Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Golf 7 lost AIR CARE after swapping Climatronic panel
    Apr 2018
    ITALY
    Hello all,
    I am in the process of retrofitting heated seats and the auxiliary heater, so I replaced the Climatronic panel in order to obtain the missing buttons. Since I did the swap, everything works fine (after I did basic settings / first AC compressor run-in), but I have lost the AIR CARE function that was under setting in the Climatronic menu.
    I have looked everywhere in the coding and adaptations but could not find any related entry.
    I suppose the Climatronic panel I installed is older and has an older firmware. I asked the dealer to update it, they tried but ODIS refused to update because ODIS is online and it says that particular panel should not be in my car.
    Does anybody know if the AIR CARE function is actually related to the panel firmware?
    Does anybody know if ODIS can be forced to update the firmware?
    I attach the details: top is car's original panel (AIR CARE ok but no aux heat / heated seats buttons) and bottom is current panel (all buttons but no AIR CARE).
    Oct 2014
    Arandjelovac, Serbia
    Post full Auto Scan, please.
    Apr 2018
    ITALY
    Here you go, this is with the original panel. I don't have one at hand with the current panel but nothing changes except module 08 details. Of course coding and adaptations were matched after replacing the panel.
    Oct 2014
    It's not full AS file. Missing something like:
    Saturday,01,October,2016,16:03:46:09030
    VCDS Version: 16.8.2.3  HEX-V2 CB: 0.4324.4
    Data version: 20160926 DS261.0
    VIN: TMBPH16Y013252230   License Plate: AR005HD
    Mileage: 88830km-55196mi   Repair Order:
    I'm sorry, I have to thread lock, based on e-mail report.
    Please wait for Admin decision. Thread lock until further notice.
  5. Likes Uwe, Eric liked this post
    Posts edited and thread unlocked.
    The OP (darkchina811) has a legitimate VCDS system. There is no excuse for him to be using a cloned/pirate one.
  7. Likes Boki Ar liked this post
    Apr 2018
    ITALY
    Here's a recent scan, all the errors are just because I disconnected battery/airbags. Normally, zero errors.
    Monday,27,August,2018,19:05:50:06888
    VCDS Version: 18.2.1.5  HEX-V2 CB: 0.4411.4
    VIN: WVWZZZAUZHW0xxxxx   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZHW0xxxxx   Mileage: 20502km-12739miles
    Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
       Component: R4 1.4l TFS   H25 2833
       Revision: R7H25---
       Coding: 0119003223241D082000
       ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
       ROD: EV_ECM14TFS01104E906027HB.rod
       VCID: 6B833BBF03045EDFB46-803E
       CAN Converter 01:
    17158 - Databus
                        Mileage: 20458 km
                        Date: 2018.08.26
                        Time: 00:22:28
                        Coolant temperature: 21 C
                        Intake air temperature: 21 C
                        Voltage terminal 30: 12.133 V
                        Unlearning counter according OBD: 36
                        Acceleration: 0.000 m/s
                        Cruise Control System (CCS): status-Bits 0-7: 0
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 131
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                        Drivetrain coordinator: brake fault status-Bits 0-7: 4
              U0428 00 [032] - -
                        Mileage: 20458 km
                        Date: 2018.08.26
                        Time: 00:22:27
                        Voltage terminal 30: 12.180 V
                        Outside air temperature: 215 C
                        Absolute intake pressure: 99 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 47.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Overrun cut-off-Bits 0-7: 0
       Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
       Component: ESC           H62 0637
       Revision: 00000000    Serial number: 91596000011507
       Coding: 01FA6AA1242219704779060841C62980562498E26082947300200078C00203
       ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
       VCID: 74B120C35E3A812765C-8020
    0297 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 165
                        Mileage: 20458 km
                        Date: 2018.08.26
                        Time: 00:22:28
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 165
                        Mileage: 20458 km
                        Date: 2018.08.26
                        Time: 00:22:38
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 165
                        Mileage: 20458 km
                        Date: 2018.08.26
                        Time: 00:22:38
       Part No SW: 5G0 907 044 BE    HW: 5G0 907 044 BE
       Revision: 00001K08
       Coding: 00020004100110011005004000101022
       Part No SW: 5Q0 937 084 CJ    HW: 5Q0 937 084 AL
       Component: BCM MQBAB M   H24 0175
       Serial number: 01061616601135
       Coding: 00000842C20102FB4B644080B11403281000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 025D761B148EBF97670-8056
       Component: WWS    160522  043 0551
       Serial number:         160601172917
       Coding: 0E4DFD
       Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
       Serial number: 90482146
       Coding: 02006C
       Serial number: 000000000ZY15028208R
       Serial number: 00000000000030139763
       Revision: --------    Serial number: 39331616902729
       Coding: 0031151001
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 43D3B31F4B14769F2C6-8016
    13637426 - Databus
                        Reset counter: 165
                        Mileage: 20458 km
                        Date: 2018.08.26
                        Time: 00:22:28
       Serial number: 003F6R1V1W4Y
       VCID: 41DFB9175108648F3EA-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 35767000000432B44C1Q
       Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 358670000008B4C4DB17
       Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
       Serial number: 3516502BB205729313D3
       Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
       Serial number: 3526502AF2076340F201
       Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 35565029B21160C1025X
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 13061608490829
       Coding: 0400
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 0D4755275DD0F0EF0A2-8058
       Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
       Component: KOMBI         303 8311
       Coding: 07A501002380000801083B001400000000000000
       VCID: 26150A8BD866A3B72B8-8072
       Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 E
       Component: GW MQB Mid    127 1265
       Revision: --------    Serial number: 0005024934
       Coding: 030100043F085700FB000248080F00010001050000000000000000000000
       VCID: 7BA30BFF7364CE5F246-802E
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29160001142480026234
       Coding: 28FFFF
       Serial number: 8442320304
       Serial number: 300516EEU02971
       Coding: 003B0320D000040100001000
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2DCEFB3CDE37577F0-806E
    16272 - Steering Angle Sensor
                        Reset counter: 130
                        Motor status: 00
                        System status: Reset
                        Supply voltage: 12.25 V
                        Temperature: 20.0 C
                        KFC: 3F
                        KFA: 00 90
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 12.30 V
                        uAdSensI_SwitchedKl30_xdu16: 12.31 V
                        NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                        NoInitCause_RackPos_Rohwert: 00 C0
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: activated
                        RP_CNTERR: activated
       Serial number: 280516EER24731
       Coding: 003B0120DE00040100801000
       VCID: 42DDB61B540E7F97270-8016
       Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
       Component: MU-S--ER      710 0744
       Coding: 02730000AA0000005111000100080A001F0206D40120010003
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 2C01F8A3C68A99E7FDC-8078
       Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJT00QNA
    1564 - Microphone 1
              B129B 13 [008] - Open Circuit
                        Reset counter: 168
                        Mileage: 20458 km
                        Date: 2018.08.26
                        Time: 01:49:29
                        Voltage terminal 30: 14.5 V
    End----------(Elapsed Time: 01:59, VBatt start/end: 12.3V/12.3V)-----------
  9. Likes Uwe liked this post
  10. #7
    Oct 2017
    Northwest UK
    Can you please delete all DTC's and post a new scan.
    Did you car have AC Manuel and you upgraded to a climatronic?
  11. #8
    May 2017
    Quote Originally Posted by myounus View Post
    No, he retrofitted aux heater and heated seats which means you need to swap the climatronic panel as well as his old one did not have buttons for heated seats and no button for aux heater start / stop.
    SW update can be done with ODIS-E. But OP needs to obtain the flash file by himself from Erwin. Unfortunately for OPs Climatronic panel, there's no sw update available
    What was OPs previous climatronic part number?
    I don't know exactly which clima versions have Aircare but if I would need to guess based on ETKA, I would guess either 5GE907044AE, 5GE907044AH or 5GE907044AP. All of these three have seat heating and aux heater buttons as well. There were not PR numbers in ETKA describing AirCare, so it's just a guess.
  12. #9
    Apr 2018
    ITALY
    Here is a clean auto scan, not that it makes any difference for module 08 anyway.
    The Climatronic that came with the car is 5G0 907 044 BK (H04 1601).
    Wednesday,29,August,2018,14:39:45:06888
    VIN: WVWZZZAUZHW0xxxxx   Mileage: 20504km-12740miles
       Revision: R7H25---
       CAN Converter 01:
    Readiness: 1110 0001
       Revision: 00001K08
       Coding: 0E4DFD
       Coding: 02006C
       Coding: 0031151001
       Coding: 0400
       Coding: 28FFFF
       Coding: 8107
    End----------(Elapsed Time: 01:58, VBatt start/end: 12.0V/12.0V)-----------
  13. #10
    Oct 2017
    Northwest UK
    It's not required for the electric aux heater that's usually present in most diesel models in the uk. If retrofitting the webasto aux heater then I'm not sure what's the part numbers would be of compatible climatronic panels. I've never retrofitted it but have seen it on a friend's Golf R factory fitted where he switched it on/off through the screen.
    I think the easiest way (in the absence of a flashing tool) would be to purchase an updated panel.
