Results 1 to 8 of 8
Thread: 2010 AUDI S5 / A5 CABIOLET ROOF RESET ADAPTION
    Apr 2017
    I have replace the luggage blind switch/potentiometer in the LHR of vehicle and the centre rear servo lock for the roof stowage lid lock. all functions, as it should no faults return.
    on most other convertibles i have repaired there is a adaption routine that can be run to make sure all the limit switches are correctly aligned. there are functions in output tests, adaption and basic settings, but none react. is there any security entry code, or a sequence that should be followed?
    SCAN ATTACHED
    Friday,14,September,2018,15:02:38:08836
    VCDS Version: 18.2.1.5 (x64)
    VIN: WAUZZZ8F1AN019278 License Plate: BJ10UJO
    Mileage: 101830km-63274mi Repair Order: S5 cab 2010
    Chassis Type: 8F-AU48 (8T0)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 26 30 36 42 46 47 52
    53 55 56 5F 62 6C 72
    VIN: WAUZZZ8F1AN019278 Mileage: 101830km-63274miles
    Address 01: Engine (J623-CAKA) Labels:| 06E-907-551-CAK.clb
    Part No SW: 8K0 907 551 HW: 8K0 907 551
    Component: 3.0T SIMOS84 H06 0005
    Revision: --------
    Coding: 011C000C240F0128
    Shop #: WSC 02145 785 00200
    ASAM Dataset: EV_ECM30TFS8K0907551 A01007
    ROD: EV_ECM30TFS8K0907551_A01.rod
    VCID: 6ED3E22EB1B58134C6-803A
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 8K1 927 156 B HW: 0B5 927 156 E
    Component: 0B5 30TFSIRdW H03 0002
    Revision: --H03--- Serial number: 0000000474
    Coding: 000001
    ASAM Dataset: EV_TCMDL501 A02044
    ROD: EV_TCMDL501.rod
    VCID: 346730469F19EBE4F0-8060
    Part No SW: 8K0 907 379 BE HW: 8K0 907 379 BE
    Component: ESP8 quattro H04 0030
    Coding: 294D08
    Shop #: WSC 02391 823 56573
    VCID: 7DF1D562E4D3EAAC4F-8028
    Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
    Component: BCM2 1.1 H02 0327
    Coding: 011300
    Shop #: WSC 02399 823 56573
    VCID: 0109A992982B8E4C2B-8054
    Subsystem 1 - Part No SW: 8T0 959 754 Q HW: 8T0 959 754 Q
    Component: FBSAUDIB8 IDG H37 0060
    Serial number: 0510000000712012
    Component: J764 ELV MLB H37 0042
    Serial number: 0210000007602015
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
    Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
    Component: KLIMA 3 ZONEN H08 0171
    Revision: D1000000 Serial number: 01090220100090
    Coding: 66170000
    VCID: 77FDC74AC6EFC0FC15-8022
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H25 0380
    Revision: 10025001 Serial number: 00000000583602
    Coding: 260050914074AF010009000300005D5D0F1D438A0201014100 0000
    VCID: 3C771866BF4923A438-8068
    Subsystem 1 - Part No SW: 8F2 955 119 HW: 8K2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 040210 H05 0021
    Serial number: SWF10020045376
    Coding: 00FD11
    Component: RLS H04 0003
    Serial number: 10710171
    Coding: 02562A
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Serial number: 00000000000302101244
    Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
    Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
    Component: PARKHILFE 8K H06 0070
    Revision: 11001001 Serial number: 50941004405329
    Coding: 300102
    VCID: 489F74B6FB917F04AC-801C
    Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
    Part No SW: 8F0 959 655 HW: 8F0 959 655
    Component: AirbagVW-AU10 H10 0430
    Serial number: 003A4D064YVJ
    Coding: 30363635353130303030554A305238463053
    ASAM Dataset: EV_AirbaAU10SMEAU485 001004
    ROD: EV_AirbaAU10SMEAU485.rod
    VCID: 75E1CD42D4E3B2EC07-8020
    Serial number: 6334MSME4F112F20D
    Serial number: 6344MSME4F120E21D
    Serial number: 6352QSME385034066
    Serial number: 6362QSME25514E0AJ
    Serial number: 63732SME324E0432V
    Serial number: 63832SME4A4E2430+
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90315JB90005T
    Coding: 000036
    VCID: 3D711562A4532AAC0F-8068
    Component: E221 - MFL H02 0010
    Part No SW: 8T0 920 981 M HW: 8T0 920 981 M
    Component: KOMBIINSTR. H36 0255
    Revision: 00000000 Serial number: CSI74602A
    Coding: 2F0719000B002600010000
    VCID: 46837A8EF18569745E-8012
    Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
    Component: GW-BEM 5CAN-M H10 0105
    Revision: FB900055 Serial number: 5500F101298103
    Coding: 00C303
    VCID: 000FAC969321874424-8054
    Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
    Component: J367-BDM H07 0170
    Serial number: 10006741290110
    Address 26: Auto Roof (J256) Labels:| 8F0-959-255.clb
    Part No SW: 8F0 959 255 HW: 8F0 959 255
    Component: VSG-AUDI-B8 H09 0170
    Shop #: WSC 02135 785 00200
    ASAM Dataset: EV_ElectRoofContr 001007
    ROD: EV_ElectRoofContr.rod
    VCID: 71E9F952A08B9ECCDB-8024
    Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
    Part No SW: 8K0 907 440 B HW: 8K0 907 440
    Component: STS H04 0020
    Revision: S0H04000 Serial number: 00000000013411
    Coding: 01010101000000000000000102
    Shop #: WSC 02391 823 56541
    VCID: 2D5125227433BA2CBF-8078
    End-------------------------(Elapsed Time: 03:50)-------------------------
    Oct 2017
    Northwest UK
    There are no security codes for running output tests. Does the roof open/close?
    Apr 2017
    yes it opens and closes.
    Apr 2017
    i will take another look at output tests again tomorrow, pretty sure they were greyed out, which is why i thought there might be a entry code first?
    Apr 2017
    yes just checkedagain on output tests, it only tests selected curcuits, not a full adaption map as you can do on the mk2 TT roof?
    adaption looks more promising, but there is no codes or info to support its use that i have found upto now.
    United States
    Hi Andy,
    This controller shouldn't require a reset after repairs.
    Jef has been working on the following recently:
    https://www.youtube.com/watch?v=-3Sb7E2NxPM
    and
    http://wiki.ross-tech.com/wiki/index...(FH)_Auto_Roof
    This is an older thread but relevant to the roof/car type:
    https://forums.ross-tech.com/showthr...op-issue-B11A0
    As far as ADP options go it looks like you can turn off production mode (aka Factory mode). BS contains [*IDE00498*] Resetting of all adaptation values .. but that's the nasty group that can create No EOL Programming DTCs in something like a Level Controller module so we always advise against using it when the outcome is unknown.
  7. Likes Uwe, Andy liked this post
    Apr 2017
    A5 cabriolet roof fault resolved
    Dana, all the links and information very helpful, thank you, by comparing info, I identified f202 as the main issue, the links supplied suggested a switch below the rear window. It is actually on the joint above the driver on the right hand side, it looks like an inductive switch, the wires inside the adjoining loom had broken because the turn is too tight, and will be a regular failure. I have taken the cable out of the retainer and extended the loop to resolve future fatigue issues. I will add the photo I have taken, when I get back in front of a PC
  9. Likes Uwe, Dana, Eric liked this post
  10. #8
    Administrator Andy's Avatar
    Sector 7G
    Here's the pic sent by andy b with his permission to post here:
    Thanks!
  11. Likes Uwe, Eric, Dana liked this post
