Results 1 to 4 of 4
Thread: Bentley Arnarge 2007 delete Phone Module? Comms noise and Parasitic drain ...
    Verified VCDS User FioranoCars's Avatar
    Oct 2016
    Hi
    Got a 2007 Bentley with a parasitic drain and noise on coms, which we are in the final stages of proving to the Telephone Control Module (stripping to access it is no fun!). As the owner does not use said dated unit he'd rather not replace it with a new unit of the same dated design, and just remove it!
    Question is this, do any of the other units need to be coded to say it's gone to avoid errors being stored (ie TPMS, Radio, CAN Gateway/Integration ECU (this vehicle does not have navigation))
    If so, any clues on which ECU need to be modified and hints about the new codings needed please?
    If not, are the errors going to create other issues (beyond being stored - ie keeping an ECU awake and causing a parasitic drain!)?
    The low voltage and other errors appear to be related to the car having drained flat, and clear/road test ok ...except:
    00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
    This one within the TPM, although it displays information fine, and the relearn feature triggers display messages too. Does the DIP (Driver Information Display) have it's own address for diagnostics?
    Is this one of those "features" for this model, and it can be ignored or is a result of incorrect coding/configuration?
    Full scan below, but thanks in advance for any help
    Richard
    PS Already sent via email the ECU scans for label file creation, except the ABS, which does not use the usual security code 4...8, is there an alternative code I can try to pull a file from that ECU to send over for you at RossTech?
    Friday,17,August,2018,14:30:11:48085VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.7.1.1 (x64)  HEX-NET CB: 0.4427.4
    Data version: 20180731 DS293.0
    VIN: SCBLC48F17CH12312   License Plate:
    Chassis Type: 8F (3Z - Bentley Arnage (2007 > 2010))
    Scan: 01 02 03 15 19 47 56 65 77
    Address 01: Engine        Labels: None
       Part No: PB1 165 11P C
       Component: ME711ST10 EU4R  G   07AC
       Revision: --H01---    Serial number: VWZ1Z0F2886538
       Shop #: WSC 01666 772 38280
       VCID: 54E4AAD8F6409AEAE0-5160
    050181 - Implausible Data Received from Cruise Control Module
                   U0405 - 002 -  - Intermittent
                        Mileage: 48167 km
                        Temperature: 74.0C
                        Temperature: 72.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 5.969 V
    Readiness: 0010 1001
    Address 02: Auto Trans        Labels: None
       Part No SW: PB1 156 20P A    HW: GS1 911 1
       Component: ZWIC2820  6.75 RdW  2820
       Revision: 00000001    Serial number:        0008306
       Coding: 0001111
       VCID: 52E8ACC0CC5494DAF2-5160
    Address 03: ABS Brakes        Labels: None
       Part No: PC1 000 53P F
       Component: ESP 5.7 rear    H00 0012
       Coding: 0008695
       VCID: 52E8ACC0CC5494DAF2-51CE
                000 -  -  - Intermittent
    Address 15: Airbags        Labels: None
       Part No SW: 3Z7 909 601     HW: 3Z7 909 601
       Component: 01 Airbag 9.42  H09 0060
       Revision: 92H09006    Serial number: 003000001DBS
       Coding: 0012337
       Shop #: WSC 98765 666 30559
       VCID: 7DB22F7C244ABBA27F-8028
       Subsystem 1 - Serial number: 63300RB4        E
       Subsystem 2 - Serial number: 63400RB4        F
       Subsystem 3 - Serial number: 63500RB4        G
       Subsystem 4 - Serial number: 63600RB4        H
       Subsystem 5 - Serial number: 63700RB4        I
       Subsystem 6 - Serial number: 638  RB4        9
    00532 - Supply Voltage B+
    Address 19: CAN Gateway        Labels: None
       Part No HW: HW1 03
       Revision: 11001001    Serial number: 00000000000363
       VCID: 55E257DCFDBA83E217-5160
       Subsystem 13 - Part No: 3Z0 909 901
       Component: CAN LS Gateway      0105
       Shop #: WSC 12336 024 394758
    Address 56: Radio        Labels: None
       Part No: PM1 121 70P C
       Component: concert II  GRO    0002
       Coding: 01002
       VCID: 5CF442F8CE9052AA28-4B00
    Address 65: Tire Pressure        Labels: None
       Part No: 3W7 907 273
       Component: Reifendruckueberw.  0003
       Coding: 0080324
       Shop #: WSC 98765 666 36774
       VCID: 7DB22F7C254ABBA27F-5160
    01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
    Address 77: Telephone        Labels: None
       Part No SW: PM1 144 36P A    HW: PM1 144 36P A
       Component: UHV Premium rSAP    0020
       Coding: 0000256
       VCID: 618A730CB9F27F427B-5160
    End----(Elapsed Time: 01:55, VBatt start/end: 11.4V/11.3V. VIgn 11.4V)-----
    Oct 2017
    Northwest UK
    All modules are registered through the CAN Gateway. If a module is removed then the tick is removed from the gateway, another autoscan will display any new errors. If the CAN is linked through databus then those errors will become apparent and guide us on what adaptations need disabling too. As each car is unique the setups are too, therefore it's not possible to second guess this.
    Oct 2016
    Thanks, hopefully will get a clear run at this on Monday, so will update once I have removed and got before and after data line signals and drain results.
    United States
    Quote Originally Posted by FioranoCars View Post
    Thanks for the files. We do not have an alternative SA code for that ABS module.
