Hi Guys...
I have customer who bought this car after someone swapped engine from 2,5 AKE to 1.9 AVF and gearbox was also changed from automatic to manual. Everything works fine and no foults but CCS is not working. All coding is ok. I checked all signals and had to repair only clutch pedal wiring. I dont have car speed signal in ECU. In all other modules speed signal is present. Speedometer in dash works fine. When I put wire ws/bl directly from dash pin 21 (green plug speed signal) to ECU pin 20 nothing is changing. There was modification in this model that till some year it took speed signal from gearbox and after it took from ABS and go by CAN ?? So maybe they put newer ECU that wait for CAN speed signal ?? Actual engine ECU Part number 038906019JT. Sorry for not having autoscan
Rgs.
Rgs.
