Results 1 to 6 of 6
Thread: First scan Tiguan Allspace (after towbar fitted)
    Aug 2018
    Hi All,
    Just got HEX-V2 delivered this morning so I thought I would post the first scan, there are a lot of Problems but it Looks like it relates to when I had a towbar fitted at 65miles.
    Will it be ok to clear them ?
    jp59
    Saturday,01,September,2018,11:39:26:11747
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WVGZZZ5NZJM155270   License Plate: HG18 KVD
    Mileage: 1909km-1186mi   Repair Order: 001
    Chassis Type: 5N-VW37 (3Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 5F 69 6D A5
    VIN: WVGZZZ5NZJM155270   Mileage: 1909km-1186miles
    Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 HS    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H24 3713
       Revision: B4H24---
       Coding: 0119001203461D082000
       Shop #: WSC 00066 790 00451
       ASAM Dataset: EV_ECM20TDI01104L906026HS 004004
       ROD: EV_ECM20TDI01104L906026GQ_004.rod
       VCID: 025D891F548DCF27673-8056
    9 Faults Found:
    17156 - Databus
              U1123 00 [040] - Received Error Message
                        Fault Frequency: 7
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 12:19:03
                        Coolant temperature: 64 °C
                        Intake air temperature: 48 °C
                        Voltage terminal 30: 12.140 V
                        Unlearning counter according OBD: 19
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
    17158 - Databus
                        Mileage: 102 km
                        Time: 00:00:00
                        Coolant temperature: 56 °C
                        Intake air temperature: 51 °C
                        Voltage terminal 30: 12.100 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
    21606 - Implausible Data Received from Body Control Module (Central Electric)
              U0422 00 [032] - -
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:34
                        Coolant temperature: 63 °C
                        Intake air temperature: 61 °C
                        Voltage terminal 30: 12.180 V
                        Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 65.2 °C
                        Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: 57.9 °C
                        Particle filt.inlet temp.sens.1 bank 1: raw value: 59.1 °C
                        Particle filter outlet temp.sens.1 bank 1: raw value: 52.9 °C
                        Exh. gas recirc.temp. sens. 2 bank 1: raw value: 2222.0 °C
                        Shut-off timer: last engine shut-off time: 7557 s
    20360 - Power Supply Terminal 15
              P3325 00 [032] - Implausible
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
                        Immobilizer snapshot A-Sia Error Snap A: 00 00 00
                        Immobilizer snapshot B-Sia Error Snap B: 00 00 00
    7135 - Body Control Module (Central Electric)
              U0140 00 [032] - No Communications
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:32
                        Voltage terminal 30: 12.220 V
                        Cruise Control System (CCS): status-Bits 0-7: 7
                        selected gear-Bits 0-7: 0
    26468 - Terminal 15 Voltage
              P151B 00 [032] - Implausible
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:31
                        Intake air temperature: 60 °C
                        Engine status: COENG_READY
              U0428 00 [032] - -
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:24:55
                        Coolant temperature: 57 °C
                        Intake air temperature: 50 °C
                        Cruise Control System (CCS): status-Bits 0-7: 0
    4717 - Body Control Module (Central Electric)
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:32
    4720 - Body Control Module (Central Electric 2)
              U0141 00 [032] - No Communications
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:31
                        Cruise Control System (CCS): status-Bits 0-7: 6
       Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
       Component: ESC           H25 0413
       Revision: 00000000    Serial number: 50738000000731
       Coding: 0BEE939A44251B714779070762C349D0C922D8E2E046927D34605078C02A4200002864121A1C230935351919323200
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
       VCID: 76B5E5CF0845E3875BB-8022
    8 Faults Found:
    0297 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:24:55
    8228 - Databus
              [FCAN: Klemmen_Status_01 is not received]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:32
    8301 - Databus
              [FCAN: BCM_01_alt veraltet bit is set]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:36
    8302 - Databus
              [FCAN: Wischer_01_alt veraltet bit is set]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:36
    8303 - Databus
              [FCAN: ZV_02_alt veraltet bit is set]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
    8304 - Databus
              [FCAN: WWSs_01_alt veraltet bit is set]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:36
    8374 - Databus
              [FCAN: Dimmung_01 is not received]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
    16411 - Display for Tire Pressure Monitoring
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:16:22
       Part No SW: 5NA 907 044 Q    HW: 5NA 907 044 Q
       Component: AC Automat    H35 4401
       Revision: 20K03000    Serial number: 00000D00140004
       Coding: 0012010420211001110510000010142A
       ASAM Dataset: EV_ACClimaPrehVW37X 002025
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 4DC76A23DD53C05FCA1-8018
       Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
       Component: E265KlimaHeck  H02 0201
       Serial number:       04031501850571
       Part No SW: 5Q0 937 086 BK    HW: 5Q0 937 086 BF
       Component: BCM PQ37BOSCH 034 0246
       Revision: --------    Serial number: C8640504180225
       ROD: EV_BCMCONTI.rod
       VCID: 04518F074E99C11755F-8050
       Subsystem 1 - Part No SW: 5NN 955 119 A    HW: 5NN 955 119 A  Labels: 1KX-955-119.CLB
       Component: 326 RL 180227  034 0373
       Serial number: 18022421112010
       Component: RLHS  050 0107
       Serial number: SAY18M04D13H11M51S46
       Coding: 00A8DD
       Serial number: 000000000ZY180642Z2D
       Serial number: 00000000000099823984
    13 Faults Found:
    589593 - Databus
              U1200 00 [008] - Defective
              [CAN-BusOFF]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:32:02
    589592 - Databus
              U1201 00 [008] - No Communications
              [CAN Keine Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:32:02
    919560 - Light Switch
              B126A 29 [136] - Signal Implausible
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:32:02
    460041 - Heated Rear Window
              B1265 14 [008] - Open or Short to Ground
                        Reset counter: 40
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 11:08:17
    66314 - Positioning Motors for Headlight Range
              B1528 F1 [008] - Control Voltage Implausible
                        Reset counter: 45
                        Mileage: 24 km
                        Date: 2018.08.04
                        Time: 11:38:45
    263442 - Siren / Alarm Horn for Anti-Theft Alarm System
              B131D F7 [008] - No Release by Immobilizer
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:32:02
    264452 - No Communications with Anti-Theft Sensor
              U10F4 00 [008] - -
              [Sensor-DWA->kein Signal/ Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:32:02
    132619 - Voltage Supply; Terminal 30; Right
              B140E 13 [008] - Open Circuit
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:32:02
    132363 - Voltage Supply; Terminal 30; Left
              B140D 13 [008] - Open Circuit
                        Reset counter: 40
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 11:08:17
    133131 - Voltage Supply Terminal 30
              B1423 13 [008] - Open Circuit
                        Reset counter: 40
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 11:08:18
    133387 - Voltage Supply; Terminal 30 for Central Locking
              B140F 13 [008] - Open Circuit
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:32:02
    262936 - Sensor for anti-theft alarm system
              B1330 29 [008] - Signal Implausible
                        Reset counter: 58
                        Mileage: 1351 km
                        Date: 2018.08.23
                        Time: 15:45:47
    197904 - Central Locking
              B140A 4B [008] - Over temperature
                        Fault Frequency: 9
                        Reset counter: 45
                        Mileage: 24 km
                        Date: 2018.06.16
                        Time: 09:14:44
       Serial number: 000116643R17293
       Coding: 0471451901
       VCID: 4BC3643B2347CE6FD45-801E
    6 Faults Found:
    12665088 - Databus
              [Bodycomputer 2 / Zentralmodul Komfortsystem / ZKE - Klemmen_Status_01 - kein Signal/keine Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:32
    12664864 - Databus
              [Steuergerät für BCM - Dimmung_01 - kein Signal/keine Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
    12664882 - Databus
              [Bordnetzsteuergerät - Gateway_72.BCM_01_alt - kein Signal/keine Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:36
    12664883 - Databus
              [Bordnetzsteuergerät - Gateway_72.Klimasensor_02_alt - kein Signal/keine Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
    13637426 - Databus
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:24:56
    12664885 - Databus
              [Bordnetzsteuergerät - Gateway_72.Licht_Anf_01_alt - kein Signal/keine Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:32
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 2A0060C950FF8728749C8145604087
       VCID: 3E253DEF60F56BC743B-806A
    10 Faults Found:
    1220 - Databus
              [FAULT_TIMEOUT_BLINKMODI_02]
                        Fault Frequency: 7
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:46
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 33 °C
                        Longitudinal_acceleration_vehicle_reference: -0.84 m/s²
                        Status_ACC_System: ACC_irreversible error
    0803 - Databus
              [FAULT_BV1_FEHLER]
                        Fault Frequency: 16
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
                        Voltage terminal 15: 12.2 V
                        Control Module temperature: 31 °C
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:24:56
                        Control Module temperature: 37 °C
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Fault Frequency: 17
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:32
                        Voltage terminal 15: 12.1 V
    2055 - Databus
              [FAULT_ALP_STEERINGWHEEL_INIT]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:24:57
    1401 - Databus
              [FAULT_TIMEOUT_Klima_Sensor_02_alt]
                        Fault Frequency: 9
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:34
    2178 - Databus
              [FAULT_WIPER_CONTROL_UNIT_OBSOLETE_DATA]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:37
                        Control Module temperature: 32 °C
    1394 - Databus
              [FAULT_TEMP_INIT]
                        Fault Frequency: 9
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:34
    2182 - Databus
              [FAULT_BRAKINGLIGHT_OLD]
                        Fault Frequency: 13
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
    1229 - Control Module Incorrectly Coded
              U1014 00 [008] - -
              [FAULT_CODING_AAG]
                        Fault Frequency: 14
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Serial number: 003VWM05XNS5
       Coding: 98CCC0C0000000005C5450CF008800000065
       VCID: 094F9E3369BB9C7F269-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 5NC857705C0024S00937
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 5NC857706C0016S00614
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 001 503 18
       Serial number: 357000000002CB596C2V
       Subsystem 4 - Part No SW: -----------    HW: 480 001 503 18
       Serial number: 35800000000871986C2Q
       Subsystem 5 - Part No SW: -----------    HW: 480 402 803 18
       Serial number: 3510001B129B7D43B646
       Subsystem 6 - Part No SW: -----------    HW: 480 401 003 18
       Serial number: 3520001B929485A18372
       Subsystem 7 - Part No SW: -----------    HW: 480 400 302 18
       Serial number: 3550001C92843FB175DI
    6 Faults Found:
    1051909 - Databus
              [NWD: 0x30B Kombi_01 error value KBI_Airbag_Lampe]
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:36
    1054981 - Databus
              [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:37
    1048576 - Databus
              [NWD: 0x5F0 Dimmung_01 Timeout]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:35
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:24:57
    1054208 - Databus
              [NWD: 0x3C0 Klemmen_Status_01 Timeout]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
    1053706 - Databus
              [NWD: 0x3DB Gateway_72 old value BCM1_Rueckfahrlicht_Schalter]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:38
       Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 10021820240677
       Coding: 0C00
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 0557920345A3F81F421-8050
    131140 - Databus
              U1121 00 [024] - Missing Message
              [Time-Out Klemmen_Status_01: Time-Out Gateway]
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Reset counter: 40
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
                        Operating time: 526 min
                        Supply voltage: Terminal 30: 12.4 V
                        Voltage at switch: 4.98 V
                        Terminal 15 status: not active
                        System status: 30
       Part No SW: 5NA 920 951 B    HW: 5NA 920 951 B
       Component: KOMBI         380 0310
       Coding: 27A40800E780060001886B031401000000000000
       VCID: 40D943171A011D37317-8014
    16776960 - Databus
              [ACC_02 keine Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 12:19:01
    16776961 - Databus
              [ACC_04 keine Kommunikation]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 12:19:01
       Component: GW MQB High   518 5323
       Serial number: 19031800840201
       Coding: 030500045F087300FB07225C0A0F00010001070000000000000000000000
       Shop #: WSC 00066 790 00442
       ROD: EV_GatewNF_VW27.rod
       VCID: 38292BF742D155F7897-806C
       Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 0431804064030350AT3B
       Coding: 2C0000
       Serial number: 8158535700
    131598 - Body Control Module (Central Electric)
              U0140 00 [008] - No Communications
              [Timeout Knoten 0x0E / 09 - Bodycomputer 1/ Bordnetzsteuergerät / el. ZE]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:33
                        Terminal 15: On
    66304 - Databus
              U1124 00 [008] - Additional Installations Detected
              [Mehrverbau CAN]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:00:00
                        Terminal 15: OFF
       Component: Haldex4Motion H52 7084
       Serial number: HA1-00016.11.17
       Coding: 0101
       VCID: 4CC167272649C957DDF-8018
       Serial number: 5038810701852
       Coding: 00310A20D001028000001000
       VCID: 47CB580B3F2F2A0FF0D-8012
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000000292581
       Coding: 0D0000
              B1487 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 9
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:24:56
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1081
       Coding: 91170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73B3DCDB1B37F6AF7C5-8026
    17152 - Indicator Lamp for Electro-Mechanical Power Steering
              C10D5 04 [008] - Internal System Fault
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:31
                        Motor status: 00
                        Supply voltage: 12.25 V
                        Temperature: 26.0 °C
                        KFC: 43
                        KFA: 00 00
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 12.39 V
                        uAdSensI_SwitchedKl30_xdu16: 12.31 V
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    26624 - Databus
              [KLSTAT_01 Botschaft - CAN-Timeout]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:31
                        Motor status: 00
                        KFC: 68
                        KFA: 00 00
                        Environmental conditions: 20
                        uioUdNotFilt_xdu16: 12.17 V
                        uAdSensI_SwitchedKl30_xdu16: 12.06 V
       Serial number: 6038807902151
       Coding: 00310220DE01028000001000
       VCID: 46D5550F382533070BB-8012
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000000288682
       Coding: 050000
       Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
       Component: MU-S-ND-ER    851 0867
       Coding: 02730601FF00000051110101008808001F0500C601200100CF
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 323D19DFA4ADBFA7B73-8066
       Component: ABT_Std-2_Nav  H51 8130
       Serial number: VWZ6ZHV0740047
       Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
       Component: ECE1 2018  --- 0915
    6705 - Databus
              [Terminal_status: no communication]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:16:21
                        Voltage terminal 30: 12.1 V
       Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
       Component: Anhaenger     H27 0260
       Revision: 8C001004    Serial number: 0445295045
       Coding: 0100000202000000
    340484 - Databus
              [Central module comfort system - no signal/communication]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:32
    116996 - Databus
              [Electronic central electrics - no signal/communication]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:32
    656650 - Bulb for Right Turn Signal on Trailer
              C10F6 15 [008] - Open or Short to Plus
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 12:19:32
    656906 - Bulb for Left Turn Signal on Trailer
              C10F7 15 [008] - Open or Short to Plus
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 12:45:32
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: A2-C758-8680-0
       Coding: 0A80
       ROD: EV_DeckLidCONTIAU736_VW27.rod
       VCID: 41DF4613110B143F3E9-8014
    0055 - Databus
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:01:00
       Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H08 1272
       Serial number: 11021841K20662
       Coding: 0003070601020401000213448150A90084000E000020
       ROD: EV_MFKBoschMQBB_VW27.rod
       VCID: 08499B3772B1E577397-805C
    10 Faults Found:
    1123173 - Databus
              [ESP_21_ESP_Systemstatus]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:24:58
                        Control Module temperature: 24 °C
                        Outside air temperature: 77.0 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 3.3 s
                        mid: 02 E0
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1123368 - Databus
              [Timeout_Gateway_72_BCM_01_alt]
                        Reset counter: 49
                        Control Module temperature: -258 °C
                        Outside air temperature: 77.5 °C
                        Vehicle speed: 655.35 km/h
                        System run time: 0.0 s
                        Voltage terminal 15: 11.2 V
                        mid: 02 93
                        Status of camera: Initializing
                        Engine_Running_Info: 255
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1123378 - Databus
              [Timeout_Gateway_72_Klima_Sensor_02_alt]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:35
                        Control Module temperature: 21 °C
                        System run time: 4.7 s
                        mid: 02 92
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1123376 - Databus
              [Timeout_Gateway_72_Wischer_01_alt]
                        Reset counter: 49
                        mid: 02 8F
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1123379 - Databus
              [Timeout_Gateway_72_WWSs_01_alt]
                        Reset counter: 49
                        mid: 02 8E
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1310721 - Databus
              [Timeout_Gateway_76_Innenlicht_11_alt]
                        Reset counter: 49
                        mid: 02 9B
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1123606 - Databus
              [TIMEOUT_Licht_Anf_01]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:34
                        System run time: 3.8 s
                        mid: 01 B3
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1123224 - Databus
              [TIMEOUT_Personalisierung_01]
                        Reset counter: 49
                        mid: 01 EE
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1123187 - Databus
              [RDR1_Header_FGN_Status]
                        Fault Frequency: 12
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:34
                        mid: 02 C0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    1122632 - Databus
              [TIMEOUT_RLS_01]
                        Reset counter: 49
                        Mileage: 102 km
                        Date: 2018.08.18
                        Time: 00:14:35
                        System run time: 4.8 s
                        mid: 02 08
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 1
    End----(Elapsed Time: 02:10, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
  2. Likes Uwe liked this post
  3. #2
    Aug 2016
    Eindhoven, NB, NL
    Hello and welcome to the VCDS forum. Perhaps you could clear all the errors and make a new scan. A lot of them are intermittent, so they don't occur all the time.
  4. Likes Uwe liked this post
  5. #3
    Aug 2018
    Thanks, glad to be here and looking Forward to learning more about VCDS.
    I will do as you suggest, wish I had VCDS before I fitted towbar just for comparison.
  6. #4
    Aug 2018
    Cleared and rescan
    Much happier now, cleared faults and rescanned
    Saturday,01,September,2018,16:11:52:11747
    Mileage: 1909km-1186mi   Repair Order: 005
    Gateway Installation List:  3Q0 907 530 L
    ^^^ This time you only posted the Gateway Installation List. It looks like all the faults went away? Drive the car some and scan it again to make sure it stays clean.
    Aug 2018
    Good point, will do that, thanks
