Hey friends, i have an 2006 Audi TT with some shifting issues, car has no fault codes stored ive tried a few scans and found nothing, replaced fluid and filter and gasket change on the transmission, i am only developing this issue intermittently, car runs great sometimes regardless fast or slow the car slams hard, again no codes so maybe software?, I've attached the auto scan of car, also the car is fully stock, any advise appreciated.
Wednesday,29,August,2018,09:46:10:17560
VCDS Version: 18.2.1.2
VIN: TRUZZZ8N851011403 License Plate: AUDITTSANDY2
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: 06A-906-032-AJQ.clb
Part No: 8N0 906 018 CN
Component: 1.8L R4/5VT 0010
Coding: 11570
Shop #: WSC 01236
VCID: 7F072EFA7DB9E4BC5E-5140
TRUZZZ8N851011403 AUZ5Z0DN086045
16622 - Manifold Pressure / Boost Sensor (G31)
P0238 - 35-00 - Signal too High
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 35-00 - Implausible Signal
Readiness: 0110 1101
Part No: 09G 927 750 CA
Component: AQ 250 6F 0622
Coding: 0008201
Shop #: WSC 01236 785 00200
VCID: 72E1F7CE6EEBB9D421-5140
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-F.lbl
Part No: 8N0 907 379 J
Coding: 0019473
VCID: 438F620A01D1405C7A-5140
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00241
Shop #: WSC 01236
VCID: 2855D5A6C8B783044F-2576
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 D
Component: Airbag Front+Seite 1000
Coding: 00102
Shop #: WSC 01236
VCID: 418368024BCD524C68-5140
32-10 - Resistance Too High - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N2 920 930 G
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 06944
Shop #: WSC 60800
VCID: 36690BDE1203E5F4CD-4AEE
No Faults Found
Address 35: Centr. Locks Labels:. 8Nx-962-267.lbl
Part No: 8N8 962 267 F
Component: Central Lock D09
Coding: 06848
Shop #: WSC 01236
VCID: 448D611654DF476443-4EB4
01482 - Motors for Central Locking
29-10 - Short to Ground - Intermittent
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00009
Shop #: WSC 01236
VCID: 65CB9C92FF255E6CB4-515C
Address 56: Radio Labels: None
Part No: 4B0 035 186 N
Component: concert II GRO 0004
Coding: 04000
Shop #: WSC 01236
VCID: 2B5F2AAAD941A81CA2-4AD6
End-------------------------(Elapsed Time: 03:33)--------------------------
