Hi
I have read the wiki and a few other posts about this issue and get the general gist of what's been said about it's all in the title, namely mechanical failure! But ...
The problem appears to be intermittent and while stationary (not faulting) and driving we've so far been unable to capture any parameter to give us a clue about which component might be at fault.
We've tried soapy water, and will do again more carefully today, but if the fault is not occuring while stationary then even if it is a leak, then we're unlikely to find it this way?
The module has no label file, or coding options ... so would you like a scan of these? Please email me and I'll generate.
I assume the module is not UDS as option 8 is available, but this info is not stored in the error/log files (would that be a useful addition?) as offline right now.
The car also had an error 01577 High temperature cut out, but that has not come back. Using a different tool which had the menu option to cycle the system, this completed ok, but took a while to "pump up" in the first instance, would this be that the errors (well the 01577) was inhibiting the pump?
Not knowing the strategy of the error and which components are being plausibly verified or otherwise and as we don't have wiring for the sensor or controller, or a factory/other test plan, we're a little in the dark ... so any tips or pointers on these would be helpful ...
Here is the data from the car:
The ECU identification:
Full Read:
Monday,13,August,2018,17:58:21:48085VCDS Version: Beta 18.7.1 (x64) Running on Windows 10 x64
Address 34: Level Control Labels: NONE
Control Module Part Number: 4L0 910 553 L HW: 4L0 907 553 E
Component and/or Version: LUFTFDR.-CDC H04 7890
Software Coding: 0015510
Work Shop Code: WSC 31414 790 00001
VCID: 3326C944528EBDD2D9-8066
02645 - Valves for Level Control System
Fault Status: 00100011
Reset counter: 69
Mileage: 70905 km
Date: 2018.08.13
Time: 14:55:46
Error Code: 141
Monday,13,August,2018,17:57:42:48085VCDS Version: Beta 18.7.1 (x64)
Advanced Identification
Serial number: 15.1528-0194.2
Identification: TF7-003
Revision: --H04001
Date: 10.11.12
Test stand number: 0001
Manufacturer number: 0335
Flash Status
Programming Attempts: 1
Successful Attempts: 1
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: 10.11.12
Software
ACAN: 2.5.06
ATP20: 2.56.04
AKWP: 4.5.2
AAPPL: 7890
Misc.
Hardware number: 4L0 907 553 E
Lot Number:
Type Lock:
VCDS Info:
Labels: NONE
Full Read:
Monday,13,August,2018,17:56:13:48085VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.7.1.1 (x64) HEX-NET CB: 0.4427.4
Data version: 20180731 DS293.0
VIN: WAUZZZ4L6DD023221 License Plate:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 34 3D 42 46 4F 52 55 56
5F 62 6C 6D 6F 72
VIN: WAUZZZ4L6DD023221 Mileage: 70900km-44055miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 B HW: 4L0 907 401 C
Component: 3.0TDI EDC17 H40 0002
Revision: 53H40--- Serial number:
Coding: 2A2A4012A52701020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L2910401B 001002
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 230639042A6E2D5229-8076
4795 - Mass Air Flow Sensor (G70)
P0101 00 [096] - Implausible Signal
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AL HW: 0C8 927 750 AL
Component: AL1000 AISIN 002 2096
Coding: 001578
Shop #: WSC 57716 001 1048576
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 76A03050C97CE8FA3E-8022
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2200689
VCID: 3424CA585780BAEAC0-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702036466
Coding: 0000211
VCID: 2502271CEC5AD36247-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 IDG H01 0054
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AP
Revision: 00---031 Serial number: 00000000358057
Coding: 01009416
VCID: 2502271C2C5AD36247-8070
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H31 0400
Coding: 0033121
VCID: 6FAE05347E26D932FD-803A
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961300201172
Coding: 24031F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3424CA589F80BAEAC0-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH44 0230
Revision: 05H44000 Serial number: 00399D0C224B
Coding: 0014129
VCID: 2E10D830B9AC903AB6-807A
Subsystem 1 - Serial number: 6332QSME6728204CG
Subsystem 2 - Serial number: 6342QSME6028384AH
Subsystem 3 - Serial number: 6352QSME67284052B
Subsystem 4 - Serial number: 6362QSME63280F56N
Subsystem 5 - Serial number: 63734SME682C276EF
Subsystem 6 - Serial number: 63834SME6829235C6
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H08000 Serial number: 90026123180059
Coding: 0102142
VCID: 281C2E289B48CE0A7C-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 N HW: 4L0 920 985 N
Component: KOMBIINSTR. H35 0316
Revision: 00000000 Serial number: NGC20461E
Coding: 3356630400012600010404
VCID: 3FCE9574AEC669B22D-806A
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 H
Component: Heizgeraet H10 0140
Revision: 0000000A Serial number: 00000009024928
Coding: 0000101
VCID: 608C7608B3F8764A74-8034
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 R HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0058
Revision: LB600036 Serial number: 3600L12C18808A
Coding: 00CF07
VCID: 3E30E870A9CC60BA26-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000004120910683
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13010001936011200181
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 L HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7890
Revision: --H04001 Serial number: 15.1528-0194.2
Coding: 0015510
Reset counter: 69
Mileage: 70905 km
Date: 2018.08.13
Time: 14:55:46
Error Code: 141
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 HW: 8K0 907 440
Component: STS H04 0040
Revision: S0H04000 Serial number: 00000000072496
Coding: 01010101000000000001000202
VCID: 6B9611244A3E2512D1-803E
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000049942577
Coding: 011F06205061440004
VCID: 48DC8EA8FB082E0A9C-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01893977040000
Coding: 3809787
VCID: 383CFE684BE85E8AEC-806C
01403 - Glass-Break Sensors; Rear
Reset counter: 29
Mileage: 54139 km
Date: 2017.03.20
Time: 17:08:42
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000324103
Coding: 0011101
VCID: 5EF048F0898C40BA46-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000049026121
VCID: 47DE8D94F616217295-8012
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 130121-0004-061
Coding: 11476F1010000500
ROD: EV_HeadlRegulBasic.rod
VCID: 42C89C80D534045A42-8016
Part No SW: 4G0 035 056 G HW: 4G0 035 056
Component: Radio U STD H60 0121
Revision: AB001007 Serial number: 230A$0D7581896
Coding: 010003020100000000
Part No SW: 4L2 035 670 C HW: 4L2 035 670 D
Component: H-BNT-EU H45 0639
Revision: -------- Serial number: 220AX0D7508388
Coding: 180101060004D3EF010003556F632003040000000100000000
VCID: 2A18D4204544FC1A6A-807E
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130AM0D2638045
Subsystem 3 - Part No SW: 4L0 919 614 B HW: 4L0 919 614 B
Component: E0380 Bedient H01 0060
Serial number: 00000000000210
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000056373547
Coding: 010E06204061230004
VCID: 46C08090F11C387A6E-8012
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H07--- Serial number: 525PA8-J2Y41SP
Coding: 1021001
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C9412384F30222AD8-8038
Subsystem 3 - Serial number: RD19.01.13--H57001001A0314ÿ
Subsystem 4 - Serial number: 1A0314ÿ
02786 - Module 2 for Hatch / Trunk Lid (J756)
Reset counter: 69
Mileage: 54598 km
Date: 2017.07.04
Time: 10:36:27
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 130052155-----
VCID: 6582671CACDA136287-8030
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000049959517
Fault Frequency: 53
Reset counter: 28
Mileage: 69884 km
Date: 2018.07.22
Time: 17:37:47
01482 - Motors for Central Locking
007 - Short to Ground
Fault Status: 01100111
Fault Frequency: 61
Reset counter: 28
Mileage: 69884 km
Date: 2018.07.22
Time: 17:37:47
Fault Status: 00100110
Fault Frequency: 12
Reset counter: 67
Mileage: 70059 km
Date: 2018.07.30
Time: 12:29:30
End----------(Elapsed Time: 01:57, VBatt start/end: 14.4V/14.4V)-----------
