Results 1 to 6 of 6
Thread: Anyone have a Label File for Audi 8EC 1.8t 01 Engine Control Module
    Hawkesbury, Australia
    Hi guys,
    I'm trying to fault find a code I'm getting on my engine, but the Label file is missing for the control module.
    Does anyone have a label file for an 8EC Audi A4 1.8t?
    Ive sent the control module map and scan to the support email address, but was hoping someone here might be able to help more quickly.
    Here is my scan:
    Thursday,30,October,2014,21:34:36:18055
    VCDS Version: 12.12.3.0
    Data version: 20140822
    VIN: WAUZZZ8E96A025982   License Plate: CPG535
    Mileage: 130570km-81132mi   Repair Order:
    Scan: 01 02 03 08 09 15 16 17 25 31 33 46 56
    VIN: WAUZZZ8E96A025982   Mileage: 130570km/81132miles
       Part No SW: 8E0 909 518 AQ    HW: 8E0 909 018 B
       Component: 1.8L R4/5VT     G   0010
       Coding: 0011581
       Shop #: WSC 06335 000 00000
       VCID: 7F0D218A2DBBFBE6E27-5124
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
                P1297 - 001 -
    17544 - Fuel Trim: Bank 1 (Add)
                P1136 - 001 - System too Lean - MIL ON
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 8E3 910 155 T    HW: 01J 927 156 HT
       Component: V30 01J 1.8l5VT RdW 0010
       Revision: 00000010    Serial number: 00000001212464
       Coding: 0000001
       Shop #: WSC 21010 822 83252
       VCID: 39790F92731F15D69C3-5142
       Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
       Component: ESP8 front      H04 0120
       Coding: 0004872
       VCID: 285FDAD69BB59C5EF3D-807D
       Part No: 8E0 820 043 AJ
       Component:   A4 Klimaautomat   2831
       Coding: 00000
       Shop #: WSC 06335
       VCID: 69D99FD2133F65562C3-5124
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  ECE 0504
       Coding: 00001
       Shop #: WSC 06335
       VCID: 3B75159A292327C68EF-4B02
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H11 3530
       Revision: 91H1135    Serial number: 0036M005ALVC
       Coding: 0033722
       VCID: 3B75159A7A2327C68EF-806E
       Subsystem 1 - Serial number: 6332DRB401A1872BN
       Subsystem 2 - Serial number: 6342DRB401D0CE99%
       Subsystem 3 - Serial number: 6352ARB400739256E
       Subsystem 4 - Serial number: 6362ARB40071E94DV
       Subsystem 5 - Serial number: 63729RB4007E2FCD3
       Subsystem 6 - Serial number: 63829RB4007E2F77-
       Part No: 8E0 953 549 Q
       Component: Lenks·ulenmodul     0601
       Coding: 02141
       Shop #: WSC 06335
       VCID: 418967724BCF4D16D43-4AE8
       Part No SW: 8E0 920 901 C    HW: 8E0 920 901 C
       Component: KOMBI+WFS 3     H12 0110
       Revision: 0110        Serial number: AUX6Z0E0062549
       Coding: 0006741
       Shop #: WSC 16490 959 86059
       VCID: 2541D3E2EFA78136C8B-5124
       Coding: 0006741
    Address 33: OBD-II        Labels:
       VCID: 55A1A322AC47D1B698B-5124
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 BQ
       Component: Komfortger·t T01    3332
       Coding: 06896
       Shop #: WSC 21000
       VCID: 810927728B4F0D16143-4B02
       Subsystem 1 - Part No: 8E2959802F
       Component: Tırsteuer.FS BRM 0406
       Subsystem 2 - Part No: 8E2959801B
       Component: Tırsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8E0959801A
       Component: Tırsteuer.HL BRM 0205
       Subsystem 4 - Part No: 8E0959802A
       Component: Tırsteuer.HR BRM 0205
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 8E0 035 152 B
       Component: chorus II   GRO    0004
       Coding: 01006
       Shop #: WSC 06335
       VCID: 1F4DC10A9DFB5BE6827-4AE8
    The Engine address 01 is the file I'm chasing.
    The fault code I'm chasing is the 17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297 - 001 -.
    It's only started coming up since I replaced the crank case ventilation pipe on top of the oil filter housing.
    I've run the output tests and all seems good, but I cannot access stye Advanced Measuring blocks as the label file is missing.
    Any help is appreciated.
    Thanks Guys.
    Cristian
    2005 A4 B7 1.8t BFB
    2014 T5.2 Multivan TDI340
    Magdeburg, Germany
    Hello Cristian, you should receive a file via email later today. Please let me know if that worked for you.
  3. Likes Uwe, Cristian G liked this post
    Quote Originally Posted by Sebastian View Post
    Thanks Sebastian,
    Yes I did receive it, but had mixed results.
    It worked in 14.9 BETA, but failed in 14.10 RELEASE.
    I'm fried tonight, so going to have another look at it tomorrow in 14.10 RELEASE.
    Regards
    Cristian
    2005 A4 B7 1.8t BFB
    Hey Sebastian,
    I finally got the scan done on Sunday night.
    The label file worked.
    Here is the scan.
    Saturday,15,November,2014,19:53:24:18055
    VCDS Version: 14.10.0.0
    Data version: 20141022
    Mileage: 131117km-81467mi   Repair Order:
    Scan: 01 02 03 08 09 15 16 17 25 31 46 56
    VIN: WAUZZZ8E96A025982   Mileage: 131110km-81467miles
    Address 01: Engine        Labels: User\06B-906-018-AVJ.lbl
       Coding: 0011581
       VCID: 7F0D218A2DBBFBD9161-5142
                P1297 - 001 -
                P0300 - 001 -  - Intermittent
    16686 - Cylinder 2
                P0302 - 001 - Misfire Detected - Intermittent
    16685 - Cylinder 1
                P0301 - 008 - Misfire Detected - Intermittent
    16891 - Idle Control System RPM
                P0507 - 001 - Higher than Expected.
    Readiness: 0000 1100
       Coding: 0000001
       VCID: 39790F92731F15E9685-5124
       Coding: 0004872
       VCID: 285FDAD69BB59C6107B-807D
       Coding: 00000
       Shop #: WSC 06335
       VCID: 69D99FD2133F6569D85-5124
       Coding: 00011
       Shop #: WSC 06335
       VCID: 3B75159A292327F97A9-4B02
       Coding: 0033722
       VCID: 3B75159A7A2327F97A9-806E
       Coding: 02141
       Shop #: WSC 06335
       VCID: 418967724BCF4D29205-4B02
       Coding: 0006741
       VCID: 2541D3E2EFA781093CD-5142
       Coding: 0006741
       VCID: 2541D3E2EFA781093CD-5124
       Coding: 06896
       Shop #: WSC 21000
       VCID: 0109A7720B4F8D29605-4AE8
       Coding: 01006
       Shop #: WSC 06335
       VCID: 1F4DC10A9DFB5BD9761-4AE8
    End-------------------------(Elapsed Time: 02:30)--------------------------
    I can now access the advanced measuring blocks as well.
    Also now that we know it works, should I move the file in with the rest often label files or leave it in the user folder?
    Thanks for your help.
    Regards
    Cristian
    2005 A4 B7 1.8t BFB
  6. Likes Sebastian liked this post
    It should make no difference whether it's in the User folder or in the main Labels folder.
    Magdeburg, Germany
    ...and the next update to VCDS (as well as all future versions) will have this file out of the box, so /Labels/User/ is fine for now.
  9. Likes jyoung8607 liked this post
