Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Auxiliary Display on Mk V GTI
    Oct 2014
    Singapore
    I have retrofitted the 2015 Scirocco Auxiliary Display Meter onto my Mk V GTI .
    Got everything working except for the Charge Air metering. The module have been connected to the Dash Panel Insert CAN at Gateway #8 & #18.
    Oil Temperature, Time and Stop Watch is working okay but nothing on the Charge Air.
    From 01 Engine, I could see the charged air metering (Block 117 -4 and 119-4) but this information doesn't seem to be captured by the Gateway. Tried going into adaptation for 117 and 119 but error message say it is not available.
    From 19 Gateway, there is a measuring block 200-4 for charge air status but there is no reading.
    Long Coding on the Aux Display have been preset by factory at 05. There is no information on the various bits in the long coding helper. I tried various coding from 01 to 09 which is accepted but does not seem to work the turbo gauge. Selecting the other bits would return a "Out of Range" error message.
    Any advice would be appreciated.
    The Scirocco 2015 Auxiliary Meter placed on top of the Mk5 Dashboard temporarily
    The Gateway is not showing any data for the Charge Air status
    The Engine measuring block shows that boost pressure is metered
    Saturday,18,October,2014,17:01:26:24118
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140822
    Dealer/Shop Name: CBX Auto Services
    Workshop Code: 620 92386 091777
    VIN: WVWZZZ1KZ9U015224   License Plate: GTI JIMMY MK5 B9 AUX DISPLAY
    Chassis Type: 1K (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 47 52 55 56
              62 65 72 77 B9
    B9-Aux. Display -- Status: OK 0000
    Address 01: Engine        Labels: 06F-907-115-AXX.lbl
       Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0H83N98IY
       Coding: 040300431C070160
       Shop #: WSC 66565 257 00032
       VCID: 346DF3EA576559BE4F5-8061
       Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     431 1817
       Revision: 04843012    Serial number: 00000807071566
       Shop #: WSC 44551 111 44551
       VCID: 132F5076322BBE8636F-8046
       Revision: 00H31001
       Coding: 163B600D092300FF680D06E6901D0081B50950
       Shop #: WSC 92386 620 91777
       VCID: 7BFF18D6FABB56C6CEF-802E
       Part No SW: 5K0 907 044 AK    HW: 5K0 907 044 AK
       Component: Climatronic   130 0303
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       ROD: EV_ClimaAutoBasis_SE36.rod
       VCID: 74ED33EADFE519BE8F5-8021
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Revision: 00H54000    Serial number: 00000008814327
       Coding: E78D8F270004150047140000140000000009FE075C000100000000000000
       VCID: 336FF0F6526B5E8656F-8066
       Component: Wischer 041108 020  0501
       Coding: 00049109
       Shop #: WSC 12345
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     290708 046  0204
       Coding: 00208933
       Shop #: WSC 12345
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 M    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0030
       Revision: --------    Serial number: 56261303601016
       Coding: 349101
       ASAM Dataset: EV_EPHVA2C000000000 002011
       ROD: EV_EPHVA2C000000000_VW36.rod
       VCID: 458BBE2EC4FFD036E8B-8010
       Component: 3C AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD25X6Z1
       Coding: 0013123
       Shop #: WSC 00046 412 31414
       VCID: 3D7BD6CE642F98F6B0B-8068
       Subsystem 1 - Serial number: 6332MSME3F5622105
       Subsystem 2 - Serial number: 6342MSME3F512A77M
       Subsystem 3 - Serial number: 6352QSME3A00200E6
       Subsystem 4 - Serial number: 6362QSME3807141AC
       Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
       Component: J0527           056 0111
       Coding: 0001832
       VCID: 7AF11DD235816FCED59-802F
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H08 0010
       Coding: 00000131
       Part No SW: 56D 920 880 AX    HW: 56D 920 880 AX
       Component: KOMBI         H04 0505
       Coding: 570F01
       ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
       VCID: 830FE0360A4BAE0606F-80D6
       Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1642
       Revision:   H56       Serial number: 05021400F14335
       Coding: 350003
       VCID: 7CFD1BCAFFB551FEC75-8029
       Component: IMMO          H04 0505
       Shop #: WSC 30125 743 116003
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EAD1AD920D215F4EA59-80BF
       Revision: A1001003    Serial number: 7668831664
       VCID: 275714A656B32226FA7-8072
    03138 - Input AUX IN
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 3
                        Mileage: 93654 km
                        Date: 2002.14.29
                        Time: 16:58:03
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 1T0 035 680 D    HW: 1T0 035 680 D
       Component: RNS-MID       H60 4120
       Revision: AB001001    Serial number: VWZ6Z7L5247153
       Coding: 00050042010000800000
       VCID: 2F67FC867E437A66327-807A
       Subsystem 1 - Part No: 7L6 919 859 J
       Component: SIMA V5  7960
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
       Component: Tuer-SG         006 1210
       Coding: 0000758
       Shop #: WSC 13572 020 00252
       VCID: 3973C2DE7007A4D69C3-806C
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A51ED9285A11F4EE59-807F
       Coding: 98900A005103087F2D020F0FF0C8DFC690FC00
       VCID: 830FE036C24BAE0606F-80D6
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
    Address 47: Sound System        Labels: 3C0-035-456.lbl
       Part No SW: 3C8 035 456 C    HW: 3C8 035 456 C
       Component: DSP 10 Kanal
       Revision: 00H05001    Serial number: 75805000261201
       VCID: 2855179A9BAD2D5EF3D-807D
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
       Coding: 0001014
       VCID: 3A71DDD27501AFCE959-806F
    Address 55: Xenon Range        Labels: 1T0-907-357.lbl
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: F4EDB3EA97E599BE0F5-80A1
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
       Component: Tuer-SG         006 1301
       Coding: 0000208
       Shop #: WSC 00046 412 1012557
       VCID: 3875C7DA4B0DBDDE63D-806D
       Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
       Component: RDKBERU30     H09 0010
       Serial number: 40000000007761
       ASAM Dataset: EV_RDKBERU30 003012
       ROD: EV_RDKBERU30_SE36.rod
       VCID: 356BCEEE941F40B678B-8060
       Coding: 0000208
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
       Revision: 1B001001    Serial number: 00AAAA63112800
       Coding: 0210000000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3B7FD8D6B23B96C68EF-806E
    Address B9: Aux. Display (J285)       Labels: None
       Part No SW: 1K8 919 527 B    HW: 1K8 919 527 B
       Component: ZUSATZANZEIGE H08 0003
       Coding: 08
       ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
       ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
       VCID: 3777C4E68E13B2A66A7-8062
    Chances are your ECU doesn't broadcast a CAN message with charge ("boost") pressure.
    Oct 2014
    Singapore
    The Boost Pressure (Specified) is the same as the charge (boost) pressure, is it not ?
    Is it possible to use this information or write/modify/adaptation ?
    Specified is what the ECU wants.
    Actual is what is being meaured.
    VCDS starts a diagnostic session and makes active queries. However, I believe that gauge panel just listens passively on the bus for data broadcast by the ECU on the bus, and if your ECU does not broadcast the data that the panel needs, then it isn't going to work. VCDS cannot change what messages are broadcast by the ECU.
  5. Likes cbx750p liked this post
    Jun 2014
    Poland
    Do this same Measure Block in B9 module to see .
    But i think this same as UWE.
    If you use PolarFIS for example, they can display Turbo pressure etc from any ECU.
    Hard to say if B9 module understand that signals to display it
    Oct 2014
    Singapore
    Bro Spacewalker, are you suggesting that the PolarFIS may capture the boost charge data and share it on the LAN and the B9 Module may read this data ?
    Tried reading the measuring block of the B9 module today but the B9 Block Measure for Boost Charge is blank....meaning it is not reading anything ?
    I get this error every now and then....clear it but it appears again later...
    Tuesday,28,October,2014,09:26:37:24118
    VCDS Version: Release 12.12.3 (x64)
    CBX Auto Services
    Address B9: Aux. Display Labels: None
    Control Module Part Number: 1K8 919 527 B HW: 1K8 919 527 B
    Component and/or Version: ZUSATZANZEIGE H08 0003
    Software Coding: 07
    Work Shop Code: WSC 92386 620 91777
    ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010 (VW36)
    2097157 - Databus
    Reset counter: 51
    Mileage: 93793 km
    Date: 2003.14.07
    Time: 09:21:06
    Jun 2014
    Poland
    I try to said that Polar FIS can read that data and display it onto CLUSTER DISPLAY
    But POLAR fis was made after lot of research.
    B9 controller - design for one car , and that is it
    if you have "Receive Error... " here is a reason.
    What I will try is install B9 in younger car - to see if ECU SW is matter
  9. Likes Uwe, cbx750p liked this post
  10. #8
    Oct 2014
    Singapore
    Got the POLAR FIS Advanced fitted. Everything that the manufacturer promised, was delivered. But the 2015 Aux cluster still cannot function. They have 3 boost parameters include Atmospheric Boost but none of them worked for me.....
  11. #9
    Jun 2014
    Poland
    any update ?
  12. #10
    Oct 2014
    Singapore
    I got the latest AS Gateway..................installed but it does not work.
    Looks like the only way is for VW to release a new program with the Turbo Charge Status. A new firmware perhaps ?
    But this would never happen.
    Got to live with an auxiliary display which the Turbo Gauge doesn't work
