Hello! Got an audi a6 allroad with transmission problem, the gear lever is stuck in park.
No Communication with TCM. Checked fuses, relays and the connector on the gearbox but no joy, Anyone know if this is some common problem?
Not much left beside the mecatronic unit inside the gearbox i guess?
Tuesday,04,September,2018,08:37:34:44208
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: WAUZZZ4F9AN007515 License Plate: EYD 072
Mileage: 199820km-124162mi Repair Order:
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 18 19 20 34 36 42 46 4F 52 53
55 56 5F 62 69 6C 6D 72 76
VIN: WAUZZZ4F9AN007515 Mileage: 199820km-124162miles
02-Auto Trans -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Malfunction 0010
Address 01: Engine (CDY) Labels: Redir Fail!
Part No SW: 4F9 910 402 A HW: 4F0 907 401 E
Component: 3.0TDI EDC17G004AG 0080
Revision: 16H02--- Serial number:
Coding: 0125002C191F0928
Shop #: WSC 40170 222 91683
VCID: 2404088EE7774F6463-8070
049409 - No Communication with Transmission Control Module
U0101 - 001 -
Fault Status: 01100001
Mileage: 199828 km
Date: 2018.09.03
Time: 10:46:59
Voltage: 13.30 V
Bin. Bits: 00000000
(no units): 8.0
Bin. Bits: 00000000
001649 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Mileage: 199828 km
Date: 2018.09.04
Time: 08:30:54
Voltage: 11.93 V
Temperature: 19.8°C
Lambda: 13.3 %
Temperature: 21.6°C
001650 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Mileage: 199828 km
Date: 2018.09.04
Time: 08:30:54
Voltage: 11.93 V
Temperature: 19.8°C
Lambda: 13.3 %
Temperature: 21.6°C
001651 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Mileage: 199828 km
Date: 2018.09.04
Time: 08:30:54
Voltage: 11.93 V
Temperature: 19.8°C
Lambda: 13.3 %
Temperature: 21.6°C
Address 02: Auto Trans
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AM HW: 4F0 614 517 BD
Component: ESP8 quattro H03 0100
Coding: 0000396
Shop #: WSC 02325 785 00200
VCID: 6FAE37A27E31BC3CCE-803A
Reset counter: 101
Mileage: 199828 km
Date: 2018.09.03
Time: 10:48:09
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0013
Hex Value: 0x44A3
Hex Value: 0x00FF
Part No SW: 4F0 910 852 B HW: 4F0 905 852 E
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10604102220325
Coding: 0000131
Shop #: WSC 26624 001 1048576
VCID: 2502158AEC4DB66C74-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Component: FBSAUDIC6 IDG H01 0040
00263 - Transmission
Reset counter: 100
Mileage: 198656 km
Date: 2018.08.15
Time: 06:12:29
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 B HW: 4F1 820 043 AL
Component: KLIMABETAETIGUNGH30 0080
Revision: 00000074 Serial number: 00000000637084
Coding: 0002326
VCID: 1D723D6AC41D7EAC2C-8048
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Coding: 0013222
Shop #: WSC 02335 785 00200
VCID: 3424F8CE5797DFE4F3-8060
Subsystem 1 - Part No: 4F1 910 113 D Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0070
Revision: AA001001
VCID: 54E4984E3757FFE4D3-8000
Address 15: Airbags (J234) Labels:| 4F0-910-655-10.clb
Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003CH005835A
Coding: 30314236303630303031554A304C34463053
Shop #: WSC 02323 785 00200
ROD: EV_Airba10AURB4.rod
VCID: 302CF4DE6B8FE3C497-8064
Serial number: 3574SRB4000090412A4X
Serial number: 3584SRB400009040F0E3
Serial number: 35152RB40318QC6QSSH+
Serial number: 35252RB402L8MAVT5RGF
Serial number: 3554NRB400004B684E22
Serial number: 3564NRB400004B6F117%
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90025091420022
Coding: 0002042
VCID: 271E1F829641A47C46-8072
Component: E0221 H02 0030
Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
Part No SW: 4F0 920 933 Q HW: 4F0 920 933 Q
Component: KOMBIINSTR. H06 0138
Revision: 00300000 Serial number: BH0225Y59
Coding: 0F566A0302010008010100
Shop #: WSC 02391 823 56573
VCID: 3522C5CA9CEDC6ECC4-8060
Address 18: Aux. Heat Labels: None
Part No SW: 4F0 910 105 A HW: 4F0 265 081 AA
Component: Heizgeraet H08 0100
Revision: B Serial number: 09018641
Coding: 0000111
Shop #: WSC 02145 785 00200
VCID: 1B763372DA09709CD2-804E
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 N HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0031
Revision: MB100028 Serial number: 2800M095190497
Coding: 000303
VCID: 3A38D6F6B5F3299429-806E
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0107
Serial number: 00000000004140556340
Reset counter: 100
Mileage: 198656 km
Date: 2018.08.15
Time: 06:12:30
Bin. Bits: 00111
Voltage: 10.60 V
Count: 7
Bin. Bits: 10011
Time: 0.40 s
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 4F0 857 511 J HW: 4F0 857 511 G
Component: FLA H04 0004
Revision: AA001002
Coding: 02010464747464545425363E
VCID: 2F2EF7A27EB1FC3C8E-807A
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 D HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0030
Serial number: 00872000418500
Coding: 0000220
Part No SW: 4F0 959 760 C HW: 4F0 959 760 C
Component: MEM-FS H08 0062
Revision: AA000000 Serial number: 00001001285657
Coding: 00581300004011110000
VCID: 312AF1DA6885EACC98-8064
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000101206281
Coding: 011F06205E40410003
VCID: 46C0B206F10B5D745D-8012
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01187488920000
Coding: 3351281
VCID: 3228FED6AD83D1D4E1-8066
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 101
Mileage: 182033 km
Date: 2017.11.03
Time: 07:38:55
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000637057
Coding: 0001103
VCID: 5EF07A66899B25B475-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000101200286
VCID: 45C2B50ACC0D566C54-8010
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000321
Shop #: WSC 80093 222 71269
VCID: 210A019AF8655A4C08-8074
Fault Status: 11100100
Fault Frequency: 219
Reset counter: 101
Mileage: 198656 km
Date: 2018.08.15
Time: 06:12:29
Voltage: 10.14 V
Count: 243
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000004
VCID: 3FCEA7E26ED10CBC1E-806A
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H45 0020
Revision: AB001007 Serial number: 342FU097614634
Coding: 010003020100000000
VCID: 1F0E07620E116CBC3E-804A
Part No SW: 4E0 035 666 B HW: 4E0 035 666 B
Component: H-BN-EU H41 0047
Revision: -------- Serial number: 454EW097505175
Coding: 010100050002D3EF41002315EF6300030000
VCID: 2502158A2C4DB66C74-8070
Subsystem 1 - Part No: 8R0 060 884 E
Component: EUR 2009/2010 5805
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356EN091008083
Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F1 919 611 S
Component: Bedienteil MM H01 0060
Serial number: 00000001326063
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000101214214
Coding: 010E04204040220003
VCID: 43C6AB12C239685C7A-8016
Address 69: Trailer (J345) Labels:. 4F0-907-383.clb
Part No SW: 4F0 907 383 D HW: 4F0 907 383 D
Component: Anhaenger H08 0080
Revision: 2B002002 Serial number: 00000118780963
Coding: 0103030000000000
VCID: 2C14E0AE4FA78724AB-8078
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 D HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J9521H5
Coding: 1030305
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 G
Component: ValeoHeckdeckel H29 0410
Revision: --H29001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C9420AE4F274724EB-8038
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: RD14.05.09--H29001001C0255ÿ
Subsystem 4 - Serial number: 1C0255ÿ
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000101214213
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H02 0500
Revision: 00H02000 Serial number: 12630915615399
Coding: 0231416
VCID: 2A18E6B68553991459-807E
Fault Frequency: 230
Reset counter: 101
Mileage: 198656 km
Date: 2018.08.15
Time: 06:12:29
End----------(Elapsed Time: 02:01, VBatt start/end: 12.2V/12.2V)-----------
