Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: ACC radar adjustment on 2017 A3
    Jun 2018
    Quote Originally Posted by myounus View Post
    If you wanna play with human lives then get a backstreet job.
    As Uwe has said the system is integrated into the car's throttle and brakes. This is why you won't find 3rd party aftermarket ACC or similar ADAS products and I don't think you ever will.
    I don't think any 3rd party company could take the risk of a software error and manslaughter charges. Some things you can't avoid paying through the nose!
    Your response is unhelpful. I've never stated I want to change the alignment parameters of the ACC system. I want to align the radar unit to the parameters of the ACC system. That has nothing to do with car throttle or brakes - that is embedded in the system parameters. If it works it works. If the radar is out of alignment it stops working. ...like mine. I want to find what the alignment spec is, what my out-of-alignment is, and then turn the tip/tilt screws on the radar unit to get it working again.
    For example, if I can determine which measured value is telling me how far out the horizontal angle is I can easily find how many degrees of screw turn gives so many degrees of angle change. Same with vertical.
  2. #12
    Jun 2018
    Quote Originally Posted by MasterTommy View Post
    Provided you have adjustment screws on the radar base to physically change its alignment. I just swapped the front bumper on my tiguan (which involved removing the radar unit behind the VW emblem) and it clicks into the grille without any alignment screws present (the seat of the radar is part of the grille). Aligning is done with the same setup as in the video, but purely involves changing parameters of the radar. No static alignment possible. And if I remember correctly, a radar unit that does have alignment screws to change the physical position of the radar also needs to be calibrated afterwards just like the non-adjustable units like in my tiguan. So IMO, you’re still half-assing it by only doing a static adjustment.
    My car has tip/tilt adjustment screws on the center radar unit. It is attached to the reinforcement bar, not the grill. If there are only 2 adjustment screws how am I "half-assing" it?
  3. #13
    Jun 2018
    Here's an auto scan...
    Also if you're interested in seeing the damaged car prior to repair just google image search the VIN.
    Friday,31,August,2018,09:22:51:59265
    VCDS Version: 18.2.1.5 (x64)
    VIN: WAUSPBFF9HA039569   License Plate:
    Mileage: 26568km-16508mi   Repair Order:
    Chassis Type  FF-AU37 (5QE)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 3C 42 44 47 51 52
              55 5F 6C 75 8C A5 BB BC C0 C6 CF
    VIN: WAUSPBFF9HA039569   Mileage: 26568km-16508miles
    C6-Batt. Chrg. -- Status: Malfunction 0010
    CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CXUA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AN    HW: 04E 907 309 F
       Component: R4 1.4l TFS   H22 3695
       Revision: X3H22---
       Coding: 021D0012636401083000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM14TFS01104E906023AN 008005
       ROD: EV_ECM14TFS01104E906023AN_008.rod
       VCID: 6CD73866876C7624E8-8038
    17156 - Databus
              U1123 00 [047] - Received Error Message
                        Fault Frequency: 148
                        Mileage: 23880 km
                        Date: 2018.08.04
                        Time: 12:50:10
                        Coolant temperature: 32 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 13.200 V
                        Acceleration: 0.000 m/s²
                        Cruise Control System (CCS): status-Bits 0-7: 6
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 2
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
       Part No SW: 0DD 300 046 A    HW: 0DD 927 770 C
       Component: GSG DQ400E    H32 1602
       Revision: 00032056    Serial number: TFK01607270293
       Shop #: WSC 00099 780 00200
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021.rod
       VCID: 26430A4E59008C747E-8072
    30097 - Transmission Fluid Pressure
              P0867 00 [040] - Function Restriction due to Low Pressure
                        Fault Frequency: 9
                        Mileage: 25467 km
                        Date: 2018.08.20
                        Time: 20:54:03
                        Engine speed: 18.75 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 71 km/h
                        Control Module temperature: 24 °C
                        CURRENT pressure: -10.0 bar
                        Clutch: primary stat: Driving
                        selected gear: GANG_5
                        Driving position: N
                        Accelerator position: 0.4 %
                        DTC memory status: 12032
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
       Component: ESC           H62 0855
       Revision: 00000000    Serial number: 62216000000155
       Coding: 12FF409238232275897C0A0681CC2948021C44915081947218A1505482A802
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
       ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
       VCID: 7CF70826F70CE6A478-8028
    16401 - Tire Pressure Warning
              C102D 00 [032] -  -
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0414425711
       Coding: 030C0C
       VCID: 3B75CB3AB282219C31-806E
       Part No SW: 8V0 820 043 S    HW: 8V0 820 043 S
       Component: AC Automat    H03 0610
       Revision: 20001000    Serial number: 00000001022918
       Coding: 0300001001000000080000000000140001000000
       ASAM Dataset: EV_AirCondiFrontNARAU37X 001019
       ROD: EV_AirCondiFrontNARAU37X.rod
       VCID: 428BB6DED568505472-8016
       Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G395 pT-Sens1  H61 0006
       Subsystem 2 - Part No SW: 3Q0 963 231 D    HW: 3Q0 963 231 D
       Component: J848 HV-PTC  200 0204
       Serial number: -00103.2T.4C20340003
       Subsystem 3 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: 1F58034800PAG0MUFU02
       Subsystem 4 - Part No SW: 5QE 816 803 C    HW: 5QE 816 803 C
       Component: J842 eKK  H02 0006
       Serial number: IABB00000K0000000117
       Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H34 0236
       Serial number: 02001620400089
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EF3022EE110F4B456-802A
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 160804  043 0580
       Serial number:         160809190108
       Coding: 0A47F7
       Serial number: 62141365
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Serial number: 23 06 2016  00001032
       Serial number: 00000000000066799941
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST0014BIZX00000
       Coding: 101F00
    204546 - Remote key 2
                        Reset counter: 92
                        Mileage: 25982 km
                        Date: 2018.08.25
                        Time: 13:37:18
       Part No SW: 5QA 919 294     HW: 5QA 919 294
       Component: PDC 8 KanalH07 0031
       Serial number: 000308418616214
       Coding: 0470155811
       ASAM Dataset: EV_EPHVA18AU3700000 009027
       ROD: EV_EPHVA18AU3700000_009_AU37.rod
       VCID: 091961F2A8DEC30C73-805C
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: D51087C219FFC428949C8055000026
       Shop #: WSC 12345 123 61029
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: EV_ACCBOSCHVW416_001_VW37.rod
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
                        Reset counter: 102
                        Mileage: 26568 km
                        Date: 2018.08.30
                        Time: 22:23:42
                        Control Module temperature: 62 °C
                        Voltage terminal 15: 12.8 V
                        Status_ACC_System: ACC_irreversible error
    0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
                        Reset counter: 102
                        Mileage: 26568 km
                        Date: 2018.08.30
                        Time: 22:23:42
       Serial number: 003GCR09J8S-
       Coding: 9DFCFCC0002000009000001AC24800000065
       Shop #: WSC 29326 002 1048576
       VCID: 479DA7CAFE4A757CA5-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34230167A12081651157
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34230168A13081650032
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001HX9E7
       Coding: 303334
       Subsystem 4 - Part No SW: -----------    HW: 480 001 708 16
       Serial number: 35700000000A7194BD1S
       Subsystem 5 - Part No SW: -----------    HW: 480 001 708 16
       Serial number: 3580000000009194BD1L
       Subsystem 6 - Part No SW: -----------    HW: 480 401 708 16
       Serial number: 3510001B92205C32145N
       Subsystem 7 - Part No SW: -----------    HW: 480 401 708 16
       Serial number: 3520001B92205C33156R
       Subsystem 8 - Part No SW: -----------    HW: 480 402 607 16
       Serial number: 3550002A92095071916V
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 402 407 16
       Serial number: 3560002BF21160D161F2
       Part No SW: 8V0 953 521 KF    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 14081608490079
       Coding: EC18
       VCID: 081F64F6B3D4BA046C-805C
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 894     HW: 8V0 920 894
       Component: FBenUSA       H13 0045
       Coding: 08440C516F98CF050283E8101B00000000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001023
       ROD: EV_DashBoardFPKAU37X.rod
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 F    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3265
       Revision: --------    Serial number: 10081610520163
       Coding: 0201001726F200005B00121C581000000001010100010000000300000000
       ASAM Dataset: EV_GatewEVConti 013020
       ROD: EV_GatewEVConti_013.rod
       VCID: 4999A1F2E85E830CB3-801C
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20160803112839 01417
       Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
       Serial number: 0190810604
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
       Component: EBKV          H14 0200
       Serial number:   085430010337
       Coding: 03720100331A00030002050500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
       ROD: EV_BrakeBoostBoschMQBOMG_004.rod
       VCID: 50AF8C960B04B2C4F4-8004
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861230716072612
       Revision: 00000000    Serial number: 16000142422010
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3467E0069FDCEEE4F0-8060
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0410
       Revision: --------
       Coding: 04C002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
       VCID: 3979D132B8BE138C23-806C
       Serial number: 080816EH725934
       Coding: 005D1F205C00048000000003
       VCID: 4385B3DACA72595C79-8016
       Component: EPS_MQB_ZFLS  128 1072
       Coding: D106
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 4581ADC2C446676C57-8010
       Part No SW: 81A 035 466     HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0100
       Revision: 00000001    Serial number: AUZ8ZAGHX004YQ0
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 62CB565E75A8305452-8036
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
       Component: LE Gen 3.3H11 1032
       Revision: 00H11000
       Coding: 40020000000000000000
       ASAM Dataset: EV_DMCM08530115G0907080E 001008
       ROD: EV_DMCM08530115G0907080E.rod
       VCID: 29590172481EA30C53-807C
       Serial number: 150716EGE3465A
       Coding: 005D17205E00048000000003
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0E5A001123200400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E73C22EA19034B416-806A
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8V1 035 880     HW: 8V1 035 880
       Component: MU-P-LNS-US   052 0694
       Serial number: A702H0G7510874
       Coding: 017393020000000011220002041A00102F0029E5017001047E
       VCID: 77FD170ACE2AC5FC15-8022
       Subsystem 1 - Part No SW: V03 959 801 GF    HW: -----------
       Component: NAR 2016/2017  --- 0054
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY20752D
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL108081600010557
       Component: Gracenote2---  --- 3009
              B11CF 53 [009] - Deactivated
                        Reset counter: 47
                        Mileage: 23880 km
                        Date: 2018.08.04
                        Time: 08:49:07
                        Voltage terminal 30: 13.3 V
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    6696 - Instrument Cluster Control Module on Optical Bus
              U10C0 00 [008] - No Communication
                        Reset counter: 126
                        Mileage: 25459 km
                        Date: 2018.08.18
                        Time: 20:13:27
                        Voltage terminal 30: 13.4 V
       Coding: 0273100102002001400040
       ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
       Component: OCULowMQBUS   007 0568
       Coding: 017393011080BA0100F800000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
       Component: BECM          H05 0911
       Serial number: U3010028
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006040
       ROD: EV_BECM06020115C6915182_VW37.rod
       Battery Junction Box:
       Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
       Component: BJB  H28 0240
       Cell module: control module 1:
       Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D1  H14 0481
       Serial number: V013C1622530948
       Cell module: control module 2:
       Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D2  H14 0481
       Serial number: V013C1622530951
       Cell module: control module 3:
       Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D3  H14 0481
       Serial number: V013C1622531067
       Cell module: control module 4:
       Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D4  H14 0481
       Serial number: V013C1622530946
       Cell module: control module 5:
       Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D5  H14 0481
       Serial number: V013C1622531055
       Cell module: control module 6:
       Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D6  H14 0481
       Serial number: V013C1622531056
       Cell module: control module 7:
       Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D7  H14 0481
       Serial number: V013C1622531066
       Cell module: control module 8:
       Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D8  H14 0481
       Serial number: V013C1622530947
    26701 - Battery Charger Input
              P0D81 00 [096] - Implausible Signal
                        Mileage: 25095 km
                        Date: 2018.08.16
                        Time: 09:19:04
                        Pack Voltage: 351.3 V
                        Pack Current: -0.00 A
                        Isolation Resistance: 5080 kOhm
                        Maxumum charge current limit: 126 A
                        Maximum discharge current limit: 295.5 A
                        Contactor Voltage: 0 V
                        OBD unlearned counter: 14
                        Crash status: 00
                        Pilot Line Status: 00
                        Fuse Status: 00
                        (Minus) Contactor Status: 00
                        (Plus) Contactor Status: 00
                        Terminal 15 status: 00
                        Max Cell Temperature: 28 °C
                        Min Cell Temperature: 27 °C
                        Air inlet temperature: 27 °C
                        Air outlet temperature: 26 °C
                        LV Battery Voltage: 12.5 V
                        Min.cell voltage: 3.655 V
                        Max.cell Voltage: 3.659 V
                        Max.cell SOC: 42 %
                        Min.cell SOC: 41 %
                        Hybrid Battery Pack Remaining Life: 40.8 %
                        Max Charge Pack Current(10s duration): 0 A
                        Max Discharge Pack Current(10s duration): 0.0 A
                        Max Pack Voltage(10s duration): 350 V
                        Min Pack Voltage(10s duration): 350 V
                        Max.cell Voltage(10s duration): 3.661 V
                        Min.cell Voltage(10s duration): 3.655 V
                        Accelerator Pedal Position D: 14.5 %
                        Calculated LOAD Value: 0.0 %
                        Engine coolant temperature: 51 °C
                        Engine RPM: 0.00 /min
                        Vehicle Speed Sensor: 0 km/h
                        Ambient Air Temperature: 215 °C
                        Hybrid Battery Pack Remaining Life: 40.78 %
                        control module system voltage: 12.547 V
                        absolute load: 0.0 %
                        Time After Engine Start: 0 s
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 02081611K10671
       Coding: 0403070300000201012223468048490080000E200020
       ROD: EV_MFKBoschMQBB_VW36.rod
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 200716EGK09733
       Coding: 000C17204000048000000002
       Serial number: 200716EGK09732
    Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
       Part No SW: 5QE 035 335 L    HW: 5QE 035 335 B
       Component: E_SOUND_SG    H09 0212
       Serial number: EN163117810000
       Coding: 04
       ASAM Dataset: EV_ENoiseS1NNVW3707 006013
       ROD: EV_ENoiseS1NNVW3707_006.rod
       VCID: 4A9B9EFEED588814BA-801E
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 AG    HW: 5QE 915 682 AG
       Component: OBC KOSTAL    H31 4013
       Revision: --------    Serial number: 2107160GD0007I
       Coding: 105168023000
       ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
       ROD: EV_OBCSinglPhaseKLOMQB12P.rod
       VCID: 122B469EC58800D482-8046
    2097696 - Charging Socket A for AC Connection
              P31C7 00 [008] - Open Circuit
                        Reset counter: 118
                        Mileage: 25095 km
                        Date: 2018.08.16
                        Time: 09:19:04
    Address CF: Lane Chge Asst 2
    Interface not compatible.
    End-------------------------(Elapsed Time: 06:33)--------------------------
  4. #14
    Oct 2017
    Northwest UK
    Audigroovin, I think we are all saying the same thing that it is not possible to accurately re-align the radar without re-calibrating it. This cannot be correctly/accurately done without the use of specialist equipment. Due to the safety nature of the unit's purpose, i.e. Accelerating and braking when a vehicle is in front of you, the parameters have to be set/aligned by proper equipment.
  5. Likes Uwe liked this post
  6. #15
    Dec 2016
    Amsterdam
    Quote Originally Posted by audigroovin View Post
    I clearly stated that if there are adjustment screws, its still only one step in the 2-part calibration proccess. The second part is what you’re completely ignoring if you only align it using the screws.
    Current:
  7. Likes Uwe liked this post
  8. #16
    Jun 2018
    Perhaps you are right but that conflicts with what I've read online of other people's similar issue wherein they make an adjustment to the tip/tilt and the system turns back on. Maybe VAG has changed the design for this model year and changed that wherein the system shuts down and losses its alignment completely. If that latter is correct that also conflicts with measured values that show measured angles. I think that if the system can measure itself, output alignment parameters, and turn itself off when it measures something that is out of alignment, then it must know what the alignment needs to be.
    Address 13: Auto Dist. Reg (5Q0 907 572 G)
    22:09:21
    IDE08768 Mirror deviation: horizontal 0.260 °
    IDE08769 Mirror deviation: vertical -0.484 °
    IDE08936 Misalignment angle: horiz 0.014 °
    IDE08937 Misalignment angle: horiz: fast algorithm -0.044 °
    IDE09380-IDE01784 Performed adjustment-Misalignment angle 0.01 °
    IDE09380-MAS08804 Performed adjustment-Horizontal offset angle 5.08 °
    IDE09380-MAS08805 Performed adjustment-Vertical offset angle -2.40 °
    IDE09906 Vertical deadjustment -0.113 °
    ENG00935 Status_ACC_System ACC_irreversible error
  9. #17
    But doesn't "irreversible error" suggest that even when the alignment is corrected some further action may be required?
  10. #18
    Jun 2018
    Yes, the line in the measured values, "ENG00935 Status_ACC_System ACC_irreversible error" makes little sense. Does something require replacement? It's also shown in the auto-scan, copied below...
    C1103 00 [009] - -
    Reset counter: 102
    Mileage: 26568 km
    Date: 2018.08.30
    Time: 22:23:42
  11. #19
    Lafayette, CO
    What about non OEM targets and racks?
    Is there liability to anyone other than the driver of the car?
    Is the driver tasked with paying attention and not relying on the ADAS in the operations manual?
    Does that relieve equipment manufacturers and repair facilities from prosecution?
    We have been trying to wrap our heads around ADAS for awhile now.
    The market interest is keen, yet it seems like most all are rushing down a path that we are not convinced is the best way forward.
    People are spending thousands of dollars on systems that we think are highly questionable.
    Shops are using systems that are not OEM for these calibrations.
    Aftermarket companies are resizing the targets and moving them closer!
    They are proposing new locations, putting them on the windshield to align these systems!
    We think you are borderline crazy doing this with anything other than OEM systems and targets, legally acquired from Bosch.
    I am not a lawyer, but I have heard others question if there is any legal co-operation between USA and China.
    The company that I see is selling more of this then anyone is based in Shenzhen, China.
    I think the Hella Guttman choice is a better one, at least they are an OEM supplier.
    I watched a dealer technician setting the lane assist on a Subaru last month.
    The target was located carefully with instructions from the Subaru Select Monitor 4.
    The car was in the learning mode. I did not see him put it into learning mode.
    It did not acquire the target where it was set.
    The tech went to the target and bumped it with his hand!
    Now the car was happy.
    That left me wondering.
    What are you all thinking?
  12. Likes Uwe liked this post
  13. #20
    Jun 2018
    Wow, so much ignorance. I got my ACC working over a year ago, soon after I posted here. The design intent of the system is that the puck up front is aligned to the thrust axis of the vehicle. All anyone has to do is put a 4 foot x 2 foot sheet metal target bonded to a flat particle board panel a few feet in front of the vehicle and geometrically align it to the car. The ekta manual describes set up. Then run Odis to calibrate. Unless your vehicle is grossly out of alignment this is not an issue. The whole $10k alignment rig is ridiculous. Home Depot rig does same thing for $10. Use firewall for datum reference, measure angle car is resting on, etc... your adjusting in tip tilt the target to be normal to the thrust axis of the car.
