- Joined
- Aug 22, 2014
- Messages
- 500
- Reaction score
- 231
- Location
- Maryland, USA
- VCDS Serial number
- C?ID=66650
Hello friends,
I am faced with rough cold start rough idling which lasts for about 45 seconds. But car idles and drive ok when engine warm.Also fuel pump activation when the driver door is opened seem not available so car takes few more seconds to start in cold times.
I suspected air leak somewhere but so far no leaks found in the intake system. Also on same car the voice command function does not work, though the button on steering wheel seem ok and replaced with new.
Some help with this will be appreciated.
Thanks for reading.
Thanks for reading.
Tuesday,14,August,2018,16:43:39:46890
VCDS Version: 18.2.1.2 (x64)
VIN: WAUDN74F78N015312 License Plate: KIRK
Mileage: 227950km-141641mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 13 15 16 17 19 1E 36 37 42
46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUDN74F78N015312 Mileage: 227950km-141641miles
1E-Media Player 2 -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
Address 01: Engine (BXA) Labels: Redir Fail!
Part No SW: 4F1 910 562 A HW: 4F1 907 552 B
Component: 5.2L V10/4V FSI ª0010
Revision: 5HH02--- Serial number:
Coding: 01050009190F0260
Shop #: WSC 09417 067 57207
VCID: 234E2695E262D25C1A-8076
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold - MIL ON
Fault Status: 11100010
Mileage: 227885 km
Date: 2018.08.11
Time: 14:00:31
RPM: 1820 /min
Load: 50.2 %
Speed: 84.0 km/h
Temperature: 99.0°C
Temperature: 53.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
Part No SW: 4F5 910 156 F HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0010
Revision: --H03--- Serial number: 0108189
Shop #: WSC 02325 758 00200
VCID: 2B5ECEB58AB21A1CA2-807E
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 P HW: 4F0 614 517 P
Component: ESP 8.0 quattro H05 0070
Coding: 0020920
VCID: 3162DCDDA89E70CC98-8064
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0040
Revision: 09010701 Serial number: 10601600809937
Coding: 0000007
Shop #: WSC 02323 758 00200
VCID: 244C2589E76CD56463-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 D HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 361FL077516430
Coding: 0010003
Shop #: WSC 12345 111 45725
Subsystem 2 - Serial number: 00000000887862
Subsystem 3 - Serial number: 0109.10.070000000100010587ÿ
Subsystem 4 - Serial number: 010587ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030255294
Coding: 0524330
VCID: 1C3C1D69DF1CEDA4DB-8048
Fault Status: 01100101
Reset counter: 39
Mileage: 150948 km
Date: 2013.05.01
Time: 07:41:07
00733 - Potentiometer in Positioning Motor for Rear Footwell Vent (G141)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 1
Mileage: 227958 km
Date: 2018.08.14
Time: 16:22:17
Voltage: 11.70 V
(no units): 30.0
(no units): 255.0
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Coding: 0115123
Shop #: WSC 02335 758 00200
VCID: 3064D9D9A39479C497-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: 27563285565A3E7C46-8072
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0101396
Coding: 0000100
VCID: 2F66DAA5BEAA663C8E-807A
Address 11: Engine II Labels: Redir Fail!
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4F0 910 561 C HW: 4F0 907 561 B
Component: ABSTANDSREGELUNGH01 0020
Revision: -------- Serial number: 00000000000000
Coding: 0041118
02002 - Heater for Distance Regulation Sensor (Z47)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 144
Mileage: 223273 km
Date: 2017.05.19
Time: 14:24:14
Temperature: 27.0°C
Voltage: 12.80 V
Bin. Bits: 00000
Hex Value: 0x2A11
Hex Value: 0x0002
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7Q AIRBAG AUDI8RH30 0400
Revision: 02H30000 Serial number: 003BMD02061F
Coding: 0014161
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME1B75156DA
Subsystem 3 - Serial number: 6342CSME19494957A
Subsystem 4 - Serial number: 6352QSME2B724F0DV
Subsystem 5 - Serial number: 6362QSME2E31212FI
Subsystem 6 - Serial number: 63734SME2D742C1DC
Subsystem 7 - Serial number: 63834SME2D52117B1
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
014 - Defective - Intermittent - MIL ON
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H02000 Serial number: 90055071610166
Coding: 0012151
VCID: 27563285965A3E7C46-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 S
Component: KOMBIINSTR. M73 H21 0220
Revision: 00400000 Serial number: 66F53ML47
Coding: 2257288
Shop #: WSC 12345 067 57207
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D074148012
Coding: F5D5DEF7717A06
Shop #: WSC 09417 444 85746
VCID: 6CDC0DA94F3CDD24EB-8038
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046005 Serial number: AUZ5ZBG3415848
VCID: 183401792B248184FF-804C
02261 - Data Medium
Fault Status: 00101110
Reset counter: 29
Mileage: 223273 km
Date: 2017.05.19
Time: 14:23:59
Text: 00000000
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 61C26C9DB8FE804C48-8034
01450 - Switch for Driver Seat; Tilt Adjust; (E222); Forward
Fault Status: 00100011
Reset counter: 31
Mileage: 227532 km
Date: 2018.07.26
Time: 11:36:49
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H49 1100
Revision: 00000000 Serial number: 395FK077501050
VCID: 3874E1F94BE4A184DF-806C
03183 - Data Media not Compatible
Reset counter: 29
Mileage: 227322 km
Date: 2018.07.23
Time: 17:48:25
Hex Value: 0x5B56
Hex Value: 0x14E9
Hex Value: 0x0000
Hex Value: 0x0000
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: …–„
Coding: 0051947
VCID: 2C5CCDA98FBC1D24AB-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H25 0200
Revision: 02000025 Serial number: 01050738400000
Coding: 4483101
01134 - Alarm Horn (H12)
Reset counter: 2
Mileage: 205271 km
Date: 2016.01.06
Time: 16:36:36
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000036444
Coding: 0000026
VCID: 254A388DEC562C6C74-8070
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000025143
Coding: 0012014
VCID: 5EB857618980BFB475-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: p$…
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0008022
Shop #: WSC 02145 758 00200
VCID: 20442999F374C94407-8074
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
VCID: 295234BD804E080C50-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 394FT077782301
VCID: 2E58C7A1B9A06F3485-807A
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000088508
Shop #: WSC 09417 444 54683
Component: von VA0 2706191855
Coding: 344630393135313035442056413032373036313931383535
Shop #: WSC 00000 384 00290
02256 - Quiescent Current
Fault Status: 00100001
Fault Frequency: 11
Reset counter: 41
Mileage: 224419 km
Date: 2018.06.05
Time: 03:17:49
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0051754
Shop #: WSC 02327 758 00200
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000600015317
Coding: 0062725
VCID: 22402391FD78DB5411-8076
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000705290113
Shop #: WSC 12336 024 394758
VCID: 346CD5C9578C45E4F3-8060
Reset counter: 1
Mileage: 227958 km
Date: 2018.08.14
Time: 16:19:22
02084 - Component Protection
Reset counter: 0
Time Indication: 1
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7420IE
Coding: 1000204
VCID: 5DBA506D8486A4AC6C-8008
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0051754
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Revision: 00H09000 Serial number: 06230717600671
Coding: 0221306
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H16 0950
Revision: 00000000 Serial number: 00000007580200
Coding: 0010900
End-------------------------(Elapsed Time: 03:49)--------------------------
Address 46: DTCs cleared
Tuesday,14,August,2018,16:46:09:46890
VIN: License Plate: KIRK1
Control Module Part Number: 4F1 910 562 A HW: 4F1 907 552 B
Component and/or Version: 5.2L V10/4V FSI ª0010
Software Coding: 01050009190F0260
Work Shop Code: WSC 09417 067 57207
Mileage: 227885 km
Date: 2018.08.11
Time: 14:00:31
RPM: 1820 /min
Load: 50.2 %
Speed: 84.0 km/h
Temperature: 99.0°C
Temperature: 53.0°C
Voltage: 13.716 V
Address 01: Engine (4F1 910 562 A)
16:46:35 Group 030
00111 Bin. Bits
0100 Bin. Bits
00111 Bin. Bits
0100 Bin. Bits
16:46:40 Group 031
1.00 (no units)
1.00 (no units)
1.00 (no units)
1.00 (no units)
16:46:53 Group 032
3.0 % Lambda
-8.6 % Lambda
3.5 % Lambda
-3.5 % Lambda
16:47:00 Group 033
-3.9 % Lambda
1.50 V Voltage
2.3 % Lambda
1.50 V Voltage
16:47:35 Group 103
5.23 bar Pressure
1597 (no units)
1200 (no units)
ADP. Run
16:47:43 Group 106
35.07 bar Pressure
80.0 % Load
