Saturday,18,August,2018,17:01:08:32918
VCDS Version: 18.2.1.2 (x64)
Dealer/Shop Name: aes bradford
VIN: WAUZZZ8P2CA016716 License Plate:
Chassis Type: 8P-AU35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 61 77
VIN: WAUZZZ8P2CA016716 Mileage: 34430km-21393miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PP HW: 03L 906 023 KS
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: AUX7Z0K5FNO03M
Coding: 00114014030501080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM16TDI02103L906023PP 003009
ROD: EV_ECM16TDI.rod
VCID: 0304030A8A958E5C3A-8056
7329 - Mass Air Flow Sensor (G70)
P0101 00 [232] - Implausible Signal
Mileage: 34126 km
Date: 2018.07.11
Time: 06:15:18
Engine speed: 1349.25 /min
Vehicle speed: 53 km/h
Coolant temperature: 79 °C
Intake air temperature: 23 °C
Voltage terminal 30: 14.118 V
Air mass: actual value (mg/stroke)-MAF_MES: 365.462 mg/stroke
Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL: 1.28662
EGR Solen.val.: actual value-ANG_EGRV[0]: 0.000 %
Throttle valve adapter: actual value-ANG_THR[0]: 99.997 %
Charge air pressure specified value-MAP_SP_MMV: 1077.76 hPa
Charge air pressure: actual value-MAP_MMV: 1077.76 hPa
Engine torque-TQI_SP: 0.00 Nm
7300 - Throttle Position Sensor (G69)
P0123 00 [175] - Signal too High
Mileage: 34096 km
Date: 2018.07.11
Time: 00:02:54
Engine speed: 985.50 /min
Normed load value: 6.3 %
Coolant temperature: 58 °C
Intake air temperature: 28 °C
Voltage terminal 30: 12.085 V
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
Throttle valve: activation-PWM_HBR_THR[0]: 0.000 %
Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.995 V
Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.688 V
Throttle valve adapter: offset open-V_THR_TOL[0]: 4.600 V
Throttle valve adapter: status-LF_STATE_THR_DISP[0]: 0
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Fault Frequency: 75
Mileage: 34096 km
Date: 2018.07.11
Time: 00:02:54
Engine speed: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 12.5 V
9867 - Coolant Pump 2
P261A 00 [175] - Open circuit
Mileage: 34096 km
Date: 2018.07.11
Time: 00:03:15
Engine speed: 980.00 /min
Normed load value: 7.5 %
Coolant temperature at radiator outlet: actual value-TCO_2: 20 °C
Battery voltage: 14.1 V
9870 - Coolant pump 2
P261B 00 [175] - Implausible signal
Mileage: 34096 km
Date: 2018.07.11
Time: 00:07:35
Engine speed: 1040.75 /min
Coolant temperature: 65 °C
Intake air temperature: 32 °C
Coolant temperature at radiator outlet: actual value-TCO_2: 21 °C
Readiness: 1 4 0 0 0
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
VCID: 7BF47BEAFA65F69C72-802E
Reset counter: 136
Date: 2018.07.11
Time: 01:14:22
Count: 3
Count: 20992
Count: 195
Count: 43008
Fault Status: 01100101
Reset counter: 136
Mileage: 34096 km
Date: 2018.07.11
Time: 01:14:23
Count: 7
Count: 2
Count: 4608
Count: 279
Count: 43008
Count: 65280
Reset counter: 136
Mileage: 34096 km
Date: 2018.07.11
Time: 01:14:23
Count: 7
Count: 2
Count: 4608
Count: 295
Count: 43008
Count: 65280
Reset counter: 136
Mileage: 34096 km
Date: 2018.07.11
Time: 01:14:23
Count: 7
Count: 2
Count: 4608
Count: 270
Count: 43008
Count: 65280
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0180
Revision: 000166 Serial number: 8P0820043BM
VCID: 78FE64E60B53DD841F-802C
Fault Status: 00101001
Fault Frequency: 20
Reset counter: 185
Mileage: 104136 km
Date: 2018.05.05
Time: 21:30:16
Temperature: 22.0°C
Voltage: 11.90 V
Load: 9.0 %
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
Component: BCM PQ35 M 110 0667
Revision: AJ110667
Coding: 4E000A2FA005F000207041E00100014C427A23AA006DC12AE4008F800041
VCID: 3F8CCFFAAEFD2ABC1E-806A
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Component: Innenraumuebe H04 0020
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Fault Status: 00101010
Fault Frequency: 21
Reset counter: 187
Mileage: 34096 km
Date: 2018.07.11
Time: 00:09:45
Term 15 Off
Voltage: 12.25 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861201301216
Coding: 000002
VCID: 489ED426FB336D04AF-801C
Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003JU005L574
Coding: 303142413039303030384A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 52AAF64E056FD7D4C1-8006
Serial number: 34928RB40000684ABC5
Serial number: 35028RB400006852B22A
Serial number: 35128RB40000684AB49R
Serial number: 35228RB400006852B4BN
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 34096 km
Date: 2018.07.11
Time: 00:03:24
9444117 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Mileage: 34096 km
Date: 2018.07.11
Time: 00:03:24
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Mileage: 34096 km
Date: 2018.07.11
Time: 00:03:27
Mileage: 34096 km
Date: 2018.07.11
Time: 00:03:27
B1007 1B [137] - Resistance Too High
Mileage: 34096 km
Date: 2018.07.11
Time: 00:03:27
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0004042
VCID: 4682DA1E31277B745D-8012
Part No SW: 8P0 920 983 HW: 8P0 920 983
Component: KOMBIINSTR. VDO H02 0150
Revision: D0H02002 Serial number: 2245K002002059
Coding: 0260428
Shop #: WSC 24257 001 1048576
VCID: 77FC67DA064DD2FC16-8022
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 181211F2003222
Coding: 350101
VCID: 3B74BBEABAE5369C32-806E
Revision: D0H02002 Serial number: AUX7Z0K5FNO03M
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
Component: Tuer-SG H04 0101
Coding: 0131636
VCID: 489ED4263B336D04AF-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 232 3305
Revision: 00H22000
VCID: 377CA7DA46CD12FCD6-8062
Fault Status: 11100101
Mileage: 34096 km
Date: 2018.07.11
Time: 00:02:53
Battery Volts: 12.1 V
DU
Temperature: 27.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 8P3 035 382 E HW: 8P3 035 382 E
Component: AB2 SUBWOOFERBOXH31 0160
Revision: 00007 Serial number: 92157116305640
VCID: 3560ADD25CC1E0ECC4-8060
Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
Coding: 0131636
VCID: 4998D1222039940CB0-801C
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
Component: R Concert2+ H05 0293
Revision: 00H05000 Serial number: AUZ1Z3M3001051
Coding: 0710011
VCID: 72EA56CE6D2FB7D421-8026
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: F30F185A
VCID: 71E859C2A8298CCCD8-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900692151
02252 - Generator
Reset counter: 136
Mileage: 34096 km
Date: 2018.07.11
Time: 00:03:54
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005484371
Coding: 0001222
End-------------------------(Elapsed Time: 02:27)--------------------------
