Thanks Uwe. As you will see from the Auto-Scan, the retrofit resulted in a number of faults with a combination of undetectable modules, component protection, and missing messages.
Original seats were standard (i.e., not multicontour) with heating, ventilation, and driver side memory. Rear seats were heated.
The new installed front seats are multicontour with heating, ventilation, massage, and memory. The new installed rear seats have no features. The seats were purchased from Ebay.de and came from a 2015 A7 donor vehicle - I can try and track down additional info if needed but not sure I have it immediately on hand.
I had hoped to tackle the 'simplest' issue (with the rear seat tensioner) first and didn't want to overload others with too much extra info. Your point is taken though and I probably didn't send enough to work with. Attached below is the full Auto-Scan.
My issues are as follows:
1. The centre rear tensioner is triggering the airbag light as mentioned previously.
2. Missing signals from the driver side multicontour module. I'm going to look into whether the power is successfully getting to the multicontour module (seems to be a dual power input from two different pins). The other functions (heating/ventilation/basic seat adjustment) are working as intended so I must be getting some communication and power to the main seat control module. The memory function is not working right now but component protection is active.
3. I am getting missing signals to the passenger side seat (both the main control module and multicontour module on this side). The ventilation and heating functions on this side are not responding to the corresponding buttons (i.e., I can see them lit but nothing is happening). I am getting basic seat adjustments so that suggests to me that there is at least some power getting to the seat.
4. The multicontour modules (both sides) are not detectable regardless of whether I have them installed on the can gateway.
5. The rear HVAC error codes make complete sense to me - my original rear seats had heating. The new ones do not. This function is not a priority for me so I probably will not go through the expense of installing the heating pads on the new seats. If I can turn off the fault code it would be nice, but it's not a big deal.
I hope this helps.
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
53 55 56 5F 62 6C 6D 72 82 88 89 8F 90 AC
VIN: WAU2MCFC0EN035306 Mileage: 48413km-30082miles
88-Multicont. Seat Driver -- Status: Cannot be reached 0100
89-Multicont. Seat Pass. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 N HW: 4G0 907 401 E
Component: 3.0TDI FSA H14 0013
Revision: 58H14---
Coding: 1A2A4012052601050000
Shop #: WSC 55334 002 1048576
ASAM Dataset: EV_ECM30TDI0114G0907401N 002013
ROD: EV_ECM30TDI0114G0907401N_002.rod
VCID: 2E05F2B78097D247D3B-807B
Readiness: 0 0 0 1 1
Part No SW: 4G0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H16 1008
Revision: --H16---
VCID: 3C21C8FF46EB30D76DF-8069
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 27A79703E4E5E9C04B00
Shop #: WSC 02391 785 00200
VCID: 3A2DCEE74CDF0EE77F3-806F
Part No SW: 4H0 907 064 DR HW: 4H0 907 064 DR
Component: BCM2 2.0 H35 0510
Coding: 0DAA2046000000000000
VCID: 7CA108FF06EBF0D72DF-8029
Serial number: 2313000127184004
Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF
Component: KLIMA 4 ZONEN H13 0087
Serial number: 13071300040233
Coding: 368320BE59
ASAM Dataset: EV_AirCondiComfoUDS 002040
VCID: 639353839BD52F2F0C5-8037
0321 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Sitzmemory Beifahrerseite: kein Signal / Kommunikation]
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:46
Voltage terminal 30: 12.00 V
Outside air temperature: 27.5 ∞C
Engine speed: 0 /min
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001460858
Coding: 0D072096073E9FE081000884A0003820CF9CD308A6090239800308457B00
VCID: 6FBB2FB3479D9B4F98D-803B
Component: WWS57X 130628 H36 0080
Serial number: 130705052607
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21525962
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 G HW: 4G0 941 531 G
Component: E1 - LDS H07 0044
Serial number: 16 04 2013 00000704
Component: USHL4.2 H30 0030
Serial number: 0000002274555R6VT402
Subsystem 5 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0002
Serial number: 00000000001306201504
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0002
Serial number: 00000000001306202394
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA106044000004064196
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 2D984AB6000000000001
Subsystem 9 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0002
Serial number: 00000000001305280480
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0002
Serial number: 00000000001305280116
Revision: 11001001 Serial number: 61061319701052
Coding: A8C303
VCID: 71BF29CB51298DBF8E9-8025
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003930$
Coding: 30314531313130303133554A304C34473853
VCID: 3333E3C36BB5FFAFBC5-8067
Serial number: 3575HRB400M50H4K81K4
Serial number: 3585HRB400I50GS6B293
Serial number: 3515JRB401C50K2G818J
Serial number: 3525JRB401850K2G89DT
Serial number: 3554VRB400850KBAI24$
Serial number: 3564VRB400650KBACQ4D
9441819 - Safety belt tensioner igniter; rear; center
B1012 1B [137] - Resistance Too High
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:51
Revision: -------- Serial number: 90372MGB000MW
Coding: 000434
VCID: 3829D4EF72531CF7897-806D
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 27 06 2013 11293008
Part No SW: 4G8 920 932 S HW: 4G8 920 932 S
Component: TDieRdw H80 0618
Revision: 30460230 Serial number: 658120713596052
Coding: 0BA602060B430008020100
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 3FDBBFF357FD2BCF48D-806B
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000001021902
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 0119280803
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 130522000000000002E8
5046 - Control Module for Multi-Contour Seat; Driver Side
U1083 00 [009] - No Communications
[Steuerger‰t f¸r IVB Fahrerseite Keine Kommunikation]
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:46
Voltage terminal 30: 11.9 V
Voltage terminal 15: 11.9 V
Control Module temperature: 37 ∞C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
5047 - Control Module for Multi-Contour Seat; Passenger Side
U1085 00 [009] - No Communications
[Steuerger‰t f¸r IVB Beifahrerseite Keine Kommunikation]
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:46
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
U1101 00 [009] - Active
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:45
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Address 28: HVAC, Rear (E265) Labels:| 4G0-919-158.clb
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0087
Serial number: 14071300040047
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
VCID: 372BD7D37FCD138F80D-8063
0116 - Temperature Sensor for Rear Right Seat
B1114 15 [009] - Open or Short to Plus
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:46
0119 - Temperature Sensor for Rear Left Seat
B1113 15 [009] - Open or Short to Plus
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:46
0124 - Rear Right Seat Heater
B1118 15 [009] - Open or Short to Plus
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:46
0127 - Rear Left Seat Heater
B1117 15 [009] - Open or Short to Plus
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:46
Part No SW: 4G8 959 760 C HW: 4G8 959 760 C
Component: MEM-FS H04 0157
Revision: AA000000 Serial number: 00000066604512
Coding: C0183B0085016201010001010101112030303333203333
Shop #: WSC 06745 128 28888
VCID: 3A2DCEE74C5F0EE77F3-806F
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:44
03657 - Control Module for Multicontour Seat; Front Passenger-Side
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:44
00461 - Control Module for Seat Memory; Passenger (J521)
Reset counter: 83
Mileage: 48413 km
Date: 2018.09.12
Time: 21:08:44
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA82049N30
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3635DAD778C7EA879BB-8063
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH04 0060
Revision: 00H04000 Serial number: 6PZ 010 287-08
Coding: 0000003
VCID: 3635DAD77447EA879BB-8063
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H04 0060
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F09.07.1300H04000AMS15605ˇ
Subsystem 4 - Serial number: S15605ˇ
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F57025E00628002000412
VCID: 47CBA7130FAD630FF0D-8013
Component: RCEPS H38 0010
Revision: 00001000 Serial number: 0008657047
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323DE6C794AFF6A7B73-8067
Revision: 00002001 Serial number: 0311046857
Coding: 0126023A20FAF08580A00A8402030D470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000165948
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO22926533
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00003942747
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA106239000004185385
Subsystem 6 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B
Component: GEB.F.Heckoef H16 0810
Serial number: 93040984
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000013290
Coding: 030000
VCID: 1D67257BFDB159DF7A1-8049
Component: TSG BF H03 0507
Coding: 011F57025E00628002000402
VCID: 46D5AA1708A77A070BB-8013
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000762383
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C01F8BFB68BA057FDF-8079
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130715-0002-150
Coding: 1223A6601002A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2D07F5BB8D91A95FEA1-8079
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Revision: AB001007 Serial number: 156GA0D7828839
Coding: 020007010000000001
VCID: 2411109FDEDB681735F-8071
Part No SW: 4G0 035 664 E HW: 4G0 035 664 E
Component: H-BN-NA H40 0735
Revision: -------- Serial number: 193G00D7507807
Coding: 090200040003E5EF55128B0E00000003F00001020000000000
VCID: 280904AFA2F38C77197-807D
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD002B8SY
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Serial number: 90349MGG000BU
Component: CD-Database 5298
Component: TSG HL H03 0507
Coding: 010F17024000628002000002
VCID: 49CFA12B19B9957FE69-801D
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0150
Revision: 11001001 Serial number: 82330JF0095456
Coding: 0205000001010100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
ROD: EV_CamerSysteTopViewAUDI_005.rod
VCID: 2B03FBA3B385A76FF45-807F
Part No SW: 4G8 959 107 R HW: 4G8 959 107 G
Component: HDSG-Modul H13 0043
Revision: 12013001 Serial number: 180300679
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 44D1B01F3E1B481715F-8011
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 K HW: 4G8 919 604 K
Component: HeadUpDisplay 004 0201
Coding: A20000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
VCID: 3B23CBE343E537EF645-806F
Address 88: Multicont. Seat Driver
Address 89: Multicont. Seat Pass.
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313FE9CB91A9CDBFCE9-8065
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0010
Revision: 00000000 Serial number: 131550127
ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 02:45, VBatt start/end: 12.0V/12.1V)-----------
