Results 1 to 7 of 7
Thread: VW Jetta 2009 2.0t engine problems
    Feb 2015
    The backstory is I picked up this 2009 VW Jetta to be a daily driver. I knew it had faults, but needed to check them out. After weeks of driving, a few more have been added.
    I ran scan n both 9M and 1K. It seems 1K did not save. I can scan and repost if need be.
    At first, just a misfire and leak in air intake system, plus fan faults came up. The only noticeable issue was slight delay when starting in first gear.
    Last time driving home, I noticed the engine lost power occasionally around upper 2k rpm area wen accelerating from a stand still. Usually in first and some times in second gear or even third. This happened at first on the freeway in heavy traffic, but no necessarily stand still. Letting go of the gas, then reengaging accelerator pedal would get engine going again. No necessarily a loss of engine, as much as a loss of power(nothing behind gas pedal being pressed). I never let engine die, so not sure if it would just completely die.
    Appreciate any help, especially where to start. I will ohm out #1 ignition coil and check for thermal switch issues with fan. Of course any suggestions would be appreciated.
    Thank you!
    Leo
    Mileage: 210900km-131047mi   Repair Order:
    Chassis Type: 1K (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: XXXXXX1KXXXXXXXX   Mileage: 210900km-131047miles
    Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
       Part No SW: 1K0 907 115 AF    HW: 1K0 907 115 AD
       Component: 2.0l R4/4V TFSI     0010
       Revision: E3H12---    Serial number: VWX7Z0H724H025
       Coding: 0403010818070160
       VCID: 6ADBE2D145CC1314A6-803E
    7 Faults Found:
    000369 - Fuel Trim; Bank 1
                   P0171 - 000 - System Too Lean - MIL ON
                        Fault Status: 11100000
                        Mileage: 206627 km
                        Time: 21:30:47
                        RPM: 839 /min
                        Load: 20.8 %
                        Speed: 3.0 km/h
                        Temperature: 99.0C
                        Temperature: 46.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.462 V
    006480 - Radiator Fan (V7)
                   P1950 - 000 - Movement Restricted / Jammed - Intermittent
                        Fault Frequency: 21
                        Mileage: 209346 km
                        Time: 07:00:23
                        RPM: 2984 /min
                        Load: 34.1 %
                        Speed: 122.0 km/h
                        Temperature: 96.0C
                        Temperature: 36.0C
                        Voltage: 13.843 V
    006481 - Radiator Fan 2 (V177)
                   P1951 - 000 - Movement Restricted / Jammed - Intermittent
                        Mileage: 209800 km
                        Time: 16:40:04
                        RPM: 2530 /min
                        Load: 11.8 %
                        Speed: 87.0 km/h
                        Temperature: 95.0C
                        Temperature: 36.0C
                        Voltage: 13.716 V
    001287 - Idle Control System RPM
                   P0507 - 000 - Higher than Expected. - Intermittent
                        Fault Frequency: 21
                        Mileage: 206731 km
                        Time: 08:39:33
                        RPM: 926 /min
                        Load: 15.7 %
                        Temperature: 99.0C
                        Temperature: 37.0C
                        Voltage: 13.716 V
    008825 - Leak in Air Intake System
                   P2279 - 000 -  - MIL ON
                        Mileage: 207183 km
                        Time: 07:13:36
                        RPM: 759 /min
                        Load: 14.5 %
                        Temperature: 99.0C
                        Temperature: 43.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.589 V
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected - Intermittent
                        Mileage: 209650 km
                        Time: 12:05:17
                        RPM: 1679 /min
                        Load: 25.1 %
                        Speed: 23.0 km/h
                        Temperature: 66.0C
                        Temperature: 47.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.589 V
                   P0087 - 000 - Too Low - Intermittent
                        Mileage: 210888 km
                        Time: 15:06:05
                        RPM: 2646 /min
                        Load: 72.5 %
                        Speed: 108.0 km/h
                        Temperature: 97.0C
                        Temperature: 50.0C
                        Voltage: 13.462 V
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Component: ESP MK60EC1   H45 0109
       Revision: 00H45001
       Coding: 113B600D492500FE880D06EC921D00413000
       Shop #: WSC 39839 001 1048576
       VCID: 7EF3DE81E9448FB46A-802A
       Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 7CF7D4893F589DA444-8028
       Revision: 00H54000    Serial number: 00000001047687
       Coding: 14058E234004150007140000001400000008730B5C000120000000000000
       VCID: 326B3AB1AD9C9BD4DE-8066
       Component: Wischer 160808 021  0501
       Coding: 00038805
       Shop #: WSC 00066
       Revision: 05034000    Serial number: 003B6M06CJPI
       Coding: 0013889
       VCID: 6CD7E4C94F380D24D4-8038
       Subsystem 2 - Serial number: 6332MSME3D4311095
       Subsystem 3 - Serial number: 6342MSME3D43122FF
       Subsystem 4 - Serial number: 6351HSME174A00470
       Subsystem 5 - Serial number: 6361HSME174A0072%
       Subsystem 6 - Serial number: 63727SME173A5E549
       Subsystem 7 - Serial number: 63827SME17241004N
       Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
       Coding: 0000021
       VCID: 0305AF7542A6E25C05-8056
    00576 - Terminal 15
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 1K0 920 954 R    HW: 1K0 920 954 R
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0H724H025
       Coding: 0023203
       VCID: 3B7517957AD65A9C0D-806E
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 010708F1000856
       Coding: E9807F070003021002
       VCID: 356101AD5CF28CECFB-8060
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       Shop #: WSC 40945 444 125953
       VCID: 0407AC6947A8E5643C-8050
       Component: Radio DE2       016 0020
       Revision: 00016000    Serial number: VWZ4Z7H2201327
       Coding: 0040401
       VCID: 2959DDDD804AD80C6F-807C
    End-------------------------(Elapsed Time: 05:22)--------------------------
    Sunday,26,August,2018,13:55:35:46074
    VCDS Version: 18.2.0.3 (x64)
    VIN: 3VWRA71K49M034284   License Plate: LEO JETTA
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWRA71K49M034284   Mileage: 210900km-131047miles
    7 Faults Found:
                        Mileage: 206627 km
                        Time: 21:30:47
                        RPM: 839 /min
                        Load: 20.8 %
                        Speed: 3.0 km/h
                        Temperature: 99.0C
                        Temperature: 46.0C
                        Voltage: 13.462 V
                        Fault Frequency: 21
                        Mileage: 209346 km
                        Time: 07:00:23
                        RPM: 2984 /min
                        Load: 34.1 %
                        Speed: 122.0 km/h
                        Temperature: 96.0C
                        Temperature: 36.0C
                        Voltage: 13.843 V
                        Mileage: 209800 km
                        Time: 16:40:04
                        RPM: 2530 /min
                        Load: 11.8 %
                        Speed: 87.0 km/h
                        Temperature: 95.0C
                        Temperature: 36.0C
                        Voltage: 13.716 V
                        Fault Frequency: 21
                        Mileage: 206731 km
                        Time: 08:39:33
                        RPM: 926 /min
                        Load: 15.7 %
                        Temperature: 99.0C
                        Temperature: 37.0C
                        Voltage: 13.716 V
                        Mileage: 207183 km
                        Time: 07:13:36
                        RPM: 759 /min
                        Load: 14.5 %
                        Temperature: 99.0C
                        Temperature: 43.0C
                        Voltage: 13.589 V
    000769 - Cylinder 1
                        Mileage: 209650 km
                        Time: 12:05:17
                        RPM: 1679 /min
                        Load: 25.1 %
                        Speed: 23.0 km/h
                        Temperature: 66.0C
                        Temperature: 47.0C
                        Voltage: 13.589 V
                        Mileage: 210888 km
                        Time: 15:06:05
                        RPM: 2646 /min
                        Load: 72.5 %
                        Speed: 108.0 km/h
                        Temperature: 97.0C
                        Temperature: 50.0C
                        Voltage: 13.462 V
       Revision: 00H45001
       Coding: 00038805
       Shop #: WSC 00066
       Revision: 00000000    Serial number: AUZ4Z7H0389436
       Coding: 0000100
       VCID: 33653FB5528692DCD5-8066
                        Reset counter: 196
                        Mileage: 209812 km
                        Time: 07:21:20
       Coding: 0013889
       Coding: 0000021
    00576 - Terminal 15
       Coding: 0023203
       Component: IMMO            3HL 1222
       Revision: 72009005    Serial number: 00000792688729
       Coding: 0001205
       VCID: 6FEDF3C57E2EF63CF1-803A
       Part No: 1K0 909 144 C
       Revision: 00H15000
       VCID: 2A5B22D1854CD31466-807E
       Revision: 72009005    Serial number: 00000000688813
       Coding: 0001204
       VCID: 70EFF0B96310E9C4E8-8024
       Coding: 0040401
       Revision: 12006001    Serial number: 00000003349861
       Coding: 0001168
       VCID: 76E3C6A10174C7F432-8022
       Coding: 0100101
                        Mileage: 198878 km
                        Time: 00:19:38
       Revision: 12006001    Serial number: 00000003361491
       Coding: 0001168
       VCID: 77FDCBA5067EBEFC29-8022
    End-------------------------(Elapsed Time: 02:01)--------------------------
    Sep 2016
    Riga, Latvia
    http://wiki.ross-tech.com/wiki/index...1/P2279/008825
    This may be helpful. Pay attention to special note at the end of page.
    P.S. this apply to RoW 2,0T engines, too.
    Feb 2015
    Quote Originally Posted by MartinsX View Post
    Interesting read. Watched Humble Mechanic explain how to check and what goes bad on them. Explains rear main seal leak. Thank you.
    Feb 2015
    Update. Pulled Pressure Control Valve and found nothing wrong. Checking the intake manifold. Anything in particular to observe?
    Feb 2015
    Thanks for all of the help. Followed a DIY for pulling transmission even though I have pulled mk3&4 around 5-6 times.
    Replaced rear main seal with ECS billet aluminum permanent fix. Shame on VW for going so cheap on their original rear main seal for the MK5 platform.
    Put it back together along with resurfacing the flywheel( since I was in there) and replacing the clutch, input and output shaft seals. She runs like a champ. Check engine light gone.
    Found out my turbo is leaking a bit of oil into the pancake pipe, which is my next big job. Gotta save money to afford even the OEM replacement.
  7. Likes Jack@European_Parts liked this post
    The seal is the affect not the cause......
