Results 1 to 6 of 6
Thread: 2007 jetta wolfs 5mt us/nar - slow/delayed rpm drop when shifting or coasting
    This is for now just a general question, my sister bought this car new, so it has been in the family since then.
    As far as I remember, the car has always done this, so I simply accepted as normal behavior.
    It is not really a problem, it's just always been more a curiosity and less a minor annoyance.
    Anyway, 2.5L 5MT with lots of miles.
    When shifting, or even revving up the engine a bit, then letting of of the throttle, the engine seems to have a slight delay in dropping RPM's.
    Its only like half a second or so, and I always assumed it was some kind of shift assist, to keep the rpms from dropping too fast while shift.
    But its also quite noticeable when coasting. The car will coast for that half second or so, before the engine breaking starts to occur and you can feel the engine drag slow the vehicle.
    My main question, is this considered normal behavior, or a symptom of something not quite right but not throwing any errors, like throttle body alignment, weak throttle return spring, or some other related throttle/rpm situation?
    Secondary question, if it is normal, is there a way to disable that functionality (either vcds or some other physical modification) ?
    I know, autoscan;
    Wednesday,12,September,2018,20:27:11:03587
    VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
    VIN: 3VWEF71K87M169975   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWEF71K87M169975   Mileage: 294090km-182739miles
    65-Tire Pressure -- Status: Not registered 0011
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 T    HW: 07K 906 032 Q
       Component: 2.5l R5/4V      G   9653
       Revision: --H01---    Serial number: VWZ7Z0G9063400
       Coding: 0000001
       Shop #: WSC 00066 000 00000
       VCID: 3A38F72975519A9429-806E
       Revision: 00H11001
       Coding: 0021122
       VCID: 73A61A0D12BB2BDC2A-8026
       Part No SW: 1K0 820 047 JT    HW: 1K0 820 047 JT
       Component: Climatic PQ35   143 1515
       Revision: 00143034    Serial number: 00000000000000
       VCID: 7F4EC63D2EF37FBC5E-802A
       Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
       Revision: 00H52000    Serial number: 00000000611882
       Coding: A4058E234004150007140000001400000009730B5C0000
       VCID: 6B96026D4A8BF31CE2-803E
       Component: Wischer 210407 020  0501
       Coding: 00000005
       Component: 6A AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M01GN0$
       Coding: 0013889
       VCID: 6C9401714F85F424EB-8038
       Subsystem 2 - Serial number: 6332MSME16766E22F
       Subsystem 3 - Serial number: 6342MSME10441C04+
       Subsystem 4 - Serial number: 6351HSME0D0A4023%
       Subsystem 5 - Serial number: 6361HSME0D11112D0
       Subsystem 6 - Serial number: 63727SME0C285B457
       Subsystem 7 - Serial number: 63827SME0C561761%
       Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
       Component: Lenksäulenmodul 036 0070
       Coding: 0000021
       VCID: 004C45C1530D004427-8054
       Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
       Revision: V0003000    Serial number: VWZ7Z0G9063400
       Coding: 0021407
       VCID: 383CED214B5D8884DF-806C
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 230307F1001947
       Coding: 3D3F034007001002
       VCID: 2F2ED67DBE134F3C8E-807A
                000 -  -
                        Mileage: 285387 km
                        Time: 14:01:42
       Component: IMMO            3HL 1610
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000538578330
       Coding: 0001205
       VCID: 3B36F22D7A6BA39C32-806E
    01552 - Motor for Central Locking; Drivers Door (V56); Lock
                        Fault Status: 00101100
                        Reset counter: 226
                        Mileage: 219133 km
                        Reset counter: 226
                        Mileage: 219139 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.069 H07 1806
       VCID: 3424D91157356CE4F3-8060
       Component:    KSG PQ35 RDK 052 0218
       Coding: 13900F880186083F3904058FB0880F0488DCA0
       Shop #: WSC 00066 123 12345
       VCID: 044449D147151C6403-8050
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000025878327
       Coding: 0001204
       VCID: 3C34F1317F65A4A43B-8068
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
                        Reset counter: 226
                        Fault Status: 01111000
                        Reset counter: 186
                        Mileage: 230159 km
                        Fault Status: 01101100
                        Reset counter: 186
                        Mileage: 202033 km
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
       Component: Radio DE2       020 0023
       Revision: 00020000    Serial number: VWZ4Z7K6494339
       Coding: 0010401
       Shop #: WSC 24171 444 04877
       VCID: 200C2541F3CDE04407-8074
    00856 - Radio Antenna
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000001316425
       Coding: 0001168
       VCID: 3E30FB396979B6B415-806A
       Component:    RDK              0440
       Coding: 0100101
                        Fault Status: 01110100
                        Reset counter: 252
                        Mileage: 257601 km
                        Time: 19:00:07
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000001303467
       Coding: 0001168
       VCID: 3FCE863D6E73BFBC1E-806A
    End----------(Elapsed Time: 01:23, VBatt start/end: 14.0V/14.2V)-----------
    Quote Originally Posted by D-Dub View Post
    I've experienced this on many cars, and have always been told it's a deliberate "feature" in the engine management to reduce emissions as well as helping shifts.
    I would class this as normal behaviour, if slightly annoying.
  3. Likes DrPeter, D-Dub liked this post
    16.4905° S, 151.7375° W
    I have heard and felt the same thing too, and I agree, it is annoying.
    Also there is appears to be a similar 'emissions reducing' strategy when decelerating, the ECM holds the throttle plate open a little, I would imagine to reduce any hydrocarbons and to lower manifold vacuum.
    Agree, it is annoying.
    drpeter
  5. Likes D-Dub liked this post
    ok, at least that seems to makes the car not broken (in that regard anyway lol), and I'm not alone, or crazy, for noticing and not liking it.
  7. Likes DrPeter, NZDubNurd liked this post
  8. #5
    VC PCV leaking into intake?................
    Above Magic!
  9. #6
    Hi Jack, thanks for the input!
    This particular behavior on this vehicle has been around since before I can remember. It was my sisters, and I bought it a few years ago.
    It's not my primary vehicle, but I try to drive it at least once a week (4-6 times a month).
    The valve cover/pcv was replaced earlier this year actually, I had to get it done to pass inspection (CEL).
    So, unless it was messed up before, and since the valve cover/pcv replacement, then I would hope that is not it still causing a problem.
