Hello all,
I am in the process of retrofitting heated seats and the auxiliary heater, so I replaced the Climatronic panel in order to obtain the missing buttons. Since I did the swap, everything works fine (after I did basic settings / first AC compressor run-in), but I have lost the AIR CARE function that was under setting in the Climatronic menu.
I have looked everywhere in the coding and adaptations but could not find any related entry.
I suppose the Climatronic panel I installed is older and has an older firmware. I asked the dealer to update it, they tried but ODIS refused to update because ODIS is online and it says that particular panel should not be in my car.
Does anybody know if the AIR CARE function is actually related to the panel firmware?
Does anybody know if ODIS can be forced to update the firmware?
I attach the details: top is car's original panel (AIR CARE ok but no aux heat / heated seats buttons) and bottom is current panel (all buttons but no AIR CARE).
Thanks
Thanks
Removed. Data from a clone/pirate copy of VCDS is not welcome here.
