Results 1 to 4 of 4
Thread: A/C intermittant only DTC and problem
    Jul 2018
    uWE and peter helped with assessing DPF condition on 06 V10, only 1 problem left HVAC.. Intermitanta/c RCV operation c dtc code 00898 on auto scan some times , last eve went to HVAC control MVB 13 field 1 gave 8 in field 1 which indicates compressor off;outside temp too low which sensor is this or is it a coding problem? 4 zone climate in71 degree shop which registered on front dash screen, A/C has a number of temp sensors, which one is problematic for #8 outside temp?? thanks
    Fault is shown in this scan.
    This:
    00898 - Control Circuit A/C compressor
    ... doesn't strike me as a temperature sensor problem.
  3. Likes iichel liked this post
    Jul 2018
    009 mean anything/ does this have to be coded?
    "009" mean: Open or Short to Ground - Intermittent
  6. Likes Fredrick Awuor liked this post
