Results 1 to 9 of 9
Thread: 2018 Tiguan SEL MK2 Auto Headlights Sensitively
    Sep 2018
    Leonartown, MD, USA
    MK2 Tiguan for US market uses infrared (?) sensor as a triger to change from day to night mode (or night to day). The sensor is on the middle of the dashboard (not the one by rear mirror). Does anyone know which module or where adjustments can be change to either lowere sensitivity or change timing? Auto headlights are flashing (nave change day to night) each time shadow passes through it. Morning and evening drives through foresty area are very entertaining and annoying especially for oncoming traffic.
    I am referring to auto-headlight function not auto high beams assist, just auto turn on and off of main headlights.
    Added AutoScan per PetrolDave (fyi,the fault in 69 not related to the headlight light sensitivity).
    Wednesday,05,September,2018,18:53:49:30494
    VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4411.4
    VIN: 3VV2B7AX3JM002106   License Plate:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 69 6C
              6D 75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 15506km-9634miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H30 0004
       Revision: 1DH30000
       Coding: 012A00122476010FB4000000000000000000000000000000
       Shop #: WSC 00066 790 00291
       ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
       ROD: EV_ECM20TFS0115NA907115A.rod
       VCID: 3C34CD1FB71CB9A438-8068
    Readiness: 1110 1101
       Part No SW: 09G 927 158 Q    HW: 09G 927 158
       Component: AISIN AQ8     206 3379
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00453
       ROD: EV_TCMAQ450031_VW27.rod
       VCID: 41CABCEBD0FED44C6B-8014
       Revision: 00000000    Serial number: 50987000000137
       Coding: 0BFA6BA454201B6EC5780300A2C949D0D62AD8A3C045927C18415058C28A4200002864121A1C230935351919323200
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 77BE1233CEBA5AFC15-8022
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0434760327
       Coding: 032C0C070F
       Part No SW: 5NN 907 044 A    HW: 5NN 907 044 A
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000D00004849
       Coding: 0002002410011800100501401211140E
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 4AD89BC7EDC81714BA-801E
       Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
       Component: BCM PQ37BOSCH 034 0243
       Revision: --------    Serial number: C864120417023U
       ROD: EV_BCMCONTI.rod
       VCID: 0C545DDFA73C492448-8058
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 170308  034 0373
       Serial number: 17030521051340
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Serial number: 71808607
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3200008950FF8728749C8145304097
       Shop #: WSC 00066 790 00274
       VCID: 3E30C717A100ABB416-806A
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    004 0336
       Serial number: 003NUM057U6/
       Coding: 8CCCFC00000000005000001AC20800000065
       VCID: 054268FB8456386C17-8050
       Occupant Detection:
       Serial number: IBH0000000000073RU0R
       Coding: 303351
       Subsystem 2 - Part No SW: -----------    HW: 480 001 503 17
       Serial number: 357000000000D3191223
       Subsystem 3 - Part No SW: -----------    HW: 480 001 503 17
       Serial number: 358000000003D3191227
       Subsystem 4 - Part No SW: -----------    HW: 480 402 503 17
       Serial number: 3510001A32527B23351L
       Subsystem 5 - Part No SW: -----------    HW: 480 401 901 17
       Serial number: 3520001B922A9B34353/
       Subsystem 6 - Part No SW: -----------    HW: 480 402 103 17
       Serial number: 3550001C724CDB2395AI
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 103 17
       Component: FrontSensor_P  000 6149
       Serial number: 3560001C724CDB2392BH
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 07041708491719
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 075E62F3BE5A2A7C65-8052
       Part No SW: 5NA 920 850 A    HW: 5NA 920 850 A
       Component: KOMBI         361 8311
       Coding: 0BA5001AA788CF0502887B095400000020000000
       VCID: 3D32C01BAC06B0AC0F-8068
       Component: GW MQB High   518 5286
       Serial number: 08051700840113
       Coding: 030500347F085900FB0322581E0F00010001050000000000000000000000
       Shop #: WSC 00066 790 00064
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F2EEA53766A523C8D-807A
       Subsystem 2 - Part No SW: 5NN 959 442 A    HW: 5NN 959 442 A
       Serial number: 0201700020200003BL2B
       Coding: 2C0000
       Serial number: 0475402904
       Serial number: HA1-00003.11.16
       Coding: 0101
       Serial number: 17000075290009
       Coding: 0800000000000000
       Shop #: WSC 00066 790 00440
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71AA2C2BA0DE04CCDB-8024
       Component: HRE_Master    H12 0080
       Serial number: 0431834720
       Coding: 01012103
       ROD: EV_HREntryHella_VW37.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0434370916
       Coding: 010121
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Component: TSG FS        010 0032
       Serial number: 7028702000146
       Coding: 00301B200000028000000000
       VCID: 45C2A8FBC4D6F86C57-8010
       Serial number: 00000000000005973918
       Coding: 011000
       Revision: 00000000    Serial number: 0001620982
       Coding: 01000010004001
       ROD: EV_SteerAssisVWBSMQBA_009.rod
       VCID: 40CCB9EFDBF4DD4464-8014
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Component: TSG BFS       010 0032
       Serial number: 8028712700422
       Coding: 003013200000028000000000
       VCID: 44C4B5FFCFECC16440-8010
       Serial number: 00000000000006065356
       Coding: 091000
       Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
       Component: MU-S-NS-US    840 0755
       Coding: 02730602BE00000051220001001808001F0500C401200105C6
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 3228E32765587FD4E2-8066
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H50 8120
       Serial number: VWZ6ZHT1300503
       Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0447480187
       Coding: 0200000202000000
       Shop #: WSC 03099 444 12345
       VCID: 42C8B3E7D5F8CF5472-8016
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Reset counter: 248
                        Mileage: 15506 km
                        Date: 2018.09.05
                        Time: 18:51:20
       Coding: 0123060121002017300040
       VCID: 393AD40BB82E8C8C23-806C
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
       Coding: 0A88
       ROD: EV_DeckLidCONTIAU736_VW27.rod
       Component: OCULowMQBUS   007 0570
       Coding: 02230602C2823A017F1E06020000
       ROD: EV_OCULowMQB.rod
       VCID: 43C6B6E3CAE2C65C79-8016
       Component: SAD_STG_1     013 0005
       Coding: 00804073260C
       ROD: EV_SunRoofCONTIAU736.rod
    End----------(Elapsed Time: 01:46, VBatt start/end: 12.6V/12.6V)-----------
    Please post an Auto-Scan of your Tiguan.
    Sep 2018
    Leonartown, MD, USA
    added scan to first post.
    thanks
    That BCM has this Adaptation Channel:
    IDE08786-ENG115724 -- Assistance light functions - Lichtsensorempfindlichkeit
    ; sensitive,
    ; normal,
    ; non sensitive,
    "Lichtsensorempfindlichkeit" means "light sensor sensitivity"
    Maybe try "non sensitive" to see what effect it has?
  5. Likes tomekd77 liked this post
    Sep 2018
    Leonartown, MD, USA
    ; sensitive,
    ; normal,
    ; non sensitive,
    Thanks Uwe,
    It was set to normal and non sensitive was accepted. Can't really tell now it that was car is in garage.
    Do you know which sensor module is using?
    The is one on the dashboard, which sense light intensity and adjusted back light to the LCD; and gauges and there is second one just at the bottom of the windshield - I think climatologist uses it as well... I though I read it's infrared sensor. Our Tiguans don't have light sensor by the mirror - just humidity not even rain season in SEL. BTW, changing adaptation cleared Personalization settings, not sure if that was expected....the key seas Driver 1, Driver 2 difficults....
    Tom
    Quote Originally Posted by tomekd77 View Post
    Nope. I have no hands-on with the new Tiguan -- yet.
    Dec 2016
    DE
    The adaption channel should also be changable from the Car setup menu in your HMI. Maybe because of this overlapping personalization settings where cleared?
  9. Likes PetrolDave liked this post
  10. #8
    Sep 2018
    Leonartown, MD, USA
    TBAx, if you referring to sensitivity setting adjustment in the infotainment - seams like US Tiguan SEL doesn't have that adjustment. Actually VW "forgot" how auto headlights works all together, there was a lot of cars which were not coded properly. Light switch in Auto would turn lights permanently and turn Nav screen in night mode - independently to light conditions outside. Dealer visit was required to correct that in J519. ( https://forums.vwvortex.com/showthre...ot-turning-off )
    Tom
    Last edited by tomekd77; 09-07-2018 at 09:54 AM. Reason: found invoice referring J519, to enable auto-headlights in SEL
  11. #9
    Sep 2018
    Leonartown, MD, USA
    ; sensitive,
    ; normal,
    ; non sensitive,
    Revisiting the thread, "non sensitive" appears not to be the asware for my Tiguan.
    I had a chance to drive Tiguan during nice bright day yesterday unders numerous overpasses each time light would turn on and navigation would go into night mode. I ended up turning Auto switch to Off to avoid road rage in front of me
    Any other ideas?
