Saturday,12,May,2018,12:37:55:31796
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Dealer/Shop Name: HS-Werkzeughandel
VIN: 3VWBG6162CM104076 License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 46 4F 52 56 62 72 77
VIN: 3VWBG6162CM104076 Mileage: 87280km-54233miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 AP HW: 07K 906 055
Component: 2,5L 125KW G01 1101
Revision: T4H06--- Serial number:
Coding: 0000071
VCID: 7CA003F82AECA4A72E0-8028
001056 - Catalyst System; Bank 1
P0420 - 000 - Efficiency Below Threshold - MIL ON
Fault Status: 11100000
Mileage: 83071 km
Date: 2017.01.03
Time: 11:44:31
RPM: 1667 /min
Load: 87.8 %
Speed: 87.0 km/h
Temperature: 87.0°C
Temperature: 44.0°C
Absolute Pres.: 790.0 mbar
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 000 - Implausible Signal - MIL ON
Fault Frequency: 62
Mileage: 85703 km
Date: 2012.07.22
Time: 08:30:56
RPM: 1425 /min
Load: 31.8 %
Speed: 38.0 km/h
Temperature: 87.0°C
Temperature: 46.0°C
Absolute Pres.: 930.0 mbar
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: B43B40F8892208FE2D0B02EB911F1061211000
VCID: 7DA60EFC3DF6ADAF19E-8028
013 - Check DTC Memory
Fault Status: 01101101
Página 1
Scan-3VWBG6162CM104076-20180512-1237-87280km-54233mi
Fault Frequency: 33
Reset counter: 192
Mileage: 85508 km
Date: 2012.04.26
Time: 20:04:40
Count: 32768
Count: 4608
Count: 8193
Count: 50944
Count: 767
Part No SW: 5K0 907 044 ER HW: 5K0 907 044 ER
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000004002
Shop #: WSC 00066 000 00119
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 7F5AF4F4377ABFBF0B2-802A
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0064
Revision: BC021001
Coding: 08000A3A882DE3C040080080040001E40370008850A089605C8000000040
VCID: 3E24C9F0707076B7404-806A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 061211 05 54 0403
Coding: 02300A
Subsystem 2 - Part No: 1K8 951 171
Fault Status: 00101010
Fault Frequency: 40
Reset counter: 232
Mileage: 85271 km
Date: 2012.04.05
Time: 00:46:29
Voltage: 10.70 V
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 65
Mileage: 85239 km
Date: 2017.08.31
Time: 00:00:04
Term 15 Off
Voltage: 12.45 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5C6 919 475 HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0005
Revision: -------- Serial number: 84091134700237
Coding: 108001
Página 2
ASAM Dataset: EV_EPHVA18VW3610000 001003
ROD: EV_EPHVA18VW3610000.rod
VCID: 71BE22CC712ED9CF8D6-8024
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6RA6FVSD
Coding: 00003242
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 323CEDC0B4A8A2D7B4C-8066
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME19276666ZZZCrash
sensor for side airbag: front passenger side:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME374C6566ZZZ0
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME13162A16ZZZJ
Serial number: 3526KSME510D2216ZZZK
Part No SW: 1K5 953 501 Q HW: 5K0 953 569 H
Revision: FF010040 Serial number: 20111214301815
Coding: 018A140000
Shop #: WSC 00066 000 00152
VCID: 392EDAEC69DE518F756-806C
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
Part No SW: 5C6 920 871 HW: 5C6 920 871
Component: KOMBI H04 0617
Coding: 171A00
VCID: 698E4AAC59FE210FC56-803C
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 13011201290888
Coding: 351002
VCID: 3D26CEFC7D766DAF59E-8068
Component: IMMO H04 0617
VCID: 6A8C35A05CF82A17CCC-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660997775
VCID: 290E0AAC99FEE10F056-807C
Página 3
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0515
Revision: 12110009 Serial number: 0004011737
Coding: 0010B7
Shop #: WSC 01383 790 50316
VCID: 1C602378C62C04A78E0-8048
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 007 1508
Serial number: 00000006257116
Coding: 000090
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 01030100
VCID: 6FBA24B4679ACF3F9B2-803A
Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Serial number: WRH0003XW3+
Coding: 180000
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0515
Revision: 14110009 Serial number: 0004011047
Coding: 0011B6
VCID: 1D662E7CDD360DAF79E-8048
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1508
Serial number: 00000006271337
Coding: 000090
66562 - Heated Exterior Mirror
B11F8 14 [009] - Open or Short to Ground
Reset counter: 83
Mileage: 82075 km
Date: 2016.09.04
Time: 17:03:50
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L1647172
Coding: 01000410040006
VCID: 23121884FBD23B5F4FA-8076
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661499192
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270A0C948F6AD77F132-8072
End----------(Elapsed Time: 01:30, VBatt start/end: 12.1V/12.2V)-----------
