Results 1 to 6 of 6
Thread: How to lower airsuspension on 2017 Q7
    New User
    Sep 2018
    Norway
    Hi
    Someone told me that its possible to lower the air suspension on Q7 using VCDS?
    I have the standard air suspension and would like a more aggressive look like the sport suspension which is 15mm lower I think?
    I hope someone can help me
    We'll need to see an Auto-Scan from your Q7 to be able to help you.
  3. Likes Sacha35, iichel, Uwe liked this post
    New User
    Sep 2018
    Norway
    A lot if fault codes here. Not one errormessage in car mmi display. Bought the car 1 week ago so I would need to talk to the seller.
    Friday,07,September,2018,20:23:18:28780
    VCDS Version: 18.2.1.5 (x64)
    VIN: WAUZZZ4M3HD028651   License Plate: MAGNUS
    Mileage: 27655km-17184mi   Repair Order:
    Chassis Type  4M-AU73 (8W7)
    Scan: 01 02 03 06 08 09 13 15 16 17 18 19 23 2B 36 3C 42 44 46 47
              51 52 5F 69 6C 6D 74 81 8B 8C A5 AC BA BB BC C5 C6 CA CF
    VIN: WAUZZZ4M3HD028651   Mileage: 27655km-17184miles
    23-Brake Booster -- Status: Malfunction 0010
    46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
    74-Chassis Control -- Status: INTERFACE NOT COMPATIBLE
    C5-Therm. mgt. -- Status: Malfunction 0010
    C6-Batt. Chrg. -- Status: Malfunction 0010
    CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CVZA)       Labels: Redir Fail!
       Part No SW: 4M0 907 401 A    HW: 059 907 309 F
       Component: 3.0TDI MD1    H23 0008
       Revision: C7H23---
       Coding: 2A2A403A057E050335382B00000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114M0907401A 001016
       ROD: EV_ECM30TDI0114M0907401A.rod
       VCID: 275784455E9D787C45-8072
       Active accelerator pedal:
       Subsystem 1 - Part No SW: 4M1 723 523     HW: 4M1 723 523
       Component: J1115 - FFP  H17 0007
       Serial number: 123456789ABCDEFGHIJK
       Clutch Control Unit Sub:
       Subsystem 2 - Part No SW: 0D7 142 057 D    HW: 0D7 142 057 D
       Component: J1128 CCU  H04 0031
    17158 - Databus
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:19
                        Engine speed: 1782.50 /min
                        Vehicle speed: 68 km/h
                        Coolant temperature: 93 C
                        Intake air temperature: 22 C
                        Voltage terminal 30: 13.200 V
                        Unlearning counter according OBD: 33
                        Engine status: COENG_RUNNING
    23467 - Brake Booster Control Module
              U103F 00 [032] - Implausible signal
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
                        Coolant temperature: 92 C
                        Intake air temperature: 23 C
                        Voltage terminal 30: 12.740 V
                        Com st X Set1 Val1-Bits 0-7: 0
                        Com st X Set1 Val2-Bits 0-7: 0
                        Com st X Set1 Val3-Bits 0-7: 0
                        Com st X Set1 Val4-Bits 0-7: 0
                        Com st X Set1 Val5-Bits 0-7: 0
                        Com st X Set1 Val6-Bits 0-7: 0
                        Com st X Set1 Val7-Bits 0-7: 0
                        Com st X Set1 Val7-Bits 0-7: 193
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 4M0 927 158 M    HW: 0D7 927 156 B
       Component: 0D7 30TDIRdW  H03 1009
       Revision: --H03---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002011
       ROD: EV_TCMALX52011.rod
       VCID: 3E794121A107D9B416-806A
       Automatic Transmission Fluid Pump:
       Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
       Component:     V552 ATFP  D.4 0000
       Serial number:             00001057
    Address 03: ABS Brakes (J104)       Labels:. 4M0-907-379-PRE-V1.clb
       Part No SW: 4M0 907 379 P    HW: 4M0 907 379 P
       Component: ESP9 Premium  H09 0649
       Coding: 2C9830B232A40A9ED1A41896187E52AAF6A6DA340C4C508B18184A556F655B
       Shop #: WSC 36596 001 1048576
       ASAM Dataset: EV_ESP9BOSCHAU536P 011013
       ROD: EV_ESP9BOSCHAU536P.rod
       VCID: 448D33C9CFEBB36440-8010
    12891401 - Unknown Error Code
              U04B5 00 [032] - -
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
    12891402 - Unknown Error Code
              U04B5 00 [032] - -
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
    4560900 - Unknown Error Code
              C0598 00 [032] -  -
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:20
    4560898 - Unknown Error Code
              C0598 00 [032] -  -
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
    4560902 - Unknown Error Code
              C0598 00 [032] -  -
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
    4560896 - Unknown Error Code
              C0598 00 [032] -  -
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
    Address 06: Seat Mem. Pass (J521)       Labels:* None
       Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
       Component: MEM-BFS       008 0031
       Serial number: 00000226565779
       Coding: 001010000000B0410000010101010000110000313100000000000000000000
       ROD: EV_SCMPasseSideCONTIAU736.rod
       VCID: 3B7F4835B215CC9C31-806E
       Part No SW: 4M0 820 043 AD    HW: 4M0 820 043 AD
       Component: Klima Zone 3  H52 0093
       Coding: 661A48094548400D02220280820000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 67D7C4459E1DB87C85-8032
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000001127749
       Serial number: B798855800PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
       Component: Klima Heck  H40 0073
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0266
       Coding: 07501943C13900CD4501571958BF88F9130331009000000000000000E00016810A4502AB32B71A
       ASAM Dataset: EV_BCM1BOSCHAU736 018006
       ROD: EV_BCM1BOSCHAU736_018_AU49.rod
       VCID: 0201F5D1957F7D5432-8056
       Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
       Component: WWS536 160911  043 0893
       Serial number: 89555300401625500689
       Coding: 1BC7F7
       Serial number: 62404927
       Coding: 0200FF
       Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
       Component: E1 - LDS  H06 0008
       Serial number: 30 06 2016  00524385
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE101081611521135
       Coding: 030000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: Q00215340
       Subsystem 6 - Part No SW: 4M0 925 301 H    HW: 4M0 925 301 H
       Component: SL-Q7NF/AU736  H10 0013
       Serial number: 00000000000000004794
    15 Faults Found:
    65914 - Databus
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:37
                        average_Voltage_terminals: 14.20 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 27.50 C
                        interior_temperature: 31.00 C
                        Vehicle speed: 0.00 km/h
                        Terminal control-Terminal 75 status: On
                        Terminal control-Terminal 15 status signal: On
                        Terminal control-Terminal 15 via CAN: On
                        Terminal control-Term 75: qualification: OFF
    65915 - Databus
                        Fault Frequency: 7
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.03
                        Time: 11:39:38
                        average_Voltage_terminals: 14.80 V
                        interior_temperature: 28.00 C
                        Vehicle speed: 1.78 km/h
    65942 - Control Module for Wiper Motor(s)
              U113C 00 [008] - Impausible Message
                        Reset counter: 226
                        Mileage: 26623 km
                        Date: 2018.08.13
                        Time: 08:40:37
                        average_Voltage_terminals: 11.70 V
                        Outside air temperature sensor-Outside air temperature on CAN: 16.00 C
                        interior_temperature: 18.00 C
                        Terminal control-Terminal 75 status: OFF
                        Terminal control-Terminal 15 status signal: OFF
                        Terminal control-Terminal 15 via CAN: OFF
    66069 - Sensor for Rain and Light Detection
              U113B 00 [008] - Impausible Message
                        Reset counter: 226
                        Mileage: 26623 km
                        Date: 2018.08.13
                        Time: 09:53:06
                        Outside air temperature sensor-Outside air temperature on CAN: 17.50 C
                        interior_temperature: 17.50 C
                        Terminal control-Terminal 75 status: Not available
                        Terminal control-Terminal 15 via CAN: Not available
    66937 - Unknown Error Code
              B1366 F0 [008] - Unknown Error Elaboration
                        Reset counter: 226
                        Mileage: 26623 km
                        Date: 2018.08.13
                        Time: 08:45:06
                        average_Voltage_terminals: 11.80 V
    66949 - Databus
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:39
    66950 - Databus
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:39
    66961 - Databus
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:39
    66962 - Databus
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:39
    196720 - Front Parking Aid Sensor(s)
              B10FC 13 [008] - Open Circuit
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:32
                        average_Voltage_terminals: 12.40 V
    196758 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:19
                        average_Voltage_terminals: 13.30 V
                        Outside air temperature sensor-Outside air temperature on CAN: 19.00 C
                        interior_temperature: 24.50 C
                        Vehicle speed: 68.71 km/h
    196898 - Databus
                        Fault Frequency: 15
                        Reset counter: 238
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:33
                        average_Voltage_terminals: 13.40 V
    327698 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:19
                        average_Voltage_terminals: 13.20 V
                        Vehicle speed: 68.72 km/h
    327712 - Databus
                        Fault Frequency: 10
                        Reset counter: 238
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:33
    66340 - No Communications with Rain/Light Sensor
              U10F6 00 [008] - -
                        Reset counter: 226
                        Mileage: 26623 km
                        Date: 2018.08.13
                        Time: 08:40:37
       Part No SW: 4M0 907 561 D    HW: 4M0 907 561
       Component: LRR4          H10 0220
       Coding: 5477FFFB58FFEC0A949C80E0
       ASAM Dataset: EV_ACCBOSCHAU736 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 31636A1D605936CC9B-8064
    9 Faults Found:
    2172 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.07
                        Time: 15:47:13
                        Control Module temperature: 28 C
                        Voltage terminal 15: 12.0 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s
    2101 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
                        Control Module temperature: 33 C
                        Voltage terminal 15: 12.8 V
                        Velocity_vehicle_reference: 19.09 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.17 m/s
                        Status_ACC_System: ACC_activ_controlled
    2153 - Databus
                        Reset counter: 238
                        Mileage: 26608 km
                        Date: 2018.08.07
                        Time: 15:47:13
    2115 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
    1134 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.07
                        Time: 15:47:13
    1135 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.07
                        Time: 15:47:13
    1136 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.07
                        Time: 15:47:13
    1137 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.07
                        Time: 15:47:13
    2068 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:19
                        Voltage terminal 15: 13.1 V
                        Velocity_vehicle_reference: 19.23 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.07 m/s
       Part No SW: 4M0 959 655     HW: 4M0 959 655
       Component: Airbag10.44   H70 0086
       Serial number: 003L10031H8B
       Coding: AAFCF0C00CA0000098F600F3C04C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 78F59739C3A327841C-802C
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 4M0857705D0301Q01588
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 4M0857706J0301Q01213
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 061 510 16
       Component: SideSensor_Df  1E2 0887
       Serial number: 3577Y00A51FFD1113293
       Subsystem 4 - Part No SW: -----------    HW: 442 061 510 16
       Component: SideSensor_Pf  1E2 0887
       Serial number: 3587Y00A31FD753221E4
       Subsystem 5 - Part No SW: -----------    HW: 442 0B0 310 16
       Component: SideSensor_Dr  1C7 0148
       Serial number: 3517700BB21590A1430.
       Subsystem 6 - Part No SW: -----------    HW: 442 0B0 310 16
       Component: SideSensor_Pr  1C7 0148
       Serial number: 3527700AF2235620A30$
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 109 16
       Component: FrontSensor_D  1C5 014A
       Serial number: 3557500C321ADC71E34L
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C2 109 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500C321ADC70B2BO
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C2 109 16
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A121F10C161C-
       Subsystem 10 - Part No SW: -----------    HW: 442 420 809 16
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00B71FB75F3F0B7
       Subsystem 11 - Part No SW: -----------    HW: 442 420 809 16
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00991FFD130634T
       Central Sensor XY:
       Subsystem 12 - Part No SW: -----------    HW: 410 203 110 16
       Component: CentrSensorXY  1C8 0108
       Serial number: I0O78009D21A82B4611$
    1060613 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:18
    1060614 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:18
    1060615 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:18
    1060617 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:18
       Part No SW: 4M0 907 129 JE    HW: 4M0 907 129 JE
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 7CFD8B29F79B0BA478-8028
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 4M0 920 794 B    HW: 4M0 920 794 B
       Component: FHybRDW       H15 0302
       Coding: 040401D07C9800080BA669703204600000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       ROD: EV_DashBoardAU736_AU49.rod
       VCID: 32616511655F0DD4E2-8066
    16777046 - Charger for HV Battery
              U1139 00 [008] - No Communications
                        Fault Frequency: 9
                        Reset counter: 245
                        Mileage: 26623 km
                        Date: 2018.08.15
                        Time: 15:13:35
    16776982 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.03
                        Time: 11:39:35
    16777089 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:31
    Address 18: Aux. Heat (J364)       Labels:* None
       Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
       Component: HSG           H10 0080
       Coding: 0D0803
       ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
       ROD: EV_AuxilParkHeateEBEAU736.rod
       VCID: 2953827D48894E0C53-807C
       Part No SW: 8W7 907 468 D    HW: 8W7 907 468 C
       Component: Gateway       H30 0309
       Revision: 5C000001    Serial number: 0185C285716A26
       Coding: 02010101000206C08C82010000590032DC520007180000000175079E10000000
       ASAM Dataset: EV_CGateCONTIAU491 002040
       ROD: EV_CGateCONTIAU491_002_AU49.rod
       VCID: 4C9D1BE9E7BB7B2488-8018
       Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
       Component: J453 MFL  H06 0002
       Serial number: 20161025030053 00411
       Serial number: 2222561904
    131662 - Lane change assistant control module
              U1045 00 [008] - No communication
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:43:14
    131670 - Automatic distance regulation 2
              U1071 00 [008] - No communication
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:36
    131671 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [008] - -
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:36
    131722 - Control Module 2 for Lane Change Assistance
              U10A5 00 [008] - No Communications
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:43:14
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 4M0 909 059 C    HW: 4M0 909 059
       Component: J539 EBKV H11 0194
       Serial number:   085430010692
       ASAM Dataset: EV_BrakeBoostBOSCHAU736 001001
       ROD: EV_BrakeBoostBOSCHAU736.rod
       VCID: 346D63099F4B03E4F0-8060
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 4M0 909 057 A    HW: 4M0 909 057
       Component: VX70BrakeAssi  H04 0153
       Serial number: 05802861260916081834
    208896 - FlexRay Databus Defective
              U0080 00 [096] - -
                        Mileage: 27477 km
                        Date: 2018.09.04
                        Time: 12:34:14
    216064 - Brake Pedal Position Sensor 1/2
              P05E0 00 [032] - Correlation
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:17
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 16000250107011
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       Component: MEM-FS        008 0031
       Serial number: 00000226565538
       Coding: 00181B000000B0410000010101010000110000313100000000000000000000
       ROD: EV_SCMDriveSideCONTIAU736.rod
       Part No SW: 4M0 907 566 B    HW: 4M0 907 566
       Component: MRR1Rear      H13 0230
       Revision: --------
       Coding: 1EC002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
    1192210 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:19
                        Control Module temperature: 38 C
                        Voltage terminal 30: 13.20 V
                        Vehicle speed: 49.18 km/h
                        Terminal 15 status: OFF
                        Voltage terminal 15: Measured value not available
       Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
       Component: TSG FS        009 0055
       Serial number: 0000224201871
       Coding: 005D9A015E000080000130B2
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       VCID: 40853FD9DBF3AF4464-8014
    524420 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.03
                        Time: 11:39:40
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H20 0005
       Serial number: 0000387818
       Coding: B0150101010001
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
    3149825 - Databus
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:31
                        FreezeFrame_mw_120C_Timeout-Engine speed: 0 /min
                        FreezeFrame_mw_120C_Timeout-System status: Reset
                        FreezeFrame_mw_120C_Timeout-Supply voltage: Terminal 30: 11.75 V
                        FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
                        FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
                        FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
                        FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: On
                        FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: 459.45
                        FreezeFrame_mw_120C_Timeout-ARA signal red cyclic: 00
                        FreezeFrame_mw_120C_Timeout-PLA signal red cyclic: 00
                        FreezeFrame_mw_120C_Timeout-SCU state: System OK
                        FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
    3148801 - Databus
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:31
                        FreezeFrame_mw_120C_Timeout-Supply voltage: Terminal 30: 11.76 V
    Address 46: Central Conv.
    Interface not compatible.
       Part No SW: 4M0 035 223 C    HW: 4M0 035 223
       Component: MIB2_amp_PD   H03 0440
       Serial number: 00000000000591
       Coding: 0135960B008AF53AAF0000010001
       ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
       ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
       VCID: 234F90552AA5945C19-8076
       Part No SW: 4M1 907 080 B    HW: 4M1 907 080 B
       Component: A73P7828S1000 H02 0018
       Revision: --H02---
       Coding: 01000000000000000000
       ASAM Dataset: EV_DMCM08530214M1907080B 001002
       ROD: EV_DMCM08530214M2907080.rod
       VCID: 2C5D7B69477B5B24A8-8078
       Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
       Component: TSG BFS       009 0055
       Serial number: 0000224890618
       Coding: 005D9A015E000080000130B0
       ROD: EV_DCU2PasseSideMAXHCONT.rod
       VCID: 3F873C25A60DD0BC1D-806A
    524420 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.03
                        Time: 11:39:40
       Part No SW: 4M1 035 036     HW: 4M1 035 036
       Component: MU-P-LN-EU    033 0917
       Serial number: A805K0GB001145
       Coding: 013796010000000053110002000A00332F001DE5017001009E
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 63CFD0556A25D45C59-8036
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Subsystem 2 - Part No SW: 4M1 919 605     HW: 4M1 919 605
       Component: AU536_DU_HIGH  H44 0008
       Serial number: AUZ8Z9GJM007BD
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
       Component: ControlUnit_P  H15 0209
       Serial number: 27101600000000000446
       Component: Gracenote2  --- 1015
    7173 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:56
                        Voltage terminal 30: 14.2 V
                        BAP-BAP_Function_ID: 02
    7194 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.06
                        Time: 07:25:25
                        Voltage terminal 30: 14.9 V
    7205 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 235
                        Mileage: 26623 km
                        Date: 2018.08.15
                        Time: 15:13:35
                        Voltage terminal 30: 15.1 V
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H20 0214
       Revision: 9A001003    Serial number: 0420863037
       Coding: 0110000202010000
       VCID: 336F60159A4504DCE9-8066
       Trailer Articulation Angle Sensor:
       Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
       Component: G820 KNWINSEN  H18 0019
       Serial number: 35022
       Part No SW: 4M0 907 428 E    HW: 4M0 907 428
       Component: Areaview 2    H13 0315
       Serial number: C854607JG005175
       Coding: 02350601BF0FA10008404500
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
       ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
    9598995 - Video Signal Line for Front Surroundings Camera
              B1278 01 [008] - Electrical Failure
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:37
    13706029 - Voltage Supply for Camera; Front
              B1862 01 [008] - Electrical Failure
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:30
       Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: 31022578700000
       Coding: 00F0
       ROD: EV_DeckLidCONTIAU736_VW27.rod
    Address 74: Chassis Control
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M1 713 041 F    HW: 4M1 713 041 F
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20161020001950
       ASAM Dataset: EV_GSMWaehlZFAU736 001016
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 28558779538377044C-807C
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 4M0 907 541 D    HW: 4M0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU736 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
       VCID: 2F676C65766D203C8D-807A
    Address 8C: Hybrid Battery
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
       Component: BVS           H14 0042
       Coding: 040703060000040202202387CD0000B4B0F0C020E280
       ROD: EV_BVSMLBevKOSTAAU736.rod
    1122561 - Databus
                        Fault Frequency: 11
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:31
                        Control Module temperature: 32 C
                        Voltage terminal 15: 11.50 V
    1122656 - Databus
                        Fault Frequency: 12
                        Mileage: 26608 km
                        Date: 2018.08.03
                        Time: 11:39:33
                        Control Module temperature: 30 C
                        Voltage terminal 15: 11.10 V
    1123714 - Databus
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:38
                        Voltage terminal 15: 14.30 V
    1123173 - Databus
                        Reset counter: 238
                        Mileage: 27424 km
                        Date: 2018.09.03
                        Time: 20:52:19
                        Voltage terminal 15: 13.30 V
    1123735 - Databus
                        Fault Frequency: 6
                        Reset counter: 226
                        Mileage: 26608 km
                        Date: 2018.08.02
                        Time: 15:22:34
                        Voltage terminal 15: 13.50 V
    1123600 - predictive route data
              B1630 02 [008] - Signal Failure
                        Reset counter: 240
                        Mileage: 27546 km
                        Date: 2018.09.05
                        Time: 11:34:16
                        Control Module temperature: 35 C
                        Voltage terminal 15: 12.10 V
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H04 0005
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736.rod
       VCID: 30656F196B533FC494-8064
    Address BA: Motor Mounts (J931)       Labels: None
       Part No SW: 4M0 907 145 D    HW: 4M0 907 145 B
       Component: AEMevo        H09 0111
       ASAM Dataset: EV_AEMZFAU736 006012
       ROD: EV_AEMZFAU736_006_AU73.rod
       Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
       Component: TSG HFS       009 0055
       Serial number: 0000226381029
       Coding: 004D980000000080000030A0
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       VCID: 428135D1D5FFBD5472-8016
       Component: TSG HBFS      009 0055
       Serial number: 0000226358179
       ROD: EV_DCU2RearPasseMAXHCONT.rod
    Address C5: Therm. mgt. (J1024)       Labels:* None
       Part No SW: 4M0 965 429 D    HW: 4M0 965 429 B
       Component: TME-Max       H04 0021
       Serial number: 0027434
       Coding: 01
       ASAM Dataset: EV_ThermContrVISAU49X 001023
       ROD: EV_ThermContrVISAU49X_VW37.rod
       VCID: 387557398323E784DC-806C
       Subsystem 1 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
       Component: G395 pT-Sens1  H10 0009
       Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
       Component: J848 HV-PTC  H09 0208
       Serial number: LM163023003810000310
       Subsystem 3 - Part No SW: 4M0 816 797 A    HW: 4M0 816 797 A
       Component: J842 EKK es33  H02 0012
       Serial number: 00000000016102600214
       Refrigerant Pressure And Temperature Sender 2:
       Subsystem 4 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
       Component: G826 pT-Sens2  H10 0009
       Refrigerant Pressure And Temperature Sender 3:
       Subsystem 5 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
       Component: G827 pT-Sens3  H10 0009
       Refrigerant Expansion Valve 1:
       Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
       Component: N636 EV1_KaMi  H12 0102
       Serial number: 00000000000150148272
       Refrigerant Shut Off Valve 2:
       Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
       Component: N640 AV2_KaMi  H12 0102
       Serial number: 00000000000130149739
       Refrigerant Shut Off Valve 3:
       Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
       Component: N641 AV3_KaMi  H12 0102
       Serial number: 00000000000130149732
       Refrigerant Shut Off Valve 4:
       Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
       Component: N642 AV4_KaMi  H12 0102
       Serial number: 00000000000130149532
       Refrigerant Shut Off Valve 5:
       Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
       Component: N643 AV5_KaMi  H12 0102
       Serial number: 00000000000130149508
    37116 - Implausible Data Received from Battery Energy Control Module 2
              U0413 00 [040] - -
                        Mileage: 27433 km
                        Date: 2018.09.04
                        Time: 07:43:52
                        Expanded ambient data 1-Voltage terminal 30: 0.000 V
                        Expanded ambient data 1-Vehicle speed: 0 km/h
                        Expanded ambient data 1-System status: Control operation: ignition on
                        Expanded ambient data 1-Power quota setting by energy management: 00
                        Expanded ambient data 1-Status of drive readiness hybrid: Engine start
                        Expanded ambient data 1-Ambient temperature: 14.50 C
                        Expanded ambient data 1-current state of low temp.circ.: 00
                        Expanded ambient data 1-previous state low-temp.circ.: 00
                        Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
                        Expanded ambient data 1-current state of high-temp.circ.: 00
                        Expanded ambient data 1-previous state of high-temp.circ.: 00
                        Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
                        Expanded ambient data 1-current state of battery low temp.circ.: 00
                        Expanded ambient data 1-previous state of battery low temp.circ.: 00
                        Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 01
                        Expanded ambient data 1-current state of battery cold circuit: 00
                        Expanded ambient data 1-previous state of battery cold circuit: 00
                        Expanded ambient data 1-Operating time in the current state of the cold circuit: 01
    37134 - Implausible Data Received from Battery Energy Control Module 2
              U0413 00 [040] - -
                        Mileage: 27433 km
                        Date: 2018.09.04
                        Time: 07:43:52
    60016 - Unknown Error Code
              P13F1 00 [047] - -
                        Fault Frequency: 146
                        Mileage: 26608 km
                        Date: 2018.08.08
                        Time: 10:13:22
                        Expanded ambient data 1-Power quota setting by energy management: 15
                        Expanded ambient data 1-Ambient temperature: 27.00 C
                        Expanded ambient data 1-current state of battery low temp.circ.: 07
                        Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 21
                        Expanded ambient data 1-Operating time in the current state of the cold circuit: 23
    Address C6: Batt. Chrg. (AX4)       Labels:* 5QE-915-681.clb
       Part No SW: 5QE 915 681 G    HW: 5QE 915 681 G
       Component: OBC Delta-ES  H55 0721
       Coding: 11508B207004
       ASAM Dataset: EV_OBCTwoPhaseDT2AU736 006011
       ROD: EV_OBCTwoPhaseDT2AU736_006_AU73.rod
       VCID: 50A50F990B935FC4F4-8004
    13705528 - Databus
                        Reset counter: 226
                        Mileage: 26623 km
                        Date: 2018.08.13
                        Time: 08:23:37
    Address CA: Sunroof
    Address CF: Lane Chge Asst 2
    End-------------------------(Elapsed Time: 07:53)--------------------------
    Gateway Installation List:  8W7 907 468 D
    Quote Originally Posted by audinorway View Post
    LOTS of Fault Frequency 1 faults, try learning all fault codes and see which, if any, come back.
    New User
    Sep 2018
    Norway
    What does fault frequency 1 faults mean?
    Should I do a new scan - delete - scan?
    Fault Frequency 1 means the fault has only been seen 1 time, so it MIGHT just a glitch or a battery change or ...
    What you should do is clear ALL the faults in ALL the modules (try the clear all feature [Auto-Scan] then [Clear all DTCs], see http://www.ross-tech.com/vcds/tour/autoscan.php), then do a new scan and post the new scan.
  8. Likes Uwe liked this post
