Results 1 to 5 of 5
Thread: 2013 Tiguan Trailer Hitch retrofiting (not OEM) - need confirmation
    Aug 2018
    France
    Hi !
    I need your confirmation about the coding modifications I made during my Trailer Hitch retrofitting on my Tiguan 2013 facelift.
    The wirring harness with module is : Brink ref 756693, everything is working fine, no error are stored and the trailer hictch works perfectly.
    Is the trailer stabilization well effective as I didn't change ABS module ?
    Also, is the start/stop disabled inside module 01-Engine, because I don't see the orange light of the button switching on in my car (which occur if I press this button) ?
    I have collected many informations from this thread : http://wiki.ross-tech.com/wiki/index...rofitting_(5N)
    and also from other threads and I have performed the following changes:
    19-CAN Gateway/Installation list/"69-trailer" changed to ticked
    01-Engine/Coding/Byte 5/bit 4 changed to ticked
    10-Park/Steer Assist/Byte 0/bit 0-1 changed to "trailer hitch installed (manually removable)"
    03-ABS Brakes: seen in Adaptation/Channel 56 Trailer stabilization was already set on "Enabled"
    (I have also tried to enter security code "61378" without success) I don't know if something need to be changed in this module ?
    09-Cent. Elect/Coding/Byte 15/bit 2 was already ticked "rear fog light inactive while trailer attached"
    My scan :
    Sunday,05,August,2018,15:38:12:03297
    VCDS Version: 17.8.0.1
    VIN: WVGZZZ5NZEW507xxx   License Plate:
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 4C 52 53 56 61
              62 69 72 77
    VIN: WVGZZZ5NZEW507xxx   Mileage: 133830km-83158miles
       Part No SW: 03L 906 018 E    HW: 03L 907 309 AE
       Component: R4 2,0L EDC   H28 4572
       Revision: 41H28---    Serial number: 00000000000000
       Coding: 00190032043601080000
       ASAM Dataset: EV_ECM20TDI01103L906018E 003008
       ROD: EV_ECM20TDI01103L906018E.rod
       VCID: 2C5DEBAD4707D62606-8078
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
       Component: J104   C6 450M VD70 0011
       Revision: --H07---    Serial number: 00000007112777
       Coding: 0038206
       VCID: 6ED921A5799BE43668-803A
       Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004003
       VCID: 79F302F9F8D5B38ECD-802C
       Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
       Component: BCM PQ35 M    122 0173
       Revision: BC122001
       Coding: 40180A3BE8251AC0408800C0340001244B51AA88433181606480C7000041
       VCID: 4281A515DD833056DC-8016
       Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS 270513 03  32  0010
       Coding: 009F95
       Component: RLS 030613 05  54  0403
       Coding: 06304D
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56261315101344
       Coding: 158203
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 448DA30DCF973E66EE-8010
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20J VW10 HI   2118
       Revision: 26019000    Serial number: 003L7PB8FJ5S
       Coding: 0012362
       VCID: 7CFD1BED3FE786A6D6-8028
       Subsystem 1 - Serial number: 6332MTS613291343
       Subsystem 2 - Serial number: 6342MTS638721333
       Subsystem 3 - Serial number: 6351HTS6OBM51CKJ
       Subsystem 4 - Serial number: 6361HTS67PQG0CKR
       Part No SW: 5K0 953 501 BH    HW: 5K0 953 569 L
       Revision: FF010042    Serial number: 20130606100886
       Coding: 1182140000
       VCID: 71E33AD9A0A5FBCE75-8024
       Component: E221__MFL-TAS  H31 0033
       Coding: 820000
       Part No SW: 5N0 920 883 C    HW: 5N0 920 883 C
       Component: KOMBI         H04 0611
       Coding: 111F01
       VCID: 346DF3CD9F378EE65E-8060
       Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1642
       Revision:   H58       Serial number: 240513F1002102
       Coding: 356002
       VCID: 7AF11DF5F5D3B896C4-802E
       Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
       Component: Haldex 4Motion      0043
       Coding: 0000005
       VCID: 4D9B8629D4DDFF2E31-8018
       Component: IMMO          H04 0611
       VCID: 6AD12DB58D73081634-803E
    Address 2E: Media Player 3
       Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0503
       Revision: 12110009    Serial number: 0007037574
       Coding: 0210BE
       VCID: 3973C2F9B855738E8D-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1504
       Serial number: 00000007978246
       Coding: 000090
       Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.286 1202
       Revision: 1BH04839    Serial number: 00131480210401
       Coding: 0000258
       VCID: 3F87ACE16E715DBEB3-806A
       Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0503
       Revision: 14110009    Serial number: 0007045046
       Coding: 0211BE
       VCID: 3A71DDF5BD53789684-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1504
       Serial number: 00000007950373
       Coding: 000090
       Revision:   H19       Serial number: 00000001083828
       Coding: 0026167
       VCID: 3669C9C5414B9CF660-8062
       Part No SW: 3C8 035 195 F    HW: 3C8 035 195 F
       Component: RCD510        H04 5018
       Revision: -----21S    Serial number: VWZ4Z3N1124998
       Coding: 0100040004000C
       VCID: 2B5FE8B14A09D11E0F-807E
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1642
       Coding: 030F1859
       VCID: 71E33AD9A8A5FBCE75-8024
       Component: J367-BDM  H07 0180
       Serial number: 30146125531491471996
       Component: ConWysTrailer H07 0100
       Revision: 3A001001    Serial number: 00000132425721
       Coding: 0100000100000000
       Shop #: WSC 00007 223 174336
       VCID: 3065FFDD632FB2C63A-8064
       Part No SW: 5N0 035 729     HW: 5N0 035 729
       Component: TELEFON       H05 0315
       Revision: 1B001001    Serial number: 00007664842614
       Coding: 0A01000080010101
       ROD: EV_UHVUMI.rod
       VCID: 6DDB26A9BC9D1F2E51-8038
    End-------------------------(Elapsed Time: 03:25)--------------------------
    Here is the view of the Brink module :
    https://i.goopics.net/NKaER.jpg
    Thanks a lot for your help on this
    Last edited by Uwe; 09-03-2018 at 09:44 PM. Reason: Reverted IMG tags to URL, but still no pic.
    Aug 2018
    France
    I try another link for the picture, hope it will work
    Aug 2018
    France
    Up. Does someone can confirm my coding is correct please ?
    Moving to Retrofits.
  5. Likes Dana liked this post
    The changes you made appear to be correct.
    It isn't uncommon to have Trailer stabilization Enabled in the ABS module. The fact that changes were not needed isn't something I would worry about.
    Start Stop wasn't in any of our NAR 5N Tiguans but I believe it will be disabled when a trailer connection is detected. Do make sure it still works properly when the vehicle is up to temp and driven without a trailer connected.
  7. Likes Uwe liked this post
