Friday,07,September,2018,01:06:35:29185
VCDS Version: 18.2.1.5 (x64) HEX-NET CB: 0.4411.4
VIN: WVGZZZ1TZBW007863 License Plate:
Mileage: 178250km-110759mi Repair Order:
Chassis Type: 1T-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56 61 62 72 77
VIN: WVGZZZ1TZBW007863 Mileage: 178250km-110759miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AS HW: 03L 906 023 A
Component: 1,6l R4 CR td H23 7003
Revision: -------- Serial number: 00000000000000
Coding: 00194036032401080000
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_ECM16TDI02103L906023AS 003002
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 77BE2644CEBF45FC15-8022
6118 - Cruise Control Switch (E45)
P0568 00 [037] - Implausible Signal
Mileage: 178251 km
Date: 2018.09.07
Time: 12:00:56
Coolant temperature: 48 °C
Intake air temperature: 30 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 12.875 V
Accelerator position: normalized-Accelerator position: 0.00 %
Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 10000010
Readiness: 1110 1000
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 323B401609220E014C1302EA901C7051310000
VCID: 0444418887691E6400-8050
Reset counter: 17
Mileage: 178251 km
Date: 2013.01.28
Time: 11:43:22
Count: 3
Count: 2
Count: 29184
Count: 166
Count: 43008
Count: 65022
Part No SW: 5K0 907 044 CM HW: 5K0 907 044 CM
Component: Climatronic H16 0808
Revision: 00003001
Coding: 0000000003
VCID: 78BC2578C3A14A841C-802C
Part No SW: 5K0 937 087 H HW: 5K0 937 087 H
Component: BCM PQ35 H 011 0035
Revision: BE011001
Coding: 40180A3890251AE040080080140081E443518E08426DA1606480C7000041
Shop #: WSC 26297 000 1048576
VCID: 3A38FF70B52D98942A-806E
Subsystem 1 - Part No: 1T1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 07071 21 0512
Coding: 009795
Component: RLS 190710 05 54 0403
Coding: 0330ED
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5N0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H02 0045
Revision: -------- Serial number: 65031019102908
Coding: 108001
ASAM Dataset: EV_EPHVA14VW3680000 001005
ROD: EV_EPHVA14VW3680000.rod
VCID: 3A38FF70BD2D98942A-806E
12718592 - Databus
[Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Reset counter: 57
Mileage: 178251 km
Date: 2018.09.07
Time: 11:46:13
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D006HR4
Coding: 0012338
VCID: 373EE644463F85FCD5-8062
Subsystem 1 - Serial number: 6332QSME79630E32J
Subsystem 2 - Serial number: 6342QSME1B645808J
Subsystem 3 - Serial number: 6352QSME1C5A5722L
Subsystem 4 - Serial number: 6362QSME19670E2EV
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20171222201032
Coding: 718A200000
Shop #: WSC 01286 386 08256
VCID: 02484790957D105432-8056
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Serial number: 0012229
Coding: 820000
226838 - Turn Signal Switch
B1144 12 [008] - Short to Plus
Reset counter: 57
Mileage: 178251 km
Date: 2018.09.07
Time: 11:59:51
227355 - Windshield Wiper/Washer Switch
B1149 13 [009] - Open Circuit
Reset counter: 17
Mileage: 178251 km
Date: 2018.09.07
Time: 11:59:28
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Reset counter: 17
Mileage: 178251 km
Date: 2018.09.07
Time: 11:59:28
Part No SW: 1T0 920 871 D HW: 1T0 920 871 D
Component: KOMBI H05 0404
Coding: 181B00
VCID: 3424D1489F496EE4F0-8060
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 5K0 963 271 C
Component: Zuheizer 051 2606
Revision: 00051000 Serial number: 09021535000000
Coding: 0000031
VCID: 2F2EDE24BE6F4D3C8D-807A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 110710F1000339
Coding: E9A07F06000E0204008002
VCID: 2E10C320B965443486-807A
Component: IMMO H05 0404
VCID: 6A980F308D0DE8149A-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2111
Coding: 0131253
VCID: 48DC95B83BC1FA04AC-801C
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.235 0802
Revision: 1AH03729 Serial number: 00101860256501
Coding: 0000258
VCID: 3B36FA747A17A19C31-806E
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131253
VCID: 47DE968436DFF57CA5-8012
Address 56: Radio Labels:
VCID: 55E24CCCAC7357EC27-FFFE
Component: Batt.regelung H25 5603
Coding: 030B185A
VCID: 71AA185CA8DB1BCCDB-8024
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790299404
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0131216
Shop #: WSC 01324 020 1012552
VCID: 3228D750AD5D60D4E2-8066
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0131216
VCID: 3326D254524769DCE9-8066
Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668297752
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 312AD85C605B5BCC9B-8064
9457425 - Left audio channel for speech/telephone
B104F 11 [000] - Short to GND
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Reset counter: 17
Mileage: 174069 km
Date: 2018.06.07
Time: 13:25:30
9457169 - Right audio channel for speech/telephone
B104E 11 [000] - Short to GND
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 17
Mileage: 174069 km
Date: 2018.06.07
Time: 13:25:30
End----------(Elapsed Time: 01:30, VBatt start/end: 12.6V/12.4V)-----------
