- Joined
- Dec 2, 2016
- Messages
- 85
- Reaction score
- 25
- Location
- Cardiff(ish), South Wales, UK.
- VCDS Serial number
- C?ID=288281
Hi Folks,
Been asked to replace Xenon headlights on a MK7 Golf GTD with the single U LED DRL and halogen indicator with headlights that have the double U LED DRL and LED indicator from a MK7 Golf R.
I have searched but I keep coming up with info to change from full halogen headlights to the Xenon units.
Does anyone know the coding and (if needed) Pin layout changes required? From what I have seen, both headlight units require the same amount of pins so it should be a case of coding?
Car is currently in bits, hence all the fault codes, Autoscan:
Adaptmap:
Saturday,25,August,2018,18:40:21:50827
VCDS Version: 18.2.1.2 HEX-NET CB: 0.4411.4
Dealer/Shop Name: Lightrofit
VIN: WVWZZZAUZEW151451 License Plate: MIKEYGOLFMK7
Mileage: 47559km-29551mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZEW151451 Mileage: 47559km-29551miles
10-Park/Steer Assist -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 EP HW: 04L 907 309 A
Component: R4 2,0L EDC H22 6283
Revision: 81H22---
Coding: 01190012034505082000
ASAM Dataset: EV_ECM20TDI01104L906021EP 002006
ROD: EV_ECM20TDI01104L906021AE.rod
VCID: 77BE1AA7CE0BCFFC16-8022
7 Faults Found:
8670 - Exhaust Gas Temp Bank 1 Sensor 2
P2084 00 [096] - Implausible Signal
21469 - Neutral Gear Sensor
P15A1 00 [047] - Implausible Signal
21605 - Sensor for Ambient Air Temperature (G17)
P0070 00 [175] - Malfunction
10092 - Neutral Gear Sensor
P15A0 00 [047] - Electrical Malfunction
10093 - Neutral Gear Sensor
P15A2 00 [032] - Short to GND
U0428 00 [032] - -
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [047] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Readiness: 1 1 0 0 1
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 626630000001D9
Coding: 01FA8AA13425096D037B060541C42980512C90C0608294F5F4605074C009
VCID: 7BB60697F223EB9C72-802E
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
8196 - Databus
[FCAN : ACC_10 message is not received]
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[IPB: Supply Voltage below undervoltage threshold]
32948 - Comfort limitation
C10D7 00 [008] - -
[IPB-Miscellaneous: EEPROM data failure]
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120114202100011005000000101000
VCID: 383CD99B83950084DF-806C
459527 - Databus
[Klima_Sensor_02 - empfangener Fehlerwert]
1048834 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
[PTC-Reduzierung durch BCM]
P1719 00 [008] - -
[PTC-Reduzierung durch MSG]
459025 - Databus
[Radio - kein Signal/Kommunikation]
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011327803406
Coding: 03100A42C20122FB0B244080B10C0728100A000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130915 042 0551
Serial number: 130924032254
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M10D06H03M06S03S1
Coding: 00A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY132460EGT
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000027903592
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO2404472/
Coding: 181901
19 Faults Found:
1798 - Dimming for Interior Illumination
B1200 12 [008] - Short to Plus
5130 - Bulb for Front Left Turn Signal
B11E8 15 [009] - Open or Short to Plus
6666 - Bulb for Low Beam Headlamp Left
B1217 15 [009] - Open or Short to Plus
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [009] - Voltage Supply Open or Short to Plus
132363 - Voltage Supply; Terminal 30; Left
B140D 13 [008] - Open Circuit
132619 - Voltage Supply; Terminal 30; Right
B140E 13 [008] - Open Circuit
133131 - Voltage Supply Terminal 30
B1423 13 [008] - Open Circuit
133387 - Voltage Supply; Terminal 30 for Central Locking
B140F 13 [008] - Open Circuit
137217 - Outside temperature sensor
B103F 1B [009] - Resistance Too High
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
267012 - No Communications with Anti-Theft Siren / Alarm Horn
U10F3 00 [008] - -
[Sirene-DWA->kein Signal/Kommunikation]
395273 - Control Circuit for Signal Horn
B1344 14 [008] - Open or Short to Ground
460041 - Heated Rear Window
B1265 14 [008] - Open or Short to Ground
540693 - Databus
[LWR_AFS_01 Datenbus fehlende Botschaft]
589592 - Databus
U1201 00 [008] - No Communications
[CAN Keine Kommunikation]
919560 - Light Switch
B126A 29 [008] - Signal Implausible
934148 - No Communications with Rain/Light Sensor
U10F6 00 [008] - -
[Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
939524 - No Communications with Humidity Sensor
U10F5 00 [008] - -
[Sensor für Feuchteerkennung->kein Signal/ Kommunikation]
947204 - Control Module for Wiper Motor
U10A3 00 [008] - No Communications
[Scheibenwischermotor Fahrerseite->kein Signal/ Kommunikation]
Address 10: Park/Steer Assist
Address 13: Auto Dist. Reg
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR00U7H+
VCID: 7F4EF287E63BF7BC5E-802A
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E17031740708
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E20031740627
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 609 13
Serial number: 35767000000AEACC9D0M
Subsystem 4 - Part No SW: ----------- HW: 480 001 609 13
Serial number: 358670000004A41CBD0+
Subsystem 5 - Part No SW: ----------- HW: 480 400 410 13
Serial number: 35165029D1142C8382CB
Subsystem 6 - Part No SW: ----------- HW: 480 400 410 13
Serial number: 35265029F1142C845299
Subsystem 7 - Part No SW: ----------- HW: -----------
Component: FrontSensor_D --- ----
Serial number: -------------------$
7 Faults Found:
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [136] - Open or Short to Plus
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [136] - Open or Short to Plus
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
9634901 - Control Module for Front Left Belt Tensioner
B1304 55 [009] - Not configured
9635157 - Control Module for Front Right Belt Tensioner
B1305 55 [009] - Not configured
1054981 - Databus
[NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Part No SW: 5Q0 953 507 AG HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 03101304220143
Coding: 0C00
ROD: EV_SMLSKLOMQB_013_AU37.rod
Part No SW: 5G6 920 970 A HW: 5G6 920 970 A
Component: KOMBI 314 2210
Coding: 27AD01002F80260001886A01000000
VCID: 2E10FFC371D1CE3485-807A
8 Faults Found:
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_NAV SD_0x32 keine Kommunikation]
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_AWV_0x1B keine Kommunikation]
16776960 - Databus
[ACC_02 keine Kommunikation]
16776961 - Databus
[ACC_04 keine Kommunikation]
16776970 - Databus
[LWR_AFS_01 keine Kommunikation]
13639936 - Databus
[Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0001061245
Coding: 030100040B087300EF00067E080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009_VW37.rod
VCID: 3B36C697B2A32B9C32-806E
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0038
Serial number: 27130001506360073382
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 3928200603
6 Faults Found:
131594 - Parallel Parking Assistance Control Module
U104E 00 [009] - No communication
[Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
131598 - Body Control Module (Central Electric)
U0140 00 [008] - No Communications
[Timeout Knoten 0x0E / 09 - Bodycomputer 1/ Bordnetzsteuergerät / el. ZE]
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
[Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
[Globaler Timeout CAN-Infotainment]
66566 - Extended CAN Bus (SAE Bus C)
U0046 00 [009] - Malfunction
[Bus defekt CAN-Extended]
65798 - Extended CAN in One-Wire Mode
U0054 00 [008] - -
[Eindrahtfehler CAN-Extended]
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 21091304080394
Coding: 003F0220D001048100001000
VCID: 3FCEB287A6BB37BC1E-806A
Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 E
Component: EPS_MQB_ZFLS 502 5011
Coding: 8101
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: EV_SteerAssisMQB_009_VW37.rod
VCID: 3326EEB79AF3E3DCEA-8066
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 28091304081112
Coding: 003F0020DE01048100801000
VCID: 3E30CF83A1B13EB415-806A
Address 55: Headlight Range
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 874 HW: 5G0 035 874
Component: MU-S-ND-ER 040 0421
Serial number: V7F02109130001
Coding: 02730001FF00000021111201002800001F0202060100010045
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 679E4AE79EAB5F7C86-8032
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H51 0022
Serial number: VWZ8Z9NJ901YF5
Subsystem 2 - Part No SW: 5G0 919 866 E HW: -----------
Component: ECE 2013/14 --- 0034
11 Faults Found:
B1064 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung]
B1061 13 [008] - Open Circuit
[Hochtonlautsprecher Kanal 3: Unterbrechung]
0005 - Antenna Amplifier 1 for Radio
B126D 13 [008] - Open Circuit
0006 - Antenna Amplifier 2 for Radio
B126E 13 [008] - Open Circuit
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [008] - Open Circuit
2565 - GPS Antenna
B1054 13 [008] - Open Circuit
[GPS aerial - open circuit]
6179 - Display Module 1 for Multimedia System
B1297 F6 [008] - Cable for Video Signal; Open Circuit
1024 - Interface for External Media Devices (MEDIA-IN)
B1288 13 [008] - Open Circuit
U1111 00 [009] - -
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
7178 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0011
Serial number: 130918200929
VCID: 6B9636D782437B1CE2-803E
End----(Elapsed Time: 01:40, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
Adaptmap:
;SW:5Q0-937-084-AA HW:5Q0-937-084-AA --- Cent. Elect.
;Component:BCM MQBAB H H14 0112, Coding:03100A42C20122FB0B244080B10C0728100A000000000000000000000000
;EV_BCMCONTI,011001,EV_BCMBOSCH_011.rod
;Saturday,25,August,2018,18:36:22:50827
;VCDS Version: Release 18.2.1 Data version: 20180518 DS287.1
;VCID: 77BE1AA7CE0BCFFC16-8022
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2000 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,320 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,320 ms,9
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,9
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,9
IDE01550-Service position,170.494336 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,No ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,No ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,2
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,3
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,3
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,3
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,3
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,3
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,3
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,13
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,13
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,13
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,13
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,13
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,13
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separate ,3
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,3
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,3
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,3
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,3
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,3
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.100 %,3
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,3
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,manual ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,116 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,2 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,5
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,5
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,time value ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,1
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,1
IDE04928-ENG148904-Anti-theft device-Überwachung Innenentriegelungshebel,not active ,1
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,4
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,4
IDE05144-Read parameter address,00 00 00 ,3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,37 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,41 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,00 ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,00 ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,1C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1A ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,35 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,3F ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,minimize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,minimize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,127 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,127 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,63 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,10 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,86 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,86 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,89 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,26 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,10 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,10 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,10 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,10 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,26 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,1E ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,1F ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,41 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,42 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00 ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2F ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2A ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,26 ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,27 ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,6 - LED Lichtmodul ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,6 - LED Lichtmodul ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,34 - LED Bremsleuchten ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,34 - LED Bremsleuchten ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,36 - LED Kleinleistung ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,36 - LED Kleinleistung ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,only_if_closed ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,only_if_closed ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,13 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,14 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,2 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,4 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,24 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,24 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,28 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,8 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,8 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,9 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,10 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,8 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,8 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,8 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,8 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,8 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,8 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,9 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,9 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,10 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,10 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,9 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,10 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,6 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,7 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,14
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,14
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,14
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,14
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,14
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,14
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,14
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,14
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,14
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,14
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,14
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,14
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,14
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,14
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,6
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,6
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,6
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,active ,6
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,6
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,2
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,2
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,2
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG148891-A/C heater function via remote control-Anzahl zulaessiger Remotestarts,2 ,2
IDE07007-ENG148876-A/C heater function via remote control-RemoteStart Betrieb Dauer,10 min,2
IDE07356-Position during interval mode,31.494474 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,not active ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,1 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,No ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,Yes ,6
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,No ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,6
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,6
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,6
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,not active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,1
IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner,not active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,1
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,1
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10298-Alternating park position 1,7.494498 °,2
IDE10299-Alternating park position 2,29.494476 °,2
MAS01490-Energy management,active ,1
MAS05055-lower turn position,31.494474 °,2
MAS05056-upper turn position,170.494336 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,3
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,3
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,3
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,3
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,3
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,3
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,3
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,3
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,3
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,3
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,3
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,3
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,3
ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 lx,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 %,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 %,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 %,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 %,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 %,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 %,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 %,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 %,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 %,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 %,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 %,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 %,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 %,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 %,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 %,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 %,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 %,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 %,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 %,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 %,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 %,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 %,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0 ,10
ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0,0 lx,8
ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1,8 lx,8
ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2,50 lx,8
ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3,500 lx,8
ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0,6.0 %,8
ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1,6.0 %,8
ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2,100.0 %,8
ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3,100.0 %,8
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam ,16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F ,16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41 ,16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam ,16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,10 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,10 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,10 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,00 ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,00 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,34 - LED Bremsleuchten ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake light ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Blinken links aktiv (beide Phasen) ,16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,10 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,00 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,00 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,34 - LED Bremsleuchten ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake light ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,Blinken rechts aktiv (beide Phasen) ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,63 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2F ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,1C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,10 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2A ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,86 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,86 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,35 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3F ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
Elapsed Time: 01:04
