Friday,17,August,2018,06:39:33:59358
VCDS Version: 18.7.1.1 (x64) HEX-NET CB: 0.4427.4
Data version: 20180731 DS293.0
Mileage: 33156km-20602mi Repair Order:
Chassis Type: F4-AU49 (4M1)
Scan: 01 03 08 09 15 16 17 19 22 2B 42 44 46 52 5F 6C A5 BB BC CA
VIN: WAUNNAF44HA164460 Mileage: 33156km-20602miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC) Labels:. 06K-907-425-V2.clb
Part No SW: 8W0 906 259 J HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0002
Revision: --H15---
Coding: 0A5900120326010E34000000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
ROD: EV_ECM20TFS020_AU49.rod
VCID: C8DC22587354A50A1C-809C
25763 - Clutch Slip Monitoring
P1743 00 [032] - Signal too Large
15130 - Radiator Fan (V7)
P1950 00 [032] - Movement Restricted / Jammed
Address 03: ABS Brakes (J104) Labels:. 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 G HW: 8W0 907 379 J
Component: ESP9 Plus H06 0719
Coding: 18AA409920A80A9A11A24097207D4292E64196180204508802044249678269
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: C9DA275C685E5C0203-809C
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 0205
Coding: 140805085544000D10000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: C4C436684F7C816AF0-8090
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J216 FLuftV H08 0003
Serial number: 00000000000001458872
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: F42801A880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
131078 - Reference Voltage
B10AD 16 [009] - Voltage Too Low
Reset counter: 24
Mileage: 20504 km
Date: 2018.04.05
Time: 12:09:38
Voltage terminal 30: 15.01 V
Outside air temperature: 6.50 °C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CB HW: 8W0 907 063 BB
Component: BCM1 MLBevo H13 0266
Coding: 8045836254690CCD05158714180C10BB100B3D08000000000000000000001A0000600002001204
Shop #: WSC 06325 790 00001
VCID: FDB2838C6C1630A2FF-80A8
Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 170303 043 0813
Serial number: 89435300301706201689
Coding: 5BC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20369695X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 10 02 2017 00764768
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z3G0902
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20170131113821 00439
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE104021723510519
Interior Light Module:
Subsystem 7 - Part No SW: 8W0 947 135 AK HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00315428
Subsystem 8 - Part No SW: 8W0 925 301 AT HW: 8W0 925 301 AT
Component: SL-B9/Q5NF H17 0010
Serial number: 2616000209589006
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 G HW: 8W0 959 655 G
Component: Airbag10.44 H05 0104
Serial number: 003UQ000RTRD
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005015
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: CDD2134C9C3640222F-8098
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0102R00251
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0100R01107
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J17000720FE0P
Subsystem 4 - Part No SW: ----------- HW: 442 062 003 17
Serial number: 3577Y00BF20669829566
Subsystem 5 - Part No SW: ----------- HW: 442 062 003 17
Serial number: 3587Y00BF2066981A4CC
Subsystem 6 - Part No SW: ----------- HW: 442 0B3 003 17
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700B52220D26A26+
Subsystem 7 - Part No SW: ----------- HW: 442 0B3 003 17
Serial number: 3527700B52220D27120S
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 103 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AF21FBF13008K
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 103 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500AF21FBF16019Q
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GB HW: 4M0 907 129 GB
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: F6A09CA0492063FABE-80A2
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 840 A HW: 8W5 920 840 A
Component: MMA4M17BENUS H06 0363
Revision: 0363v1.0 Serial number: E7DFSH44T
Coding: 08EE5191A080CF050203A8601800000000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: BC344E88378CF9AA88-80E8
16777022 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[NAV_SD_0x32 communication error bap_error_timeout heartbeat]
Reset counter: 217
Mileage: 32525 km
Date: 2018.08.10
Time: 17:56:13
16776985 - Databus
[QSP_03 communication error can_error_timeout]
Reset counter: 219
Mileage: 32572 km
Date: 2018.08.11
Time: 06:20:51
Part No SW: 4M1 907 468 D HW: 4M1 907 468 A
Component: Gateway H16 0108
Revision: 4V020004 Serial number: 0444V006317322
Coding: 030100010000064029070000005900104C280007000000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 002040
ROD: EV_GatewCONTIAU736_002_AU49.rod
VCID: B83C529803B4D58A6C-80EC
Subsystem 1 - Part No SW: 8W0 951 523 E HW: 8W0 951 523 E
Component: J453 MFL H04 0002
Serial number: 20170328003149 20068
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 3514853604
Address 22: AWD (J492) Labels: None
Part No SW: 8W0 927 755 HW: 0CJ 927 749
Component: B9_ML4_N_SD4 H01 0004
Serial number: 1619617003
Coding: 31000000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: N/A
VCID: 8248F07015E84F5A82-80D6
No ASAM data for: "EV_AWDCQUOD31" (AU49)
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000056820010
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: B22860B0E5C83FDA52-80E6
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W0 959 593 E HW: 8W0 959 593
Component: TSG FS 005 0057
Serial number: 0000247791637
Coding: 001F0B204000108000000080
ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
VCID: CCD41E48672C492A38-8098
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: C1CA3F7C506E9442DB-8094
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 CB HW: 8W0 907 064 B
Component: BCM2 MLBevo 018 0344
Coding: 012C000048000080650780002601000033000000010023500F04000000040030001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 012013
ROD: EV_BCM2HellaAU736_012_AU49.rod
VCID: FEB0848061102BBAE6-80AA
Subsystem 1 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000038115745
Part No SW: 8W0 959 592 E HW: 8W0 959 592
Component: TSG BFS 005 0057
Serial number: 0000247559457
ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
VCID: CBD61D5462224E1231-809E
Part No SW: 8W0 035 664 F HW: 8W0 035 664 A
Component: MU-HS--US 045 0143
Coding: 01940100FF0A000013220001061F04002F0024D401F001000A
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP_AU49.rod
VCID: BD32438C2C96F0A2BF-80E8
Subsystem 1 - Part No SW: 8W1 919 604 HW: 8W1 919 604
Component: DU Std AU49x H32 0160
Serial number: TPO00101031700720065
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8W0 919 614 J HW: 8W0 919 614 J
Component: ControlUnit_B H21 0134
Serial number: APVAK128021700040043
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0294010100002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv.rod
VCID: B32665B41AD236D259-80E6
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 B HW: 8W0 907 217
Component: BVS H15 0042
Coding: 0404090100000201022000A0800000FC00F0C0100020
ROD: EV_BVSMLBevKOSTAAU736.rod
VCID: BB364D943282FE9281-80EE
Part No SW: 8W0 959 595 E HW: 8W0 959 595
Component: TSG HFS 005 0057
Serial number: 0000250944507
Coding: 000F0B200000108040000080
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: CED0144091307B3A56-809A
Component: TSG HBFS 005 0057
Serial number: 0000250944510
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 A HW: 4M0 907 594
Component: SAD_STG_1 012 0003
Coding: 208000049100
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
VCID: B42466A81FDC31EA40-80E0
End----------(Elapsed Time: 01:39, VBatt start/end: 12.2V/12.2V)-----------
