Results 1 to 10 of 10
Thread: 2018 Tiguan SEL MK2 North-America Failed Tow Hitch Module Coding Attempt - Need Help.
    Sep 2018
    Leonartown, MD, USA
    Greetings,
    I’m a new Ross-tech user, with limited VW software knowledge. Appreciate any help.
    Moderator please move the post to correct section as needed.
    Car:
    2018 VW Tiguan SEL North America (long wheel base). Car comes with Adaptive Cruse Control (no front camera) and rear collision aid (I think its rear camera based since no acoustic sensors are present).
    Objective:
    Retrofit/Code 5NN-055-203 kit hitch module with 4 pin trailer connector.
    Background:
    I purchased kit 5NN-055-203 from, VW Naples, FL dealer, which comes with a 4 pin tow harness and module #5Q0907383N. In U.S. 4 pin provides basic lights to a trailer (turn signal, stop, back lights).
    The Module 5Q0907383N has 4 ports(A,B,C,D). The largest module, port A, connects to provided trailer harness. Tiguan’s existing harness has 2 connectors, larger (20?) and smaller (10pin). The 5Q0907383N has two 10pin ports (C and D). I connected Tiguans 10pin to port closer to larger connector - C leaving second 10pin port D on the module empty. Installation instructions specify connection of two leaded wire behide the glove box as well which I did. Any verification of installation would be appreciated, the VW instructions are not detailed what to do with port D.
    My first coding attempt failed and I disconnected the module to eliminate all the errors I was getting. The errors were related to front assist not available, rear collision warning not working, stop start not working….). I used battery charger to maintain voltage, cleared OBDII and did not notice Long Code Helper omittance of one of the codes made it more confusing.
    Manual code entry was necessary, Long Helper is missing value for bit 5 of 01. Missing value “66” caused ACC not available/error, Start/Stop Disable, (front assist cleared after drive)
    My coding attempt was based on flowing post: https://forums.ross-tech.com/showthr...North-America)
    The scans:
    Prior to hardware installation:
    Scan-3VV2B7AX3JM002106-20180721-1245-13706km-8516mi
    Saturday,21,July,2018,12:45:31:30494
    VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4411.4
    VIN: 3VV2B7AX3JM002106   License Plate:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 6C 6D
              75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 13706km-8516miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H30 0004
       Revision: 1DH30000
       Coding: 012A00122466010FB4000000000000000000000000000000
       Shop #: WSC 00066 790 00291
       ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
       ROD: EV_ECM20TFS0115NA907115A.rod
       VCID: 3C34CD1FB71CB9A438-8068
    7657 - Secondary Air Injection System Switching Valve Bank 1
              P2440 00 [096] - Stuck Open
                        Mileage: 12632 km
                        Date: 2018.07.10
                        Time: 17:04:03
                        Engine speed: 1289.00 /min
                        Normed load value: 16.1 %
                        Vehicle speed: 7 km/h
                        Coolant temperature: 48 °C
                        Intake air temperature: 39 °C
                        Voltage terminal 30: 14.440 V
                        Unlearning counter according OBD: 21
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
       Part No SW: 09G 927 158 Q    HW: 09G 927 158
       Component: AISIN AQ8     206 3379
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00453
       ROD: EV_TCMAQ450031_VW27.rod
       VCID: 41CABCEBD0FED44C6B-8014
       Revision: 00000000    Serial number: 50987000000137
       Coding: 0BFA6BA454201B6EC5780300A2C949D0D62AD8A3C045927C18415058C28A4200002864121A1C230935351919323200
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 77BE1233CEBA5AFC15-8022
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0434760327
       Coding: 032C0C070F
    14222592 - Databus
              [Message ELV_01 missing]
                        Reset counter: 205
                        Mileage: 1048574 km
                        Time: 00:00:00
                        Terminal_15_Kessy_specified_value: OFF
                        Terminal_15_Kessy_actual_value: OFF
                        Terminal_15_central electric_actual_value: Timeout
                        Terminal_15red_Kessy_specified_value: OFF
                        Terminal_15red_Kessy_actual_value: OFF
                        Terminal_S_Kessy_specified_value: OFF
                        Terminal_S_Kessy_actual_value: OFF
                        Terminal_S_central electric_actual_value: Timeout
                        ZAT_pressed: OFF
                        Enabling immobilizer: Condition not met
                        Control Module Voltage: 12.644 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Actuation to the inside: active
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: closed
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 5NN 907 044 A    HW: 5NN 907 044 A
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000D00004849
       Coding: 0002002420011800100501001211140E
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 4AD89BC7EDC81714BA-801E
       Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
       Component: BCM PQ37BOSCH 034 0243
       Revision: --------    Serial number: C864120417023U
       ROD: EV_BCMCONTI.rod
       VCID: 0C545DDFA73C492448-8058
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 170308  034 0373
       Serial number: 17030521051340
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Serial number: 71808607
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3200008150FF8728749C8145304097
       Shop #: WSC 00066 790 00274
       VCID: 3E30C717A100ABB416-806A
    0836 - Databus
              [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                        Reset counter: 219
                        Mileage: 12775 km
                        Date: 2018.07.15
                        Time: 07:58:36
                        Voltage terminal 15: 13.1 V
                        Control Module temperature: 47 °C
                        Velocity_vehicle_reference: 3.92 m/s
    196741 - Sensor for Automatic Distance Control
              [FCTSEN_BLOCKAGE]
                        Reset counter: 231
                        Mileage: 13670 km
                        Date: 2018.07.21
                        Time: 10:34:55
                        Voltage terminal 15: 12.8 V
                        Control Module temperature: 37 °C
                        Velocity_vehicle_reference: 24.82 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.16 m/s²
    196742 - Sensor for Automatic Distance Control
              [FCTSEN_DEC_BLOCKAGE]
                        Reset counter: 231
                        Mileage: 13672 km
                        Date: 2018.07.21
                        Time: 10:36:34
                        Control Module temperature: 36 °C
                        Velocity_vehicle_reference: 20.37 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.53 m/s²
    196743 - Sensor for Automatic Distance Control
              [FCTSEN_INC_BLOCKAGE]
                        Reset counter: 231
                        Mileage: 13668 km
                        Date: 2018.07.21
                        Time: 10:32:25
                        Velocity_vehicle_reference: 21.65 m/s
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    004 0336
       Serial number: 003NUM057U6/
       Coding: 8CCCFC00000000005000001AC20800000065
       VCID: 054268FB8456386C17-8050
       Occupant Detection:
       Serial number: IBH0000000000073RU0R
       Coding: 303351
       Subsystem 2 - Part No SW: -----------    HW: 480 001 503 17
       Serial number: 357000000000D3191223
       Subsystem 3 - Part No SW: -----------    HW: 480 001 503 17
       Serial number: 358000000003D3191227
       Subsystem 4 - Part No SW: -----------    HW: 480 402 503 17
       Serial number: 3510001A32527B23351L
       Subsystem 5 - Part No SW: -----------    HW: 480 401 901 17
       Serial number: 3520001B922A9B34353/
       Subsystem 6 - Part No SW: -----------    HW: 480 402 103 17
       Serial number: 3550001C724CDB2395AI
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 103 17
       Component: FrontSensor_P  000 6149
       Serial number: 3560001C724CDB2392BH
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 07041708491719
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 075E62F3BE5A2A7C65-8052
       Part No SW: 5NA 920 850 A    HW: 5NA 920 850 A
       Component: KOMBI         361 8311
       Coding: 0BA4001AA788CF0502886B095400000020000000
       VCID: 3D32C01BAC06B0AC0F-8068
       Component: GW MQB High   518 5286
       Serial number: 08051700840113
       Coding: 030500347F085900FB0322581E0F00010001050000000000000000000000
       Shop #: WSC 00066 790 00064
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F2EEA53766A523C8D-807A
       Subsystem 2 - Part No SW: 5NN 959 442 A    HW: 5NN 959 442 A
       Serial number: 0201700020200003BL2B
       Coding: 2C0000
       Serial number: 0475402904
       Serial number: HA1-00003.11.16
       Coding: 0101
       Serial number: 17000075290009
       Coding: 0800000000000000
       Shop #: WSC 00066 790 00440
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71AA2C2BA0DE04CCDB-8024
       Component: HRE_Master    H12 0080
       Serial number: 0431834720
       Coding: 01011103
       ROD: EV_HREntryHella_VW37.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0434370916
       Coding: 010111
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Component: TSG FS        010 0032
       Serial number: 7028702000146
       Coding: 00301B200000028000000000
       VCID: 45C2A8FBC4D6F86C57-8010
       Serial number: 00000000000005973918
       Coding: 011000
       Revision: 00000000    Serial number: 0001620982
       Coding: 01000010004001
       ROD: EV_SteerAssisVWBSMQBA_009.rod
       VCID: 40CCB9EFDBF4DD4464-8014
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Component: TSG BFS       010 0032
       Serial number: 8028712700422
       Coding: 003013200000028000000000
       VCID: 44C4B5FFCFECC16440-8010
       Serial number: 00000000000006065356
       Coding: 091000
       Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
       Component: MU-S-NS-US    840 0755
       Coding: 02730602BE00000051220001001808001F0500C401200105C6
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 3228E32765587FD4E2-8066
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H50 8120
       Serial number: VWZ6ZHT1300503
       Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
       Component: NAR 2017  --- 0525
       Coding: 0123060120002017300040
       VCID: 393AD40BB82E8C8C23-806C
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
       Coding: 0A08
       ROD: EV_DeckLidCONTIAU736_VW27.rod
       Component: OCULowMQBUS   007 0570
       Coding: 02230602C2823A017F1E06020000
       ROD: EV_OCULowMQB.rod
       VCID: 43C6B6E3CAE2C65C79-8016
       Component: SAD_STG_1     013 0005
       Coding: 00804073260C
       ROD: EV_SunRoofCONTIAU736.rod
    End----------(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.3V)-----------
    After Installation and my last attempt to get it to work, after that I disconnected and worked on reverting changes back:
    Scan-3VV2B7AX3JM002106-20180902-1031-15347km-9536mi
    Sunday,02,September,2018,10:31:05:30494
    Workshop Code: 000 03743 000000
    Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 69 6C
              6D 75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 15347km-9536miles
       Revision: 1DH30000
    17156 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 15347 km
                        Date: 2018.09.02
                        Time: 09:39:01
                        Coolant temperature: 29 °C
                        Intake air temperature: 28 °C
                        Voltage terminal 30: 12.820 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
                        Mileage: 12632 km
                        Date: 2018.07.10
                        Time: 17:04:03
                        Unlearning counter according OBD: 25
       Component: VWKESSYMQB    036 VWKESSYMQB    036 08110811
       Coding: 032C0C070F
       Coding: 0002002410011800100501401211140E
    0836 - Databus
                        Reset counter: 26
                        Mileage: 15274 km
                        Date: 2018.08.29
                        Time: 15:43:42
                        Voltage terminal 15: 13.6 V
                        Control Module temperature: 60 °C
                        Velocity_vehicle_reference: 4.86 m/s
                        Longitudinal_acceleration_vehicle_reference: -1.63 m/s²
    1229 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [FAULT_CODING_AAG]
                        Reset counter: 243
                        Mileage: 15347 km
                        Date: 2018.09.02
                        Time: 09:39:02
                        Voltage terminal 15: 12.7 V
                        Control Module temperature: 28 °C
                        Longitudinal_acceleration_vehicle_reference: -0.16 m/s²
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       Coding: 0BA5001AA788CF0502887B095400000020000000
       Coding: 2C0000
    66304 - Databus
              U1124 00 [008] - Additional Installations Detected
              [Mehrverbau CAN]
                        Reset counter: 28
                        Mileage: 15347 km
                        Date: 2018.09.02
                        Time: 09:22:00
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: OFF
       Coding: 0101
       Coding: 01011103
       Coding: 010111
       Coding: 011000
       Coding: 091000
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0447480187
       Coding: 0100000202000000
       VCID: 42C8B3E7D5F8CF5472-8016
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Reset counter: 243
       Coding: 0A08
    End------(Elapsed Time: 15:33, VBatt start/end: 12.3V/12.3V, Deb=2)--------
    Removed Hardware, check 01 bit 5 46 (couse of my frustrations):
    Scan-3VV2B7AX3JM002106-20180903-1224-15416km-9579mi
    Monday,03,September,2018,12:24:27:30494
              75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 15416km-9579miles
       Revision: 1DH30000
       Coding: 012A00122446010FB4000000000000000000000000000000
    17149 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [175] - -
              [Checking coding/versions ofcontrol modules in drivetrain]
                        Mileage: 15356 km
                        Date: 2018.09.03
                        Time: 08:26:05
                        Engine speed: 709.50 /min
                        Normed load value: 2.7 %
                        Coolant temperature: 99 °C
                        Intake air temperature: 62 °C
                        Voltage terminal 30: 13.240 V
                        ACC variants-Bits 0-7: 2
                        CCS Switch-Bits 0-7: 2
                        Cruise control switch actuation-Bits 0-7: 32
                        Cruise control switch actuation-Bits 0-7: 1
                        ACC variants (coding)-Bits 0-7: 2
    Readiness: 0000 1100
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [009] - -
                        Reset counter: 244
                        Mileage: 15356 km
                        Date: 2018.09.03
                        Time: 08:47:57
       Coding: 032C0C070F
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 244
                        Mileage: 15356 km
                        Date: 2018.09.03
                        Time: 08:47:27
                        Voltage terminal 15: 12.3 V
                        Control Module temperature: 88 °C
                        Status_ACC_System: ACC_irreversible error
    2119 - Databus
              U1122 00 [009] - Implausible Message
              [FAULT_TSK_ACC_CODING_PLAUS_FAIL]
                        Reset counter: 244
                        Mileage: 15356 km
                        Date: 2018.09.03
                        Time: 08:47:27
                        Longitudinal_acceleration_vehicle_reference: -0.19 m/s²
    196698 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [008] -  -
              [ALN_EAL_MAX_PWR_LOW_NEAR]
                        Reset counter: 28
                        Mileage: 15356 km
                        Date: 2018.09.03
                        Time: 08:47:27
    196835 - Internal Fault
              B200F F0 [008] - Unknown Error Elaboration
              [FCTSEN_BELOW_MIN_PERF_DIST_AZ]
                        Reset counter: 28
                        Mileage: 15356 km
                        Date: 2018.09.03
                        Time: 08:47:27
                        Control Module temperature: 89 °C
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       Coding: 2C0000
       Coding: 0101
       Coding: 01011103
       Coding: 010111
       Coding: 011000
       Coding: 091000
       Coding: 0A08
    End----------(Elapsed Time: 01:44, VBatt start/end: 12.4V/12.4V)-----------
    After I figured out that Long Code Helper was missing a bit, and this is my configuration now. (I have not been able to verify ACC function - if it tracks traffic in front):
    Scan-3VV2B7AX3JM002106-20180903-1247-15416km-9579mi
    Monday,03,September,2018,12:47:47:30494
              75 CA
       Revision: 1DH30000
    Readiness: 1110 1101
       Coding: 032C0C070F
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       Coding: 2C0000
       Coding: 0101
       Coding: 01011103
       Coding: 010111
       Coding: 011000
       Coding: 091000
       Coding: 0A08
    End----------(Elapsed Time: 01:43, VBatt start/end: 12.6V/12.5V)-----------
    Thanks!
    Tom
    Oct 2017
    Northwest UK
    Hi Tom
    You post is very confusing. What is the current status?
    Are you retrofitting according to a VW provided guide? Module 5Q0907383N is for trailer recognition. A Passat module also has abcd so yours is not unique. If you follow a standard VW wiring guide then it will also specify coding via ODIS and will not specific the coding or adaptations that are required to make this work.
    It appears your have a V2 cable which would specific on the error codes which databus is producing an error on the CAN network which makes it a heck of a lot easier in guiding adaptations. If you need help with the coding then I would recommend you make a scan before making any changes, connect it all back up and post a scan with your faults. Please explain what you've done so far so we can look and guide you on what the error codes means.
    Hope this helps
  3. Likes Uwe liked this post
    Sep 2018
    Leonartown, MD, USA
    myounus,
    You are right original post is confusing. Sorry about that.
    This is clear version:
    Scan without module connected:
    Tuesday,04,September,2018,15:57:14:30494
              75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 15487km-9623miles
       Revision: 1DH30000
    Readiness: 0000 0100
       Coding: 032C0C070F
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       Coding: 2C0000
       Coding: 0101
       Coding: 01011103
       Coding: 010111
       Coding: 011000
       Coding: 091000
       Coding: 0A08
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.3V)-----------
    Scan with module connected as per original post, with errors, no cods were modified.
    Tuesday,04,September,2018,16:02:30:30494
              6D 75 CA
    69-Trailer -- Status: Not registered 0011
       Revision: 1DH30000
    17156 - Databus
                        Mileage: 15487 km
                        Date: 2018.09.04
                        Time: 16:00:25
                        Coolant temperature: 80 °C
                        Intake air temperature: 73 °C
                        Voltage terminal 30: 12.280 V
       Coding: 032C0C070F
              U1014 00 [009] - -
              [FAULT_CODING_AAG]
                        Reset counter: 247
                        Mileage: 15487 km
                        Date: 2018.09.04
                        Time: 16:00:25
                        Voltage terminal 15: 12.2 V
                        Control Module temperature: 55 °C
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       Coding: 2C0000
    66304 - Databus
              U1124 00 [009] - Additional Installations Detected
              [Mehrverbau CAN]
                        Reset counter: 247
                        Mileage: 15487 km
                        Date: 2018.09.04
                        Time: 15:57:00
                        Supply voltage: Terminal 30: 12.4 V
                        Terminal 15: OFF
       Coding: 0101
       Coding: 01011103
       Coding: 010111
       Coding: 011000
       Coding: 091000
       Shop #: WSC 03743 123 12345
                        Reset counter: 243
                        Mileage: 15350 km
                        Date: 2018.09.02
                        Time: 16:56:17
    342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
              U0011 00 [008] - Performance
              [Convenience data bus - no signal/communication]
                        Reset counter: 32
       Coding: 0A08
    End----------(Elapsed Time: 01:57, VBatt start/end: 12.3V/12.3V)-----------
    Suggested coding as for original trailer.
    Use battery charger.
    Disable start/stop with button (if installed - placed at gearshift or middle of instrument)
    Change WSC etc. to none zero in VCDS, see here.
    [19-CAN Gateway] > [Installation list] > [69] > [Save coding], explanation here.
    Explanation
    [Controller number] > New coding
    [01] > 012A00122476010FB4000000000000000000000000000000
    [13] > 3200008950FF8728749C8145304097 (Secure access first)
    [3C] > 01012103
    [69] > 0200000202000000
    [6C] > 0123060121002017300040
    [6D] > 0A88
  6. Likes Uwe, tomekd77 liked this post
    Sep 2018
    Leonartown, MD, USA
    Thanks, looks 69 needs some work.
    Explanation
    [3C] > 01012103
    [6D] > 0A88
    Thanks NEtech
    Changes per your suggestion, much better, looks like 69 needs some tweaking. I tried 0100000202000000 and 0200000202000000 with the same error code showing.
    Wednesday,05,September,2018,18:53:49:30494
              6D 75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 15506km-9634miles
       Revision: 1DH30000
       Coding: 012A00122476010FB4000000000000000000000000000000
       Coding: 032C0C070F
       Coding: 3200008950FF8728749C8145304097
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       Coding: 2C0000
       Coding: 0101
       Coding: 01012103
       Coding: 010121
       Coding: 011000
       Coding: 091000
       Coding: 0200000202000000
       Shop #: WSC 03099 444 12345
                        Reset counter: 248
                        Mileage: 15506 km
                        Date: 2018.09.05
                        Time: 18:51:20
       Coding: 0123060121002017300040
       Coding: 0A88
    End----------(Elapsed Time: 01:46, VBatt start/end: 12.6V/12.6V)-----------
    Tom
    Sep 2018
    Leonartown, MD, USA
    The error P1757 Open Circuit and supply voltage 136203 implies no power to the module, but that is not the case since the module accepts coding, right?
    Or is this error referring to a voltage that's should present so it can be switched by the trailer module 5Q0907383N to trailer when connected?
    Do I have an issue how other modules are affected by addition of 5Q0907383N or the issue is within 5Q0907383N?
    The tow kit module came with a activation codes, would that be helpful?
    My initial attempt did not get me far so I rather avoid random code flipping.
    Any suggestions would be appreciated, thanks in advance.
    Tom
    Sep 2018
    Explanation
    [3C] > 01012103
    [6D] > 0A88
    Everything above except 69 with 0200000200000000 does the trick. I have no errors. Was stumped for quite sometime on this. Thanks Netech.
  10. Likes Uwe, jyoung8607 liked this post
  11. #8
    Sep 2018
    Leonartown, MD, USA
    Here are my scans without errors.
    I left 69 set at 0200000200000000 but 0200000000000000 returns without errors as well.
    Both these bits are referring to bus power and pin 9 and pin 10 respectively in long code helper, does anyone know what that refers to?
    Friday,07,September,2018,10:33:08:30494
              6D 75 CA
    VIN: 3VV2B7AX3JM002106   Mileage: 15525km-9646miles
       Revision: 1DH30000
    Readiness: 0000 0001
       Coding: 032C0C070F
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       Coding: 2C0000
       Coding: 0101
       Coding: 01012103
       Coding: 010121
       Coding: 011000
       Coding: 091000
       Coding: 0200000200000000
       Coding: 0A88
    End----------(Elapsed Time: 01:46, VBatt start/end: 12.5V/12.5V)-----------
    69 set at 0200000000000000
    Friday,07,September,2018,10:10:07:30494
              6D 75 CA
       Revision: 1DH30000
       Coding: 032C0C070F
       Occupant Detection:
       Coding: 303351
       Coding: 0410
       Coding: 2C0000
       Coding: 0101
       Coding: 01012103
       Coding: 010121
       Coding: 011000
       Coding: 091000
       Coding: 0200000000000000
       Coding: 0A88
    End----------(Elapsed Time: 01:46, VBatt start/end: 12.6V/12.5V)-----------
    Thanks!
    Tom
  12. Likes jyoung8607 liked this post
  13. #9
    Aug 2019
    Canada
    Not to bring up an old thread but I just installed the OEM wiring. I managed to activate everything with a few tweaks the actual wiring seems to be working. My 360 Area view seems to have stopped working, and I have a few other errors Still that I can't seem to figure out. Errors are under the following modules. 10 Park steer assist, 13 Auto dist Reg, 44 Steering Assist, 4b mutifuction, 5f information electr, 69 trailer, 6c backup cam, a5 frt sens drive assist. I followed the coding above to a t but i'm wondering if I have more options on my vehicle which is causing the erros.
  14. #10
    Jul 2020
    @VolksTrooper did you ever get yours figured out? I am having an issue with A5 that I can’t seem to figure out.
    Here is my thread, https://forums.ross-tech.com/showthr...th-America-USA
    Don’t mean to thread jack.
