I've been struggling (and failing) to get my 2017 A4 Premium BASE to open and close its windows from the key radio remote (no advanced key/kessy installed).
In the process, I apparently broke my sunroof settings and calibration. I've been playing in modules 09 and 46 primarily, both long coding and adaptation. I have tried returning the long coding to my original values, but don't have a way of doing that with adaptations. I did not keep a log of every adaptation setting I made (lesson learned).
When I tried the sunroof, the new non-knob sunroof switch is all different then it was before my coding. only 2 of the positions do anything (open and close manually), and the fully closed position is not an automatic stop - If I want to close it I have to precisely find that place and release the button. AAlso, the "dip" it did before when closing from the vent position is completely gone.
After turning off the car and back on, it got worse. it now only opens about a third of the way, and still has all the symptoms listed above.
I assume (guess) that when I changed some setting, it erased the factory calibration and "home" position. I see some basic settings for normalization and calibration, but I don't know what is what so I haven't touched them for fear of making it worse.
a) can someone send be the appropriate service manual page(s) for sunroof?
b) what is the process for recalibrating the sunroof and setting the home position?
c) any ideas on what coding I messed up to eliminate the automatic functions of the sunroof? I'm holding out some hope they will come back after calibration.
Thanks!
Dave
Thanks!
Dave
