.clb
       Styreenhedsnr: SW: 1S0 919 475 B    HW: 1Q0 919 475
       Komponent	: PARKHILFE 3K  H03 0013
       Revision: --------    Serienummer: 32931833102541
       Kodning	: 108004
       ASAM datasæt: EV_EPHVA14VW1200000 001009
       ROD: EV_EPHVA14VW1200000.rod
       VCID: 392F2FEF29D3D49F99B-806C
    Styreenhed  15: Airbags (J234)     Forklaringsfil:* NEZ\5K0-959-655.clb
       Styreenhedsnr: SW: 1S0 959 655 E    HW: 1S0 959 655 E
       Komponent	: VW10Airbag02N 010 0007
       Revision: --------    Serienummer: 003EQ002382F
       Kodning	: 00000000000000000000000000000000324E
       ASAM datasæt: EV_AirbaVW10BPAVW12X 001001
       VCID: 40D9420B4A098557DE5-8014
       Crashsensor til sideairbag i f��side:
       Serienummer: 3497ARB40675KNKGQ0J2
       Crashsensor til sideairbag i passagerside:
       Serienummer: 3507ARB40675KNKGE8R+
       Crashsensor til frontairbag i f��side:
       Serienummer: 3557BRB40675LKOCPH3+
    Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\1Sx-920-xxx-17.clb-SRI1
       Styreenhedsnr: SW: 1S0 920 870 C    HW: 1S0 920 870 C
       Komponent	: KOMBI         H12 0100
       Revision: X0012001    Serienummer: 00000000000000
       Kodning	: 114A010000
       ASAM datasæt: EV_KombiUDSMM9RM10 A05808
       ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
       VCID: 313F17CFF1A31CDF21B-8064
    Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:. NEZ\6N0-909-901-6R.clb
       Styreenhedsnr: SW: 1S0 909 901     HW: 1S0 937 090 J
       Komponent	: GW-K-CAN TP20 H82 0762
       Revision: BW082001
       Kodning	: 001201
       VCID: 70B9D2CB3AA955D76E5-8024
    Styreenhed  25: Startspærre (J334)     Forklaringsfil:| NEZ\5K0-920-xxx-25.clb
       Styreenhedsnr: SW: 5K0 953 234     HW: 1S0 920 870 C
       Komponent	: IMMO          H12 0100
       Kodning	: 000000
       Forhandler	: WSC 00000 000 00000
       ASAM datasæt: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6A8DC0A31CF5AF07201-803E
    Styreenhed  44: Servostyring (J792)     Forklaringsfil:| NEZ\6Rx-909-144-V2.clb
       Styreenhedsnr: SW: 6R1 909 144 AN    HW: 6R1 909 144 E
       Komponent	: EPS_TRW_ALow  313 3150
       Serienummer: CIBT1211
       Kodning	: 000700
       ASAM datasæt: EV_SteerAssisUDSTRW 016134
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 03538D071B9F5E4F837-8056
    Styreenhed  5F: Informationselek. (J794)     Forklaringsfil:| NEZ\5G0-035-MIB-ENT2.clb
       Styreenhedsnr: SW: 1S0 035 869 B    HW: 1S0 035 869 B
       Komponent	: MU-E-D-EU     068 7338
       Serienummer: 08111800020362
       Kodning	: 02210100BE00000041111101018002001F000AC40001010001
       ASAM datasæt: EV_MUEnt4CGen2LGE 001032
       VCID: 353723DF05CB30FF7D3-8060
    Styreenhed  61: Batteriregulering (J840)     Forklaringsfil:. NEZ\1S0-907-534.clb
       Styreenhedsnr: SW: 1S0 907 534     HW: 1S0 937 090 J
       Komponent	: Batt.regelung H82 0762
       Kodning	: 032B7856
       Undersystem 1 - Styreenhedsnr: SW: 1S0 915 181 D    HW: 1S0 915 181 D
       Komponent	: J367-BDM  H08 0270
       Serienummer: 65318C01336061100578
    Styreenhed  A9: Lydsvingninger (J869)     Forklaringsfil: NEZ\4H0-907-159.clb
       Styreenhedsnr: SW: 1S0 907 159     HW: 4H0 907 159 A
       Komponent	: SAS-GEN 2     H07 0003
       Serienummer: 181026200567
       ASAM datasæt: EV_SoundActuaGen2AU64X 003010
       VCID: 73B3DDC74B3F6ECF937-8026
    Styreenhed  AD: Bremsesensor (J939)     Forklaringsfil: NEZ\1S0-907-201.clb
       Styreenhedsnr: SW: 1S0 907 201 A    HW: 1S0 907 201 A
       Komponent	: CV-SENSOR     H08 0460
       ASAM datasæt: EV_CVSen 001001
       ROD: EV_CVSen.rod
       VCID: 2809FAABC2795D17F65-807C
    Slutning------(Forløbet tid: 01:13, VBat. start/slut: 13.1V/13.1V)--------
  7. #25
    Sorry I did mean to ask for a Danish Autoscan, just the first was incomplete, it is for English here in the forum.
  8. Likes Uwe liked this post
  9. #26
    Jan 2019
    Oh, I misunderstood.
    Here's a complete english log file for anyone interested.
    And I'm still interested in testing a label file for the english VCDS.
    Sunday,13,January,2019,15:09:09:42085
    VIN: WVWZZZAAZKDx   License Plate:
    Mileage: 1090km-677mi   Repair Order:
    VIN: WVWZZZAAZKDx   Mileage: 1090km-677miles
    Address 01: Engine (J623-DKRA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 025 F    HW: 04C 907 309 BA
       Component: R3 1.0l TFS   H20 6355
       Revision: D8H20000
       Coding: 00190032232401000000
       ASAM Dataset: EV_ECM10TFS01104C906025F 003009
       VCID: 2313ED87BB5FBE4FA39-8076
    33708 - Unknown Error Code
              P2B63 00 [032] - -
                        Mileage: 115 km
                        Date: 2019.01.04
                        Time: 13:23:38
                        Engine speed: 3120.50 /min
                        Normed load value: 29.8 %
                        Vehicle speed: 121 km/h
                        Coolant temperature: 96 °C
                        Intake air temperature: 35 °C
                        Voltage terminal 30: 12.200 V
                        Unlearning counter according OBD: 20
                        Outside air temperature: 5 °C
                        Absolute intake pressure: 91 kPa abs
                        Engine torque: 77.5 Nm
                        Fuel: tank fill level: 35.0 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Intake camshaft bank1 active operating mode-Bits 0-7: 1
                        Overrun cut-off-Bits 0-7: 0
    Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
       Part No SW: 1S0 614 517 R    HW: 1S0 614 517 R
       Component: EBC 460 ESP   H17 0031
       Serial number: A01WKG6
       Coding: B9BF64712BB002F89DFE26F7D4AD40505FB000
       ASAM Dataset: EV_Brake1ESPEBC460TRW 002107
       VCID: 3E253CF330FDF3A7AC7-806A
       Part No SW: 1S0 907 044     HW: 1S0 907 044
       Component: Climatronic   H05 0102
       Revision: K0000000
       VCID: 6C81C6BB1681B137523-8038
       Coding: 7AB82B0000010000090807D06CEB8ED079C0706D60CF2D602101000B0900
       Coding: 0228DD
       Coding: 181100
       Coding: A4FFFF
    Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
       Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
       Component: PARKHILFE 3K  H03 0013
       Revision: --------    Serial number: 32931833102541
       Coding: 108004
       ASAM Dataset: EV_EPHVA14VW1200000 001009
       VCID: 392F2FEF29D3D49F995-806C
       Part No SW: 1S0 959 655 E    HW: 1S0 959 655 E
       Component: VW10Airbag02N 010 0007
       Revision: --------    Serial number: 003EQ002382F
       Coding: 00000000000000000000000000000000324E
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
       VCID: 40D9420B4A098557DEB-8014
       Serial number: 3497ARB40675KNKGQ0J2
       Serial number: 3507ARB40675KNKGE8R+
       Serial number: 3557BRB40675LKOCPH3+
    Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
       Part No SW: 1S0 920 870 C    HW: 1S0 920 870 C
       Component: KOMBI         H12 0100
       Revision: X0012001    Serial number: 00000000000000
       Coding: 114A010000
       ASAM Dataset: EV_KombiUDSMM9RM10 A05808
       VCID: 313F17CFF1A31CDF215-8064
       Part No SW: 1S0 909 901     HW: 1S0 937 090 J
       Component: GW-K-CAN TP20 H82 0762
       Revision: BW082001
       Coding: 001201
       VCID: 70B9D2CB3AA955D76EB-8024
       Part No SW: 5K0 953 234     HW: 1S0 920 870 C
       Component: IMMO          H12 0100
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       VCID: 6A8DC0A31CF5AF0720F-803E
    Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
       Part No SW: 6R1 909 144 AN    HW: 6R1 909 144 E
       Component: EPS_TRW_ALow  313 3150
       Serial number: CIBT1211
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016134
       VCID: 03538D071B9F5E4F839-8056
       Part No SW: 1S0 035 869 B    HW: 1S0 035 869 B
       Component: MU-E-D-EU     068 7338
       Serial number: 08111800020362
       Coding: 02210100BE00000041111101018002001F000AC40001010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       VCID: 353723DF05CB30FF7DD-8060
       Part No SW: 1S0 907 534     HW: 1S0 937 090 J
       Component: Batt.regelung H82 0762
       Coding: 032B7856
       Subsystem 1 - Part No SW: 1S0 915 181 D    HW: 1S0 915 181 D
       Component: J367-BDM  H08 0270
       Serial number: 65318C01336061100578
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 1S0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0003
       Serial number: 181026200567
       VCID: 73B3DDC74B3F6ECF939-8026
    Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
       Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
       Component: CV-SENSOR     H08 0460
       ASAM Dataset: EV_CVSen 001001
       ROD: EV_CVSen.rod
       VCID: 2809FAABC2795D17F6B-807C
    End----------(Elapsed Time: 01:14, VBatt start/end: 13.3V/13.3V)-----------
  10. Likes Uwe liked this post
