Results 1 to 6 of 6
Thread: Mk7 Golf/GSW LED Reverse Light Coding
    Verified VCDS User Blade3562's Avatar
    May 2017
    Picked up some Phillips 921 LEDs to improve the awful reverse light brightness on my Mk7s. I currently have no bulb errors, but I want to code them properly to insure it stays that way!
    The light channels are Leuchte 28RFL and Lecuthe 29RFL. For the led plate lights I had to change lasttyp to "43 - allgemeine LED" and change dimmerwert AB from 100 to 127.
    I understand the dimmerwert function adjusts brightness and the full brightness for LEDs is 127. Sadly I'm lost when it comes to the bulb types. When I reference the available bulb types it seems there are several LED lasttyp that would for this application, mainly 32, 37, 40, 43, and 45.
    Jun 2017
    Just try 43. It does no harm.
    The worst thing that could happen is that you get a bulb error. Then try another Lasttyp.
  3. Likes Blade3562, Uwe liked this post
    May 2017
    Hadez looks like 43 works! Thanks! Any explanation on the differences between the different LED lasttyps or should I just assume 43 automatically for any general non brake/turn/headlight LED
    Jun 2017
    Behind each Lasttyp (load type) is propably a specific resistor value regarding bulb error detection.
    The most common goal is to get it to work so you pick any Lasttyp that brings no error.
    What we do not know is if there really came an error when the bulb is faulty because of any hardcoded resistor value...
    As LEDs do not break that often...this might not be that important.
  6. Likes Uwe liked this post
    ^^^ Blade: Notwithstanding hadez16's sage reply, I suspect the problem with your first choice of Lasttyp setting, was your dimmwert setting.
    Not all LED settings in the Lastyyp channel will support a value of 127 - lots still have a max setting of 100 (just like incandescent lamps). This doesn't mean that the illumination is any less - it simply means less graduations between max and min values.
  8. Likes AutosoundT% liked this post
  9. #6
    Don - is there a definitive (or even partial) list of the maximum value for all Lasttyp values? - or is that WIP?
