- Joined
- Apr 9, 2014
- Messages
- 2,304
- Reaction score
- 2,252
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
Sunday,16,September,2018,18:38:46:36026
VCDS Version: 18.7.2.1 (x64) HEX-NET CB: 0.4436.4
Data version: 20180808 DS295.0
VIN: WVWZZZAUZFP License Plate: TIMMI G7 MARIA SÕIDAB
Mileage: 66780km-41495mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 13 15 16 17 18 19 42 44 52 5F 69
VIN: WVWZZZAUZFP Mileage: 66780km-41495miles
Address 01: Engine (J623-CPWA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 N HW: 04E 907 309 E
Component: 1.4l TSI CNG H12 7572
Revision: WIH12---
Coding: 0125001A247405082000
Shop #: WSC 00028 028 00074
ASAM Dataset: EV_ECM14CSI01104E906016N 001006
ROD: EV_ECM14CSI01104E906016N_001.rod
VCID: 2D12C2F87C9D8422B9-8078
CAN Converter 01:
10204 - Misfire detected during Nat.Gas Operation
P3361 00 [096] - -
Mileage: 66245 km
Date: 2018.09.13
Time: 10:05:21
Engine speed: 696.00 /min
Normed load value: 19.6 %
Coolant temperature: 69 °C
Intake air temperature: 41 °C
Voltage terminal 30: 14.465 V
Unlearning counter according OBD: 30
Mass flow through throttle valve: 8.7 kg/h
A/C compressor: load current: act. value: -287.50 A
10199 - Cylinder 3 Misfire detected during Nat.Gas Operation
P3364 00 [096] - -
Mileage: 66245 km
Date: 2018.09.13
Time: 10:06:26
Mass flow through throttle valve: 23.8 kg/h
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
Part No SW: 0CW 300 047 S HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5250
Revision: 00043014 Serial number: CU501407216686
Shop #: WSC 00028 028 00067
ROD: EV_TCMDQ200021_VW27.rod
VCID: 4BD6AC60E249AA1287-801E
10817 - Clutch 1
P189A 00 [072] - Clearance too Small
Mileage: 66497 km
Date: 2018.09.15
Time: 07:37:41
Engine speed: 6155.50 /min
Engine torque: 104 Nm
Vehicle speed: 70 km/h
Control Module temperature: 73 °C
CURRENT pressure: -5.5 bar
selected gear: GANG_R
Driving position: s
Accelerator position: 0.0 %
DTC memory status: 47616
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 62104000000804
Coding: 04FA6AA124231171037A060441C82920562488C0608294F3F8225078C202
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 46C09D54F92B577A58-8012
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 S HW: 5G0 907 426 S
Component: AC Manuell H02 0907
Revision: 00001K06
Coding: 02020004204101001000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 3B36FCA0B2E91A9237-806E
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 26
Mileage: 64372 km
Date: 2018.08.09
Time: 05:30:23
Outside air temperature: 17.0 °C
Engine speed: 1100 /min
Temperature after evaporator: 18.0 °C
System run time-Engine running time: 2 s
System run time-Terminal 15 on: 6 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86580308141092
Coding: 00021846C24100534BE44000001C07081400000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: 79BA26A8F855E88265-802C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140721 043 0551
Serial number: 140728023233
787462 - Relay for Headlight Washer System
B1262 15 [009] - Open or Short to Plus
Reset counter: 80
Mileage: 65284 km
Date: 2018.08.28
Time: 22:00:58
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 04081403210650
Coding: 001C1900FE0739
VCID: 383CE3AC83DF318ADA-806C
1541 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [008] - -
[FAULT_MISALIGNMENT_VERTICAL]
Fault Frequency: 39
Reset counter: 182
Mileage: 63868 km
Date: 2018.07.30
Time: 10:00:26
Control Module temperature: 41 °C
Voltage terminal 15: 14.6 V
Vehicle speed: 16.19 m/s
Acceleration: -0.30 m/s²
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR07S3ZH
Shop #: WSC 00028 028 00063
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F4EC8B0E671C6B25B-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169667B11081440405
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169668B11081471455
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 708 14
Serial number: 35767000000F0BA0701T
Subsystem 4 - Part No SW: ----------- HW: 480 000 708 14
Serial number: 35867000000E5395C01Z
Subsystem 5 - Part No SW: ----------- HW: 480 400 608 14
Serial number: 3516502A316DB803B013
Subsystem 6 - Part No SW: ----------- HW: 480 400 608 14
Serial number: 3526502A316DB80221B5
Subsystem 7 - Part No SW: ----------- HW: 480 400 508 14
Serial number: 3556502B916DB8026018
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 569 A HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: -------- Serial number: 20161113500233
Coding: 0C10
Shop #: WSC 40410 222 194943
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C34FFBCB7E71DAA3E-8068
Part No SW: 5G1 920 742 HW: 5G1 920 742
Component: KOMBI 204 4280
Coding: 07A411082780000800882A011400000000000000
VCID: 65827AD864ED7C62B1-8030
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 B HW: 5Q0 963 272 B
Component: STH-MQB 006 0069
Coding: 1309
VCID: 3522EA9894CDCCE2C1-8060
Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
Serial number: 00000000000000919895
0035 - Crash Signal
B1073 00 [009] - -
Reset counter: 225
Mileage: 63254 km
Date: 2018.01.23
Time: 21:00:03
Operating condition of parking heater: OFF
71
Coolant temperature of parking heater: 70 °C
Coolant temperature: 76 °C
Engine running status: detected
Fuel level: 11 l
Heater output: 0 W
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 08081410802767
Coding: 030100342B085700EF00005C1C0F00010001050000000000000000000000
ROD: EV_GatewConti_011_VW37.rod
VCID: 42C88144D5036B5A74-8016
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 27140001953180014317
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 5758734003
Part No SW: 5Q4 959 393 C HW: 5Q4 959 393 B
Component: TSG FS 009 0015
Serial number: 0000112888058
Coding: 003003208000028000001000
VCID: 43C68440CA1962527F-8016
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006267984
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 0103
ROD: EV_SteerAssisMQB_010.rod
VCID: 41CA8E48D00570426D-8014
Part No SW: 5Q4 959 392 C HW: 5Q4 959 392 B
Component: TSG BFS 009 0015
Serial number: 0000113000381
Coding: 003001208000028000801000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006276610
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 824 A HW: 5G0 035 824 A
Component: MU-S--ER 041 0421
Serial number: V1E00208143270
Coding: 02730200FF00000011110001000800001F0100940100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 230624C02A5942521F-8076
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H60 0030
Serial number: VWZ8Z9PS203E1Y
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 F HW: 5Q0 907 383 C
Component: Anhaenger H14 0137
Revision: 8B001001 Serial number: 0342394189
Coding: 0100000202000000
VCID: 3A38F9A4BDD3239A2C-806E
End------(Elapsed Time: 10:12, VBatt start/end: 12.1V/12.1V, Deb=2)--------
01
;SW:04E-906-016-N HW:04E-907-309-E --- Engine
;Component:1.4l TSI CNG H12 7572, Coding:0125001A247405082000
;EV_ECM14CSI01104E906016N,001006,EV_ECM14CSI01104E906016N_001.rod
;Sunday,16,September,2018,18:31:04:36026
;VCDS Version: Beta 18.7.2 (x64) Data version: 20180808 DS295.0
;VCID: 2D12C2F87C9D8422B9-8078
IDE02332-Deactivate production mode,00 00 00 ,3
IDE04158-Activation of start-stop function,active ,1
IDE04617-Protective function,Enabled ,1
IDE06648-Activation of interior auxil. heating,active ,1
IDE07612-Fuel quality specification,1.05 ,1
Elapsed Time: 00:02
;SW:0CW-300-047-S HW:0AM-927-769-K --- Auto Trans
;Component:GSG DQ200-MQB H43 5250, Coding:0014
;EV_TCMDQ200021,001001,EV_TCMDQ200021_VW27.rod
;Sunday,16,September,2018,18:31:54:36026
;VCID: 4BD6AC60E249AA1287-801E
Elapsed Time: 00:01
;SW:5Q0-907-379-M HW:5Q0-907-379-H --- ABS Brakes
;Component:ESC H31 0571, Coding:04FA6AA124231171037A060441C82920562488C0608294F3F8225078C202
;EV_Brake1UDSContiMK100IPB,033001,EV_Brake1UDSContiMK100IPB_033.rod
;Sunday,16,September,2018,18:32:09:36026
;VCID: 46C09D54F92B577A58-8012
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE03493-Driver door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Weak ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-IDE05287-Electromechanical parking brake-Automatic application,activated ,2
IDE04645-MAS05667-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated ,2
IDE04765-Counter steer support,Strong ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire pressure monitoring display,2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake booster,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05337-Starting vibration reduction,Strong ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS08145-Hill-start assistant: increase threshold,3 %,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,2
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,2
ENG118148-Developer_Function_1,0 ,1
Elapsed Time: 00:13
;SW:5G0-907-426-S HW:5G0-907-426-S --- Auto HVAC
;Component:AC Manuell H02 0907, Coding:02020004204101001000000000000000
;EV_ACManueBHBVW37X,003019,EV_ACManueBHBVW37X_003_VW37.rod
;Sunday,16,September,2018,18:32:47:36026
;VCID: 3B36FCA0B2E91A9237-806E
IDE00001-Production mode,Deactivating ,3
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1
IDE01479-Gear ratio of engine - A/C compressor,0.00 ,1
IDE01483-Blower voltage for voice operation,not activated ,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01503-Runtime for compressor run-in basic setting,120 s,1
IDE02155-Reset all counters,not activated ,1
IDE03176-Duration of compressor run in,60 s,1
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06546-Interior target temperature for production routines,22 °C,1
IDE06547-Air distribution for production routines,No effect ,1
IDE06593-Recirculation air for production routines,No effect ,1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,not active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE80007-Analysis 7,00000000 00000000 ,2
IDE80008-Analysis 8,active ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,6 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,40 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,60 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,80 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,100 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,0 %,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 %,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,40 %,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,60 %,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 %,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
ENG122846-ENG99557-dimming_characteristic_3-X2,6 ,12
ENG122846-ENG102140-dimming_characteristic_3-X3,40 ,12
ENG122846-ENG102936-dimming_characteristic_3-X4,60 ,12
ENG122846-ENG103548-dimming_characteristic_3-X5,80 ,12
ENG122846-ENG113992-dimming_characteristic_3-X6,100 ,12
ENG122846-ENG99777-dimming_characteristic_3-Y1,0 %,12
ENG122846-ENG100480-dimming_characteristic_3-Y2,6 %,12
ENG122846-ENG100773-dimming_characteristic_3-Y3,40 %,12
ENG122846-ENG100631-dimming_characteristic_3-Y4,60 %,12
ENG122846-ENG102174-dimming_characteristic_3-Y5,80 %,12
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
ENG122847-ENG99557-dimming_characteristic_4-X2,6 ,12
ENG122847-ENG102140-dimming_characteristic_4-X3,40 ,12
ENG122847-ENG102936-dimming_characteristic_4-X4,60 ,12
ENG122847-ENG103548-dimming_characteristic_4-X5,80 ,12
ENG122847-ENG113992-dimming_characteristic_4-X6,100 ,12
ENG122847-ENG99777-dimming_characteristic_4-Y1,0 %,12
ENG122847-ENG100480-dimming_characteristic_4-Y2,6 %,12
ENG122847-ENG100773-dimming_characteristic_4-Y3,40 %,12
ENG122847-ENG100631-dimming_characteristic_4-Y4,60 %,12
ENG122847-ENG102174-dimming_characteristic_4-Y5,80 %,12
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %,12
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
ENG122849-illumination index grain rotary knob,search illumination ,1
Elapsed Time: 00:10
;SW:5Q0-937-086-AA HW:5Q0-937-086-AA --- Cent. Elect.
;Component:BCM PQ37BOSCH 028 0106, Coding:00021846C24100534BE44000001C07081400000000000000000000000000
;EV_BodyContrModul1UDSBosc,013005,EV_BCMBOSCH_013.rod
;Sunday,16,September,2018,18:34:00:36026
;VCID: 79BA26A8F855E88265-802C
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2000 ms,12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,320 ms,12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,320 ms,12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
IDE01550-Service position,170.49 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided ,14
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,14
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,Not Present ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,ignition ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,0 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,0 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,not enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,not active ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,not active ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,not active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,not active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,4
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,00 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,00 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,00 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,00 ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,48 ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,4C ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,37 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,41 ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,minimize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,minimize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,0 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,0 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,0 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,0 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,0 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,35 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,35 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,0 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,100 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,100 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,100 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,100 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,35 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,35 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,0 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,0 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,0 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,0 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,31 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,31 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,00 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,00 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,00 ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00 ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,00 ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,43 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,44 ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,1C ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,1D ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,not active ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,not active ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,not active ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,not active ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,not active ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,13 - Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,13 - Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,not active ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,not active ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,not active ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,11 - Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,11 - Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,only_if_closed ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,only_if_closed ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,0 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,0 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,0 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,0 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,0 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,0 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,13 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,14 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,15 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,15 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,0 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,0 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,6 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,7 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,31 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,31 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,9 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,10 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,31.49 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,not active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,0 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,sensitive ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09733-ENG147405-LED bar setting values-Sperrzeit,0 s,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,7.49 °,2
IDE10299-Alternating park position 2,29.49 °,2
MAS01490-Energy management,active ,1
MAS05055-lower turn position,31.49 °,2
MAS05056-upper turn position,170.49 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,35 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,13 - Bremsleuchten ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,35 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,13 - Bremsleuchten ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,35 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,35 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,100 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,31 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,43 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,48 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,100 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,31 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,44 ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht vorn (Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
Elapsed Time: 01:33
;SW:5Q0-907-572-D HW:5Q0-907-572-D --- Auto Dist. Reg
;Component:ACC Bosch MQB H05 0304, Coding:001C1900FE0739
;EV_ACCMRRBoschVW372,001015,EV_ACCMRRBoschVW372_VW26.rod
;Sunday,16,September,2018,18:35:45:36026
;VCDS Version: Beta 18.7.2 (x64) Data version: 20180808 DS295.0
;VCID: 383CE3AC83DF318ADA-806C
IDE00001-Production mode,Deactivating ,3
IDE00056-History data 1,On ,1
IDE00820-Activating and deactivating all development messages,OFF ,1
IDE00899-Option for presetting of time gap,On ,1
IDE01795-Heated lens,On ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE04330-Transfer of release code for a SWaP function,00 ,1
IDE07570-Multiple assignment of buttons in multi-function steering wheel,On ,1
IDE07977-Plausibilization of activation of emergency brake function,OFF ,1
IDE07978-Avoidance for impermissible passing process,OFF ,1
IDE09536-Detect. of vertical deadjustment,On ,1
Elapsed Time: 00:04
;SW:5Q0-959-655-AA HW:5Q0-959-655-AA --- Airbags
;Component:AirbagVW20 014 0386, Coding:98CCC000000000005C0000CF004800000065
;EV_AirbaVW20SMEVW37X,002130,EV_AirbaVW20SMEVW37X.rod
;Sunday,16,September,2018,18:36:07:36026
;VCID: 7F4EC8B0E671C6B25B-802A
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F FF ,18
IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,activated ,4
IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,activated ,4
IDE06527-MAS00478-Adaptation pre-crash-Reserved,2 ,4
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined ,8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined ,8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed ,8
MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined ,8
Elapsed Time: 00:03
;SW:5Q0-953-569-A HW:5Q0-953-569-A --- Steering wheel
;Component:Lenks.Modul 075 0235, Coding:0C10
;EV_SMLSVALEOMQB,001016,EV_SMLSVALEOMQB.rod
;Sunday,16,September,2018,18:36:15:36026
;VCID: 3C34FFBCB7E71DAA3E-8068
ENG126417-p_n_fehler_p_verriegelt,50 ,1
ENG120504-p_s_NWDF_spg,0 ms,1
ENG102189-p_t_blinker_entprellen,40 ms,1
ENG102332-p_t_blinker_err_el_kurzschluss,200 ms,1
ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms,1
ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms,1
ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s,1
ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms,1
ENG100988-p_t_blinker_err_gra_haengt_ein,300 s,1
ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms,1
ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s,1
ENG100923-p_t_blinker_err_unplausibel,2000 ms,1
ENG127113-p_t_blinker_err_weckkontakthaengt_aus,5000 ms,1
ENG127112-p_t_blinker_err_weckkontakthaengt_ein,3000 ms,1
ENG103471-p_t_blinker_gra_entprellen,40 ms,1
ENG101294-p_t_blinker_sperrzeit,100 ms,1
ENG127114-p_t_entprellung_p_unplausibel,400 ms,1
ENG104033-p_t_entprellzeit_ueberspannung,90000 ms,1
ENG101392-p_t_entprellzeit_unterspannung,90000 ms,1
ENG102689-p_t_fas_entprellen,40 ms,1
ENG120505-p_t_gra_ea_error,2000 ms,1
ENG101014-p_t_grahebel_entprellen,40 ms,1
ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms,1
ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms,1
ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms,1
ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s,1
ENG103536-p_t_grahebel_err_unplausibel,200 ms,1
ENG99436-p_t_hupe_entprellen,40 ms,1
ENG102496-p_t_hupe_err_hinweis,2000 ms,1
ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms,1
ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s,1
ENG101702-p_t_hupe_indien_entprellen,500 ms,1
ENG100796-p_t_spannung_obere_schwelle,18.0 V,1
ENG102338-p_t_spannung_untere_schwelle,6.5 V,1
ENG100559-p_t_wischer_entprellen,40 ms,1
ENG103039-p_t_wischer_err_el_kurzschluss,200 ms,1
ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms,1
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms,1
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s,1
ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms,1
ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s,1
ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms,1
ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s,1
ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms,1
ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s,1
ENG101592-p_t_wischer_intervall_entprellen,40 ms,1
ENG103607-p_t_wischer_winterstellung,60 s,1
Elapsed Time: 00:10
;SW:5G1-920-742 HW:5G1-920-742 --- Instruments
;Component:KOMBI 204 4280, Coding:07A411082780000800882A011400000000000000
;EV_DashBoardVDDMQBAB,009037,EV_DashBoardVDDMQBAB_009_VW37.rod
;Sunday,16,September,2018,18:28:38:36026
;VCID: 65827AD864ED7C62B1-8030
IDE00295-Oil temperature display,OFF ,1
IDE00301-Distance,66780 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,English ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,18 H,1
IDE00501-Minute,29 min,1
IDE00502-Year,2018 yr,2
IDE00503-Month,9 mon,1
IDE00504-Day,16 d,1
IDE00510-ESI: distance driven from inspection,7362 km,3
IDE00511-ESI: time from inspection,316 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,53500 km,2
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,1463 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,5.7 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS02957-Units adjusted-Time,24h ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,120 ,2
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,15000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,365 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,7300 km,2
IDE03352-FIX: Time since last time-dependent inspection,316 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,No ,1
IDE04169-Display correction of consumption and operating range: gas,100 %,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Display ,1
IDE08140-Driving profiled for range remaining CNG,3.7 kg/100 km,2
IDE08247-Driving profile for range remaining LPG,10.0 l/100km,2
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,45 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,17 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,32 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,46 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,08 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,20 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,12 ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG119874-Gas_functionality,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,No ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,1.400 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,active ,4
Elapsed Time: 00:25
;SW:5Q0-963-272-B HW:5Q0-963-272-B --- Aux. Heat
;Component:STH-MQB 006 0069, Coding:1309
;EV_AuxilParkiHeateWOS,002014,EV_AuxilParkiHeateWOS.rod
;Sunday,16,September,2018,18:36:38:36026
;VCID: 3522EA9894CDCCE2C1-8060
IDE00470-Initial fuel filling,Yes ,1
IDE06640-MAS01167-Transfer fuel pump-Actuation time,15 s,5
IDE06640-MAS05078-Transfer fuel pump-Minimum tank level,127 l,5
IDE06640-MAS05079-Transfer fuel pump-Fuel reserve amount,100 ml,5
IDE06640-MAS05080-Transfer fuel pump-Maximum standing time,0.0 H,5
IDE06640-MAS05689-Transfer fuel pump-Activation delay,10 s,5
IDE06642-MAS05071-Coolant change-over valve-Temperature difference: engine/parking heater,5 °C,4
IDE06642-MAS05072-Coolant change-over valve-Maximum engine rpm,2000 /min,4
IDE06642-MAS05073-Coolant change-over valve-Residual heat: threshold,55 °C,4
IDE06642-MAS05074-Coolant change-over valve-Note engine rpm,No ,4
IDE06686-Insufficient voltage threshold,11.3 V,1
IDE06687-CO2 adjustment,157 ,1
IDE06688-Auxil. heater activation,active ,1
IDE06689-Low voltage detection: time limit,20.0 s,1
IDE06690-MAS05059-Auxil. heat control parameters-Lower temperature threshold: ambient temperature,5.0 °C,11
IDE06690-MAS05060-Auxil. heat control parameters-Upper temperature threshold: ambient temperature,12.0 °C,11
IDE06690-MAS05061-Auxil. heat control parameters-Temperature hysteresis: ambient temperature for USA vehicle,3.0 °C,11
IDE06690-MAS05062-Auxil. heat control parameters-Lower temperature threshold: coolant temperature via CAN,72 °C,11
IDE06690-MAS05063-Auxil. heat control parameters-Upper temperature threshold: coolant temperature via CAN,88 °C,11
IDE06690-MAS05064-Auxil. heat control parameters-Lower temperature threshold for partial load after full load,74 °C,11
IDE06690-MAS05065-Auxil. heat control parameters-Lower temperature threshold for starting from control pause,76 °C,11
IDE06690-MAS05066-Auxil. heat control parameters-Upper temperature threshold for full load after partial load,84 °C,11
IDE06690-MAS05067-Auxil. heat control parameters-Upper temperature threshold for control pause,88 °C,11
IDE06690-MAS05068-Auxil. heat control parameters-Temperature threshold for control mode,82 °C,11
IDE06691-MAS05064-Parking heat control parameters-Lower temperature threshold for partial load after full load,58 °C,7
IDE06691-MAS05065-Parking heat control parameters-Lower temperature threshold for starting from control pause,60 °C,7
IDE06691-MAS05066-Parking heat control parameters-Upper temperature threshold for full load after partial load,82 °C,7
IDE06691-MAS05067-Parking heat control parameters-Upper temperature threshold for control pause,88 °C,7
IDE06691-MAS05068-Parking heat control parameters-Temperature threshold for control mode,82 °C,7
IDE06691-MAS05069-Parking heat control parameters-Temperature threshold for activation of fresh air blower,45 °C,7
IDE06691-MAS05070-Parking heat control parameters-Control behavior,Continuous ,7
IDE06692-Note request for aux. heater from A/C system,Do not ignore ,1
IDE06693-Evaluate air pressure via CAN,Yes ,1
IDE06694-MAS05076-Minimum burn time-Time,300 s,2
IDE06694-MAS05077-Minimum burn time-Temperature threshold offset,4 °C,2
MAS01488-MAS03873-recirc. pump-Duty cycle,not active ,5
MAS01488-MAS05072-recirc. pump-Maximum engine rpm,12750 /min,5
MAS01488-MAS06093-recirc. pump-Lowest temperature for request of exterior water pump,-20 °C,5
MAS01488-MAS06094-recirc. pump-Lowest activation temperat. for request of exterior water pump,150 s,5
MAS01488-MAS06095-recirc. pump-Maximum temperature for request of exterior water pump,180 s,5
MAS05075-Evaluate ethanol content,Yes ,1
MAS09096-Recirc. pump locking mechan.,1 ,1
ENG119729-activacion_of_simulated_flamme_run_for_emv_measuring,No ,1
ENG119721-development_data_on_CAN,not active ,1
Elapsed Time: 00:05
;SW:5Q0-907-530-T HW:5Q0-907-530-M --- CAN Gateway
;Component:GW MQB High 212 2186, Coding:030100342B085700EF00005C1C0F00010001050000000000000000000000
;EV_GatewConti,011017,EV_GatewConti_011_VW37.rod
;Sunday,16,September,2018,18:29:51:36026
;VCID: 42C88144D5036B5A74-8016
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
IDE00002-Transport mode,not active ,1
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01211-Static current measuring mode,not activated ,1
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01459-Energy management heat output control status,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
IDE01860-Generator specified voltage value variable,10.6 V,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
IDE02200-Component protection showroom mode,not active ,1
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 03 ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE04186-Battery terminal recognition,connected ,1
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated ,1
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error ,1
IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
IDE06541-Distance left for deactivation of transport mode,50 ,1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,not activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE07838-Counter for inconsistent states,519 ,2
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE08624-MKE Check box,activated ,1
IDE10735-Number requests autonomous recharging,9 ,1
IDE10736-Cyclization limitation request battery service,0 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,not activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,activated ,3
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %,10
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100 ,10
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms,10
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms,10
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms,10
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms,10
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms,10
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms,10
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active ,3
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active ,3
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active ,3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,0 ms,12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,1000 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG118779-IDE02583-Multi_function_steering_wheel_control_module Coding Value-Steering wheel Tiptronic switch,not installed ,3
ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-Version,ACC ,3
ENG118779-MAS09758-Multi_function_steering_wheel_control_module Coding Value-Temperature sensor,not installed ,3
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1,active ,3
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2,not active ,3
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,14 s,5
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
Elapsed Time: 00:22
;SW:5Q4-959-393-C HW:5Q4-959-393-B --- Door Elect, Driver
;Component:TSG FS 009 0015, Coding:003003208000028000001000
;EV_DCUDriveSideEWMAXCONT,006001,EV_DCUDriveSideEWMAXCONT.rod
;Sunday,16,September,2018,18:36:56:36026
;VCDS Version: Beta 18.7.2 (x64) Data version: 20180808 DS295.0
;VCID: 43C68440CA1962527F-8016
IDE00001-Production mode,00000000 00000000 00000000 ,3
IDE02332-Deactivate production mode,00000000 00000000 00000000 ,3
ENG117304-Patch_Code_Driver_Side_Rear,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E 97 01 03 4D 15 20 3D 04 68 00 00 00 00 00 00 00 00 00 C2 32 04 B4 66 ,128
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %,1
ENG117302-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1,6D 4E 03 02 00 00 18 24 7F 7C 02 9A 15 0D 2A 7A 04 0F 1E 18 07 00 05 3E 23 03 00 14 28 AA 00 00 1E 5A AA 08 0A 05 05 00 00 00 23 64 1E 1E 0A 68 04 00 09 00 73 00 04 35 4C C0 05 0E 16 4C 54 64 96 14 96 8C 7D 7D 7D 7D A0 80 98 94 90 90 90 90 9A 32 02 06 08 0A 00 00 00 32 04 A4 0F F5 F5 1E 23 0C 1E 69 46 0A 50 96 00 00 96 96 05 00 00 00 01 01 4C 00 00 02 03 05 14 75 33 00 00 00 05 68 ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,14 04 30 03 48 1F 13 00 14 14 00 28 00 22 02 58 01 90 02 58 0A 7D 0C 1E 28 00 32 32 00 F0 00 00 00 00 00 00 00 E4 00 00 3F 05 9C 4E 20 4D 58 1D 0C 0C 4E 44 A7 4D 9F 32 0A 9C 1F 9C 00 00 00 00 00 00 00 00 00 FA 00 00 33 33 30 31 03 00 00 00 00 00 00 00 00 00 06 44 ,88
Elapsed Time: 00:06
;SW:5Q0-909-144-P HW:5Q0-909-144-P --- Steering Assist
;Component:EPS_MQB_ZFLS 123 1043, Coding:0103
;EV_SteerAssisMQB,010031,EV_SteerAssisMQB_010.rod
;Sunday,16,September,2018,18:37:12:36026
;VCID: 41CA8E48D00570426D-8014
IDE03724-Straight line running,active ,1
IDE03734-Support power,100% ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE04555-Activation of pwr steering asst without engine running,not active ,1
IDE05162-Software end stop,active ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE07540-Download without rest bus,not active ,1
IDE09571-RPM monitoring,active ,1
MAS02080-XCP calibration protocol,not active ,1
Elapsed Time: 00:02
;SW:5Q4-959-392-C HW:5Q4-959-392-B --- Door Elect, Pass.
;Component:TSG BFS 009 0015, Coding:003001208000028000801000
;EV_DCUPasseSideEWMAXCONT,006001,EV_DCUPasseSideEWMAXCONT.rod
;Sunday,16,September,2018,18:37:26:36026
;VCID: 42C88144D5036B5A74-8016
ENG117308-Patch_Code_Passenger_Side_Rear,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E 97 01 03 4D 15 20 3D 04 68 00 00 00 00 00 00 00 00 00 C2 32 04 B4 66 ,128
ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %,1
ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %,1
ENG117306-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1,67 4E 03 02 00 00 18 24 7F 7C 02 9A 15 0D 2A 7A 04 0F 1E 18 07 00 05 3E 23 03 00 14 28 AA 00 00 1E 5A AA 08 0A 05 05 00 00 00 23 64 1E 1E 0A 68 04 00 09 00 73 00 04 35 4C C0 05 0E 16 4C 54 64 96 14 96 8C 7D 7D 7D 7D A0 80 98 94 90 90 90 90 9A 32 02 06 08 0A 00 00 00 32 04 A4 0F F5 F5 1E 23 0C 1E 69 46 0A 50 96 00 00 96 96 05 00 00 00 02 01 4C 00 00 02 03 05 14 75 33 00 00 00 2B 85 ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,14 04 30 03 48 1F 13 00 14 14 00 28 00 22 02 58 01 90 02 58 0A 7D 0C 1E 28 00 32 32 00 F0 00 00 00 00 00 00 00 E4 00 00 3F 05 9C 4E 20 4D 58 1D 00 00 4E 44 A7 4D 9F 32 0A 9C 1F 9C 00 00 00 00 00 00 00 00 00 FA 00 00 33 33 30 31 03 00 00 00 00 00 00 00 00 00 C3 84 ,88
Elapsed Time: 00:06
;SW:5G0-035-824-A HW:5G0-035-824-A --- Information Electr.
;Component:MU-S--ER 041 0421, Coding:02730200FF00000011110001000800001F0100940100010001
;EV_MUStd4CPASE,002039,EV_MUStd4CPASE_VW37.rod
;Sunday,16,September,2018,18:37:55:36026
;VCID: 230624C02A5942521F-8076
IDE00346-Summertime-automatic,Europe ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,5E 05 A1 20 60 56 05 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 05 A1 20 60 56 05 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02330-Number 2 for Info call,5E 06 91 64 77 61 56 05 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 06 91 64 77 61 56 05 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,48 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,48 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,48 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,48 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,48 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,48 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,48 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,48 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,48 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,48 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,48 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,48 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,48 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,48 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,48 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,48 ,49
IDE02502-Confirmation of installation change,CF CC ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03581-ENG117690-Vehicle function list CAN-Adaptive_key_msg_bus,Comfort data bus ,8
IDE03581-ENG117691-Vehicle function list CAN-Adaptive_key_school,Not available ,8
IDE03581-ENG117688-Vehicle function list CAN-Driving_school,Not available ,8
IDE03581-ENG117689-Vehicle function list CAN-Driving_school_msg_bus,Databus Infotainment ,8
IDE03581-ENG107608-Vehicle function list CAN-MFL,Available ,8
IDE03581-ENG117681-Vehicle function list CAN-MFL_msg_bus,Databus Infotainment ,8
IDE03581-ENG117683-Vehicle function list CAN-Oil_level,Not available ,8
IDE03581-ENG117684-Vehicle function list CAN-Oil_level_msg_bus,Databus drivetrain ,8
IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering,Not available ,8
IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus,Suspension data bus ,8
IDE03581-ENG98994-Vehicle function list CAN-Trailer,Not available ,8
IDE03581-ENG117682-Vehicle function list CAN-Trailer_msg_bus,Comfort data bus ,8
IDE03581-ENG99892-Vehicle function list CAN-VIN,Available ,8
IDE03581-ENG117687-Vehicle function list CAN-VIN_msg_bus,Comfort data bus ,8
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,40
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,40
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,40
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,40
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,40
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,40
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,40
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,40
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,40
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,40
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,40
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,40
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,40
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,40
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,40
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,40
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,40
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,40
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,40
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,40
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,40
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,40
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,40
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,activated ,40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,activated ,40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,40
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,40
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,40
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,40
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,40
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,40
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,40
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,40
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,40
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,activated ,40
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,40
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,40
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,40
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,40
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,40
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,40
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,40
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,40
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,40
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,40
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,40
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,40
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,40
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,40
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,40
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,40
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,40
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,40
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,40
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,40
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,40
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,40
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,40
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,40
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,40
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,40
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,not activated ,40
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,40
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,40
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,40
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,40
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,not activated ,40
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,40
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,40
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,40
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,40
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,40
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,40
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,40
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,40
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,40
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,40
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,40
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,40
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,40
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,40
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,40
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,activated ,40
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,40
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,not activated ,40
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,40
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,40
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,40
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,40
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,40
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,40
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,40
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,40
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,40
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,40
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,40
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,40
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,40
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,40
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,40
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,40
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,40
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,not activated ,40
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,40
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,40
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,40
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,40
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,40
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,40
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,40
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,40
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,40
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,40
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,40
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,40
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,40
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,40
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,40
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,40
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,40
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,40
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,40
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,not activated ,40
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,40
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,40
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,40
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,40
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,40
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,40
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,40
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,40
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,40
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,activated ,40
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,40
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,40
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,40
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,40
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,40
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,40
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,40
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,40
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,40
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,40
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,activated ,40
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,40
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,40
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,40
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,40
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,40
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,40
IDE04300-ENG117511-Vehicle menu operation-menu_display_side_assistant,not activated ,40
IDE04300-ENG117515-Vehicle menu operation-menu_display_side_assistant_after_disclaimer,not activated ,40
IDE04300-ENG117512-Vehicle menu operation-menu_display_side_assistant_clamp_15_off,not activated ,40
IDE04300-ENG117513-Vehicle menu operation-menu_display_side_assistant_over_threshold_high,activated ,40
IDE04300-ENG117514-Vehicle menu operation-menu_display_side_assistant_standstill,not activated ,40
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,40
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,40
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,40
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,40
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,40
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,activated ,40
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,40
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,40
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,activated ,40
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,40
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,40
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,40
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,40
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,40
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,40
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,40
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,40
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,40
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,40
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,40
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,40
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,40
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,40
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,40
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,40
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,40
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,40
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,40
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,40
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,40
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,40
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,40
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,40
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,40
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,40
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,53
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Databus extended ,53
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,53
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,Suspension data bus ,53
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,53
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,Not available ,53
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,activated ,53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,Comfort data bus ,53
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,53
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,53
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,53
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Databus Infotainment ,53
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,53
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,53
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,53
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Comfort data bus ,53
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,not activated ,53
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Databus Infotainment ,53
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,53
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,Comfort data bus ,53
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,53
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Comfort data bus ,53
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,53
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,Comfort data bus ,53
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,53
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,53
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,53
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,Databus Infotainment ,53
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,53
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,53
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,not activated ,53
IDE04307-ENG125040-Vehicle function list BAP-Ecall_msg_bus_0x33,Comfort data bus ,53
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,53
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Comfort data bus ,53
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,53
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,Comfort data bus ,53
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,53
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Databus drivetrain ,53
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,53
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,53
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,not activated ,53
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Databus extended ,53
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,53
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Comfort data bus ,53
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,53
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,53
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,53
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,53
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,53
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,Not available ,53
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,not activated ,53
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,53
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,53
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,Comfort data bus ,53
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,activated ,53
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,53
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,53
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,53
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,53
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,Not available ,53
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,activated ,53
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,53
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,53
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Databus extended ,53
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,53
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,53
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,53
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Databus extended ,53
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,53
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,Terminal 15 ,53
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,53
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,53
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,not activated ,53
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Databus Infotainment ,53
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,53
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,53
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,53
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Comfort data bus ,53
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,6
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,6
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,6
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,6
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,6
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 90 01 58 02 2C 01 5E 01 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 F7 ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
Elapsed Time: 00:19
;SW:5Q0-907-383-F HW:5Q0-907-383-C --- Trailer
;Component:Anhaenger H14 0137, Coding:0100000202000000
;EV_TrailFunctGener2Hella,001005,EV_TrailFunctGener2Hella_VW26.rod
;Sunday,16,September,2018,18:38:21:36026
;VCID: 3A38F9A4BDD3239A2C-806E
IDE00001-Production mode,not active ,3
Elapsed Time: 00:01
