Results 1 to 5 of 5
Thread: Module BF02, does VCDS show this?
    Tartu, Estonia
    Hello
    During AID retrofits I've encountered a module BF02 not being registred when identifying with ODIS.
    Is this something that's hidden somewhere or can VCDS also show this?
    When doing AID retrofit i always use ODIS - You know, immobiliser and stuff... and i think that is the reason I've never encounter such thing in VCDS.
    gif upload
    The world is my oyster...
  2. Likes downtime liked this post
  3. #2
    What kind of car is this?
    Tartu, Estonia
    Any car with VC/AID i guess.
    http://forums.ross-tech.com/showthre...-1-8TSI-MY2018
    But i think I figured out where this is selected. In 5F adaption channels:
    IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module
    But can it be worth adding to VCDS autoscan gateway list?
    Dec 2016
    Amsterdam
    Nice one, didnt spot that module yet.
    Would it be possible to add a tree-type control module list at some point? Could be handy, since most cars now have two masters; 19 for CAN networks and 5F as MOST-busmaster.
    Would also make entire networks not communicating more obvious.
    Current:
    Tartu, Estonia
    Today I encountered similar "problem" with Audi A6 MY2016. If You take any autoscan of this car it doesn't show amplifer, because it is installed in MOST bus from MIB and not GW.
    Tuesday,03,December,2019,20:28:30:57784
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
    Dealer/Shop Name: LeVWFreaks.eu
    VIN: WUAZZZ4G3GN   License Plate:
    Mileage: 40878km-25400mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 22 28 36 3B 3C 42
              44 46 52 53 55 5F 62 65 6C 6D 72 82 84 85 8B 8E 8F 90 BA
    VIN: WUAZZZ4G3GN   Mileage: 40878km-25400miles
    84-Night Vision -- Status: OK 0000
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CWUB)       Labels: Redir Fail!
       Part No SW: 4G0 906 560 F    HW: 4H0 906 014
       Component: V8 4.0l TFSI  H63 0005
       Revision: NCH63---
       Coding: 122A00326546090B3000
       Shop #: WSC 57251 003 1048576
       ASAM Dataset: EV_ECM40TFS0114G0906560F 001006
       ROD: EV_ECM40TFS0114G0906560F.rod
       VCID: 2B000D0F638B2BDF4C5-807E
    5270 - Output for Starter Relay
              P0615 00 [032] - Open Circuit
                        Mileage: 40609 km
                        Date: 2019.12.01
                        Time: 11:12:28
                        Engine speed: 664.00 /min
                        Normed load value: 7.1 %
                        Coolant temperature: 56 °C
                        Intake air temperature: 16 °C
                        Voltage terminal 30: 14.347 V
                        Unlearning counter according OBD: 26
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
       Part No SW: 4G0 927 158 AN    HW: 0BK 927 156 AM
       Component: 0BK 40TFSIRdW H19 1002
       Revision: --H19---
       Coding: 000001
       VCID: 7AAEF84BDC514257873-802E
       Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
       Component: ESP9 Premium  H01 0100
       Coding: 64BF994926FD99929F00
       ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
       VCID: 42DE40ABF401CA979F3-8016
       Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
       Component: BCM2 2.0      H37 0572
       Coding: 05A96F0E000000000000
       VCID: 7DA4F357CDFF756FA21-8028
       Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
       Component: KLIMA 4 ZONEN H14 0112
       Coding: 680210B8150000
       VCID: 6A8EC80BACF1F2D7773-803E
       Part No SW: 4H0 907 063 EK    HW: 4H0 907 063 EK
       Component: BCM1 2.0      H20 0367
       Revision: 25020001    Serial number:
       Coding: 0105001440349FF2F90140C7A0001800CF9CC7082E08020180000894E101130200400019010000
       VCID: 75B4EB77F5CF2D2FEA1-8020
       Component: WWS57X 151018  H38 0080
       Coding: 0045F7
       Coding: 0200FD
       Subsystem 3 - Part No SW: 4G0 941 531 BH    HW: 4G0 941 531 BH
       Component: E1 - LDS  H07 0044
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Coding: 020300
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0080
       Coding: B82B27
       ASAM Dataset: EV_EPHVA2CAU64X0000 001014
       ROD: EV_EPHVA2CAU64X0000.rod
       VCID: 36362C7BA8C9663723B-8062
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Coding: 7E04010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 290CF707697739CFBE9-807C
    Address 14: Susp. Elect.        Labels: None
       Part No SW: 4G0 907 376     HW: 4G0 907 376 A
       Component: J250 DRC FahrwerH02 0040
       Coding: 0000000
       VCID: 6B80CD0FAF8BEBDF0C5-803E
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Coding: 30333130313730323630554A304C34473053
       VCID: 3B203D4F93EBBB5FDC5-806E
       Serial number: /
       Serial number: .
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Coding: 0000FD
       VCID: 3728217FAF439F3F38D-8062
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Part No SW: 4G0 920 931 M    HW: 4G0 920 931 M
       Component: TBenRdwAccNv  H11 0106
       Revision: 08001098    Serial number:
       Coding: 138F110BAFD50008000400
       ASAM Dataset: EV_RBD4K 004055
       ROD: EV_RBD4K_AU57.rod
       VCID: 303A1A634AAD4807797-8064
       Part No SW: 4G8 907 468 F    HW: 4G8 907 468
       Component: J533--Gateway H14 0083
       Coding: C0ED07481C
       ASAM Dataset: EV_GatewPkoUDS 001028
       Voltage stabilizer:
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Coding: 010100
       VCID: 3A2E384B9C518257C73-806E
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H17 0200
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 280AF203727D00C7A17-807C
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0112
       Coding: 20
       VCID: 3E26345B80F9AE77FBB-806A
       Revision: AA000000    Serial number:
       VCID: 77A8E17FEFC35F3FF8D-8022
       Component: SARA 6D red   H04 0056
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3728217FAFC39F3F38D-8062
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H08 0060
       Coding: 040311
       VCID: 392C274799D7894FCE9-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0060
       Coding: 040311
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0511
       Coding: 011F16015E00628002080013
       VCID: 45D45BB7E5AFFDAFBA1-8010
       Component: RCevo         H53 0202
       Revision: 00000003    Serial number:
       Coding: 011101010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2E384B9CD18257C73-806E
       Revision: 00002001    Serial number:
       Coding: 013A0E20A0B93081C33009840C0312470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 A
       Component: Sensor, DWA  005 0002
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Coding: 011F16015E00628002080002
       VCID: 46D65CBBD8A9F6B7B3B-8012
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D0403175D9F25EF521-8078
       Coding: 04FA0A202A1F0200
       VCID: 34321673BEB574271DF-8060
       Coding: E01F00
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Left:
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0031
       Coding: E01F00
       Matrix Headlamp Powermodule 1 Right:
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0031
       Coding: E01F00
       Part No SW: 4G1 035 021 N    HW: 4G1 035 021 D
       Component: MU-H-LND-EU   051 1425
       Coding: 017562010000000013111102000A00132F0008E5F17001009F
       VCID: 2514FB37056F1DAF9A1-8070
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Multimedia Operating Unit:
       Component: Gracenote2  --- 1017
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
                        Reset counter: 137
                        Mileage: 40878 km
                        Date: 2019.12.03
                        Time: 20:26:17
                        Voltage terminal 30: 14.9 V
                        Software module: status-SW_Status_Consistency: 00 28 13
                        Software module: status-SW_Status_Device: Mmx2Mmx2Mmx2M
       Coding: 010F14014000628002080002
       VCID: 49CC5787C9B719CF5E9-801C
    Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
       Component: RDKBERU25     H10 0820
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 2A0E080B6C7132D7B73-807E
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 027500010A002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
       VCID: 78AAE243E25D5047F17-802C
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0151
       Revision: 14005001    Serial number:
       Coding: 093205C030
       ROD: EV_HDSGAu571.rod
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
       Component: HeadUpDisplay H08 0306
       Coding: D70000
       ASAM Dataset: EV_HUDContiC7 001027
       ROD: EV_HUDContiC7.rod
       VCID: 35342B77B5CF6D2F2A1-8060
    Address 84: Night Vision (J853)       Labels:* None
       Part No SW: 4G0 907 547 A    HW: 4G0 907 547
       Component: NV-ECU-Gen3   H08 0107
       Coding: 301100
       ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
       ROD: EV_NightVisioGen3AE4AU64X.rod
       VCID: 2C020E1366852CE745F-8078
       Camera For Night Vision System:
       Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
       Component: NV-CAM-Gen3  H03 0006
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 6A160000
       ROD: EV_OnBoardCamerDPC.rod
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E04010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 2708F13F7F630FBFA8D-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Coding: 04C0BB1B1111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Component: RGS-VL        H14 0080
       Coding: 0066E608031F0376070308014240C0010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313C1F6741A7410F769-8064
       Component: RGS-VR        H14 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 323E106B44A17A170F3-8066
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H10 0008
       Revision: 00001001    Serial number:
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X_AU57.rod
    End----------(Elapsed Time: 02:39, VBatt start/end: 14.7V/14.7V)-----------
    It is reachable directly though.
    Tuesday,03,December,2019,20:28:51:57784
    VCDS Version: Release 19.6.2 (x64)
                    Address 47: Sound System
    Control Module Part Number: 4G5 035 223 E
      Component and/or Version: MIB2_amp_P    H02 0440
               Software Coding: 01756208018AF02A5A0000010000
                Work Shop Code: WSC 02391
                          VCID: 2412E6330E55E4A78DF-8070
    Advanced Identification/FAZIT
         Identification: BGE-001
         Date: 10.01.16
         Manufacturer number: 0233
         Test stand number: 1784
    Flash Status
         Programming Attempts(data): 3/3/3/0
         Successful Attempts(data): 3/3/3/3
         Flash Tool Code(data): 00200 785 02391
    Misc.
         Hardware number: 4G5 035 223
         Workshop System Name: J525
         Equipment/PR Code: 00000000000000000000000B
         Dataset Number: 4G1909510L
         Dataset Version: 0011
         ASAM Dataset: EV_AMPMst16C4Gen2BOSE
         ASAM Dataset Revision: 001001
    Car Info
         Chassis Number: WUAZZZ4G3GN
    VCDS Info:
           Labels: None
           ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
    Tuesday,03,December,2019,20:29:12:57784
    VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
    LeVWFreaks.eu
                    Address 47: Sound System       Labels: None
    Control Module Part Number: 4G5 035 223 E    HW: 4G5 035 223
                Work Shop Code: WSC 02391 785 00200
                  ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001 (AU57)
  7. Likes Uwe, Dana, PetrolDave liked this post
