The complete Auto-Scan from this vehicle in addition to the repair history would be helpful. If you changed Coding or Adaptations please include the contents of the CSV files as well. This thread explains that in some detail.
If you are repairing a factory installed DRL module/headlight system we can move this to the Car Repair Support sub forum.
Saturday,22,September,2018,13:13:25:48569
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
VIN: WAUSGAFC8CN014955 License Plate:
Mileage: 145968km-90700mi Repair Order: audi 09/22
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90
VIN: WAUSGAFC8CN014955 Mileage: 145968km-90700miles
84-Night Vision -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CGXB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH05 0010
Revision: --H05---
Coding: 1A2A0034056600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
ROD: EV_ECM30TFS0214G0907551A_003.rod
VCID: 270BF8F6CF66CFAF10E-8072
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 P HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 0003
Revision: --H08---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002017
VCID: 3B23348623EE7B4F646-806E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 G HW: 4G0 907 379 G
Component: ESP PREMIUM H09 0250
Coding: 44A70F0322E5F0C04B00
ASAM Dataset: EV_ESPPremiAU57X 004017
VCID: 353722BE05CAAD3F922-8060
Part No SW: 4H0 907 064 BR HW: 4H0 907 064 BR
Component: BCM2 2.0 H31 0330
Coding: 0D8A2000000000000000
VCID: 7AADF1826CD482473F0-802E
Component: J764 ELV MLB H39 0046
Serial number: 2311000119933005
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H11 0056
Serial number: 12061100040273
Coding: 668320BA1C
ASAM Dataset: EV_AirCondiComfoUDS 002029
VCID: 2809FBCAC278C0D7194-807C
0379 - Supply Voltage Terminal 30 for Coolant Pump
B11D5 01 [009] - Electrical Failure
Reset counter: 87
Mileage: 145968 km
Date: 2018.09.20
Time: 03:37:44
Voltage terminal 30: 12.12 V
Outside air temperature: 26.5 °C
Interior temperature: 27.15 °C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001101690
Coding: 0D072091073E9FE081000884A0003820CF9CD308A2090125800308453B00
VCID: 6E85CDD2209CDEE7938-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 110523 H35 0051
Serial number: 110525050954
Coding: 0045F7
Component: RLS H04 0003
Serial number: 11490065
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 08 06 2011 00000549
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R0DK101
Subsystem 5 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0006212328
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0001
Serial number: 00000000001104180652
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0002
Serial number: 00000000001606214340
Subsystem 8 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA101510000000312971
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: C0380DA5000000000001
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0001
Serial number: 00000000001105250360
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0001
Serial number: 00000000001105250159
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Reset counter: 87
Mileage: 145968 km
Date: 2018.09.20
Time: 03:37:00
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000007
VCID: 2D070ADEED1AE5FFEA2-8078
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901114301470
Coding: 280904
Shop #: WSC 09401 444 103838
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 678BB8F60FE60FAFD0E-8032
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D800434F7
Coding: 303145313131303030324A55304C34473853
Shop #: WSC 08479 002 1048576
VCID: 33331CA60BBEB30FBC6-8066
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y160001G57003
Serial number: 3575HRB404T0ILP0985Q
Serial number: 3585HRB405H0IRE031HA
Serial number: 3515JRB405R0I70IOP2T
Serial number: 3525JRB40530I70IAHJ1
Serial number: 3554VRB40630I3H08G8/
Serial number: 3564VRB40630I3H0E1J0
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KF50006M
Coding: 00043C
VCID: 38292B8A12585057894-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H07 0009
Serial number: 19 11 2010 11068885
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 982 G HW: 4G8 920 982 G
Component: TBenUsaAccNv H71 0375
Revision: 26181114 Serial number: 658190611593006
Coding: 0BC601060F03D705020100
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K.rod
VCID: 38292B8A12D85057894-806C
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000174879
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
VCID: 323D19A2F4A4BA07B70-8066
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650671102
Address 28: HVAC, Rear (E265) Labels:| 4G0-919-158.clb
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0056
Serial number: 09061100040845
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
VCID: 303913AAFAA88817C14-8064
0068 - Position Sensor in Rear Left Upper Body Vent
B10E5 15 [009] - Open or Short to Plus
Reset counter: 87
Mileage: 145968 km
Date: 2018.09.20
Time: 03:37:44
Voltage terminal 30: 12.18 V
Supply voltage for external components: 5.00 V
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006204203
Coding: C0581B008F002001000001010101102030303232203232
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA42013UB20
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D070ADEED9AE5FFEA2-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH01 0030
Revision: 00H01000 Serial number: 6PZ 010 287-08
Coding: 0000007
VCID: 363525B2144CA6279B8-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H01 0030
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F06.06.1100H010003CZ22102ÿ
Subsystem 4 - Serial number: Z22102ÿ
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F57225E00628002000413
Shop #: WSC 02312 785 00200
VCID: 41DF466E4182119F3EA-8014
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0029088653
Coding: 101000010000
Shop #: WSC 50303 000 1048576
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0151167128
Coding: 0126023A20FAF48580B00A80020100000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000037679
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Serial number: WOO1234245
Coding: 001F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00000280988
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA102622000000315136
Part No SW: 4G0 035 465 A HW: 4G0 035 465
Component: BO G3 C7 H07 0130
Revision: 05S00000 Serial number: 0012571
VCID: 2313ECE6BBDE238F4C6-8076
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Serial number: 00404110002414
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F57225E00628002000402
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000088520
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D01C2DC74F2C70F0-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 110612-0004-043
Coding: 1223A6601002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2C0107DAD680ECF7FDC-8078
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H51 0112
Revision: AB001007 Serial number: 156F$0B7514692
Coding: 020007010000000001
VCID: 211FE6EEA1C2319F5EA-8074
02983 - Connection between Impedance Converter 1 and Window Antenna
Reset counter: 87
Mileage: 145968 km
Date: 2018.09.20
Time: 03:37:52
Voltage: 12.30 V
Part No SW: 4G0 035 746 B HW: 4G0 035 746
Component: H-BNT-NA H48 0549
Revision: -------- Serial number: 031FT0B7508084
Coding: 090200040003EDEF75168B0E00000003100001000000000000
VCID: 2615F5F2C8ECD6A72B8-8072
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300XA1I
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0204
Serial number: 90349KF80006W
Component: CD-Database 3371
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17224000628002000002
VCID: 44D14F7A5E9004B715C-8010
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J1XG551
Coding: 1080013
Shop #: WSC 18497 002 1048576
VCID: 2615F5F2C4ECD6A72B8-8072
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 M HW: 4G8 959 107 G
Component: HDSG-Modul H13 0039
Revision: 12013001 Serial number: 137100055
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 3FDB409637F6676F48E-806A
Component: TSG HR H04 0212
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 D HW: 4G8 919 604 D
Component: HeadUpDisplay 007 0103
Coding: DA0000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: 34311FBA0EB0B437A5C-8060
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40036897
Coding: 1411
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 313F16AEF1A2811FCEA-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001110800623
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597B2FEF5EA1DBFE22-8030
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3601010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_PRE_MISALIGNMENT]
Reset counter: 87
Mileage: 145968 km
Date: 2018.09.20
Time: 03:37:44
Control Module temperature: 29 °C
Voltage terminal 15: 12.114 V
Velocity_vehicle_reference: -0.00 m/s
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0034
Serial number: 000040182705117
Coding: 038198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2517F2FEB56ADDBF222-8070
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBBD0D62716D7EF98E-803A
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B9D3AA3A28C817814-8024
End----------(Elapsed Time: 02:59, VBatt start/end: 12.1V/12.0V)-----------
