- May 1, 2014
- 58
- 53
- Northern Ireland
- C?ID=109519
Have this out on hire, thought a scan would be beneficial
Thursday,23,August,2018,19:01:39:49196
VCDS Version: 18.2.1.2 (x64)
Workshop Code: 874 00874 000874
VIN: WVWZZZAUZJW219150 License Plate: KG5479
Mileage: 968km-601mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZJW219150 Mileage: 968km-601miles
Address 01: Engine (2D2D2-DDYA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 GT HW: 04L 907 445 E
Component: R4 1.6l TDI H01 3757
Revision: 22005001
Coding: 0111401243451D092000
ASAM Dataset: EV_ECM16TDI03004L906056GT 004004
ROD: EV_ECM16TDI03004L906056GS_004.rod
VCID: 0505E9DA84E10A6C14-8050
Readiness: N/A
Part No SW: 5Q0 614 517 CQ HW: 5Q0 614 517 AC
Component: ESC H25 0423
Revision: 00000000 Serial number: 50458000000436
Coding: 01FA8AA1242109754778060560C32580512490E26006A4733440F078C002430B00000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW27.rod
VCID: 020FF2C695CF3D5431-8056
Part No SW: 5G0 907 426 AQ HW: 5G0 907 426 AQ
Component: AC Manuell H03 1801
Revision: 00001K06
Coding: 00120104202110001000000000000002
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 7AFF8A26FD1F759469-802E
Part No SW: 5Q0 937 084 CN HW: 5Q0 937 084 CE
Component: BCM MQBAB M H36 0253
Serial number: 01001805900373
ROD: EV_BCMCONTI.rod
VCID: 0607EED6B9E701741D-8052
Component: WWS 180212 042 0551
Serial number: 180219170214
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 047 0105
Serial number: S6Y18M02D26H16M27S46
Coding: 00A8DD
Serial number: 000000000ZY1803725XF
Serial number: 00000000000000090783
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418018053
Coding: 0471051801
VCID: 4B911FE2E2053C1C82-801E
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 2B00608151FFC728949C810560400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E774636A1B799B415-806A
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWR3XYBRT
Coding: 98CCC000000000005C0000CF008800000065
VCID: 091DE5EAA8F96E0C70-805C
Belt Pretensioner left:
Serial number: 34169677E05031810255
Coding: 333135
Belt Pretensioner right:
Serial number: 34169676E06031840542
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 303 18
Serial number: 3570000000069950FB2T
Subsystem 4 - Part No SW: ----------- HW: 480 000 303 18
Serial number: 3580000000050AF00C2H
Subsystem 5 - Part No SW: ----------- HW: 480 400 303 18
Serial number: 3510001AF28F9E53140A
Subsystem 6 - Part No SW: ----------- HW: 480 400 303 18
Serial number: 3520001C12929722D45-
Subsystem 7 - Part No SW: ----------- HW: 480 402 602 18
Component: FrontSensor_D 000 6149
Serial number: 35500019D28F9E55957T
Part No SW: 5Q0 953 507 FT HW: 5Q0 953 549 F
Revision: -------- Serial number: 04031804221099
Coding: 0400
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 0D15D1FADC91722C5C-8058
Part No SW: 5G1 920 941 C HW: 5G1 920 941 C
Component: KOMBI 202 1440
Coding: 27A42A002780060001886B011401000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009008
ROD: EV_DashBoardJCIMQBAB_009.rod
VCID: 295D856A48390E0C50-807C
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0007553605
Coding: 030100045F086800FB00005C080F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW27.rod
VCID: 387B502E8393A784DF-806C
Serial number: 39180000324410028085
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6572576804
Component: TSG FS 020 0041
Serial number: 230218EBM28658
Coding: 00310220D001048000001000
VCID: 438137C2CA55F45C7A-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000019764399
Coding: 0D0000
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Coding: 81170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73E1A702DA7504DC2A-8026
Component: TSG BFS 020 0041
Serial number: 240218EBN25876
Coding: 00310020DE01048000801000
VCID: 428F32C6D54FFD5471-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000019638917
Coding: 150000
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 851 0867
Coding: 02731001FF00000051110101008808001F0500C601200100CF
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 326F620665EF4DD4E1-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHV0542295
Subsystem 2 - Part No SW: 3G0 919 866 BJ HW: -----------
Component: ECE1 2018 --- 0915
End-------------------------(Elapsed Time: 03:39)--------------------------
