Results 11 to 20 of 21
Thread: Best way to get full dump of all adaptations and coding?
    United States
    I agree. CAN modules (which pre-date the B9 in question) will show Error Security access required without a SA code https://forums.ross-tech.com/showthr...l=1#post118973
    The MQB maps we reviewed yesterday had all Adp channels with and without a SA codes entered but I like to use one when possible on all vehicles.
    In BikePilot's case I believe running complete Debug Level 2 maps should be good enough before the trip to the dealer.
  2. Likes Andy, Boki Ar liked this post
  3. #12
    Jul 2015
    Kent, UK
    Auto-Scan with Debug Level (on the Options screen) set to 2.
    Is that going to achieve what is desired - that is, all modules?
    I thought Debug set to 2 only mapped undocumented modules, that is, modules without a label file?
    Julian
    From the web site:
    Type #1: To create a map from all undocumented control modules in the car, please perform the following procedure:
    [Options]
    Debug Level: 2
    [Apply]
    [Auto-Scan]
    Select Chassis Type
  4. #13
    Nov 2017
    I think that documentation is out of date or Debug 2 works differently on newer cars. On the first day I bought my car, I ran a Debug 2 Autoscan and it gave me everything, labels or not. The only thing I have noticed is that it doesn't output a .pla and .plb any more but instead an amap.csv and bmap.csv file
  5. #14
    Jul 2015
    Kent, UK
    Quote Originally Posted by o33err View Post
    I've just rerun VCDS 18.9.0 with Debug set to 2 on my 2005 A8 D3. It only scanned and dumped variables for ECUs without a label file [4 in my case] and created a .PLA & .PLB for each of those ECUs! [That is, a total of only 8 files for the whole scan].
    Hmmm; interesting and illogical
    Shouldn't a Debug value [2 in this case] work consistently in all environments?
    Julian
  6. #15
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by JulianHicks View Post
    Somewhat, yeah, for historical reasons.
    Debug 2 on non-UDS controllers, all K-line and older CAN stuff, will output PLA/PLB files only a label file doesn't exist already. It was invented back when Ross-Tech needed people to submit this data, in order to make label files. This existed before it was so common to have hundreds of tweakable adaptation channels, before there was so much interest in archival and comparison.
    If you need to, you can tell VCDS to dump the contents of an individual controller through the "Controller Channel Map" menu under "Applications" even if there's already a label file, but there's no direct way to force them all. Some people have been known to move the contents of the Labels directory elsewhere, temporarily, to kind of trick VCDS into it, but you need to be careful or be willing to reinstall.
    Debug 2 on UDS-based controllers will unconditionally dump out all measuring and adaptation values. It's mainly a testing or archival aid, to snapshot the state of things before you make changes or to document the state after. For UDS controllers, label files have much less relevance, just manually documented coding information (if applicable, the new "experimental" stuff isn't in there) and some other internal hints and pointers.
    It's very possible to have a mix of those behaviors in the same car, to have some UDS and some non-UDS controllers.
    If I had a magic wand, I would make this functionality consistent AND accessible through some friendly menu instead of an arcane debug setting. This already exists, in part, in the "Controller Channel Map" menu. I'd go a little further, and place all the output in a VIN-specific directory under C:\Ross-Tech\VCDS\Logs, potentially with date-time sub-directories under that to maintain history. But I don't have a magic wand, and I have no idea what's on Ross-Tech's development backlog, so I make do. It's not much of a hardship once you know how it works.
    Silence gives consent.
  7. Likes Uwe, D-Dub liked this post
  8. #16
    Temporarily renaming the Labels folder to, for example, ~Labels should work.
    Beware however, that on old, non-UDS cars, especially those with lot of modules like a D3 A8, an Auto-Scan with Debug Level 2 and no labels found can take a really long time. Make sure you have an adequate battery charger properly connected.
  9. Likes jyoung8607, PetrolDave liked this post
  10. #17
    Is there any reason to not do scans with a vehicle running ? (instead of on a charger)
  11. #18
    Cincinnati, OH
    Quote Originally Posted by D-Dub View Post
    As an exception, I happen to know the VW Atlas (and probably the Teramont, and Skoda Kodiaq) likes to throw over-temp DTCs on the LED headlight controllers if it's left at stationary idle for a long time. Seen that a bunch of times. I've not seen any driver-perceivable effect as a result.
    Other than that, no serious reason that I'm aware of, other than the fuel spent and the additional idle time on the engine. There will be certain changes you can't make with VCDS, but you should be able to read all day long.
  12. Likes Eric liked this post
  13. #19
    From a purely electrical standpoint, it should be fine.
    But whether letting a car idle for so long is an acceptable practice or not might be questionable. I prefer to avoid doing that if at all possible.
  14. Likes Eric liked this post
  15. #20
    Jul 2015
    Kent, UK
    Just for completeness, from my point of view, anyway; I ran Debug 2 on my 2016 A8 D4.
    Can't tell from the Autoscan if modules are UDS or not [might be a useful addition to the log data] but I still didn't get a 'complete' set for all ECUs and I didn't even get a full set of .PLA/.PLB files for the ECUs that didn't have label files. For the record:
    ECUs with 'Labels: None' that DID NOT produce a .PLA/.PLB
    01, 19, 3B, 6C, 6D, 6F, 88, 89
    ECUs with 'Labels: None' or 'Labels: Redir failure!' that DID produce a .PLA/.PLB - Redir failures in RED
    06, 09, 20, 36, 42, 47, 52, 56, 57, 62, 72
    And finally guys @ Ross Tech; given the comments of 'usefulness' of label files earlier in this thread, do you want the .PLA/.PLB files that VCDS generated for my car?
    Wednesday,10,October,2018,11:46:47:53697
    VCDS Version: 18.9.0.2
    VIN: WAUZZZ4H4GN002801   License Plate:
    Chassis Type: 4H-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 20 30 34 36 3B 42 44 46 47
              52 53 55 56 57 5F 62 6C 6D 6F 72 81 88 89 8F 90 AC
    VIN: WAUZZZ4H4GN002801   Mileage: 47298km-29389miles
    01-Engine                 -- Status: OK 0000
    02-Auto Trans             -- Status: OK 0000
    03-ABS Brakes             -- Status: OK 0000
    04-Steering Angle         -- Status: OK 0000
    05-Acc/Start Auth.        -- Status: OK 0000
    06-Seat Mem. Pass         -- Status: OK 0000
    08-Auto HVAC              -- Status: OK 0000
    09-Cent. Elect.           -- Status: OK 0000
    15-Airbags                -- Status: OK 0000
    16-Steering wheel         -- Status: OK 0000
    17-Instruments            -- Status: OK 0000
    19-CAN Gateway            -- Status: OK 0000
    20-High Beam Assist.      -- Status: OK 0000
    30-Special Function II    -- Status: OK 0000
    34-Level Control          -- Status: OK 0000
    36-Seat Mem. Drvr         -- Status: OK 0000
    3B-Sensor Elect.          -- Status: OK 0000
    42-Door Elect, Driver     -- Status: OK 0000
    44-Steering Assist        -- Status: OK 0000
    46-Central Conv.          -- Status: OK 0000
    47-Sound System           -- Status: OK 0000
    52-Door Elect, Pass.      -- Status: OK 0000
    53-Parking Brake          -- Status: OK 0000
    55-Headlight Range        -- Status: OK 0000
    56-Radio                  -- Status: OK 0000
    57-TV Tuner               -- Status: OK 0000
    5F-Information Electr.    -- Status: OK 0000
    62-Door, Rear Left        -- Status: OK 0000
    6C-Back-up Cam.           -- Status: OK 0000
    6D-Trunk Elect.           -- Status: OK 0000
    6F-Centr. Conv. II        -- Status: OK 0000
    72-Door, Rear Right       -- Status: OK 0000
    81-Gear Shift             -- Status: OK 0000
    89-Multicont. Seat Pass.  -- Status: OK 0000
    8F-Pretens. Frt Left      -- Status: OK 0000
    90-Pretens. Frt Right     -- Status: OK 0000
    AC-Reductant Control      -- Status: OK 0000
    Address 01: Engine (J623-CTBA)       Labels: None
       Part No SW: 4H0 907 401 Q    HW: 4G0 907 401 E
       Component: 3.0TDI EDC17  H14 0002
       Revision: 58H14---
       Coding: 0A2A4032052601030800
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TDI0114H0907401Q 001002
       ROD: EV_ECM30TDI0114H0907401Q.rod
       VCID: 326B7DA965FEA0DA13-8066
       Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
       Component: 0BK 30TDIRdWH19 1005
       Revision: --H19---
       ASAM Dataset: EV_TCMALX51011 002022
       ROD: EV_TCMALX51011.rod
       VCID: 7CF79391F73AA6AA89-8028
    Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
       Part No SW: 4H0 907 379 T    HW: 4H0 907 379 T
       Component: ESP PREMIUM   H10 0665
       Coding: 60E5AB8006A7D501E300
       ASAM Dataset: EV_ESPPremi 005024
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 4385286DCA44195288-8016
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.CLB
       Part No SW: 4H0 907 064 GB    HW: 4H0 907 064 GB
       Coding: 05B76F4E000000000000
       VCID: 6FEDB4DDBE4CCD323C-803A
       Serial number: 3215000075301016
    Address 06: Seat Mem. Pass (J521)       Labels: NONE
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Component: MEM-BFS       H08 0156
       Revision: AA000000    Serial number: 00000147560992
       Coding: C038320085047201000001010101112131313333283333
       VCID: 356146B59C90B7E236-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 P    HW: 4H0 820 043 P
       Component: Klima 2 Zonen H20 0210
       Coding: 3621002E300000
       ASAM Dataset: EV_AirCondiFront 003001
       ROD: EV_AirCondiFront_002.rod
       VCID: 2D516ED57CC0FF224E-8078
    Address 09: Cent. Elect. (J519)       Labels: REDIR FAIL!
       Part No SW: 4H0 907 063 DB    HW: 4H0 907 063 AB
       Revision: 19020001    Serial number: 00001092140002
       Coding: 0105001440349FE0C9014084A0001800009DC30A2F0802018000089461001700004000240B0000
       VCID: 6BD5A0CD8A54311210-803E
       Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 140718  H36 0090
       Serial number:         150204164211
       Coding: 0045F7
       Serial number: 24007920
       Coding: 02004E
       Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
       Component: E1 - LDS  H07 0044
       Serial number: 01 06 2015  00001958
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA120636000012702541
       Coding: 020300
       Serial number: EC3840B7000000000001
       Revision: --------    Serial number: 003P10051WWD
       Coding: 30333045313430303038554A305234483053
       VCID: 3B75508DB2B46192C0-806E
       Serial number: 3575HRB404P3BA9U2HCU
       Serial number: 3585HRB404P3BA9UEHD1
       Serial number: 3515JRB401E54QJ25POS
       Serial number: 3525JRB401E54QJ2F987
       Serial number: 3554VRB405J3FGI859JZ
       Serial number: 3564VRB405J3FGI8BOTO
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.CLB
       Revision: --------    Serial number: 01335OES001ET
       Coding: 000034
       VCID: 377D4CBD869C45F224-8062
       Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
       Component: E221 - MFL  H09 0010
       Serial number: 16 04 2015  B0048356
       Part No SW: 4H0 920 910 R    HW: 4H0 920 910 R
       Component: TDieGB------- H53 0803
       Revision: 38081205    Serial number: 658020615592020
       Coding: 33A608001B412600010000
       ASAM Dataset: EV_RBD4K 004050
       ROD: EV_RBD4K.rod
       VCID: 336578AD9AE4A9D218-8066
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
       Component: Analoguhr D4  H05 0225
       Serial number: 2150429000990
       Part No SW: 4H0 907 468 AG    HW: 4H0 907 468 AC
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000001862281
       Coding: C0CD077F08
       ASAM Dataset: EV_GatewPkoUDS 001028
       VCID: 76E381B9C916FCFAFF-8022
       Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
       Component: J367-BDM  H08 0181
       Serial number: 52136407171911070810
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
       Serial number: 15154000523021200410
    Address 20: High Beam Assist. (J844)       Labels: NONE
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04028B6B74745D545420363E00
       VCID: 67DDDCFD96BC157274-8032
    Address 30: Special Function II (J843)       Labels: 8K0-907-440.CLB
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000078296
       Coding: 01010101000000000001000202
       VCID: 64C7CBF1678A7E6A51-8030
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Coding: 008000
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F6D74DD76CC8D327C-807A
    Address 36: Seat Mem. Drvr (J136)       Labels: NONE
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000147560994
       Coding: C0383B0085057201000001010101112131313333203333
    Address 3B: Sensor Elect. (J849)       Labels: None
       Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA7702PU2O
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 377D4CBD8E9C45F224-8062
    Address 42: Door Elect, Driver (J386)       Labels: NONE
       Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
       Component: TSG FA        H07 0280
       Revision: --------    Serial number: 0000152451232
       Coding: 011F1E015E0162C202083006
       VCID: 489F3F41FB623A0A5D-801C
       Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
       Component: RCEPS         H43 0012
       Revision: 00001000    Serial number: 0030770572
       Coding: 101000010001
       ASAM Dataset: EV_RCEPS 009013
       ROD: EV_RCEPS_009.rod
       VCID: 39794A85B8885382D2-806C
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.CLB
       Revision: 00002001    Serial number: 0365208788
       Coding: 011B0E2280B93981F320C784080316470000000000000000000000000000
       Subsystem 1 - Part No: 4H0 951 177
       Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
       Component: Dachelektroni  H13 0080
       Serial number: A2015000000000838437
       Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93529295
    Address 47: Sound System (J525)       Labels: NONE
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007001    Serial number: 00000000174789
       Coding: 030000
       VCID: 1D31BE1504600FA2DE-8048
    Address 52: Door Elect, Pass. (J387)       Labels: NONE
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H07 0280
       Revision: --------    Serial number: 0000152244640
       VCID: 3C775391BFBA66AAC9-8068
       Revision: --------    Serial number: 00000001494872
       ROD: EV_ParkiBrake_VW51.rod
       Coding: 02F6021022630200
       VCID: 34677BB19FEAAEEA01-8060
       Coding: E00200
       Coding: E00200
    Address 56: Radio (R)       Labels: REDIR FAIL!
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H60 0154
       Revision: AB001007    Serial number: 109FX0F8040437
       Coding: 010103010000000001
       VCID: 2D516ED574C0FF224E-8078
    Address 57: TV Tuner (R78)       Labels: NONE
       Part No SW: 4G0 919 129 C    HW: 4G0 919 129
       Component: NGTV-DVB      H04 0690
       Revision: R0043000    Serial number: 06801302049601
       Coding: 03000000
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6XX-5F.CLB
       Part No SW: 4H0 035 646 A    HW: 4H0 035 666 S
       Component: H-BN-EU       H49 1034
       Revision: --------    Serial number: 493FU0FB001311
       Coding: 02010100000BF1EF45908B1E00000003E00001020000000000
       VCID: 254196F52C30C76286-8070
       Subsystem 1 - Part No: 8R0 060 884 CR
       Component: EUR 2015  2102
       Subsystem 2 - Part No SW: 4H0 919 604 H    HW: 4H0 919 604 H
       Component: DU8 D4 SV NB  H63 0060
       Serial number: AUZ8ZDFY900CJUZ
       Subsystem 3 - Part No SW: 4H2 919 600 L    HW: 4H2 919 600
       Component: E380 BDT D4  H11 0110
       Serial number: 00000000196332
       Component: CD-Database  6208
    Address 62: Door, Rear Left (J388)       Labels: NONE
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H07 0280
       Revision: --------    Serial number: 0000151390045
       Coding: 010F1E01400062C202083006
       Shop #: WSC 52891 002 1048576
       Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
       Component: TopView       H07 0330
       Revision: 11001001    Serial number: 82330JF0232953
       Coding: 020E000001000000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
       ROD: EV_CamerSysteTopViewAUDI_008_AU64.rod
       VCID: 2E5369D971C6843A77-807A
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
       Component: HDSG-Modul    H12 0049
       Revision: 10012001    Serial number: 144500094
       Coding: 021004C020
       ASAM Dataset: EV_DeckLidContrUnit 001032
       ROD: EV_DeckLidContrUnit.rod
       VCID: 6FEDB4DDB64CCD323C-803A
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Part No SW: 4H0 907 412     HW: 4H0 907 412
       Component: ALM           H05 0004
       Revision: --------    Serial number: 000000187206
       Coding: 220000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63C5C8ED6A847952A8-8036
    Address 72: Door, Rear Right (J389)       Labels: NONE
       Component: TSG HR        H07 0280
       Revision: --------    Serial number: 0000151390044
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
       Component: GSM-RL        H09 0083
       Revision: 0R0D5015    Serial number: SN150417  0185
       ROD: EV_GSM2x3Mono.rod
       VCID: 2C5763D147DAF62A59-8078
    Address 88: Multicont. Seat Driver (J873)       Labels:* None
       Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
       Component: IVB           H07 0042
       Serial number: 00021483083002
       Coding: 672FF2
       ROD: EV_IVBDriveSideFrnt.rod
    Address 89: Multicont. Seat Pass. (J872)       Labels:* None
       Serial number: 00021485080501
       Coding: 272FF2
       Coding: 00060000031F030000030800424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 316972A560F89BC26A-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 151030176
       ROD: EV_RDCMA00100_008.rod
    End---------------------(Elapsed Time: 40:09, Deb=2)-----------------------
    Julian
