Results 1 to 10 of 11
Thread: Retrofit ACC VW T6
    Sep 2018
    Retrofit ACC VW T6
    Hello
    I am attempting a retrofit of ACC to a T6 transporter. I have changed the ABS pump to the correct type for ACC but I need to modify the coding for the function Front Assist with City Braking w/ACC FTS. Previous function was Front Assist with City Braking w/o ACC.
    Original ABS Code is: 307E40986566847E0C7D027CA68921D379F700
    Can someone help modify the code?
    ABS Part Number: 7E0907975Q (new fitted part) Type MK100ESC.
    Many thanks
    Colin
    Often (usually?) the coding of the ABS is also dependent on other modules fitted to the vehicle, so were going to need you to post a full VCDS Auto-Scan (between CODE tags - see my signature how to).
  3. Likes Uwe liked this post
    Sep 2018
    Please see the attached. This is with the new unit fitted.
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 02 03 04 08 09 10 13 15 17 19 25 5F 61 0B
    VIN: WV1ZZZ7HZJH072570   Mileage: 13710km-8518miles
    Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 KG    HW: 04L 907 445
       Component: R4 2.0l TDI   H02 3771
       Revision: 23002001
       Coding: 00254014434501090000
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
       ROD: EV_ECM20TDI03004L906056KG_004.rod
       VCID: 7CB40B82F708FCAA7E-8028
    25130 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [163] - -
              [Checking coding/versions ofcontrol modules in drivetrain]
                        Mileage: 13718 km
                        Date: 2009.01.31
                        Time: 12:44:25
                        Coolant temperature: 22 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 11.625 V
                        Acceleration: 0.000 m/s˛
                        Cruise Control System (CCS): status: ERROR
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                        Drivetrain coordinator: brake function status-ABS intervention: No
                        Drivetrain coordinator: brake function status-ESP intervention: No
                        Drivetrain coordinator: brake function status-EDL intervention: No
                        Drivetrain coordinator: brake function status-ASR intervention: No
                        Drivetrain coordinator: brake function status-MSR intervention: No
                        Drivetrain coordinator: brake function status-Driver braking: No
                        Drivetrain coordinator: brake function status-HDC active: No
                        Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                        Drivetrain coordinator: brake function status-EPB active: No
                        Drivetrain coordinator: brake function status-ASP intervention: No
                        Drivetrain coordinator: brake function status-ADS intervention: No
                        Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                        Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                        Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                        Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                        Drivetrain coordinator: brake function status-ACC stopping distance control active: No
    Readiness: N/A
       Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
       Component: DSG DQ500-7F  H11 5301
       Revision: 00H11V01
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 3D32C686AC9235A209-8068
    Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
       Component: ESC           H06 0133
       Revision: 00000000    Serial number: 61887000000354
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 40CCBF72DB60584A62-8014
    11 Faults Found:
    0143 - ABS/ESP Control Module
              U10C5 00 [137] - No or Incorrect Basic Setting
              [valve calibrating data missing]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    0195 - Control module not coded
              U1013 00 [137] - -
              [ECU marked as Not Configured because vehicle ID is invalid]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    0295 - Steering angle sensor
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    0338 - ABS/ESP Control Module
              [inlet valve calibration data missing]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    4255 - Internal Fault
              B200F F0 [137] - Unknown Error Elaboration
              [Hecu_mismatch_final]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    8297 - Databus
              U1121 00 [136] - Missing Message
              [ACAN: mIdent signal timeout]
                        Reset counter: 197
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:33
    8319 - Databus
              U1122 00 [137] - Implausible Message
              [ACAN: mMotor_10 Start_Stop coding missmatch]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
    8324 - Databus
              [ACAN: LW1_ID wrong value]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:26
       Component: LENKW.SENSOR  H07 0070
       Serial number: 03101713470066
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EB0018AE114EEBA50-802A
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
       Component: Climatic-T5   H22 0708
       Revision: 00001002
       Coding: 0000000003
       Shop #: WSC 02739 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: 73A620BEDA56B3D22F-8026
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
       Component: BCM PQ25 Max4 H82 0752
       Revision: B9082001    Serial number: 4000 284170036
       Coding: B9AC393A0A61341193284F747FEB8E750F04710F60CC6D60330400230840
       Shop #: WSC 02739 534 199619
       VCID: 2B16F8DE4AE6AB12A7-807E
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 270917 04  47  0106
       Coding: 0228EE
       Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
       Component: J386__TSG_FT  003 0653
       Serial number: KU0KU026091772690596
       Coding: 1400B0
       Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
       Component: J387__TSG_BT  003 0653
       Serial number: KU0KU004101772770455
       Coding: 0400A0
       Subsystem 4 - Part No: 7E1 951 172
       Subsystem 5 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 6 - Part No: 7E1 951 172
       Subsystem 7 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H02 0103
       Serial number: 29160002249940056441
       Coding: B40000
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0212
       Revision: --------    Serial number: 28231724900983
       Coding: 30810C
       ASAM Dataset: EV_VW75XParkAssis8K 001012
       ROD: EV_VW75XParkAssis8K_001_VN75.rod
       VCID: 71AA2AB6A04A81C2DD-8024
    Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
       Part No SW: 7N0 907 572 C    HW: 7E0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 2409170440ACBC
       Coding: 00005000FE0779
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: EV_ACCBEGVW361_VW32.rod
       VCID: 3620D9AA89A4E6FAC8-8062
    1071 - Databus
              [FAULT_CIS_AXV_INVALID]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:25
                        Control Module temperature: 27 °C
                        Voltage terminal 15: 11.5 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s˛
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:25
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 157
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:25
       Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
       Component: VW10Airbag021 H08 0018
       Revision: --------    Serial number: 003V3006F51L
       Coding: 000000000000000000000000000000003231
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 3A38CD9ABDBC029A2C-806E
    9682162 - Multiple collision brake
              B13BC F2 [137] - No function
                        Mileage: 13718 km
                        Date: 2018.09.06
                        Time: 12:44:40
       Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
       Component: KOMBI         H03 1107
       Coding: 450B010300
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090 C
       Component: GW-K-CAN TP20 H82 0752
       Revision: B9082001
       Coding: 042307
       VCID: 689C47D29B90400A8A-803C
       Component: IMMO          H03 1107
       VCID: 6A983DDA8D9C721A9C-803E
       Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
       Component: MU-S-ND-ER    H41 0468
       Serial number: VWZAZ2T5409046
       Coding: 065700013C00000011111101008808001F0100D6002001004F
       Shop #: WSC 27359 003 104857
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 25020EE624029D6271-8070
       Subsystem 1 - Part No SW: 3G0 919 866 BC    HW: -----------
       Component: ECE1 2017/18  --- 0820
       Part No SW: 7E0 907 534     HW: 7E0 937 090 C
       Component: Batt.regelung H82 0752
       Coding: 030B1A73
       Shop #: WSC 02739 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
       Serial number: 7588570000170926060F
    Sep 2018
    The effective change I am making is PR code 8T2 & 6K2 to PR code 8T3 & 6K3.
    Magdeburg, Germany
    Did you get the ACC's component protection already matched? If so, how did you get around the SWaP activation of the ACC functionality?
    May 2017
    Does T6 even have component protection? I'm under the impression that no. Lot of parts are common to PQ25 platform car like prev gen Polo and Ibiza. Those did not have CP scheme yet.
    The new MQB A0 platform Polo, Ibiza etc. introduce that scheme.
    This is my understanding so please don't shoot me if I'm mistaken
    Magdeburg, Germany
    Believe me, it does (with the Instrument Cluster as CP Master) - the Transporter/Multivan was always the Frankenstein when it came to the VW parts lego game. Though the bigger problem here is SWaP, hence my question...
  9. Likes downtime liked this post
  10. #8
    May 2017
    Ok I didn't know that. Know I do. Thanks for enlightening me.
    Yes, SWaP will be an issue then. CP itself won't be a problem if there's no FeC in play but with FeC, weeeelllll... It will be a long and difficult road.
  11. #9
    Tartu, Estonia
    I think i have a idea how this can be bypassed, but it's not for public discussion.
    I've been using similar technology for retrofitting Discover Media, to cars where it was never available, without adding a emulator or patching the eeprom.
    But this would mean i need cluster, radio and radar. All components of CP system.
    The world is my oyster...
  12. Likes Uwe, downtime, dnoermann liked this post
  13. #10
    Verified VCDS User cilitkas's Avatar
    May 2016
    LT
    are you sure all t6 had CP? i have bought BCM and navi from late 2015 T6, fitted to my 2012 t5 and all works fine, no CP errors...
