No Response from Module
danguy
C?ID=337076
Not sure if it's my car, a setting or something else, so I'm posting this here. I've got a 2004 VW TDI New Beetle. What I had hoped to do was to disable the daytime running lights, as I keep having to replace the headlight bulbs. However, when I try to access the Cent. Electric module (09 I believe), I get a No Response from Module message.
Is that module not available to access for my year/make, is there a setting I need to change in the software?
I did an Auto-Scan, which does not show that module as scanned:
Saturday,15,September,2018,10:01:04:55135
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: notpostinghere License Plate: also not posting
Mileage: 227540km-141386mi Repair Order:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: notpostinghere Mileage: 227540km-141386miles
Any suggestions/thoughts appreciated. Thanks!
Dan
myounus
Northwest UK
C?ID=321059
Hi Dan
We need to see a full autoscan to be able to help.
danguy
C?ID=337076
I can do that. Wasn't sure if you needed everything. Should have searched better before I posted.
VIN: 3VWCR31C04M419947   License Plate: 5KWR419
VIN: 3VWCR31C04M419947   Mileage: 227540km-141386miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 997 016 M    HW: 028 101 114 7
   Component: R4 1,9L EDC G000SG  2878
   Revision: 12345678    Serial number: VWZ5Z0D2227040
   Coding: 0150031
   Shop #: WSC 22595 444 58789
   VCID: 280904CC0EEE6EB7197-5160
16725 - Camshaft Position Sensor (G40)
            P0341 - 000 - Implausible Signal - Intermittent
                    RPM: 882 /min
                    Torque: 40.0 Nm
                    Voltage: 14.21 V
                    Bin. Bits: 00101000
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019458
   Shop #: WSC 00028 000 00000
   VCID: 3431E0BCC2261A57A5F-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AG
   Component: 01 AIRBAG VW71      0710
   Coding: 0012337
   VCID: 7CA1089CAAF612172DF-5160
   Subsystem 1 - Part No: 1C0 959 339
   Component: BF-Gewichtsens004 ·
02511 - Control Module for Seat Occupied Recognition (J706)
            014 - Defective
00592 - Seat Belt Switch; Passenger (E25)
01221 - Crash Sensor Side Airbag; Driver Side (G179)
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 951 A
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11232
   Shop #: WSC 02408
   VCID: 1F1B1F105EA0A90F68D-4B1E
   3VWCR31C04M419947     VWZ5Z0D2227040
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70B92CACF3BE6677817-4B1E
   Part No: 1C0 959 799 G
   Component: 2K Komfortgerát HLO 0004
   Coding: 00064
   Shop #: WSC 00066
   VCID: 3B23CB80EA78D52F645-4B1E
   Subsystem 1 - Part No: 1C2959802A
   Component: 2K Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C2959801A
   Component: 2K Tõrsteuer.BF KLO 0202
            35-00 -  -
End----------(Elapsed Time: 03:40, VBatt start/end: 13.8V/13.8V)-----------
myounus
Northwest UK
C?ID=321059
This does not appear to be a proper autoscan. What cable are you using? In my signature is a link on how to perform a full autoscan.
PetrolDave
Westbury, UK
C?ID=1423
There are many missing modules in that scan log, so you have the ignition turned on when doing the auto-scan?
danguy
C?ID=337076
Yes, the ignition was on and the car running.
PetrolDave
Westbury, UK
C?ID=1423
I THINK (not 100% certain) that your car doesn't have an 09 as the functions are done by the 46. So you need to look at the 46 (Central Convenience) module, why is that saying incorrectly coded?
danguy
C?ID=337076
I did look there, but didn't see anything about the daytime running lights . . . Not sure why it is saying incorrectly coded.
The incorrect coding was kinda going to be my next question. I have no idea what that means, but it doesn't seem like a good thing. :-)
I really appreciate your responses. Thank you!
PetrolDave
Westbury, UK
C?ID=1423
Hopefully someone with access to tools that can provide coding suggestions from the VIN will come along soon...
Electrically, that generation New Beetle is essentially an Mk.4 Golf/Jetta. It does not have an 09 module, and the lights are not computer controlled. If you wish to disable DRLs, you will have to dig into the wiring diagrams and disable them the old fashioned way.
danguy
C?ID=337076
That's what I've been suspecting, but it's good to have confirmation. Thank you so much!
