2015 S3 8V Disable the EPB?
Ting
Taiwan
Hello everyone,does anyone know how to disable the EPB while opening door?
It’s annoying that every time I just get off car for a few seconds or when I parking my car on the pusher need to open the door to check that my car is in position or not,the EPB activate automatically when I open the door,is there a coding or adaptation to disable it? (But the auto hold needs to be activating still,and manually using the EPB when I need it!)
Regards.
Ting
Taiwan
I don't know why when I copy the auto scan list it is garbled,maybe it's because my VCDS is in Chinese. Could you tell me which part of the auto scan list you want to see,maybe I can translate it for you.
golfi_vend
Tartu, Estonia
C?ID=195131
We want full English unedited autoscan. :)
Ting
Taiwan
sorry for delay...I downloaded a English version of VCDS,please check the auto scan:)
The 09 and 5f malfunctions are I install the Android system and power trunk that occur error,don’t be mind.
Wednesday,12,September,2018,00:32:30:23375
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 18.2.1.5 (x64)
Workshop Code: 790 34034 012345
VIN: WAUZZZ8V1FA076134   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 42 44 52 55 5F A9 BB BC
VIN: WAUZZZ8V1FA076134   Mileage: 52349km-32528miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0A1D00322426010B2000
   Shop #: WSC 34034 790 12345
   ASAM Dataset: EV_ECM20TFS0208V0906259A 001006
   ROD: EV_ECM20TFS0205G0906259E.rod
   VCID: 3E79D4A4A12CFAB416-806B
Readiness: 0010 0001
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4932
   Revision: 05853104    Serial number: TFK01409070267
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1F47092006E693BC3D-804B
   Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
   Component: ESC           H31 0471
   Revision: 00000000    Serial number: 62864000000224
   Coding: 32F16BA254272A720378070341C7694CD62A54C0E08296F7024100788608
   Shop #: WSC 06314 790 00021
   ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
   VCID: 458BBB48C4FAA96C57-8011
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000460399
   Coding: 03000014110000011000000000001500
   Shop #: WSC 12345 123 61029
   VCID: 3261F09465742ED4E2-8067
   Serial number: 41784257000000000001
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011428300271
   Coding: 04141A42C24122F503844004B31407A80000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 00056A5C9B584C4424-8055
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140917  042 0580
   Serial number:         141001210809
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 90075912
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Serial number: 24 07 2014  00000994
   Serial number: 000000000ZY142580AJZ
   Serial number: 00000000000060744609
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO3303556%
   Coding: 901E00
202506 - Motor for Central Locking of Rear Trunk/Hatch
          B12DD 15 [008] - Open or Short to Plus
                    Reset counter: 60
                    Mileage: 1048574 km
                    Time: 00:00:00
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331428204730
   Coding: 0030050011
   ROD: EV_EPHVA18AU3700000_002_AU37.rod
   VCID: 4281A054D5D49E5472-8017
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Serial number: 003M2R08R4W$
   Coding: 98CCC000000000005C5400CA004800000065
   VCID: 4B9F8D70E29E5F1C81-801F
   Subsystem 1 - Part No SW: -----------    HW: 480 001 310 14
   Serial number: 35767000000FBC5C6115
   Subsystem 2 - Part No SW: -----------    HW: 480 001 310 14
   Serial number: 35867000000F7C5C6112
   Subsystem 3 - Part No SW: -----------    HW: 480 400 210 14
   Serial number: 35165029B175A920C226
   Subsystem 4 - Part No SW: -----------    HW: 480 400 210 14
   Serial number: 3526502C7175A9044253
   Subsystem 5 - Part No SW: -----------    HW: 480 402 208 14
   Serial number: 3556502A516C6CE180FU
   Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 13101408491678
   Coding: A018
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 09137778A8620D0C73-805D
   Part No SW: 8V0 920 871 G    HW: 8V0 920 871 G
   Coding: 03AD080A2B8000080E04AA001000000000000000
   VCID: 4085AA5CDBD88C4464-8015
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002448608
   Coding: 030100042F085A005B0002681C0B00000001010000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011_VW37.rod
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 02 10 2014  E0001154
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 4942644603
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00031.08.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 4689BC44F9FCA2745E-8013
   Serial number: 11101402090388
   Coding: 005D8E205C00040000001002
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 356BCB88941A39ECC7-8061
   Serial number: 09101402091996
   Coding: 005D86205E00040000001002
   VCID: 3F87A9A0A626F3BC1D-806B
   Coding: 01AA000001000000
   VCID: 75EB0B88D49A79EC07-8021
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 850 B    HW: 8V0 035 850 B
   Component: MU-S--CN      041 0931
   Serial number: A3600710140651
   Coding: 017303000000000021150002001A00002F0003640100010000
   ROD: EV_MUStd4CPASE_VW37.rod
   Multimedia Operating Unit:
   Subsystem 1 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000019081400020129
6170 - Display Unit 1 for Multimedia System
          B1297 4A [009] - Incorrect component(s) installed
                    Reset counter: 15
                    Mileage: 52265 km
                    Date: 2018.09.09
                    Time: 01:15:20
                    Voltage terminal 30: 12.3 V
5716 - Mechanism for Mulimedia Display Unit 1
          B1401 13 [009] - Open Circuit
                    Fault Frequency: 17
                    Reset counter: 21
                    Mileage: 52265 km
                    Date: 2018.09.09
                    Time: 01:15:20
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140910200381
   VCID: 7DFB13A8ECAA21AC4F-8029
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 02101401102059
   Coding: 004D86204000040000001002
   Component: TSG HBFS      020 0025
   Serial number: 02101406072045
End-------------------------(Elapsed Time: 06:14)--------------------------
Ting
Taiwan
Regards.
   Revision: --H13---
   Coding: 0A47F7
   Coding: 00006C
   Sun Roof:
   Coding: 901E00
                    Reset counter: 60
                    Mileage: 1048574 km
                    Time: 00:00:00
   Coding: 0030050011
   Coding: A018
   Coding: 0001
   Coding: 8103
                    Reset counter: 15
                    Mileage: 52265 km
                    Date: 2018.09.09
                    Time: 01:15:20
                    Fault Frequency: 17
                    Reset counter: 21
                    Mileage: 52265 km
                    Date: 2018.09.09
                    Time: 01:15:20
Threads merged.
Please refrain from opening new threads for the same question on the same car.
Also please see: How to get Verified.
Ting
Taiwan
Somebody help me to deal with this......PLEASE
golfi_vend
Tartu, Estonia
C?ID=195131
Why do You even think there is even a way?
Only thing i found from admaps is:
IDE03493-Driver door status,activated
Changing this to "Not Activated", may or may not work.
Ting
Taiwan
Thanks.After trying the adaptation it says need the security code but I’ve already enter the 20103 code,still cannot switch to Not activated, why?
Maybe 20103 is not the correct security code for that module version?
Ting
Taiwan
But it said security code succeeded
Mika_M
C?ID=183725
Different security codes enable different things. It may well be accepted and it possibly did enable you to change something, just not that specific setting. So another code is needed.
Ting
Taiwan
Any other codes provide? Thanks
Mika_M
C?ID=183725
I just took a look and in my car (A3 8V 2014) I also have that setting as "Activated", yet my car does not put EPB on if I open driver's door with engine running.
I don't know where the difference is, but I think that changing that particular adaptation channel will not solve your problem.
