Hi !
I need your confirmation about the coding modifications I made during my Trailer Hitch retrofitting on my Tiguan 2013 facelift.
The wirring harness with module is : Brink ref 756693, everything is working fine, no error are stored and the trailer hictch works perfectly.
Is the trailer stabilization well effective as I didn't change ABS module ?
Also, is the start/stop disabled inside module 01-Engine, because I don't see the orange light of the button switching on in my car (which occur if I press this button) ?
I have collected many informations from this thread : http://wiki.ross-tech.com/wiki/index.php/Trailer_Hitch_Retrofitting_(5N)
and also from other threads and I have performed the following changes:
19-CAN Gateway/Installation list/"69-trailer" changed to ticked
01-Engine/Coding/Byte 5/bit 4 changed to ticked
10-Park/Steer Assist/Byte 0/bit 0-1 changed to "trailer hitch installed (manually removable)"
03-ABS Brakes: seen in Adaptation/Channel 56 Trailer stabilization was already set on "Enabled"
(I have also tried to enter security code "61378" without success) I don't know if something need to be changed in this module ?
09-Cent. Elect/Coding/Byte 15/bit 2 was already ticked "rear fog light inactive while trailer attached"
My scan :
Here is the view of the Brink module :
https://i.goopics.net/NKaER.jpg
Thanks a lot for your help on this
My scan :
Sunday,05,August,2018,15:38:12:03297
VCDS Version: 17.8.0.1
VIN: WVGZZZ5NZEW507xxx License Plate:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 4C 52 53 56 61
62 69 72 77
VIN: WVGZZZ5NZEW507xxx Mileage: 133830km-83158miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 E HW: 03L 907 309 AE
Component: R4 2,0L EDC H28 4572
Revision: 41H28--- Serial number: 00000000000000
Coding: 00190032043601080000
ASAM Dataset: EV_ECM20TDI01103L906018E 003008
ROD: EV_ECM20TDI01103L906018E.rod
VCID: 2C5DEBAD4707D62606-8078
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BD HW: 5N0 614 109 BD
Component: J104 C6 450M VD70 0011
Revision: --H07--- Serial number: 00000007112777
Coding: 0038206
VCID: 6ED921A5799BE43668-803A
Part No SW: 5K0 907 044 GJ HW: 5K0 907 044 GJ
Component: Climatronic H19 1313
Revision: 00001004
Coding: 0010004003
VCID: 79F302F9F8D5B38ECD-802C
Part No SW: 5K0 937 086 Q HW: 5K0 937 086 Q
Component: BCM PQ35 M 122 0173
Revision: BC122001
Coding: 40180A3BE8251AC0408800C0340001244B51AA88433181606480C7000041
VCID: 4281A515DD833056DC-8016
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 270513 03 32 0010
Coding: 009F95
Component: RLS 030613 05 54 0403
Coding: 06304D
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261315101344
Coding: 158203
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 448DA30DCF973E66EE-8010
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__20J VW10 HI 2118
Revision: 26019000 Serial number: 003L7PB8FJ5S
Coding: 0012362
VCID: 7CFD1BED3FE786A6D6-8028
Subsystem 1 - Serial number: 6332MTS613291343
Subsystem 2 - Serial number: 6342MTS638721333
Subsystem 3 - Serial number: 6351HTS6OBM51CKJ
Subsystem 4 - Serial number: 6361HTS67PQG0CKR
Part No SW: 5K0 953 501 BH HW: 5K0 953 569 L
Revision: FF010042 Serial number: 20130606100886
Coding: 1182140000
VCID: 71E33AD9A0A5FBCE75-8024
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5N0 920 883 C HW: 5N0 920 883 C
Component: KOMBI H04 0611
Coding: 111F01
VCID: 346DF3CD9F378EE65E-8060
Part No SW: 7N0 907 530 AL HW: 7N0 907 530 AL
Component: J533 Gateway H58 1642
Revision: H58 Serial number: 240513F1002102
Coding: 356002
VCID: 7AF11DF5F5D3B896C4-802E
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
VCID: 4D9B8629D4DDFF2E31-8018
Component: IMMO H04 0611
VCID: 6AD12DB58D73081634-803E
Address 2E: Media Player 3
Part No SW: 5N0 959 701 G HW: 3C0 959 793 C
Component: TUER-SG FT 002 0503
Revision: 12110009 Serial number: 0007037574
Coding: 0210BE
VCID: 3973C2F9B855738E8D-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1504
Serial number: 00000007978246
Coding: 000090
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.286 1202
Revision: 1BH04839 Serial number: 00131480210401
Coding: 0000258
VCID: 3F87ACE16E715DBEB3-806A
Part No SW: 5N0 959 702 G HW: 3C0 959 792 C
Component: TUER-SG BT 002 0503
Revision: 14110009 Serial number: 0007045046
Coding: 0211BE
VCID: 3A71DDF5BD53789684-806E
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1504
Serial number: 00000007950373
Coding: 000090
Revision: H19 Serial number: 00000001083828
Coding: 0026167
VCID: 3669C9C5414B9CF660-8062
Part No SW: 3C8 035 195 F HW: 3C8 035 195 F
Component: RCD510 H04 5018
Revision: -----21S Serial number: VWZ4Z3N1124998
Coding: 0100040004000C
VCID: 2B5FE8B14A09D11E0F-807E
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1642
Coding: 030F1859
VCID: 71E33AD9A8A5FBCE75-8024
Component: J367-BDM H07 0180
Serial number: 30146125531491471996
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 3065FFDD632FB2C63A-8064
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 HW: 5N0 035 729
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007664842614
Coding: 0A01000080010101
ROD: EV_UHVUMI.rod
VCID: 6DDB26A9BC9D1F2E51-8038
End-------------------------(Elapsed Time: 03:25)--------------------------
