Results 1 to 3 of 3
Thread: New here
    Sep 2018
    New here
    Hello, new guy here. Lots of info, did some searching but looking for some assistance to a no response from the controller issue I receive while trying to access some menus. Specifically, the hidden menu.
    Some details:
    Battery fully charged but I do have some draw when car is off.
    2009 Audi A4 quattro 2.0T
    MMI version 0211
    Hex-V2 cable
    Surface 3 using Windows 10
    Was wondering if my MMI software version was too old?
    Here's my latest auto scan. If anyone has some input to any of the fault codes you see (besides intake manifold lol) don't hesitate to give advice. Thank you
    Thursday,13,September,2018,11:49:42:29144
    VIN: WAUSF78K79N028560   License Plate:
    Mileage: 150050km-93236mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
              65 72 77
    VIN: WAUSF78K79N028560   Mileage: 150050km-93236miles
    Address 01: Engine (-----CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 D    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0002
       Revision: E1H14---
       Coding: 0104010A190F0160
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_ECM20TFS8K2907115D A01002
       ROD: EV_ECM20TFS8K2907115D.rod
       VCID: 303913AA2AA44E07C14-8064
    14 Faults Found:
    4629 - ECM Power Relay Load Circuit
              P068A 00 [032] - Opens Too Early
                        Fault Frequency: 14
                        Coolant temperature: 27 C
                        Intake air temperature: 27 C
                        Voltage terminal 30: 8.787 V
    2975 - Intake Manifold Flap; Bank 1
              P2004 00 [104] - Stuck Open
                        Fault Frequency: 29
                        Mileage: 148239 km
                        Date: 2015.07.30
                        Time: 12:06:26
                        Engine speed: 873.50 /min
                        Normed load value: 30.6 %
                        Vehicle speed: 5 km/h
                        Coolant temperature: 72 C
                        Intake air temperature: 49 C
                        Voltage terminal 30: 12.298 V
    2977 - Intake Manifold Flap; Bank 1
              P2004 00 [096] - Stuck Open
    2968 - Intake Manifold Flap Position Sensor (Bank 1)
              P2015 00 [096] - Implausible Signal
    2970 - Intake Manifold Flap Position Sensor (Bank 1)
              P2015 00 [237] - Implausible Signal
                        Mileage: 149568 km
                        Date: 2015.10.11
                        Time: 20:21:53
                        Engine speed: 3746.00 /min
                        Normed load value: 63.1 %
                        Vehicle speed: 55 km/h
                        Coolant temperature: 90 C
                        Intake air temperature: 43 C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 12.816 V
    5671 - Boost Pressure Regulation
              P0299 00 [096] - Control Range Not Reached
    4054 - Cylinder 1
              P0301 00 [096] - Misfire Detected
                        Mileage: 150036 km
                        Date: 2016.08.12
                        Time: 09:28:33
                        Engine speed: 755.00 /min
                        Normed load value: 16.9 %
                        Coolant temperature: 52 C
                        Voltage terminal 30: 13.028 V
                        Unlearning counter according OBD: 29
    4060 - Cylinder 3
              P0303 00 [096] - Misfire Detected
                        Mileage: 150036 km
                        Date: 2016.06.29
                        Time: 14:21:38
                        Engine speed: 710.00 /min
                        Normed load value: 17.3 %
                        Intake air temperature: 28 C
                        Voltage terminal 30: 12.604 V
                        Unlearning counter according OBD: 28
    4063 - Cylinder 4
              P0304 00 [096] - Misfire Detected
                        Mileage: 150036 km
                        Date: 2016.06.29
                        Time: 14:21:38
    4057 - Cylinder 2
              P0302 00 [096] - Misfire Detected
                        Mileage: 150038 km
                        Date: 2008.12.02
                        Time: 22:41:44
                        Engine speed: 753.00 /min
                        Coolant temperature: 60 C
                        Intake air temperature: 30 C
                        Voltage terminal 30: 13.075 V
                        Unlearning counter according OBD: 32
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [096] - -
    7781 - Engine Off Timer Performance
              P150A 00 [096] - -
                        Mileage: 150050 km
                        Date: 2008.05.27
                        Time: 00:10:07
                        Coolant temperature: 55 C
                        Intake air temperature: 24 C
                        Voltage terminal 30: 11.779 V
    4201 - Fuel Level too Low
              P1250 00 [101] - -
                        Mileage: 150050 km
                        Date: 2008.05.30
                        Time: 03:05:52
                        Engine speed: 1277.00 /min
                        Normed load value: 28.2 %
                        Coolant temperature: 25 C
                        Intake air temperature: 23 C
                        Voltage terminal 30: 12.510 V
    4261 - System Voltage
              P0562 00 [096] - Too Low
                        Fault Frequency: 6
                        Mileage: 150050 km
                        Date: 2008.06.02
                        Time: 23:23:31
                        Voltage terminal 30: 7.491 V
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0030
       Revision: --H04---
       Coding: 001002
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 363525B2C8C060379B8-8062
       Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
       Component: ESP8 quattro  H04 0060
       Coding: 150500
       Shop #: WSC 02399 823 56573
       VCID: 79AFEE8EB9DE4F4F36A-802C
       Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
       Component: BCM2 1.1      H80 0141
       Coding: 090100
       VCID: 33331CA6DB32751FBC6-8066
       Serial number: 0508000050612013
       Serial number: 0208000047789006
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 141
                        Mileage: 150050 km
                        Date: 2008.05.27
                        Time: 00:32:34
    00955 - Key 1
                        Reset counter: 182
                        Mileage: 150050 km
                        Date: 2008.05.27
                        Time: 01:22:24
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0140
       Revision: C1000000    Serial number: 0103.09.081347
       Coding: 64002000
       VCID: 72BDD9A2E4A83C17770-8026
                000 -  -  - Intermittent
                        Reset counter: 181
                        Mileage: 150050 km
                        Date: 2008.06.02
                        Time: 23:22:21
                008 - Implausible Signal
                        Fault Status: 01101000
                        Fault Frequency: 10
                        Reset counter: 142
                        Mileage: 150036 km
                        Date: 2008.05.27
                        Time: 01:19:25
                        Reset counter: 170
                        Mileage: 150036 km
                        Date: 2008.05.27
                        Time: 00:20:30
                        Reset counter: 172
                        Mileage: 150036 km
                        Date: 2008.05.27
                        Time: 00:23:37
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Revision: 05022001    Serial number: 00000000226508
       Coding: 26001011063CAF010000080300003D0D0F1C520800010161000000
       Shop #: WSC 60173 123 10485
       VCID: 303913AA2A244E07C14-8064
       Component: WWS 120908  H06 0070
       Serial number: SWF08090125666
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10244318
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000001609080843
       Subsystem 4 - Part No SW: 8K0 907 410 A    HW: 8K0 907 410 A
       Component: UGDO HL US  H04 0060
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Serial number: 0039KD14648P
       VCID: 40D9436A9A04DE87314-8014
       Serial number: 5810000R0800001FLF
       Serial number: 6334MSME41344A7BH
       Serial number: 6344MSME3F762660J
       Serial number: 6352QSME100E2F2EP
       Serial number: 6362QSME100D171CD
       Serial number: 63732SME480A1322T
       Serial number: 63832SME240A222CY
    13697280 - Component Protection
              U1101 00 [008] - Active
                        Fault Frequency: 11
                        Mileage: 150036 km
                        Date: 2016.08.12
                        Time: 17:42:48
    13635840 - Supply voltage
              [Powersupply  lower threshold fall short of]
                        Reset counter: 181
                        Mileage: 150036 km
                        Date: 2016.08.12
                        Time: 18:00:36
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
              [Bladder Mat: functional restriction because of low voltage]
                        Reset counter: 181
                        Mileage: 150036 km
                        Date: 2016.07.08
                        Time: 06:38:14
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90315HIA000EI
       Coding: 000036
       VCID: 3D273A9EED76B36F5A2-8068
       Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
       Component: KOMBIINSTR.   H17 0224
       Revision: 00000000    Serial number: 9DR39EA98
       Coding: 8B1F09000300D705020000
       VCID: 2D070ADE3D1623EFEA2-8078
       Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0094
       Revision: 4GB20042    Serial number: 4200G088318141
       Coding: 000303
       VCID: 46D55572B8A0F0B70B8-8012
       Component: J367-BDM  H04 0150
       Serial number: 18041AE6270808
       Part No SW: 8T0 035 785     HW: 8T0 035 785
       Revision: 00000000
       Coding: 020302
       VCID: 78A9EB8A82D45647494-802C
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001149775
       Coding: 00581300000000000000
       VCID: 77ABE8B68FCA593F40E-8022
                        Reset counter: 172
    00532 - Supply Voltage B+
                        Fault Frequency: 25
                        Reset counter: 181
                        Mileage: 150036 km
                        Date: 2008.05.27
                        Time: 01:19:28
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000007645919
       Coding: 011C03204E00410001
       VCID: 41DF466E918ED78F3EA-8014
       Revision: 00002001    Serial number: 0114316859
       Coding: 0106063A007A440400B001
       Component: GTO BF  H06 0040
       Serial number: 00000000000000072208
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS034  H06 0037
    02616 - Fuel Tank Cap; Unlock
                        Fault Status: 00101001
                        Reset counter: 182
                        Mileage: 150050 km
                        Date: 2008.05.27
                        Time: 00:56:45
    02615 - Fuel Tank Cap; Lock
                        Reset counter: 182
                        Mileage: 150050 km
                        Date: 2008.05.27
                        Time: 00:57:58
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S2100000
       Coding: 0203010102
       VCID: 6E85CDD2F09018F7938-803A
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000007650507
       VCID: 40D9436A9A84DE87314-8014
                        Reset counter: 142
                        Mileage: 150050 km
                        Date: 2008.05.27
                        Time: 00:32:23
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 00000000215968
       VCID: 313F16AE212E470FCEA-8064
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000004
       VCID: 34311FBAD23C7227A5C-8060
       Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
       Component: Symph3 Sirius H02 0211
       Revision: 00000004    Serial number: AUZ5Z4H1046196
       Coding: 040200020101850043D9070800
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
                000 -  -
                        Reset counter: 141
                        Mileage: 150050 km
                        Date: 2008.05.27
                        Time: 00:21:36
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000100269263
       Coding: 010C03204000210001
       VCID: 44D14F7A8E9CC2A715C-8010
                        Reset counter: 142
                        Mileage: 150050 km
                        Date: 2008.05.27
                        Time: 00:32:24
    Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140781776533
       Coding: 0CD154
                        Fault Frequency: 8
                        Reset counter: 181
                        Mileage: 150050 km
                        Date: 2008.06.02
                        Time: 23:24:27
                        Bin. Bits: 00001000 10101001
                        Voltage: 8.20 V
                        Text:  28,0C;n.erkannt;     n.erkannt
    02214 - Tire Pressure Warning
                        Fault Frequency: 8
                        Reset counter: 181
                        Mileage: 150050 km
                        Date: 2008.06.01
                        Time: 18:31:10
                        Bin. Bits: 00001000 00100101
                        Voltage: 13.30 V
                        Text:  24,5C; -0,43bar;3441736486;A0h; 30C
                        Reset counter: 170
                        Mileage: 149972 km
                        Date: 2016.01.29
                        Time: 13:12:15
                        Bin. Bits: 00001000 10100011
                        Voltage: 14.00 V
                        Text:  25,0C;n.erkannt;     n.erkannt
                        Reset counter: 172
                        Mileage: 150036 km
                        Date: 2016.07.08
                        Time: 06:37:34
                        Bin. Bits: 00001000 00000000
                        Voltage: 11.10 V
                        Text:  27,0C;n.erkannt;3441736486;--h;---C
       Revision:             Serial number: 0000100269260
       Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005019121
       Coding: 0010370
       VCID: 3B233486FF62BD5F646-806E
                        Fault Status: 00100001
                        Reset counter: 172
                        Mileage: 150036 km
                        Date: 2008.05.27
                        Time: 00:23:15
                        Reset counter: 181
                        Mileage: 150036 km
                        Date: 2016.08.12
                        Time: 17:44:10
                        Reset counter: 170
                        Mileage: 150036 km
    End----------(Elapsed Time: 01:58, VBatt start/end: 12.2V/12.2V)-----------
  2. Likes Boki Ar liked this post
  3. #2
    Oct 2017
    Northwest UK
    You have component protection active on your airbag module - this will need to be removed by a dealer or someone with FAZIT access.
    The vast majority of the faults are due to a flat battery. Change your battery, delete all faults and then re-scan. We can then see what faults are actually active.
  4. Likes Uwe liked this post
  5. #3
    Sep 2018
    Quote Originally Posted by myounus View Post
    Will do. Thanks
