- Joined
- Apr 17, 2014
- Messages
- 620
- Reaction score
- 630
- Location
- US 2014 GTI Drivers Edition/DSG
- VCDS Serial number
- C?ID=272151
This is for now just a general question, my sister bought this car new, so it has been in the family since then.
As far as I remember, the car has always done this, so I simply accepted as normal behavior.
It is not really a problem, it's just always been more a curiosity and less a minor annoyance.
Anyway, 2.5L 5MT with lots of miles.
When shifting, or even revving up the engine a bit, then letting of of the throttle, the engine seems to have a slight delay in dropping RPM's.
Its only like half a second or so, and I always assumed it was some kind of shift assist, to keep the rpms from dropping too fast while shift.
But its also quite noticeable when coasting. The car will coast for that half second or so, before the engine breaking starts to occur and you can feel the engine drag slow the vehicle.
My main question, is this considered normal behavior, or a symptom of something not quite right but not throwing any errors, like throttle body alignment, weak throttle return spring, or some other related throttle/rpm situation?
Secondary question, if it is normal, is there a way to disable that functionality (either vcds or some other physical modification) ?
I know, autoscan;
I know, autoscan;
Wednesday,12,September,2018,20:27:11:03587
VCDS Version: 18.2.1.2 HEX-NET CB: 0.4411.4
VIN: 3VWEF71K87M169975 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWEF71K87M169975 Mileage: 294090km-182739miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 T HW: 07K 906 032 Q
Component: 2.5l R5/4V G 9653
Revision: --H01--- Serial number: VWZ7Z0G9063400
VCID: 3A38F72975519A9429-806E
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73A61A0D12BB2BDC2A-8026
Part No SW: 1K0 820 047 JT HW: 1K0 820 047 JT
Component: Climatic PQ35 143 1515
Revision: 00143034 Serial number: 00000000000000
VCID: 7F4EC63D2EF37FBC5E-802A
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000000611882
Coding: A4058E234004150007140000001400000009730B5C0000
VCID: 6B96026D4A8BF31CE2-803E
Component: Wischer 210407 020 0501
Coding: 00000005
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M01GN0$
Coding: 0013889
VCID: 6C9401714F85F424EB-8038
Subsystem 2 - Serial number: 6332MSME16766E22F
Subsystem 3 - Serial number: 6342MSME10441C04+
Subsystem 4 - Serial number: 6351HSME0D0A4023%
Subsystem 5 - Serial number: 6361HSME0D11112D0
Subsystem 6 - Serial number: 63727SME0C285B457
Subsystem 7 - Serial number: 63827SME0C561761%
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 036 0070
Coding: 0000021
VCID: 004C45C1530D004427-8054
Part No SW: 1K0 920 953 P HW: 1K0 920 953 P
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0G9063400
Coding: 0021407
VCID: 383CED214B5D8884DF-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 230307F1001947
Coding: 3D3F034007001002
VCID: 2F2ED67DBE134F3C8E-807A
Mileage: 285387 km
Time: 14:01:42
Component: IMMO 3HL 1610
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000538578330
Coding: 0001205
VCID: 3B36F22D7A6BA39C32-806E
Fault Status: 00101100
Reset counter: 226
Mileage: 219133 km
Reset counter: 226
Mileage: 219139 km
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 3424D91157356CE4F3-8060
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186083F3904058FB0880F0488DCA0
Shop #: WSC 00066 123 12345
VCID: 044449D147151C6403-8050
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000025878327
Coding: 0001204
VCID: 3C34F1317F65A4A43B-8068
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Reset counter: 226
Fault Status: 01111000
Reset counter: 186
Mileage: 230159 km
00110 - Right Mirror Turn Signal Lamp (L132)
Reset counter: 186
Mileage: 202033 km
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 020 0023
Revision: 00020000 Serial number: VWZ4Z7K6494339
Coding: 0010401
Shop #: WSC 24171 444 04877
VCID: 200C2541F3CDE04407-8074
00856 - Radio Antenna
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1120
Revision: 12006001 Serial number: 00000001316425
Coding: 0001168
VCID: 3E30FB396979B6B415-806A
Component: RDK 0440
Coding: 0100101
Fault Status: 01110100
Reset counter: 252
Mileage: 257601 km
Time: 19:00:07
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1120
Revision: 12006001 Serial number: 00000001303467
Coding: 0001168
VCID: 3FCE863D6E73BFBC1E-806A
End----------(Elapsed Time: 01:23, VBatt start/end: 14.0V/14.2V)-----------
