Wednesday,12,September,2018,00:32:30:23375
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 18.2.1.5 (x64)
Workshop Code: 790 34034 012345
VIN: WAUZZZ8V1FA076134 License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 55 5F A9 BB BC
VIN: WAUZZZ8V1FA076134 Mileage: 52349km-32528miles
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 0A1D00322426010B2000
Shop #: WSC 34034 790 12345
ASAM Dataset: EV_ECM20TFS0208V0906259A 001006
ROD: EV_ECM20TFS0205G0906259E.rod
VCID: 3E79D4A4A12CFAB416-806B
Readiness: 0010 0001
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4932
Revision: 05853104 Serial number: TFK01409070267
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1F47092006E693BC3D-804B
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62864000000224
Coding: 32F16BA254272A720378070341C7694CD62A54C0E08296F7024100788608
Shop #: WSC 06314 790 00021
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 458BBB48C4FAA96C57-8011
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000460399
Coding: 03000014110000011000000000001500
Shop #: WSC 12345 123 61029
VCID: 3261F09465742ED4E2-8067
Serial number: 41784257000000000001
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011428300271
Coding: 04141A42C24122F503844004B31407A80000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 00056A5C9B584C4424-8055
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140917 042 0580
Serial number: 141001210809
Coding: 0A47F7
Subsystem 2 - Part No SW: 8UD 955 559 B HW: 8UD 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 90075912
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
Serial number: 24 07 2014 00000994
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY142580AJZ
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000060744609
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO3303556%
Coding: 901E00
202506 - Motor for Central Locking of Rear Trunk/Hatch
B12DD 15 [008] - Open or Short to Plus
Reset counter: 60
Mileage: 1048574 km
Time: 00:00:00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39331428204730
Coding: 0030050011
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 4281A054D5D49E5472-8017
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Serial number: 003M2R08R4W$
Coding: 98CCC000000000005C5400CA004800000065
VCID: 4B9F8D70E29E5F1C81-801F
Subsystem 1 - Part No SW: ----------- HW: 480 001 310 14
Serial number: 35767000000FBC5C6115
Subsystem 2 - Part No SW: ----------- HW: 480 001 310 14
Serial number: 35867000000F7C5C6112
Subsystem 3 - Part No SW: ----------- HW: 480 400 210 14
Serial number: 35165029B175A920C226
Subsystem 4 - Part No SW: ----------- HW: 480 400 210 14
Serial number: 3526502C7175A9044253
Subsystem 5 - Part No SW: ----------- HW: 480 402 208 14
Serial number: 3556502A516C6CE180FU
Part No SW: 8V0 953 521 BP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 13101408491678
Coding: A018
ROD: EV_SMLSKLOMQB_013_AU37.rod
VCID: 09137778A8620D0C73-805D
Part No SW: 8V0 920 871 G HW: 8V0 920 871 G
Component: KOMBI H02 4291
Coding: 03AD080A2B8000080E04AA001000000000000000
VCID: 4085AA5CDBD88C4464-8015
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002448608
Coding: 030100042F085A005B0002681C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011_VW37.rod
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Serial number: 02 10 2014 E0001154
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4942644603
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00031.08.14
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
VCID: 4689BC44F9FCA2745E-8013
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 11101402090388
Coding: 005D8E205C00040000001002
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB_010.rod
VCID: 356BCB88941A39ECC7-8061
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 09101402091996
Coding: 005D86205E00040000001002
VCID: 3F87A9A0A626F3BC1D-806B
Component: LWR-ECU 005 0080
Coding: 01AA000001000000
VCID: 75EB0B88D49A79EC07-8021
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 850 B HW: 8V0 035 850 B
Component: MU-S--CN 041 0931
Serial number: A3600710140651
Coding: 017303000000000021150002001A00002F0003640100010000
ROD: EV_MUStd4CPASE_VW37.rod
Multimedia Operating Unit:
Subsystem 1 - Part No SW: 8V0 919 614 P HW: 8V0 919 614 P
Component: ControlUnit_B H41 0054
Serial number: C1000019081400020129
6170 - Display Unit 1 for Multimedia System
B1297 4A [009] - Incorrect component(s) installed
Reset counter: 15
Mileage: 52265 km
Date: 2018.09.09
Time: 01:15:20
Voltage terminal 30: 12.3 V
5716 - Mechanism for Mulimedia Display Unit 1
B1401 13 [009] - Open Circuit
Fault Frequency: 17
Reset counter: 21
Mileage: 52265 km
Date: 2018.09.09
Time: 01:15:20
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140910200381
VCID: 7DFB13A8ECAA21AC4F-8029
Part No SW: 5Q0 959 595 B HW: 5Q0 959 595 B
Component: TSG HFS 020 0025
Serial number: 02101401102059
Coding: 004D86204000040000001002
Component: TSG HBFS 020 0025
Serial number: 02101406072045
End-------------------------(Elapsed Time: 06:14)--------------------------
