Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 166
Thread: B7 RS4 rough idle nightmare - HELP PLEASE (reward offered!)
  1. #21
    Aug 2018
    Washington State, near Portland, OR
    OP Verified. Moving to Car Repair Support.
    Thanks, Uwe!
  2. #22
    Post OBD2 0x33 MODE 9 please..........?
    Also post this.
    0x01-10-091
    0x11-10-091
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
    Thank you
    Firmware looks up to date at 0060 but I'm wondering if the thing is tuned...........?
    Continue to compile.........
    Ground wires for every coil pack must be overlay-ed & with a sufficient bus to carry ground back to battery directly!
  3. Likes DPNW liked this post
  4. #23
    Aug 2018
    Thanks, Jack!
    Not sure I'm using the OBDII function correctly, but I've done my best to do as you directed. I don't have a controller at address 0x33 and am not sure how to perform OBDII functions on a specific controller, anyway. But going through the generic OBDII function on the main menu, then mode 9, yields the following data (shown as a picture as the "copy" and "save" functions are not functioning in the Mode 9 screen). Seems like VCDS is still working on something after producing this data (it says "running....", but no amount of waiting yielded more data). Let me know if you need more.
    Both 0x01-10-091 and 0x11-10-091 have a value of 4.
    How can I find out if it is tuned or not?
    Not sure how to take action on your statement regarding grounds for the coil packs. Please advise.
    Many thanks!
  5. Likes Jack@European_Parts liked this post
  6. #24
    Vehicle Identification No. WUARU78E57N904981
    Model audi rs4 qu. 4.2
    RS4
    Date of production 30.11.2006
    Year 2007
    Sales type 8EC5X9
    Engine Code BNS
    Transmission Code JMH
    Controllers started life as 8E1-910-560F than superseded to 8E1-910-560A or AX as per TSB.
    Latest firmware level is indeed 0060 but I would look to see if the controllers were modified or taken apart to see original part number on cases or if they were just updated by re-flash at dealer.
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PA Standard wheel bolts
    Vehicle class differentiation units/platform components 0CS Vehicle class differentiation -8E0-
    tail pipe 0P0 Rear exhaust tailpipe (standard)
    Emission standard 7GA Emission standard LEV 2
    Trailer hitch 1D0 without trailer towing
    airbag 4UB Airbag for NAR
    Label for central electric 0W2 Label for central electric system English-speaking countries
    Tray areas package QE1 Storage compartment package 1
    Applications GS2 Stainless steel applications
    Exterior mirror setting 6XM Exterior mirrors with memory feature, auto-dimming, power-adjustable/heated
    Left exterior mirror 5SG Left exterior mirror, flat
    Right exterior mirror 5RW Right exterior mirror, convex (US) large viewing field
    Drive type 1X1 Four-wheel drive
    Equipment levels A8U Executive US equipment
    Brake type in rear 1KY Disc brakes in rear
    batteries J0B 520 A (92 Ah) battery
    Brake type, front 1LP Disc brakes in front
    Components with special surface 6FL Exterior mirror housings in matte aluminum
    Component part sets with country-specific design requirements B0A build parts set without county specific documentatio
    Owner's manuals 0VM Information kit in American English
    CD ROM/DVD/SD card 7RS DVD (NAR)
    CD changer/CD player 7A2 CD changer
    General operating permit, alterations C00 Operating permit, initial registration
    Shock absorption/suspension, chassis 2MC Sports running gear with variable damping
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Double DIN/dual-view display 2T1 Double-sized standard (DIN)
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Load-through hatch/ski bag 3X1 Load-through hatch with ski bag
    Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
    Theft protection system 7AN Anti-theft alarm system, backup horn and towing protection
    Inserts 5TG Decorative inserts, brushed, matte aluminum
    Scuff plates 7M7 Scuff plates in door apertures
    Park distance control 7X1 Park distance control
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    Hood and trunk stay 5NC Standard tailgate vent lock
    Headlight activation 8K9 Daytime headlights with automatic headlight control and coming home function
    Fresh air intake for passenger compartment (with particulate filter) 2V1 dust-pollen filter
    Antifreeze 1C2 Antifreeze up to -35 degree celsius tolerance up to -40 degree C
    Front spoiler 5L1 Front spoiler
    Alternators 8GH Alternator 190 A
    Transmission types/gearshift mechanisms 0G1 Gearshift lever
    Transmission shafts, rear axle 1YF Transmission shafts for rear axle, diameter 75.5
    Transmission shafts 1WG Transmission shafts 88 mm in diameter
    Weight category rear axle 0YM Weight range 12 installation control only, no requirement forecast
    Weight category front axle 0JK Weight category front axle weight range 10
    Base engine TK7 8-cyl. petrol engine 4.2 l assembly 079.D (ALU)
    Tie down straps/net/pocket 6M4 Load protection system
    cruise control system 8T1 Cruise control system (CCS)
    Garage door opener VC1 Garage door opener
    Transmission specifications G0L Six-speed manual transmission for four-wheel drive vehicle
    Cruise control system and speed limiter 6Y8 Speed limiter
    Rear trim panel 6V2 Rear trim panel
    Rear spoiler 5J4 Body-colored rear spoiler
    Molded headliner 6NJ Standard molded headlining
    Rear seats 3NZ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8EH Bi-functional headlamps with gas discharge lamp, for driving on the right (US design)
    Customized installation FC0 Without individual installation
    Instrument clusters U1B Instrument cluster with mph speedometer, clock, tachometer and trip odometer
    Instrument panel 4N0 Standard dashboard (Leather trimmed minor gauges + Ipod drawer)
    Breakaway interior rearview mirror 4L7 Breakaway interior rearview mirror, auto-dimming, with compass
    Body style K8B Notchback
    Luggage compartment floor covering 6SS Luggage compartment floor covering
    Cassette and CD storage unit 4W0 without cassette / CD tray
    coolbox 1W0 Without refrigerator/glove compartment cooling system
    Fuel quantity for initial filling 1Z6 Increase in initial standard fuel filling
    Fuel systems 0F2 Fuel system for SI engine
    Body measures 5C1 Body measures for increased safety requirements
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K4 with no paint conversation
    Light package (lighting) QQ1 With additional lights (interior lighting)
    Steering system arrangement L0L Left-hand drive
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Lumbar support 7P1 Power adjustable lumbar support in front seats
    steering wheels 2FS Leather-wrapped multi-function sports steering wheel
    Speaker installation 8RY loudspeaker with BOSE-sound
    Headlight range control 8Q5 Dynamic headlight range control, with cornering light (AFS 1)
    Center armrest 6E7 Front center armrest
    Versions FN1 "RS" version
    Multi-function display/trip computer 9Q4 Multi-function display/trip computer with check control
    center console 3D2 center console
    Engine cooling 8Z5 not hot country
    Engine specifications D0W 8-cylinder petrol engine 4.2 L/309 KW (32 V) FSI, homogeneous Basic engine is: TK7/TV7
    Navigation device 7Q2 navigation system with colour screen
    Upgrading measures GP1 Vehicles with special upgrade measures
    Rear of platform module base 4P2 Rear floor panel module, type 3
    Audi Sport/ Quattro GmbH FQ1 Wheels of Audi Sport/ Quattro GmbH
    Quality class AQ0 Standard-production quality
    Wheels C5K Alloy wheels 9J x 19 -- painted, style:- 5 thin spokes
    Radios 8AY Radio navigation system
    Tire pressure monitoring system 7K7 Tire pressure monitoring system 433 MHz Basic
    tire H6Q Tires 255/35 R19 Y
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G8 Breakdown kit
    WIP RS 4 premium package
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q7 Gearshift knob in leather in aluminum look
    Self-collection / special control A00 No self-collection
    Special labels/plates 0SS Labels in English and French
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Bumper systems VJ4 bumper reinforced
    Seat belt check 9P5 Visual and acoustic seat belt reminder, electric contact
    seat covers N0Q Seat trim covers in leather
    Seat adjustment 3L4 Electric seat adjustment for both front seats, driver's seat with memory system
    seat heater 4A4 Seat heater for front and rear seats separately controlled
    Safety certificate 1QE Special labels safety certificate for Massachusetts
    Control number (no PR family) S2S Control (in-plant)
    Audio-response system/voice control QH0 without voice control
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Sunroof roller blind for rear/side windows 3Y5 Electric roll-up sunshade for rear window, mechanical for rear side windows
    power outlet 7B2 12 volt socket in luggage compartment
    Handling production and pre-production FA0 Control of standard production
    Headlamp washer system 8X1 Headlamp washer system
    Door and lid locking system 4K8 Central locking w/ radio remote contr., interior controls in fr./rr. and sep. trunk release, two-stage unlocking
    Type approval countries/countries with special requirements B34 Legal requirements USA
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Transit coating NT1 Transit coating (type 2)
    TV reception/digital radio reception QV8 Satellite radio reception NAR
    Assembly parts for engine (drive bearing) 1VJ Assembly part for 8-cyl. engine
    Identification plates 1EP Special identification label (USA)
    Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
    First aid kit / warning triangle 1T1 First aid kit
    Front seats Q1E Recaro sports seats in front
    Telephone / telematics 9ZG preperation for mobile phone with hands free teleph.
    Windshield Glass 4GP Windshield in heat-insulating glass with sunshield and viewing window for vehicle identification number
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZL Matte aluminum decorative trims
    Additional child seat anchors 3B7 Child seat anchors as per Canadian requirements a. ISOFIX child seat system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  7. Likes DPNW liked this post
  8. #25
    May 2016
    Hey, morning.
    On a new tablet so this might be SCREWED UP.
    Noted last file of page 2, voltages falling, is that a new issue or may be testing a bunch, now it is low, can bite you, make sure charge it if so, been there done that.
    Not wanting to sound dumb but noticed MBAR, staying at 980 regardless of RPM, if this is baro, my bad, but if manifold pressure it is not moving. Any way came in late an not used to this tablet, so if I sound stoned, I'm not, good luck.
    LARRIMORE
  9. Likes DPNW liked this post
  10. #26
    Crimp tests can be done with needle nose vise grips using caution or smooth jaw pinch clamp pliers.
    Rubber plugs/wedges can also be used to isolate the intake lines from booster and N80 etc... & to focus on the bank or just intake area.
  11. Likes Uwe, DPNW liked this post
  12. #27
    Aug 2018
    Quote Originally Posted by Larry Manton View Post
    ...noticed MBAR, staying at 980 regardless of RPM, if this is baro, my bad, but if manifold pressure it is not moving...
    LARRIMORE
    Thanks, Larry! You're right on the voltage. I've been trying to stay on top of that using a charger, jumper cabling in a second battery, or both. Just one more thing I don't want to deal with. Thanks for pointing that out! Would definitely be bad if I missed that.
    Not sure on the MBAR being constant. Anyone else - is that an issue or as it should be?
    Thanks, Jack. Will work on this later this evening.
    So, my current list of activities to perform:
    A. Check compression on all cylinders
    B. Visually inspect ECUs for marked part number
    C. Check fuses/battery connections in general
    D. Do crimp tests to isolate vacuum leak
    E. Measure crankcase vacuum via modified oil cap (should have the tools and the extra oil cap necessary to complete this later this week)
    Outstanding questions I have:
    1. What is "PR-Build data" requested in JPPSG? I believe, scattered in this thread, I have provided the rest of the requisite data.
    2. Please let me know what else I need to do to complete JPPSG procedure.
    3. Further feedback on fuel injectors and if replacing them with brand new OEM is still necessary. Have been searching (instead of working) and have found OEMs for $100 each, which seems like a good deal... Again, I will do this if you feel it is necessary, just want to make sure.
    4. Clarify what action I need to take on grounding the coil packs. I have sourced a suitable bus bar to use in cleanly providing an aftermarket ground for each coil pack direct to battery but want to confirm before I dive into that. I wasn't sure if your statement was general knowledge or a direction to be followed.
    5. Is a fresh auto-scan, after clearing all current DTCs, still desired?
    Thanks!
    Oh yes, and this sums up how I feel things have gone...my son found this and I found it quite funny...
  13. Likes Uwe, Jack@European_Parts liked this post
  14. #28
    I did it for you above sir.......
    https://forums.ross-tech.com/showthr...l=1#post142633
    I advise it.........can't trust reman injectors for a Gasser.
    Shaaaanaaa na na....
    https://forums.ross-tech.com/showthr...iring-Upgrades
    Always with a fresh battery too!
    FIRST!
    Remove all aftermarket FOD bullshit and make car stock to be sure consistent!
  15. #29
    Aug 2018
    Thank you! And thanks for the rest of the above feedback.
    At risk of asking a dumb question...I see your FOD statement all over the forum and want to clarify...what are you talking about? There is nothing loose or broken in my engine bay (or vehicle, for that matter) that could be FOD in the aviation sense. And then there's the "make the car stock"...so you want me to remove...the exhaust, IM spacers and...anything else not OEM? I'm hoping that we can at least get it back to pre-teardown condition with the most physically extensive mods still in place...especially since I don't have a spare exhaust setup lying around...
    Do you know what gauge the current coil pack wiring is, or do you have a recommendation of what it should be? I'd like to get supplies before I tear down the plastic conduits that hold the wires everywhere that's readily accessible or the shielding at the back of the engine bay.
    The results of the compression tests are:
    1 - 124psi
    2 - 124psi
    3 - 124psi
    4 - 125psi
    5 - 123psi
    6 - 123psi
    7 - 123psi
    8 - 126psi
    Why are the back two cylinders slightly higher than the rest of the respective bank? Is that `normal?
    The one ECU I can easily see (under the windshield cowling) is most definitely not original - it has a date of 6-11-2009...
    Idiot question, but where is the other ECU? I have literally 8,000 pages of information on the vehicle from Audi (ERWIN) but for some unknown reason that info is not anywhere I have looked...just one more for me...
    THANK YOU!!
  16. #30
    May 2016
    DPNW, the difference is miniscule, now In fairness I do know a good COMP for this motor. Most engines 120/170 but on multi valve engines I know can be over 200, so maybe somebody could chim in on history of this motor. IMO, 123-126 not stellar but on bottom of range, would like 150-170, again could be wrong, would be the first time this year, NOT.
    So as RPM goes up so does compression, hence might answer miss fire at idle, then not above. Would like to see running compression as all are so close would just do the easiest one. IF too low are sporting a miss fire.
    Also manifold flaps could create low COMP, but some of these motors out of my wheel house.
    LARIMORE
