Page 17 of 17 FirstFirst ... 7151617
Results 161 to 166 of 166
Thread: B7 RS4 rough idle nightmare - HELP PLEASE (reward offered!)
  1. #161
    Conductivity is not a big factor in secondary ignition wires (between a coil and a plug) because the voltage is so high and current is so low.
    Yeah again, what do you find in a wire when it fails usually due to green corrosion.
    Oxygen sensors are also a low-current affair, at least on the signal side of things. But I'm skeptical that Bosch would use SS for the heater circuit.
    I will send you a brand new one and you can cut it and photo it & see for yourself indeed the heater circuits are stainless steel..........
    So where does one buy this fine-stranded, Teflon insulated, stainless steel wire?
    The last time I bought was from Wurth Zebra & I bought all of the USA stock for Porsche cables or Winser and maybe even Lawson products or Grainger, Travers or McMaster Carr, Remington industries.......bla bla
    I dont apologize David I think it's all relevant..........
  2. Likes jyoung8607 liked this post
  3. #162
  4. Likes jyoung8607, D-Dub liked this post
  5. #163
  6. #164
    And no I did not tin the wires they are indeed stainless for all circuits...........
  7. #165
    May 2016
    JACK thanks, decent pricing on it also, as if you buy from local auto parts would think it was
    Clad in gold.
    LARIMORE
  8. #166
    Only US MIL spec for stainless wire would be lock wire FYI: & unless it was a strap secure braid or shield, "aviation" uses coated copper with alloys not stainless according to the old man when double checking this because honestly wasn't entirely sure myself the other day so deferred.
