Results 1 to 10 of 11
Thread: Audi A4 8K, turning off "ignition on" beep when opening door
    Sep 2015
    Is it really not possible to turn off that annoying beeping? I mean that which comes when ignition is on and you open driver door. It can be muted after couple of beeps by pressing button on wiper stalk, yes, but would be really great if it didn't even start at first place.
    Has anyone had any success with this, ever?
    Auto-scan of car in question:
    Wednesday,21,March,2018,17:33:44:26429
    VCDS Version: 18.2.0.3  HEX-V2 CB: 0.4411.4
    VIN: WAUZZZ8K7EA086543   License Plate:
    Mileage: 52370km-32541mi   Repair Order:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 72 77
    VIN: WAUZZZ8K7EA086543   Mileage: 52370km-32541miles
    Address 01: Engine (J623-CNCD)       Labels:. 06L-907-115-V1.clb
       Part No SW: 8T2 907 115     HW: 8T2 907 115
       Component: 2.0l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 0A2500322426010B2000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM20TFS0218T2907115 001006
       ROD: EV_ECM20TFS0218T2907115.rod
       VCID: 75B71C165547457F51E-8020
       Part No SW: 8K9 927 156 C    HW: 0B5 927 156 K
       Component: 0B5 20TFSIRdW H02 0003
       Revision: --H02---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501021.rod
       VCID: 3D27C4362DF7DD3F59E-8068
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Component: ESP8 quattro  H09 0020
       Coding: 315DCC01
       VCID: 094F60E6293F319F256-805C
       Part No SW: 8K0 907 064 HD    HW: 8K0 907 064 GD
       Component: BCM2 2.0      H13 0641
       Coding: 01A14000000000000000
       VCID: 79AF102679DF211F356-802C
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0513000081998013
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01211120131328
       Coding: 642002C000
       VCID: 392FD026395FE11F756-806C
       Revision: 08016001    Serial number: 00000051731201
       Coding: 2600C0108034AFC00081400300001D0D4F9C420826090201000008004401030100000024000000
       Shop #: WSC 06325 123 12345
       VCID: 78A9152242D538174A8-802C
       Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: MITSUBA141013  H18 0461
       Serial number: 1310100705216
       Coding: 004577
       Serial number: 21971404
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001211131512
       Serial number: 00684BD6000000000001
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003KFDB2ZRPM
       Coding: 30514435363030303030554A304C384B3053
       Shop #: WSC 57195 001 1048576
       VCID: 48C9A5E272358897FA8-801C
       Serial number: 6334MSME7D533075G
       Serial number: 6344MSME406A0E58L
       Serial number: 6352QSME603A1D74L
       Serial number: 6362QSME053743426
       Serial number: 63732SME60381850U
       Serial number: 63832SME4E381E4CH
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862MKM000NF
       Coding: 000016
       VCID: 48C9A5E272B58897FA8-801C
       Part No SW: 8K0 920 931 T    HW: 8K0 920 931 T
       Component: KOMBIINSTR.   H35 0564
       Revision: 00100000    Serial number: ZA8722JCE
       Coding: 138F090003010008010000
       VCID: 3FDBBE3E277BCF2F4B2-806A
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0056
       Revision: 1V080027    Serial number: 2741V13B06077D
       Coding: 80CF07FF00
       Serial number: 9320961703
       Serial number: 13325000968021200181
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0305
       Coding: 011C02204000410001
       VCID: 56F57B9AA8012E67784-8002
       Part No SW: 8K0 909 144 R    HW: 8K0 909 144 B
       Component: RCEPS         H39 0511
       Revision: 00001000    Serial number: 0014044608
       Coding: 100000000001
       Shop #: WSC 06324 123 12345
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 40D9BDC25A05B0D7328-8014
       Revision: 00002001    Serial number: 0319436430
       Coding: 0100062800B900008330013680000047
       Part No SW: 8R1 035 223 A    HW: 8R1 035 223
       Component: DSP STD       H08 0230
       Revision: 26S00000
       Coding: 0203010102
       VCID: 2B03FA6EC303438FF7A-807E
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0305
       VCID: 55F77C96B507257F71E-8000
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 30000000133088
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 392FD02639DFE11F756-806C
       Part No SW: 8R1 035 186 N    HW: 8R1 035 186 N
       Component: Concert3      H09 0470
       Revision: 00000003    Serial number: AUZ5Z6M1971127
       Coding: 0502008201018502C35B071000
       VCID: 40D9BDC25A85B0D7328-8014
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
    03138 - Input AUX IN
                        Reset counter: 213
                        Mileage: 49707 km
                        Date: 2017.12.14
                        Time: 13:45:39
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0305
       Coding: 010C02204000210001
       VCID: 59EF70A6D91F011F556-800C
       Component: TSG HR        H07 0305
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005690138
       Coding: 0010320
       VCID: 3D27C4362177DD3F59E-8068
    End----(Elapsed Time: 02:32, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Dec 2016
    DE
    As far as I know the ignition warning beep is indeed not possible to be disabled.
    Sep 2015
    That sucks.
    I do know that another annoying beep for lights on, lives in BCM coding and thus can be disabled (if on in first place, it is not in my car).
    I was thinking, how much damage would it cause if I temporarily change BCM coding to all zeroes to see if it does anything for this stupid beeping... Or maybe someone has already tried that too?
    May 2017
    The door open beeping is not coded to BCM, it is usually in instruments. So DO NOT ZERO BCM coding, you'll f*ck up the car completely.
    Dec 2016
    DE
    Additionally to what downtime said about "zeroing" your BCM coding: please keep in mind, that sometimes an unset bit means that something is present. Commonly seen in door modules.
  6. Likes downtime liked this post
    Sep 2015
    Then I shall not try that. That was, however, the method that someone used to find that "Lights on" beeping. Maybe he was just lucky, to not have his car messed up.
    May 2017
    Try to change the instrument coding to : 130F090003010008010000
    That has key warning bit disabled. It might help or not
  9. Likes Uwe liked this post
  10. #8
    Sep 2015
    Thanks, tried that already but I'm afraid it does nothing.
  11. #9
    Verified VCDS User CCSLEEPER's Avatar
    Feb 2020
    Change the country code to German in the steering wheel. Will turn off the door open beeping. and then youd have to change your degrees and miles back to F* and Kilometers to Miles and etc...
  12. Likes downtime liked this post
  13. #10
    Feb 2020
