Results 1 to 10 of 17
Thread: Aux heater retrofit, coding side
    Apr 2018
    ITALY
    I am just about to finish the Webasto aux heater retrofit. yesterday I did the fuel line, then ran the "fill fuel line" procedure and the hose is full up to the heater.
    tomorrow I will have a mechanic connect the coolant hoses, then top-up and bleed the circuit.
    that should be the end of the hardware side.
    then I need to code and do basic settings.
    since the aux heater is not a very diffused retrofit, I am finding difficult to get info about where to code/adapt.
    ok, module 18 goes to gateway installation list.
    I think there is coding on modules 08 and 09.
    is that all? how about other coding or adaptations?
    and then, how do I do basic settings, how do I initialize the heater?
    thanks
  2. Likes jyoung8607 liked this post
  3. #2
    Apr 2018
    ITALY
    see attached scan. no matter what I do, the heater has no basic settings, and I don't know how to perform them...
    Friday,14,September,2018,19:20:30:06888
    VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WVWZZZAUZHW0xxxxx   License Plate:
    Mileage: 20995km-13045mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 18 19 42 44 52 5F
    VIN: WVWZZZAUZHW0xxxxx   Mileage: 20995km-13045miles
       Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
       Component: STH-MQB       006 0069
       Coding: 1305
       VCID: 3537DDC715C0D82F922-8060
       Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001256652
    0376 - No Basic Setting
              B2010 00 [009] -  -
              [INITIAL OPERATION MISSING]
                        Reset counter: 150
                        Mileage: 20995 km
                        Date: 2018.09.14
                        Time: 19:14:00
                        Operating condition of parking heater: System malfunction
                        71
                        Coolant temperature of parking heater: 68 ∞C
                        Coolant temperature: 69 ∞C
                        Engine running status: detected
                        Fuel level: 11 l
                        Heater output: 0 W
    End----------(Elapsed Time: 01:48, VBatt start/end: 12.6V/12.5V)-----------
    Apr 2018
    ITALY
    I have coded modules 08, 09 and 17 to tell them the Aux Heater is present.
    however, I am not getting the menu under the Climatronic screen.
    Võru, Estonia
    Most likely You need to change some adaptions.
    Which one You need to figure out from different scans and admaps.
    Examples: https://forums.ross-tech.com/forumdi...on-Broken-Cars
    The world is my oyster...
    Apr 2018
    ITALY
    I browsed through ALL pages of that section and found very little cars with Aux Heater. just scans, no admaps
    Oct 2017
    Northwest UK
    Darkchina
    The scan says 'initial operation missing'. Go to 18 and choose the option for basic settings. It will cycle through the operations then complete. Save and then exit.
    Aug 2016
    Switzerland
    Perhaps it would be good to tell us a bit more about the car and show an autoscan with, for example, the module fitted.
  9. #8
    Apr 2018
    ITALY
    I made some progress. the fuel line was not filled up, that's why I could not complete the test.
    FYI, the "fuel line filling" under Basic Settings does not work, always gives an error. I had to fill the line by manually activating the metering pump from the Output Tests.
    I was then able to complete the "heater operation for production" under Basic Settings, and the error about initial operation was cleared.
    the "heater operation for customer service" does not work as well and always gives an error. anyway, I would like to know the difference between the two things.
    it seems like it's working, although it makes a bad smell like of burning plastic. I am not sure it is because the heater is brand new or if it's sympthom of a problem.
    I will keep you posted.
  10. #9
    Võru, Estonia
    Posted 3 cars with admaps to Reference Scan section
    https://forums.ross-tech.com/showthr...5-2-0TDI-140kw
    https://forums.ross-tech.com/showthr...5-1-4TSI-103kw
    https://forums.ross-tech.com/showthr...-4TSI-81kw-CNG
    I think You will be intrested in these adaption channels:
    IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,activated ,40
    IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,40
    IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,40
    IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,activated ,40
    IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,40
    , but i think in Your MIB2 case they will be named something like this:
    ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,608
    Also:
    IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,activated ,53
    IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,Comfort data bus ,53
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
    But please, autoscan and admaps!
  11. Likes Uwe liked this post
  12. #10
    Apr 2018
    ITALY
    thank you very much, I just scanned the car and will compare now to yours
    Sunday,16,September,2018,21:29:53:06888
    VIN: WVWZZZAUZHW024283   License Plate:
    Mileage: 21070km-13092mi   Repair Order:
    VIN: WVWZZZAUZHW024283   Mileage: 21070km-13092miles
    Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
       Component: R4 1.4l TFS   H25 2833
       Revision: R7H25---
       Coding: 0119003223241D082000
       Shop #: WSC 21385 002 1048576
       ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
       ROD: EV_ECM14TFS01104E906027HB.rod
       VCID: 6B833BBF03045EDFB46-803E
       CAN Converter 01:
       Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
       Component: ESC           H62 0637
       Revision: 00000000    Serial number: 91596000011507
       Coding: 01FA6AA1242219704779060841C62980562498E2608294730020507AC00203
       Shop #: WSC 131071 102 209715
       ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
       VCID: 74B120C35E3A812765C-8020
       Part No SW: 5G0 907 044 BE    HW: 5G0 907 044 BE
       Revision: 00001K08
       Coding: 00020004104111011005004000101022
       Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0138
       Serial number: 01011415700037
       Coding: 00000846C20102FB4B644080B11407281400000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 094F613729B8ECCF26A-805C
       Component: WWS    160522  043 0551
       Serial number:         160601172917
       Coding: 0E4DFD
       Component: RLHS  042 0105
       Serial number: S5Y17M06D01H13M38S50
       Coding: 06A8DD
       Serial number: 000000000ZY15028208R
       Serial number: 00000000000030139763
       Part No SW: 5Q0 919 298 D    HW: 5Q0 919 298
       Component: PARKHILFE PLA H11 0042
       Revision: --------    Serial number: 61131402901978
       Coding: 0031161041
       ASAM Dataset: EV_EPHVA2CAU3700000 003019
       ROD: EV_EPHVA2CAU3700000_003_VW37.rod
       VCID: 40D9BC135A026D87314-8014
       Serial number: 003F6R1V1W4Y
       VCID: 41DFB9175108648F3EA-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 35767000000432B44C1Q
       Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 358670000008B4C4DB17
       Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
       Serial number: 3516502BB205729313D3
       Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
       Serial number: 3526502AF2076340F201
       Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 35565029B21160C1025X
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 13061608490829
       Coding: 0400
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 0D4755275DD0F0EF0A2-8058
       Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
       Component: KOMBI         303 8311
       Coding: 03A501002390000D02083B001400000000000000
       VCID: 26150A8BD866A3B72B8-8072
    16777034 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_DoorLocking_0x0D keine Kommunikation]
                        Reset counter: 195
                        Mileage: 21060 km
                        Date: 2018.09.16
                        Time: 15:29:53
       Coding: 1305
       Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 E
       Component: GW MQB Mid    127 1265
       Revision: --------    Serial number: 0005024934
       Coding: 030100043F085700FB000248080F00010001050000000000000000000000
       VCID: 7BA30BFF7364CE5F246-802E
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29160001142480026234
       Coding: 28FFFF
       Serial number: 8442320304
       Serial number: 300516EEU02971
       Coding: 003B0320D000040100001000
       VCID: 43D3B31F4B14769F2C6-8016
       Coding: 8307
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2DCEFB3CDE37577F0-806E
       Serial number: 280516EER24731
       Coding: 003B0120DE00040100801000
       VCID: 42DDB61B540E7F97270-8016
       Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
       Component: MU-S--ER      710 0744
       Coding: 02730000AA0000005111000100080A001F0206D40120010003
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 2C01F8A3C68A99E7FDC-8078
       Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJT00QNA
    End----------(Elapsed Time: 01:49, VBatt start/end: 12.4V/12.4V)-----------
