Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 95
Thread: Retrofitting AWD to Scirocco mk3
  1. #21
    United States
    Hmm, please see if SA code 11908 is accepted at all by this controller. If it is rejected do NOT try any other codes (because that will result in lock-time) but if it happens to be accepted ... see if the same coding will copy/paste back in without an error.
  2. #22
    Mar 2014
    "Controller refused the key! Error 35: Invalid key"
  3. #23
    United States
    Quote Originally Posted by Heikki J. View Post
    OK, I figured that because most (if not all) of the 1K0-907-379-B? (Those are common in 2011+ M.Y. cars and typically use 19 bytes rather than the older 18 byte string) series controllers simply accept copy and paste coding without a SA code. I don't have anything else to suggest at this point in time.
  4. #24
    Mar 2014
    OK. By the way, yesterday I was helping a friend to replace a CAN gateway with a used one and when I recoded that I got the same "out of range" error when two bytes were not matching. There were two bytes that needed to change when installing a gateway from 4 door car to 2 door car... and I first changed only one byte and got the error. When changed the other too, coding was accepted.
    So this got me thinking that perhaps I get the error simply because everything just don't match. I just need to figure out coding that'll match with all the correct parts in my car?
  5. #25
    Jun 2014
    Hi with richard
    I have on my car the same problem with the abs after the car adjust from 2 wheel drive to 4 wheel drive
    vw transporter bj 2011 2.0 diesel dsg 180hp
    is now resolved this problem of yours if so what did you done
    best regards richard
  6. #26
    Mar 2014
    No, unfortunately I haven't solved the problem yet.
  7. #27
    Jun 2014
    Hi with richard
    is your problem with the abs of encoding already fixed my problem is fixed with 2 numbers per today to change from 09 to 11 in position 4 and 90 to 88 in position 10
  8. Likes Uwe, Heikki J., Jack@European_Parts liked this post
  9. #28
    Mar 2014
    No, I haven't solved my problem yet. Could you post your complete code before and after so I could double check if it has anything to do with my coding. Those two bytes seem so much different from my byte 04 and 10.
    My byte 04 is 49 and in my Golf R it was 09.
    My byte 10 is 01, same in Golf R. So far only documented bit has been the last bit which means the brake disc size.
  10. #29
    Jun 2014
    20 87 64 ad 09 aa 04 98 26 a6 90 74 6a 5e 16 dsg 180hp old
    20 87 64 ad 11 aa 04 98 26 a6 88 74 6a 5e 16 dsg 180hp 4motion new
  11. #30
    Mar 2014
    Thanks Richard! Seems it's quite different, mine is 19 bytes long, yours is only 15 bytes.
    How did you find the right code? Did you ask some Company to help?
