Results 1 to 10 of 10
Thread: 2010 Audi A6 Quattro(Fault Codes)
    Jul 2017
    I have an issue with my ABS system. I recently changed my driver front wheel and hub bearing, outter tie end rod and driver side wheel speed sensor. Since i have did that my Traction light, TPMS light, and ABS light come on soons i crank my car. If i erase the codes they come back on soons i reach about 5 mph.( Also my cars wobbles only on driver front side and also when i start slowing down it also wobbles.(Image of lights that shows up and VCDS fault codes)
    Lights that come on when car is cranked
    https://imgur.com/a/ymqmZb7
    Tuesday,14,August,2018,17:23:50:05661
    VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WAUKGAFB7AN036515   License Plate:
    Mileage: 159350km-99015mi   Repair Order:
    Chassis Type: FB-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
              56 5F 62 6C 72
    VIN: WAUKGAFB7AN036515   Mileage: 159350km-99015miles
    4C-Tire Pressure II -- Status: Malfunction 0010
    Address 01: Engine (CCA)       Labels: Redir Fail!
       Part No SW: 4F1 910 551 D    HW: 4F1 907 551
       Component: 3.0l V6 TFSI        0050
       Revision: --H06---    Serial number:
       Coding: 0105000A190F0120
       Shop #: WSC 08175 444 103843
       VCID: 2412E4F0D2DA9EF735C-8070
                   U1017 - 000 -
                        Fault Frequency: 164
                        Mileage: 156754 km
                        Date: 2018.07.11
                        Time: 12:03:27
                        RPM: 1248 /min
                        Mass Air / Rev.: 125.4 mg/str
                        Temperature: 79.5°C
                        Bin. Bits: 00000010
                        Load: 9.0 %
    009523 - Ignition Switch; Run/Start Position Circuit
                   P2533 - 000 - Open or Short to Ground - Intermittent
                        Fault Status: 00100001
                        Mileage: 158623 km
                        Date: 2018.08.02
                        Time: 17:47:22
                        RPM: 1344 /min
                        Mass Air / Rev.: 190.8 mg/str
                        Temperature: 76.5°C
                        Bin. Bits: 00000010
                        Voltage: 11.63 V
       Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
       Component: AG6 09L 3,0TFSI USA 0010
       Revision: --H04---    Serial number:        4539555
       Shop #: WSC 02325 785 00200
       VCID: 2A0E0AC8B0FE48870F0-807E
       Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
       Component: ESP8 quattro    H03 0060
       Coding: 0020921
       VCID: 6E86C6D84C9664A7938-803A
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                        Reset counter: 225
                        Mileage: 159333 km
                        Date: 2018.08.14
                        Time: 16:27:42
                        Hex Value: 0x1100
                        Hex Value: 0x4012
                        Hex Value: 0x0006
                        Hex Value: 0x37A7
                        Hex Value: 0x00FF
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602501421794
       Coding: 0000007
       Shop #: WSC 02324 785 00200
       VCID: 2514F9F4D9E067FF222-8070
       Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
       Component: KLIMABETAETIGUNGH30 0080
       Revision: 00000076    Serial number: 00000030563599
       Coding: 0524326
       Shop #: WSC 02335 785 00200
       VCID: 1D64D114F1B0AF3F7A2-8048
       Part No SW: 4F0 910 279 Q    HW: 4F0 907 279 A
       Component: ILM Fahrer      H24 0340
       Coding: 0139123
       VCID: 372823BC734CE56F80E-8062
       Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H10 0040
       Coding: 00056595
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
                010 - Open or Short to Plus
                        Fault Status: 01111010
                        Reset counter: 225
                        Mileage: 150448 km
                        Date: 2018.04.28
                        Time: 21:27:00
                        Reset counter: 225
                        Mileage: 152148 km
                        Date: 2018.05.12
                        Time: 21:29:00
                        Fault Frequency: 11
                        Reset counter: 225
                        Mileage: 144320 km
                        Date: 2018.03.13
                        Time: 01:20:00
                        Reset counter: 225
                        Mileage: 144300 km
                        Date: 2018.03.12
                        Time: 20:40:00
    00156 - Control Circuit for Windshield Washer Pump
                        Reset counter: 225
                        Mileage: 142128 km
                        Date: 2017.12.18
                        Time: 19:00:00
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4F0 035 110 A    HW: 4F0 035 110
       Component: CDC-MP3-Alp   H44 0140
       Revision: AA001001
       VCID: 1574C9340580F77FB22-8040
    Address 15: Airbags (J234)       Labels:| 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
       Component: Airbag AU1042 H06 0160
       Revision: --------    Serial number: 003FA0012RDS
       Coding: 303142373034303030314A55304C34463053
       ROD: EV_Airba10AURB4.rod
       VCID: 36362EB878C61C679B8-8062
       Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
       Component: BF-Gewichtss.  H03 0060
       Serial number: 5810000R0000003W4J
       Serial number: 3574SRB400009FDD0ABV
       Serial number: 3584SRB400009F94E27L
       Serial number: 3516HRB402VC0AS50SV6
       Serial number: 3526HRB402VC0AS4OKNE
       Serial number: 3554NRB40000517EBB79
       Serial number: 3564NRB4000051197E1Z
    12583424 - Powertrain Databus
              U0002 00 [008] - No Communications
              [High Speed CAN Communication Bus no signal/communication]
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90026092900003
       Coding: 0012141
       VCID: 2708F3FCA3EC75EF10E-8072
    Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
       Component: KOMBIINSTR.   H08 0144
       Revision: 00000000    Serial number: CN450YEA9
       Coding: 8BD60A050B00CF05020201
       Shop #: WSC 02391 823 56573
       VCID: 313C1DA491283B5FCEA-8064
       Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0035
       Revision: LB100029    Serial number: 2900L09A1700BA
       Coding: 000303
       VCID: 392C25844958F31F76A-806C
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790718207
       Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
       Component: MEM-FS        H08 0062
       Revision: AA000000    Serial number: 00001010017085
       Coding: 00581B00004011110000
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000102168472
       Coding: 011F57204E40410001
       VCID: 46D65E7808A68CE70B8-8012
       Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
       Component: Komfortgeraet   H29 0250
       Revision: 02500029    Serial number: 01229654010000
       Coding: 4618269
       VCID: 353429B46940177F922-8060
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
       Component: BOSE G3 C6    H01 0100
       Revision: AG001300    Serial number: 00000000041814
       Coding: 05000000
       VCID: 290CF5C4B9F8439F06A-807C
       Part No SW: 4F0 910 274 A    HW: 4F0 907 274
       Component: J793  RKA+      H02 0100
       Revision: 00000506    Serial number: 00005061074829
       Coding: 0623301
       VCID: 221EE2E8C8CE90C7470-8076
    02214 - Tire Pressure Warning
                000 -  -  - Intermittent
                        Reset counter: 250
                        Mileage: 158330 km
                        Date: 2018.07.30
                        Time: 22:55:35
                        Hex Value: 0x0002
                        Hex Value: 0x0000
                        Hex Value: 0x0007
                        Voltage: 13.70 V
                        Temperature: 37.0°C
                        (no units): 98.0
                        Fault Status: 11101101
                        Reset counter: 225
                        Mileage: 156754 km
                        Date: 2018.07.11
                        Time: 12:03:29
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0007
                        Voltage: 13.70 V
                        Temperature: 33.0°C
                        (no units): 83.0
       Part No SW: 4F0 910 280     HW: 4F0 907 280 C
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000509539
       Coding: 0002014
       VCID: 5EE69618BC36F427238-800A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000102131826
       VCID: 45D4597435A087FF022-8010
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0000222
       Shop #: WSC 02145 785 00200
       VCID: 211CEDE4CDC88BDF5EA-8074
                        Fault Status: 00101101
                        Fault Frequency: 51
                        Reset counter: 9
                        Mileage: 159312 km
                        Date: 2018.08.14
                        Time: 13:28:34
                        Voltage: 12.63 V
                        Count: 236
       Part No SW: 4L0 910 357     HW: 4L0 907 357
       Component: AFS 1           H01 0060
       Coding: 0000026
       VCID: 698CB5C47578839FC6A-803C
       Subsystem 1 - Part No: -----------
       Component: AFS-Modul links
       Subsystem 2 - Part No: -----------
       Component: AFS-Modul rechts
    02071 - Local Databus
                        Fault Status: 11100100
                        Reset counter: 94
                        Mileage: 142129 km
                        Date: 2017.12.08
                        Time: 22:37:28
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335J-097535137
       Coding: 020000010000000000
       VCID: 1D64D114FDB0AF3F7A2-8048
       Part No SW: 4E0 035 664 A    HW: 4E0 035 664 A
       Component: H-BN-NA       H45 0042
       Revision: --------    Serial number: 488J/097520192
       Coding: 010200000002E1FE41000304EF6300030000
       VCID: 221EE2E8C4CE90C7470-8076
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356JX091091752
       Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
       Component: Bedienteil MM  H01 0060
       Serial number: 00000001422512
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
       Revision:             Serial number: 0000009496373
       Coding: 010E57204040220001
       VCID: 43D0476C3B94B9CF2C6-8016
       Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
       Revision: --H03---    Serial number: 525PA8-J9925BW
       Coding: 1000304
       Revision:             Serial number: 0000009496374
    End----------(Elapsed Time: 01:52, VBatt start/end: 13.4V/13.4V)-----------
    Address 03: DTCs cleared
    Do your work over and check parts plus seek professional help if above your skill level, right?
    Induced FOD..........
    JPPSG & RTFB are a must no?
  3. Likes Fredrick Awuor liked this post
    Jul 2017
    I mean it still drives it just wobble when i drive and start braking. I was wondering if it could be that the abs system lost memory are if my rotor warped just wanted opinions before i start replacing parts.
    Jul 2017
    Im confused at what you are saying
    Quote Originally Posted by Cobie90 View Post
    I would check the wheel is OK, that the hub bearing has been properly fitted and the brake disc correctly re-fitted.
    It sounds like something is out of true causing the woble when you brake.
  7. Likes Uwe, Jack@European_Parts liked this post
    Jul 2017
    Ok thanks ill check back over my work but have you ever heard of rotors warping
    Rotors show warpage typically when you apply the brake & due to uneven braking surface as a result of overheating ,incorrect camber/toe settings, warn pads, stuck/faulty caliper/brake carrier slider or corrosion.
    Your statements imply you should not be doing these repairs or you are unsafe as a result is my opinion.
  10. Likes Fredrick Awuor liked this post
  11. #8
    Jul 2017
    I mean i changed everything properly because i did the passenger side and my car drove fine but when i changed the driver side my car started shaking and its just on my driver side...and the only fault code is
    Abs front left wheel speed sensor "Implausible signal" (G47) which is sending fault codes to my Abs module and is making my parking brake, Tpms, traction and abs light come on
  12. #9
    It's a very common problem, mentioned on almost every car owners forum.
  13. Likes Uwe, Jack@European_Parts liked this post
  14. #10
    Jul 2014
    Brake disk distortion will cause a vibration when braking, it will not cause a 00283 DTC. Did you use new parts or used? I am with Jack, you have introduced your problem. Recheck what you have done and if you used old parts change them for good quality new parts.
    Regards HMC
