Results 1 to 10 of 17
Thread: 2018 Sportwagen Comforline Sign Recognition Coding
    Oct 2017
    Canada
    I'm trying to get Sign Recognition working on our 2018 Sportwagen Comfortline with DAP. I followed the following steps:
    Select Control unit 5F (Information Electrical)
    Adaptation
    Select Car_Function_List_BAP_Gen2 traffic_sign_recognition_0x21
    Değer=Active
    Select Car_Function_Adaptations_Gen2-menu menu_display_road_sign_identification
    Değer=Active
    Go to Long Coding
    Byte 24, Activate Bit 6
    Control unit A5 (front / advance camera)
    Security access
    Access Code 20103
    Control unit Long Coding
    Byte 16, Activate Bit 4
    Select Control unit 17 (Dashboard)
    Byte 5
    Activate Bit 2
    Adaptation
    Road Sign Detection Fusion Mode
    Change to ‘Road Sign Detection’
    Reboot Infotainment
    Sign Recognition isn't working.
    I get no faults with the original coding for Module 5F is:
    02731200FF00000051220001001828001F0500D40120050002
    I get faults when I code 5F to:
    02731200FF00400051220001001828001F0500D40120050002
    Sunday,19,August,2018,11:43:10:04451
    VCDS Version Release 18.2.1 (x64) Running on Windows 10 x64(VirtualBox)
    Address 5F: Information Electr. Labels: 5G0-035-MIB-STD2.clb
    Control Module Part Number: 3Q0 035 844 B HW: 3Q0 035 844 B
    Component and/or Version: MU-S-S-US 721 0842
    Software Coding: 02731200FF00400051220001001828001F0500D40120050002
    Work Shop Code: WSC 00066 790 00073
    ASAM Dataset: EV_MUStd4CDELP 001001 (VW37)
    ROD: EV_MUStd4CDELP_VW27.rod
    VCID: 2E0606D900965347D38-807B
    Fault Codes have been Erased
    1543 - Control Module Incorrectly Coded
    U1014 00 [009] - -
    Reset counter: 137
    Mileage: 7870 km
    Date: 2018.08.19
    Time: 12:42:28
    Voltage terminal 30: 14.0 V
    Byte_Coding_Condition-byte_0_condition: OK
    Byte_Coding_Condition-byte_1_condition: OK
    Byte_Coding_Condition-byte_10_condition: ERROR
    Byte_Coding_Condition-byte_11_condition: ERROR
    Byte_Coding_Condition-byte_12_condition: ERROR
    Byte_Coding_Condition-byte_13_condition: ERROR
    Byte_Coding_Condition-byte_14_condition: ERROR
    Byte_Coding_Condition-byte_15_condition: ERROR
    Byte_Coding_Condition-byte_16_condition: ERROR
    Byte_Coding_Condition-byte_17_condition: ERROR
    Byte_Coding_Condition-byte_18_condition: ERROR
    Byte_Coding_Condition-byte_19_condition: ERROR
    Byte_Coding_Condition-byte_2_condition: OK
    Byte_Coding_Condition-byte_20_condition: ERROR
    Byte_Coding_Condition-byte_21_condition: ERROR
    Byte_Coding_Condition-byte_22_condition: ERROR
    Byte_Coding_Condition-byte_23_condition: ERROR
    Byte_Coding_Condition-byte_24_condition: ERROR
    Byte_Coding_Condition-byte_25_condition: ERROR
    Byte_Coding_Condition-byte_26_condition: ERROR
    Byte_Coding_Condition-byte_27_condition: ERROR
    Byte_Coding_Condition-byte_3_condition: OK
    Byte_Coding_Condition-byte_4_condition: OK
    Byte_Coding_Condition-byte_5_condition: OK
    Byte_Coding_Condition-byte_6_condition: ERROR
    Byte_Coding_Condition-byte_7_condition: OK
    Byte_Coding_Condition-byte_8_condition: OK
    Byte_Coding_Condition-byte_9_condition: OK
    There are no other faults. I'm using VCDS 18.2.1. Should I try a different version?
    Jun 2014
    Poland
    Quote Originally Posted by kfr- View Post
    is radio or Satnav ?
    Mar 2015
    Australia
    Why are you changing byte 6 in 5F?
    That's part of the speaker config.
    You should leave that alone...
    I think you are meaning to change byte 24 (the very last byte in your 5F coding string) from 02 to 42. This will enable traffic sign display (VZE).
    So your 5F coding should be:
    02731200FF00000051220001001828001F0500D40120050042
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
    ^^^^ just to add to my fellow countryman's sage advice- here's a more readable form of the code-strings on your hex5F module:
    Name	old code-string		new code-string
    Byte	Hex	Binary	        Hex	Binary
    0	02	00000010	02	00000010
    1	73	01110011	73	01110011
    2	12	00010010	12	00010010
    3	00	00000000	00	00000000
    4	FF	11111111	FF	11111111
    5	00	00000000	00	00000000
    6	00	00000000	40	01000000
    7	00	00000000	00	00000000
    8	51	01010001	51	01010001
    9	22	00100010	22	00100010
    10	00	00000000	00	00000000
    11	01	00000001	01	00000001
    12	00	00000000	00	00000000
    13	18	00011000	18	00011000
    14	28	00101000	28	00101000
    15	00	00000000	00	00000000
    16	1F	00011111	1F	00011111
    17	05	00000101	05	00000101
    18	00	00000000	00	00000000
    19	D4	11010100	D4	11010100
    20	01	00000001	01	00000001
    21	20	00100000	20	00100000
    22	05	00000101	05	00000101
    23	00	00000000	00	00000000
    24	02	00000010	02	00000010
    Note Byte 6, bit 6 has been altered instead of Byte 24, Bit 6
  5. Likes Uwe liked this post
    Jun 2017
    Okay...
    1) one channel is missing in 5F:
    Car_Function_Adaptations_Gen2-menu menu_display_road_sign_identification_over_treshold_high
    2) return to "Fusion" in your A5 adp channel
    Where did you read to change that????
    3) leave the 5F coding original, not necessary
    Follow these steps, ignition off, ignition on, restart DAP, delete all DTCs.
    Report back.
    And please deliver a full Auto-Scan!!
    Oct 2017
    Canada
    I don't have NAV. It's just a radio.
    Oct 2017
    Canada
    Okay...
    Report back.
    Here is the autoscan https://drive.google.com/file/d/14vM...ew?usp=sharing
  9. #8
    Oct 2017
    Canada
    https://forums.vwvortex.com/showthre...n-2018-R-in-NA
  10. #9
    Dec 2016
    Amsterdam
    Not sure if TSR works without nav. Even though it reads signs with the camera, nav data is extensively used as a redundancy.
    Current:
  11. Likes Uwe liked this post
  12. #10
    Jun 2017
    Then forget it.
    At least Discover Media needed.
  13. Likes PetrolDave, Uwe liked this post
