Results 1 to 10 of 20
Thread: ACC radar adjustment on 2017 A3
    Jun 2018
    Anyone know the meaning of these 5 measured values in attached pic? For example, does "misalignment angle" mean the angle the ECU has measured as an offset error? The 3rd line states "performed adjustment...". Does that mean that was the adjustment made at the factory that the ECU recorded?
    I ask because my ACC stopped working. I get the yellow triangle warning symbol in the dash and I get the below error code C110300. I did a rough alignment check of the radar alignment mirror that's bonded to the radar surface (square block unit in center, front, lower grill) and I calculate the mirror to be near perfect normal to the geometric vertical plane of the car and pointing .33 degrees too high to the earth level horizontal plane. I measured the mirror to be near perfect normal to the vertical car plane. I'll post the procedure separately if it makes sense to do so - if my measured offset of .33 deg is correctable and ACC starts back up.
    13 Adaptive Cruise Control
    System description: ACC BOSCH MQB
    Software number: 5Q0907572G
    Software version: 0571
    Hardware number: 5Q0907572G
    Hardware version: H10
    ODX name: EV_ACCBOSCHVW416
    ODX version: 001005
    Long coding: D50087C219FFC428949C8055000026
    Trouble codes:
    C110300 - Adaptive cruise control sensor misadjusted
    static
    static
    U112300 - Databus error value received
    Intermittent
    Oct 2017
    Northwest UK
    Could you please post a full autoscan - thanks.
    If the ACC has lost its alignment and needs recalibration then the dealers or a specialist ADAS garage with the kit would need to do it.
    Jun 2018
    Quote Originally Posted by myounus View Post
    Uh, I was not subscribed to this thread so I never go notified. Anyway, I'll post a scan tomorrow. It appears there is no calibration possible in VCDS. It provides measured values only. Is that correct? I understand that the VAS6430 aligns itself to the driving axis of the car so that the radar puck can be then aligned to the tool. This person did this... http://www.audi4ever.com/v2/blog/det...nic/index.html and I've been able to a similar alignment but with a cross-hair laser. I can post that procedure but even I adjust the radar unit perfectly to spec how do I tell the car it's aligned? And what is the spec? Normal to driving axis? I imagine horizontally it should be but vertically it might be off normal per design. There's a lot of data but no spec for it it seems.
    May 2017
    Doesn't the basic setting -> Reset misadjustment angle do just that?
    You calibrate the radar to correct angle and the run that basic setting. It should take the new values as reference.
    What has happened for the radar to lose it's adjustment? Have you done something with the bumper? Lowered the car etc.? It does not lose that without being physically moved.
    There was another similar issue on different thread and there the reason was that the radar unit was knocked out from one of the fixings. OP from that thread just clicked the fixings in place and voila, misadjustment issue gone. So check those first before doing any adjustments.
    Here's how it's done properly:
  6. Likes downtime liked this post
    Jun 2018
    I removed the bumper and removed the radar unit from it's attachment to the bumper. The same bumper was put back on. Radar unit mounts to a pin-slot repeatable arrangement on the bumper. The bumper was installed at the same elevation (markings where bolts attach were used to verify).
    Also, I do not see anything in basic settings except checking the heating function.
    Jun 2018
    That's how Audi provides a low risk and robust procedure to get repeatable calibration results from users who purchase and are trained on that system. It is not the only way to do it "properly". ....IMO. At the risk of making an inaccurate assumption the radar mirror can be aligned orthogonaly to the geometric center of the car. If you assume the center of the mirror, the center of the front facing camera, and a 3rd point that is plumb to earth define the vertical plane of the car the mirror can be aligned to that to establish its horizontal spec. Level earth can be used to align vertically. Using a cross-hair laser I found the horizontal alignment near perfect and the vertical alignment pointing down a few tenths of a degree.
    What is the software tree required for that alignment system in the video? It's not ODIS, or is it?
  9. #8
    Dec 2016
    Amsterdam
    Provided you have adjustment screws on the radar base to physically change its alignment. I just swapped the front bumper on my tiguan (which involved removing the radar unit behind the VW emblem) and it clicks into the grille without any alignment screws present (the seat of the radar is part of the grille). Aligning is done with the same setup as in the video, but purely involves changing parameters of the radar. No static alignment possible. And if I remember correctly, a radar unit that does have alignment screws to change the physical position of the radar also needs to be calibrated afterwards just like the non-adjustable units like in my tiguan. So IMO, you’re still half-assing it by only doing a static adjustment.
    Current:
  10. #9
    Quote Originally Posted by audigroovin View Post
    I would consider "low-risk, robust, and repeatable" to be essential when it comes to a system that can fully control the car's throttle and brakes.
    I've driven thousands of miles with ACC engaged in two different cars and have always been amazed at the system's ability to differentiate between vehicles that are in my lane vs. vehicles that are not in my lane, even on very curvy stretches of highway. This has also made me aware of the potential consequences if the system did not do that correctly. Personally, I would be very reluctant to use ACC on a car that had been calibrated willy-nilly, i.e. without following the correct procedures using the correct equipment.
    One of the things people seem to miss is that the centerline of the car is not what matters to here, but rather the centerline of the car's thrust angle. This is why a wheel alignment is considered a mandatory part of the procedure. We know the car you're working on has been crashed. Has the wheel alignment even been checked post-repair?
  11. #10
    Oct 2017
    Northwest UK
    If you wanna play with human lives then get a backstreet job.
    As Uwe has said the system is integrated into the car's throttle and brakes. This is why you won't find 3rd party aftermarket ACC or similar ADAS products and I don't think you ever will.
    I don't think any 3rd party company could take the risk of a software error and manslaughter charges. Some things you can't avoid paying through the nose!
