Results 1 to 5 of 5
Thread: Older versions of VCDS
    Apr 2017
    Canada
    Where can I down load older versions of VCDS? I would like to compare with latest version 18.2.1
    I don't know if I am loosing my marbles, but it seems I am missing some, but not sure (01) engine output tests.
    Also would like to use selective output test vs sequential.
    Any help would be much appreciated.
    In general, we do not make older versions available because doing so would make life too easy for people using cloned interfaces.
    What kind of car is are you working on? Have you got a scan so we can see what we know about the ECU?
  3. Likes Boki Ar liked this post
    Apr 2017
    Canada
    2010 VW Beetle Conv
    2010 VW Beetle Convertible
    Thank you for any help.
     Saturday,18,August,2018,15:20:51:63911
    VIN: 3VWRW2AL8AM007137   License Plate:
    Chassis Type: AL (AL - VW New Beetle Cab NAR (2010))
    VIN: 3VWRW2AL8AM007137   Mileage: 82520km-51275miles
    Address 01: Engine (BPS)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 CN    HW: 07K 906 032 AA
       Component: NB R5 AT        G   4572
       Revision: 1SH04---    Serial number: VWX5Z0J3157150
       Coding: 0000003
       Shop #: WSC 00066 000 00000
       VCID: 77A8E172A3C2DECF40E-8022
       Part No SW: 09G 927 750 KR    HW: 09G 927 750 KR
       Component: AQ 250 6F           1593
       Revision: 00H91000    Serial number:
       Coding: 0000008
       VCID: 0B40AD82CF5ACA2F146-513C
    Address 03: ABS Brakes        Labels:
       VCID: 55F48BFA5C0ECCDF722-FFFE
       Part No: 6Q0 909 605 AL
       Component: 02 AIRBAG VW71      0811
       Coding: 0012338
       VCID: 015C8FAAFD46907F7EA-8054
       Part No: 1C0 920 802 N
       Component: KOMBI+WEGFAHRS. M73 V05
       Coding: 09334
       Shop #: WSC 00028
       VCID: 2708F13236F28E4F10E-4B00
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V052
       Coding: 00006
       Shop #: WSC 00028
       VCID: 70BADA6EC3BC89F7814-4B00
    Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
       Part No SW: 1C0 920 802 N    HW: 1C0 920 802 N
       Component: IMMO                X007
       Revision: xxxxxxxx    Serial number: VWX5Z0J3157150
       VCID: 2708F13233F28E4F10E-513C
    Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
       Part No: 1Y0 959 255 D
       Component:  VSG  NBC       ˘
       VCID: 41DC4FAABD96507F3EA-513C
       Part No: 1C0 959 799 G
       Component: 6J Komfortgerát HLO 0004
       Coding: 00256
       Shop #: WSC 00028
       VCID: 3B203D42DA7A3AAF646-4B00
       Subsystem 1 - Part No: 1Y1959801C
       Component: 6J Tőrsteuer.FS KLO 0005
       Subsystem 2 - Part No: 1Y1959802D
       Component: 6J Tőrsteuer.BF KLO 0005
       Subsystem 3 - Part No: 1Y0959811
       Component: 6J Tőrsteuer.HL KLO 0005
       Subsystem 4 - Part No: 1Y0959812
       Component: Tőrsteuer.HR KLO 0005
       Part No: 1C0 035 196 CS
       Component:  RADIO DE2         0006
       Coding: 00401
       Shop #: WSC 00028
       VCID: 72BED066CDB0BBE7770-51A8
    End----------(Elapsed Time: 04:25, VBatt start/end: 12.2V/12.2V)-----------
    Since that's a pre-UDS module, if Selective Output tests were available and defined, they'd have to be defined in the corresponding label file. I've gone back as far as data version 20150227 and there were no Selective Output tests defined for that ECU.
    As for Sequential Output tests, the sequence is defined in the ECU, not in VCDS.
    Apr 2017
    Canada
    Thanks again for all your help.
